commit 08cbc75f96029d3092664213a844a5e25523aa35 upstream.
Clang warns:
../drivers/net/ppp/ppp_async.c:877:6: warning: misleading indentation;
statement is not part of the previous 'if' [-Wmisleading-indentation]
ap->rpkt = skb;
../drivers/net/ppp/ppp_async.c:875:5: note: previous statement is here
if (!skb)
1 warning generated.
This warning occurs because there is a space before the tab on this
line. Clean up this entire block's indentation so that it is consistent
with the Linux kernel coding style and clang no longer warns.
Fixes: 6722e78c9005 ("[PPP]: handle misaligned accesses")
Link: https://github.com/ClangBuiltLinux/linux/issues/800
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
[ Upstream commit 4c247de564f1ff614d11b3bb5313fb70d7b9598b ]
When ppp is closing, __ppp_xmit_process() failed to enqueue skb
and skb allocated in ppp_write() is leaked.
syzbot reported :
BUG: memory leak
unreferenced object 0xffff88812a17bc00 (size 224):
comm "syz-executor673", pid 6952, jiffies 4294942888 (age 13.040s)
hex dump (first 32 bytes):
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<00000000d110fff9>] kmemleak_alloc_recursive include/linux/kmemleak.h:43 [inline]
[<00000000d110fff9>] slab_post_alloc_hook mm/slab.h:522 [inline]
[<00000000d110fff9>] slab_alloc_node mm/slab.c:3262 [inline]
[<00000000d110fff9>] kmem_cache_alloc_node+0x163/0x2f0 mm/slab.c:3574
[<000000002d616113>] __alloc_skb+0x6e/0x210 net/core/skbuff.c:197
[<000000000167fc45>] alloc_skb include/linux/skbuff.h:1055 [inline]
[<000000000167fc45>] ppp_write+0x48/0x120 drivers/net/ppp/ppp_generic.c:502
[<000000009ab42c0b>] __vfs_write+0x43/0xa0 fs/read_write.c:494
[<00000000086b2e22>] vfs_write fs/read_write.c:558 [inline]
[<00000000086b2e22>] vfs_write+0xee/0x210 fs/read_write.c:542
[<00000000a2b70ef9>] ksys_write+0x7c/0x130 fs/read_write.c:611
[<00000000ce5e0fdd>] __do_sys_write fs/read_write.c:623 [inline]
[<00000000ce5e0fdd>] __se_sys_write fs/read_write.c:620 [inline]
[<00000000ce5e0fdd>] __x64_sys_write+0x1e/0x30 fs/read_write.c:620
[<00000000d9d7b370>] do_syscall_64+0x76/0x1a0 arch/x86/entry/common.c:296
[<0000000006e6d506>] entry_SYSCALL_64_after_hwframe+0x44/0xa9
Fix this by freeing skb, if ppp is closing.
Fixes: 6d066734e9f0 ("ppp: avoid loop in xmit recursion detection code")
Reported-and-tested-by: syzbot+d9c8bf24e56416d7ce2c@syzkaller.appspotmail.com
Signed-off-by: Takeshi Misawa <jeliantsurux@gmail.com>
Reviewed-by: Guillaume Nault <gnault@redhat.com>
Tested-by: Guillaume Nault <gnault@redhat.com>
[ Upstream commit 055d88242a6046a1ceac3167290f054c72571cd9 ]
Support for handling the PPPOEIOCSFWD ioctl in compat mode was added in
linux-2.5.69 along with hundreds of other commands, but was always broken
sincen only the structure is compatible, but the command number is not,
due to the size being sizeof(size_t), or at first sizeof(sizeof((struct
sockaddr_pppox)), which is different on 64-bit architectures.
Guillaume Nault adds:
And the implementation was broken until 2016 (see 29e73269aa4d ("pppoe:
fix reference counting in PPPoE proxy")), and nobody ever noticed. I
should probably have removed this ioctl entirely instead of fixing it.
Clearly, it has never been used.
Fix it by adding a compat_ioctl handler for all pppoe variants that
translates the command number and then calls the regular ioctl function.
All other ioctl commands handled by pppoe are compatible between 32-bit
and 64-bit, and require compat_ptr() conversion.
This should apply to all stable kernels.
Acked-by: Guillaume Nault <g.nault@alphalink.fr>
[ Upstream commit aad1dcc4f011ea409850e040363dff1e59aa4175 ]
The arc4 crypto is mandatory at ppp_mppe probe time, so let's put a
softdep line, so that the corresponding module gets prepared
gracefully. Without this, a simple inclusion to initrd via dracut
failed due to the missing dependency, for example.
[ Upstream commit 3ebe1bca58c85325c97a22d4fc3f5b5420752e6f ]
BUG: unable to handle kernel paging request at ffffffffa018f000
PGD 3270067 P4D 3270067 PUD 3271063 PMD 2307eb067 PTE 0
Oops: 0000 [#1] PREEMPT SMP
CPU: 0 PID: 4138 Comm: modprobe Not tainted 5.1.0-rc7+ #1
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS
rel-1.9.3-0-ge2fc41e-prebuilt.qemu-project.org 04/01/2014
RIP: 0010:ppp_register_compressor+0x3e/0xd0 [ppp_generic]
Code: 98 4a 3f e2 48 8b 15 c1 67 00 00 41 8b 0c 24 48 81 fa 40 f0 19 a0
75 0e eb 35 48 8b 12 48 81 fa 40 f0 19 a0 74
RSP: 0018:ffffc90000d93c68 EFLAGS: 00010287
RAX: ffffffffa018f000 RBX: ffffffffa01a3000 RCX: 000000000000001a
RDX: ffff888230c750a0 RSI: 0000000000000000 RDI: ffffffffa019f000
RBP: ffffc90000d93c80 R08: 0000000000000001 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffffffffa0194080
R13: ffff88822ee1a700 R14: 0000000000000000 R15: ffffc90000d93e78
FS: 00007f2339557540(0000) GS:ffff888237a00000(0000)
knlGS:0000000000000000
CR2: ffffffffa018f000 CR3: 000000022bde4000 CR4: 00000000000006f0
Call Trace:
? 0xffffffffa01a3000
deflate_init+0x11/0x1000 [ppp_deflate]
do_one_initcall+0x6c/0x3cc
? kmem_cache_alloc_trace+0x248/0x3b0
do_init_module+0x5b/0x1f1
load_module+0x1db1/0x2690
? m_show+0x1d0/0x1d0
__do_sys_finit_module+0xc5/0xd0
__x64_sys_finit_module+0x15/0x20
do_syscall_64+0x6b/0x1d0
entry_SYSCALL_64_after_hwframe+0x49/0xbe
If ppp_deflate fails to register in deflate_init,
module initialization failed out, however
ppp_deflate_draft may has been regiestred and not
unregistered before return.
Then the seconed modprobe will trigger crash like this.
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Acked-by: Guillaume Nault <gnault@redhat.com>
[ Upstream commit 9417d81f4f8adfe20a12dd1fadf73a618cbd945d ]
sk_setup_caps() is called to set sk->sk_dst_cache in pptp_connect,
so we have to dst_release(sk->sk_dst_cache) in pptp_sock_destruct,
otherwise, the dst refcnt will leak.
It can be reproduced by this syz log:
r1 = socket$pptp(0x18, 0x1, 0x2)
bind$pptp(r1, &(0x7f0000000100)={0x18, 0x2, {0x0, @local}}, 0x1e)
connect$pptp(r1, &(0x7f0000000000)={0x18, 0x2, {0x3, @remote}}, 0x1e)
Consecutive dmesg warnings will occur:
unregister_netdevice: waiting for lo to become free. Usage count = 1
v1->v2:
- use rcu_dereference_protected() instead of rcu_dereference_check(),
as suggested by Eric.
Fixes: 00959ade36ac ("PPTP: PPP over IPv4 (Point-to-Point Tunneling Protocol)")
Reported-by: Xiumei Mu <xmu@redhat.com>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit 6c57f0458022298e4da1729c67bd33ce41c14e7a ]
In certain cases, pskb_trim_rcsum() may change skb pointers.
Reinitialize header pointers afterwards to avoid potential
use-after-frees. Add a note in the documentation of
pskb_trim_rcsum(). Found by KASAN.
Signed-off-by: Ross Lagerwall <ross.lagerwall@citrix.com>
[ Upstream commit a49e2f5d5fb141884452ddb428f551b123d436b5 ]
We must validate sockaddr_len, otherwise userspace can pass fewer data
than we expect and we end up accessing invalid data.
Fixes: 224cf5ad14c0 ("ppp: Move the PPP drivers")
Reported-by: syzbot+4f03bdf92fdf9ef5ddab@syzkaller.appspotmail.com
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
[ Upstream commit bfacfb457b36911a10140b8cb3ce76a74883ac5a ]
Once dst has been cached in socket via sk_setup_caps(),
it is illegal to call ip_rt_put() (or dst_release()),
since sk_setup_caps() did not change dst refcount.
We can still dereference it since we hold socket lock.
Caugth by syzbot :
BUG: KASAN: use-after-free in atomic_dec_return include/asm-generic/atomic-instrumented.h:198 [inline]
BUG: KASAN: use-after-free in dst_release+0x27/0xa0 net/core/dst.c:185
Write of size 4 at addr ffff8801c54dc040 by task syz-executor4/20088
CPU: 1 PID: 20088 Comm: syz-executor4 Not tainted 4.16.0+ #376
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:17 [inline]
dump_stack+0x1a7/0x27d lib/dump_stack.c:53
print_address_description+0x73/0x250 mm/kasan/report.c:256
kasan_report_error mm/kasan/report.c:354 [inline]
kasan_report+0x23c/0x360 mm/kasan/report.c:412
check_memory_region_inline mm/kasan/kasan.c:260 [inline]
check_memory_region+0x137/0x190 mm/kasan/kasan.c:267
kasan_check_write+0x14/0x20 mm/kasan/kasan.c:278
sk_dst_set include/net/sock.h:1812 [inline]
sk_dst_reset include/net/sock.h:1824 [inline]
sock_setbindtodevice net/core/sock.c:610 [inline]
sock_setsockopt+0x431/0x1b20 net/core/sock.c:707
SYSC_setsockopt net/socket.c:1845 [inline]
SyS_setsockopt+0x2ff/0x360 net/socket.c:1828
do_syscall_64+0x281/0x940 arch/x86/entry/common.c:287
entry_SYSCALL_64_after_hwframe+0x42/0xb7
RIP: 0033:0x4552d9
RSP: 002b:00007f4878126c68 EFLAGS: 00000246 ORIG_RAX: 0000000000000036
RAX: ffffffffffffffda RBX: 00007f48781276d4 RCX: 00000000004552d9
RDX: 0000000000000019 RSI: 0000000000000001 RDI: 0000000000000013
RBP: 000000000072bea0 R08: 0000000000000010 R09: 0000000000000000
R10: 00000000200010c0 R11: 0000000000000246 R12: 00000000ffffffff
R13: 0000000000000526 R14: 00000000006fac30 R15: 0000000000000000
Allocated by task 20088:
save_stack+0x43/0xd0 mm/kasan/kasan.c:447
set_track mm/kasan/kasan.c:459 [inline]
kasan_kmalloc+0xad/0xe0 mm/kasan/kasan.c:552
kasan_slab_alloc+0x12/0x20 mm/kasan/kasan.c:489
kmem_cache_alloc+0x12e/0x760 mm/slab.c:3542
dst_alloc+0x11f/0x1a0 net/core/dst.c:104
rt_dst_alloc+0xe9/0x540 net/ipv4/route.c:1520
__mkroute_output net/ipv4/route.c:2265 [inline]
ip_route_output_key_hash_rcu+0xa49/0x2c60 net/ipv4/route.c:2493
ip_route_output_key_hash+0x20b/0x370 net/ipv4/route.c:2322
__ip_route_output_key include/net/route.h:126 [inline]
ip_route_output_flow+0x26/0xa0 net/ipv4/route.c:2577
ip_route_output_ports include/net/route.h:163 [inline]
pptp_connect+0xa84/0x1170 drivers/net/ppp/pptp.c:453
SYSC_connect+0x213/0x4a0 net/socket.c:1639
SyS_connect+0x24/0x30 net/socket.c:1620
Freed by task 20082:
__kasan_slab_free+0x11a/0x170 mm/kasan/kasan.c:520
kasan_slab_free+0xe/0x10 mm/kasan/kasan.c:527
__cache_free mm/slab.c:3486 [inline]
kmem_cache_free+0x83/0x2a0 mm/slab.c:3744
dst_destroy+0x266/0x380 net/core/dst.c:140
dst_destroy_rcu+0x16/0x20 net/core/dst.c:153
__rcu_reclaim kernel/rcu/rcu.h:178 [inline]
rcu_do_batch kernel/rcu/tree.c:2675 [inline]
invoke_rcu_callbacks kernel/rcu/tree.c:2930 [inline]
__rcu_process_callbacks kernel/rcu/tree.c:2897 [inline]
rcu_process_callbacks+0xd6c/0x17b0 kernel/rcu/tree.c:2914
__do_softirq+0x2d7/0xb85 kernel/softirq.c:285
The buggy address belongs to the object at ffff8801c54dc000
which belongs to the cache ip_dst_cache of size 168
The buggy address is located 64 bytes inside of
168-byte region [ffff8801c54dc000, ffff8801c54dc0a8)
The buggy address belongs to the page:
page:ffffea0007153700 count:1 mapcount:0 mapping:ffff8801c54dc000 index:0x0
flags: 0x2fffc0000000100(slab)
raw: 02fffc0000000100 ffff8801c54dc000 0000000000000000 0000000100000010
raw: ffffea0006b34b20 ffffea0006b6c1e0 ffff8801d674a1c0 0000000000000000
page dumped because: kasan: bad access detected
[ Upstream commit 6d066734e9f09cdea4a3b9cb76136db3f29cfb02 ]
We already detect situations where a PPP channel sends packets back to
its upper PPP device. While this is enough to avoid deadlocking on xmit
locks, this doesn't prevent packets from looping between the channel
and the unit.
The problem is that ppp_start_xmit() enqueues packets in ppp->file.xq
before checking for xmit recursion. Therefore, __ppp_xmit_process()
might dequeue a packet from ppp->file.xq and send it on the channel
which, in turn, loops it back on the unit. Then ppp_start_xmit()
queues the packet back to ppp->file.xq and __ppp_xmit_process() picks
it up and sends it again through the channel. Therefore, the packet
will loop between __ppp_xmit_process() and ppp_start_xmit() until some
other part of the xmit path drops it.
For L2TP, we rapidly fill the skb's headroom and pppol2tp_xmit() drops
the packet after a few iterations. But PPTP reallocates the headroom
if necessary, letting the loop run and exhaust the machine resources
(as reported in https://bugzilla.kernel.org/show_bug.cgi?id=199109).
Fix this by letting __ppp_xmit_process() enqueue the skb to
ppp->file.xq, so that we can check for recursion before adding it to
the queue. Now ppp_xmit_process() can drop the packet when recursion is
detected.
__ppp_channel_push() is a bit special. It calls __ppp_xmit_process()
without having any actual packet to send. This is used by
ppp_output_wakeup() to re-enable transmission on the parent unit (for
implementations like ppp_async.c, where the .start_xmit() function
might not consume the skb, leaving it in ppp->xmit_pending and
disabling transmission).
Therefore, __ppp_xmit_process() needs to handle the case where skb is
NULL, dequeuing as many packets as possible from ppp->file.xq.
Reported-by: xu heng <xuheng333@zoho.com>
Fixes: 55454a565836 ("ppp: avoid dealock on recursive xmit")
[ Upstream commit 77f840e3e5f09c6d7d727e85e6e08276dd813d11 ]
PPP units don't hold any reference on the channels connected to it.
It is the channel's responsibility to ensure that it disconnects from
its unit before being destroyed.
In practice, this is ensured by ppp_unregister_channel() disconnecting
the channel from the unit before dropping a reference on the channel.
However, it is possible for an unregistered channel to connect to a PPP
unit: register a channel with ppp_register_net_channel(), attach a
/dev/ppp file to it with ioctl(PPPIOCATTCHAN), unregister the channel
with ppp_unregister_channel() and finally connect the /dev/ppp file to
a PPP unit with ioctl(PPPIOCCONNECT).
Once in this situation, the channel is only held by the /dev/ppp file,
which can be released at anytime and free the channel without letting
the parent PPP unit know. Then the ppp structure ends up with dangling
pointers in its ->channels list.
Prevent this scenario by forbidding unregistered channels from
connecting to PPP units. This maintains the code logic by keeping
ppp_unregister_channel() responsible from disconnecting the channel if
necessary and avoids modification on the reference counting mechanism.
This issue seems to predate git history (successfully reproduced on
Linux 2.6.26 and earlier PPP commits are unrelated).
[ Upstream commit 0171c41835591e9aa2e384b703ef9a6ae367c610 ]
ppp_dev_uninit(), which is the .ndo_uninit() handler of PPP devices,
needs to lock pn->all_ppp_mutex. Therefore we mustn't call
register_netdevice() with pn->all_ppp_mutex already locked, or we'd
deadlock in case register_netdevice() fails and calls .ndo_uninit().
Fortunately, we can unlock pn->all_ppp_mutex before calling
register_netdevice(). This lock protects pn->units_idr, which isn't
used in the device registration process.
However, keeping pn->all_ppp_mutex locked during device registration
did ensure that no device in transient state would be published in
pn->units_idr. In practice, unlocking it before calling
register_netdevice() doesn't change this property: ppp_unit_register()
is called with 'ppp_mutex' locked and all searches done in
pn->units_idr hold this lock too.
Fixes: 8cb775bc0a34 ("ppp: fix device unregistration upon netns deletion")
Reported-and-tested-by: syzbot+367889b9c9e279219175@syzkaller.appspotmail.com
[ Upstream commit 02612bb05e51df8489db5e94d0cf8d1c81f87b0c ]
In pppoe_sendmsg(), reserving dev->hard_header_len bytes of headroom
was probably fine before the introduction of ->needed_headroom in
commit f5184d267c1a ("net: Allow netdevices to specify needed head/tailroom").
But now, virtual devices typically advertise the size of their overhead
in dev->needed_headroom, so we must also take it into account in
skb_reserve().
Allocation size of skb is also updated to take dev->needed_tailroom
into account and replace the arbitrary 32 bytes with the real size of
a PPPoE header.
This issue was discovered by syzbot, who connected a pppoe socket to a
gre device which had dev->header_ops->create == ipgre_header and
dev->hard_header_len == 0. Therefore, PPPoE didn't reserve any
headroom, and dev_hard_header() crashed when ipgre_header() tried to
prepend its header to skb->data.
skbuff: skb_under_panic: text:000000001d390b3a len:31 put:24
head:00000000d8ed776f data:000000008150e823 tail:0x7 end:0xc0 dev:gre0
kernel BUG at net/core/skbuff.c:104!
invalid opcode: 0000 [#1] SMP KASAN
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
CPU: 1 PID: 3670 Comm: syzkaller801466 Not tainted
4.15.0-rc7-next-20180115+ #97
Google 01/01/2011
RIP: 0010:skb_panic+0x162/0x1f0 net/core/skbuff.c:100
RSP: 0018:ffff8801d9bd7840 EFLAGS: 00010282
RAX: 0000000000000083 RBX: ffff8801d4f083c0 RCX: 0000000000000000
RDX: 0000000000000083 RSI: 1ffff1003b37ae92 RDI: ffffed003b37aefc
RBP: ffff8801d9bd78a8 R08: 1ffff1003b37ae8a R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff86200de0
R13: ffffffff84a981ad R14: 0000000000000018 R15: ffff8801d2d34180
FS: 00000000019c4880(0000) GS:ffff8801db300000(0000) knlGS:0000000000000000
CR2: 00000000208bc000 CR3: 00000001d9111001 CR4: 00000000001606e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
skb_under_panic net/core/skbuff.c:114 [inline]
skb_push+0xce/0xf0 net/core/skbuff.c:1714
ipgre_header+0x6d/0x4e0 net/ipv4/ip_gre.c:879
dev_hard_header include/linux/netdevice.h:2723 [inline]
pppoe_sendmsg+0x58e/0x8b0 drivers/net/ppp/pppoe.c:890
sock_sendmsg_nosec net/socket.c:630 [inline]
sock_sendmsg+0xca/0x110 net/socket.c:640
sock_write_iter+0x31a/0x5d0 net/socket.c:909
call_write_iter include/linux/fs.h:1775 [inline]
do_iter_readv_writev+0x525/0x7f0 fs/read_write.c:653
do_iter_write+0x154/0x540 fs/read_write.c:932
vfs_writev+0x18a/0x340 fs/read_write.c:977
do_writev+0xfc/0x2a0 fs/read_write.c:1012
SYSC_writev fs/read_write.c:1085 [inline]
SyS_writev+0x27/0x30 fs/read_write.c:1082
entry_SYSCALL_64_fastpath+0x29/0xa0
Admittedly PPPoE shouldn't be allowed to run on non Ethernet-like
interfaces, but reserving space for ->needed_headroom is a more
fundamental issue that needs to be addressed first.
Same problem exists for __pppoe_xmit(), which also needs to take
dev->needed_headroom into account in skb_cow_head().
Fixes: f5184d267c1a ("net: Allow netdevices to specify needed head/tailroom")
Reported-by: syzbot+ed0838d0fa4c4f2b528e20286e6dc63effc7c14d@syzkaller.appspotmail.com
Reviewed-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit f02b2320b27c16b644691267ee3b5c110846f49e ]
The mutex_destroy only makes sense when enable DEBUG_MUTEX. For the
good readbility, it's better to invoke it in exit func when the init
func invokes mutex_init.
Signed-off-by: Gao Feng <gfree.wind@vip.163.com>
[ Upstream commit 6151b8b37b119e8e3a8401b080d532520c95faf4 ]
ppp_release() tries to ensure that netdevices are unregistered before
decrementing the unit refcount and running ppp_destroy_interface().
This is all fine as long as the the device is unregistered by
ppp_release(): the unregister_netdevice() call, followed by
rtnl_unlock(), guarantee that the unregistration process completes
before rtnl_unlock() returns.
However, the device may be unregistered by other means (like
ppp_nl_dellink()). If this happens right before ppp_release() calling
rtnl_lock(), then ppp_release() has to wait for the concurrent
unregistration code to release the lock.
But rtnl_unlock() releases the lock before completing the device
unregistration process. This allows ppp_release() to proceed and
eventually call ppp_destroy_interface() before the unregistration
process completes. Calling free_netdev() on this partially unregistered
device will BUG():
kernel BUG at net/core/dev.c:8141!
CPU: 1 PID: 1557 Comm: pppd Not tainted 4.14.0-rc2+ #4
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1.fc26 04/01/2014
Call Trace:
ppp_destroy_interface+0xd8/0xe0 [ppp_generic]
ppp_disconnect_channel+0xda/0x110 [ppp_generic]
ppp_unregister_channel+0x5e/0x110 [ppp_generic]
pppox_unbind_sock+0x23/0x30 [pppox]
pppoe_connect+0x130/0x440 [pppoe]
SYSC_connect+0x98/0x110
? do_fcntl+0x2c0/0x5d0
SyS_connect+0xe/0x10
entry_SYSCALL_64_fastpath+0x1a/0xa5
RIP: free_netdev+0x107/0x110 RSP: ffffc28a40573d88
---[ end trace ed294ff0cc40eeff ]---
We could set the ->needs_free_netdev flag on PPP devices and move the
ppp_destroy_interface() logic in the ->priv_destructor() callback. But
that'd be quite intrusive as we'd first need to unlink from the other
channels and units that depend on the device (the ones that used the
PPPIOCCONNECT and PPPIOCATTACH ioctls).
Instead, we can just let the netdevice hold a reference on its
ppp_file. This reference is dropped in ->priv_destructor(), at the very
end of the unregistration process, so that neither ppp_release() nor
ppp_disconnect_channel() can call ppp_destroy_interface() in the interim.
Reported-by: Beniamino Galvani <bgalvani@redhat.com>
[ Upstream commit 0a0e1a85c83775a648041be2b15de6d0a2f2b8eb ]
Commit e5dadc65f9e0 ("ppp: Fix false xmit recursion detect with two ppp
devices") dropped the xmit_recursion counter incrementation in
ppp_channel_push() and relied on ppp_xmit_process() for this task.
But __ppp_channel_push() can also send packets directly (using the
.start_xmit() channel callback), in which case the xmit_recursion
counter isn't incremented anymore. If such packets get routed back to
the parent ppp unit, ppp_xmit_process() won't notice the recursion and
will call ppp_channel_push() on the same channel, effectively creating
the deadlock situation that the xmit_recursion mechanism was supposed
to prevent.
This patch re-introduces the xmit_recursion counter incrementation in
ppp_channel_push(). Since the xmit_recursion variable is now part of
the parent ppp unit, incrementation is skipped if the channel doesn't
have any. This is fine because only packets routed through the parent
unit may enter the channel recursively.
Finally, we have to ensure that pch->ppp is not going to be modified
while executing ppp_channel_push(). Instead of taking this lock only
while calling ppp_xmit_process(), we now have to hold it for the full
ppp_channel_push() execution. This respects the ppp locks ordering
which requires locking ->upl before ->downl.
Fixes: e5dadc65f9e0 ("ppp: Fix false xmit recursion detect with two ppp devices")
[ Upstream commit e5dadc65f9e0177eb649bcd9d333f1ebf871223e ]
The global percpu variable ppp_xmit_recursion is used to detect the ppp
xmit recursion to avoid the deadlock, which is caused by one CPU tries to
lock the xmit lock twice. But it would report false recursion when one CPU
wants to send the skb from two different PPP devices, like one L2TP on the
PPPoE. It is a normal case actually.
Now use one percpu member of struct ppp instead of the gloable variable to
detect the xmit recursion of one ppp device.
Signed-off-by: Liu Jianying <jianying.liu@ikuai8.com>
ppp_xmit_process() already locks the xmit path. If HARD_TX_LOCK() tries
to hold the _xmit_lock we can get lock inversion.
[ 973.726130] ======================================================
[ 973.727311] [ INFO: possible circular locking dependency detected ]
[ 973.728546] 4.8.0-rc2 #1 Tainted: G O
[ 973.728986] -------------------------------------------------------
[ 973.728986] accel-pppd/1806 is trying to acquire lock:
[ 973.728986] (&qdisc_xmit_lock_key){+.-...}, at: [<ffffffff8146f6fe>] sch_direct_xmit+0x8d/0x221
[ 973.728986]
[ 973.728986] but task is already holding lock:
[ 973.728986] (l2tp_sock){+.-...}, at: [<ffffffffa0202c4a>] l2tp_xmit_skb+0x1e8/0x5d7 [l2tp_core]
[ 973.728986]
[ 973.728986] which lock already depends on the new lock.
[ 973.728986]
[ 973.728986]
[ 973.728986] the existing dependency chain (in reverse order) is:
[ 973.728986]
-> #3 (l2tp_sock){+.-...}:
[ 973.728986] [<ffffffff810b3130>] lock_acquire+0x150/0x217
[ 973.728986] [<ffffffff815752f4>] _raw_spin_lock+0x2d/0x3c
[ 973.728986] [<ffffffffa0202c4a>] l2tp_xmit_skb+0x1e8/0x5d7 [l2tp_core]
[ 973.728986] [<ffffffffa01b2466>] pppol2tp_xmit+0x1f2/0x25e [l2tp_ppp]
[ 973.728986] [<ffffffffa0184f59>] ppp_channel_push+0xb5/0x14a [ppp_generic]
[ 973.728986] [<ffffffffa01853ed>] ppp_write+0x104/0x11c [ppp_generic]
[ 973.728986] [<ffffffff811b2ec6>] __vfs_write+0x56/0x120
[ 973.728986] [<ffffffff811b3f4c>] vfs_write+0xbd/0x11b
[ 973.728986] [<ffffffff811b4cb2>] SyS_write+0x5e/0x96
[ 973.728986] [<ffffffff81575ba5>] entry_SYSCALL_64_fastpath+0x18/0xa8
[ 973.728986]
-> #2 (&(&pch->downl)->rlock){+.-...}:
[ 973.728986] [<ffffffff81575334>] _raw_spin_lock_bh+0x31/0x40
[ 973.728986] [<ffffffffa01808e2>] ppp_push+0xa7/0x82d [ppp_generic]
[ 973.728986] [<ffffffffa0184675>] __ppp_xmit_process+0x48/0x877 [ppp_generic]
[ 973.728986] [<ffffffffa018505b>] ppp_xmit_process+0x4b/0xaf [ppp_generic]
[ 973.728986] [<ffffffffa01853f7>] ppp_write+0x10e/0x11c [ppp_generic]
[ 973.728986]
-> #1 (&(&ppp->wlock)->rlock){+.-...}:
[ 973.728986] [<ffffffffa0184654>] __ppp_xmit_process+0x27/0x877 [ppp_generic]
[ 973.728986] [<ffffffffa01852da>] ppp_start_xmit+0x21b/0x22a [ppp_generic]
[ 973.728986] [<ffffffff8143f767>] dev_hard_start_xmit+0x1a9/0x43d
[ 973.728986] [<ffffffff8146f747>] sch_direct_xmit+0xd6/0x221
[ 973.728986] [<ffffffff814401e4>] __dev_queue_xmit+0x62a/0x912
[ 973.728986] [<ffffffff814404d7>] dev_queue_xmit+0xb/0xd
[ 973.728986] [<ffffffff81449978>] neigh_direct_output+0xc/0xe
[ 973.728986] [<ffffffff8150e62b>] ip6_finish_output2+0x5a9/0x623
[ 973.728986] [<ffffffff81512128>] ip6_output+0x15e/0x16a
[ 973.728986] [<ffffffff8153ef86>] dst_output+0x76/0x7f
[ 973.728986] [<ffffffff8153f737>] mld_sendpack+0x335/0x404
[ 973.728986] [<ffffffff81541c61>] mld_send_initial_cr.part.21+0x99/0xa2
[ 973.728986] [<ffffffff8154441d>] ipv6_mc_dad_complete+0x42/0x71
[ 973.728986] [<ffffffff8151c4bd>] addrconf_dad_completed+0x1cf/0x2ea
[ 973.728986] [<ffffffff8151e4fa>] addrconf_dad_work+0x453/0x520
[ 973.728986] [<ffffffff8107a393>] process_one_work+0x365/0x6f0
[ 973.728986] [<ffffffff8107aecd>] worker_thread+0x2de/0x421
[ 973.728986] [<ffffffff810816fb>] kthread+0x121/0x130
[ 973.728986] [<ffffffff81575dbf>] ret_from_fork+0x1f/0x40
[ 973.728986]
-> #0 (&qdisc_xmit_lock_key){+.-...}:
[ 973.728986] [<ffffffff810b28d6>] __lock_acquire+0x1118/0x1483
[ 973.728986] [<ffffffff8146f6fe>] sch_direct_xmit+0x8d/0x221
[ 973.728986] [<ffffffff81487811>] ip_finish_output2+0x5db/0x609
[ 973.728986] [<ffffffff81489590>] ip_finish_output+0x152/0x15e
[ 973.728986] [<ffffffff8148a0d4>] ip_output+0x8c/0x96
[ 973.728986] [<ffffffff81489652>] ip_local_out+0x41/0x4a
[ 973.728986] [<ffffffff81489e7d>] ip_queue_xmit+0x5a5/0x609
[ 973.728986] [<ffffffffa0202fe4>] l2tp_xmit_skb+0x582/0x5d7 [l2tp_core]
[ 973.728986]
[ 973.728986] other info that might help us debug this:
[ 973.728986]
[ 973.728986] Chain exists of:
&qdisc_xmit_lock_key --> &(&pch->downl)->rlock --> l2tp_sock
[ 973.728986] Possible unsafe locking scenario:
[ 973.728986]
[ 973.728986] CPU0 CPU1
[ 973.728986] ---- ----
[ 973.728986] lock(l2tp_sock);
[ 973.728986] lock(&(&pch->downl)->rlock);
[ 973.728986] lock(&qdisc_xmit_lock_key);
[ 973.728986]
[ 973.728986] *** DEADLOCK ***
[ 973.728986]
[ 973.728986] 6 locks held by accel-pppd/1806:
[ 973.728986] #0: (&(&pch->downl)->rlock){+.-...}, at: [<ffffffffa0184efa>] ppp_channel_push+0x56/0x14a [ppp_generic]
[ 973.728986] #1: (l2tp_sock){+.-...}, at: [<ffffffffa0202c4a>] l2tp_xmit_skb+0x1e8/0x5d7 [l2tp_core]
[ 973.728986] #2: (rcu_read_lock){......}, at: [<ffffffff81486981>] rcu_lock_acquire+0x0/0x20
[ 973.728986] #3: (rcu_read_lock_bh){......}, at: [<ffffffff81486981>] rcu_lock_acquire+0x0/0x20
[ 973.728986] #4: (rcu_read_lock_bh){......}, at: [<ffffffff814340e3>] rcu_lock_acquire+0x0/0x20
[ 973.728986] #5: (dev->qdisc_running_key ?: &qdisc_running_key#2){+.....}, at: [<ffffffff8144011e>] __dev_queue_xmit+0x564/0x912
[ 973.728986]
[ 973.728986] stack backtrace:
[ 973.728986] CPU: 2 PID: 1806 Comm: accel-pppd Tainted: G O 4.8.0-rc2 #1
[ 973.728986] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Debian-1.8.2-1 04/01/2014
[ 973.728986] ffff7fffffffffff ffff88003436f850 ffffffff812a20f4 ffffffff82156e30
[ 973.728986] ffffffff82156920 ffff88003436f890 ffffffff8115c759 ffff88003344ae00
[ 973.728986] ffff88003344b5c0 0000000000000002 0000000000000006 ffff88003344b5e8
[ 973.728986] Call Trace:
[ 973.728986] [<ffffffff812a20f4>] dump_stack+0x67/0x90
[ 973.728986] [<ffffffff8115c759>] print_circular_bug+0x22e/0x23c
[ 973.728986] [<ffffffff810b3130>] ? lock_acquire+0x150/0x217
[ 973.728986] [<ffffffff8146f6fe>] ? sch_direct_xmit+0x8d/0x221
[ 973.728986] [<ffffffff81486853>] ? dst_mtu+0x29/0x2e
[ 973.728986] [<ffffffff8148a0bc>] ? ip_output+0x74/0x96
[ 973.728986] [<ffffffff814c559e>] ? udp_set_csum+0x207/0x21e
[ 973.728986] [<ffffffff8124c11d>] ? fsnotify_perm+0x27/0x95
[ 973.728986] [<ffffffff8124d41d>] ? security_file_permission+0x4d/0x54
[ 973.728986] [<ffffffff810ae0fa>] ? trace_hardirqs_off_caller+0x121/0x12f
In case of misconfiguration, a virtual PPP channel might send packets
back to their parent PPP interface. This typically happens in
misconfigured L2TP setups, where PPP's peer IP address is set with the
IP of the L2TP peer.
When that happens the system hangs due to PPP trying to recursively
lock its xmit path.
[ 243.332155] BUG: spinlock recursion on CPU#1, accel-pppd/926
[ 243.333272] lock: 0xffff880033d90f18, .magic: dead4ead, .owner: accel-pppd/926, .owner_cpu: 1
[ 243.334859] CPU: 1 PID: 926 Comm: accel-pppd Not tainted 4.8.0-rc2 #1
[ 243.336010] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Debian-1.8.2-1 04/01/2014
[ 243.336018] ffff7fffffffffff ffff8800319a77a0 ffffffff8128de85 ffff880033d90f18
[ 243.336018] ffff880033ad8000 ffff8800319a77d8 ffffffff810ad7c0 ffffffff0000039e
[ 243.336018] ffff880033d90f18 ffff880033d90f60 ffff880033d90f18 ffff880033d90f28
[ 243.336018] Call Trace:
[ 243.336018] [<ffffffff8128de85>] dump_stack+0x4f/0x65
[ 243.336018] [<ffffffff810ad7c0>] spin_dump+0xe1/0xeb
[ 243.336018] [<ffffffff810ad7f0>] spin_bug+0x26/0x28
[ 243.336018] [<ffffffff810ad8b9>] do_raw_spin_lock+0x5c/0x160
[ 243.336018] [<ffffffff815522aa>] _raw_spin_lock_bh+0x35/0x3c
[ 243.336018] [<ffffffffa01a88e2>] ? ppp_push+0xa7/0x82d [ppp_generic]
[ 243.336018] [<ffffffffa01a88e2>] ppp_push+0xa7/0x82d [ppp_generic]
[ 243.336018] [<ffffffff810adada>] ? do_raw_spin_unlock+0xc2/0xcc
[ 243.336018] [<ffffffff81084962>] ? preempt_count_sub+0x13/0xc7
[ 243.336018] [<ffffffff81552438>] ? _raw_spin_unlock_irqrestore+0x34/0x49
[ 243.336018] [<ffffffffa01ac657>] ppp_xmit_process+0x48/0x877 [ppp_generic]
[ 243.336018] [<ffffffff81408cd3>] ? skb_queue_tail+0x71/0x7c
[ 243.336018] [<ffffffffa01ad1c5>] ppp_start_xmit+0x21b/0x22a [ppp_generic]
[ 243.336018] [<ffffffff81426af1>] dev_hard_start_xmit+0x15e/0x32c
[ 243.336018] [<ffffffff81454ed7>] sch_direct_xmit+0xd6/0x221
[ 243.336018] [<ffffffff814273a8>] __dev_queue_xmit+0x52a/0x820
[ 243.336018] [<ffffffff814276a9>] dev_queue_xmit+0xb/0xd
[ 243.336018] [<ffffffff81430a3c>] neigh_direct_output+0xc/0xe
[ 243.336018] [<ffffffff8146b5d7>] ip_finish_output2+0x4d2/0x548
[ 243.336018] [<ffffffff8146a8e6>] ? dst_mtu+0x29/0x2e
[ 243.336018] [<ffffffff8146d49c>] ip_finish_output+0x152/0x15e
[ 243.336018] [<ffffffff8146df84>] ? ip_output+0x74/0x96
[ 243.336018] [<ffffffff8146df9c>] ip_output+0x8c/0x96
[ 243.336018] [<ffffffff8146d55e>] ip_local_out+0x41/0x4a
[ 243.336018] [<ffffffff8146dd15>] ip_queue_xmit+0x531/0x5c5
[ 243.336018] [<ffffffff814a82cd>] ? udp_set_csum+0x207/0x21e
[ 243.336018] [<ffffffffa01f2f04>] l2tp_xmit_skb+0x582/0x5d7 [l2tp_core]
[ 243.336018] [<ffffffffa01ea458>] pppol2tp_xmit+0x1eb/0x257 [l2tp_ppp]
[ 243.336018] [<ffffffffa01acf17>] ppp_channel_push+0x91/0x102 [ppp_generic]
[ 243.336018] [<ffffffffa01ad2d8>] ppp_write+0x104/0x11c [ppp_generic]
[ 243.336018] [<ffffffff811a3c1e>] __vfs_write+0x56/0x120
[ 243.336018] [<ffffffff81239801>] ? fsnotify_perm+0x27/0x95
[ 243.336018] [<ffffffff8123ab01>] ? security_file_permission+0x4d/0x54
[ 243.336018] [<ffffffff811a4ca4>] vfs_write+0xbd/0x11b
[ 243.336018] [<ffffffff811a5a0a>] SyS_write+0x5e/0x96
[ 243.336018] [<ffffffff81552a1b>] entry_SYSCALL_64_fastpath+0x13/0x94
The main entry points for sending packets over a PPP unit are the
.write() and .ndo_start_xmit() callbacks (simplified view):
.write(unit fd) or .ndo_start_xmit()
CALL ppp_xmit_process()
LOCK unit's xmit path (ppp->wlock)
CALL ppp_push()
LOCK channel's xmit path (chan->downl)
CALL lower layer's .start_xmit() callback
... might recursively call .ndo_start_xmit() ...
RETURN from .start_xmit()
UNLOCK channel's xmit path
RETURN from ppp_push()
UNLOCK unit's xmit path
RETURN from ppp_xmit_process()
Packets can also be directly sent on channels (e.g. LCP packets):
.write(channel fd) or ppp_output_wakeup()
CALL ppp_channel_push()
... might call .ndo_start_xmit() ...
RETURN from ppp_channel_push()
Key points about the lower layer's .start_xmit() callback:
* It can be called directly by a channel fd .write() or by
ppp_output_wakeup() or indirectly by a unit fd .write() or by
.ndo_start_xmit().
* In any case, it's always called with chan->downl held.
* It might route the packet back to its parent unit using
.ndo_start_xmit() as entry point.
This patch detects and breaks recursion in ppp_xmit_process(). This
function is a good candidate for the task because it's called early
enough after .ndo_start_xmit(), it's always part of the recursion
loop and it's on the path of whatever entry point is used to send
a packet on a PPP unit.
Recursion detection is done using the per-cpu ppp_xmit_recursion
variable.
Since ppp_channel_push() too locks the channel's xmit path and calls
the lower layer's .start_xmit() callback, we need to also increment
ppp_xmit_recursion there. However there's no need to check for
recursion, as it's out of the recursion loop.
Reported-by: Feng Gao <gfree.wind@gmail.com>
1. Use struct gre_base_hdr directly in pptp_gre_header instead of
duplicated members;
2. Use existing macros like GRE_KEY, GRE_SEQ, and so on instead of
duplicated macros defined by PPTP;
3. Add new macros like GRE_IS_ACK/SEQ and so on instead of
PPTP_GRE_IS_A/S and so on;
Signed-off-by: Gao Feng <fgao@ikuai8.com>
Reviewed-by: Philip Prindeville <philipp@redfish-solutions.com>
The PPTP is encapsulated by GRE header with that GRE_VERSION bits
must contain one. But current GRE RPS needs the GRE_VERSION must be
zero. So RPS does not work for PPTP traffic.
In my test environment, there are four MIPS cores, and all traffic
are passed through by PPTP. As a result, only one core is 100% busy
while other three cores are very idle. After this patch, the usage
of four cores are balanced well.
Userspace programs generally need to know the name of the ppp devices
they create. Both ioctl and rtnl interfaces use the ppp<suffix> sheme
to name them. But although the suffix used by the ioctl interface can
be known by userspace (it's the PPP unit identifier returned by the
PPPIOCGUNIT ioctl), the one used by the rtnl is only known by the
kernel.
This patch brings more consistency between ioctl and rtnl based ppp
devices by generating device names using the PPP unit identifer as
suffix in both cases. This way, userspace can always infer the name of
the devices they create.
Just several instances of overlapping changes.
Matt reported that we have a NULL pointer dereference
in ppp_pernet() from ppp_connect_channel(),
i.e. pch->chan_net is NULL.
This is due to that a parallel ppp_unregister_channel()
could happen while we are in ppp_connect_channel(), during
which pch->chan_net set to NULL. Since we need a reference
to net per channel, it makes sense to sync the refcnt
with the life time of the channel, therefore we should
release this reference when we destroy it.
Fixes: 1f461dcdd296 ("ppp: take reference on channels netns")
Reported-by: Matt Bennett <Matt.Bennett@alliedtelesis.co.nz>
Cc: linux-ppp@vger.kernel.org
Cc: Guillaume Nault <g.nault@alphalink.fr>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Reviewed-by: Cyrill Gorcunov <gorcunov@openvz.org>
It is time to add netdev_lockdep_set_classes() helper
so that lockdep annotations per device type are easier to manage.
This removes a lot of copies and missing annotations.
Instead of using a single bit (__QDISC___STATE_RUNNING)
in sch->__state, use a seqcount.
This adds lockdep support, but more importantly it will allow us
to sample qdisc/class statistics without having to grab qdisc root lock.
Cc: Cong Wang <xiyou.wangcong@gmail.com>
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Define PPP device handler for use with rtnetlink.
The only PPP specific attribute is IFLA_PPP_DEV_FD. It is mandatory and
contains the file descriptor of the associated /dev/ppp instance (the
file descriptor which would have been used for ioctl(PPPIOCNEWUNIT) in
the ioctl-based API). The PPP device is removed when this file
descriptor is released (same behaviour as with ioctl based PPP
devices).
PPP devices created with the rtnetlink API behave like the ones created
with ioctl(PPPIOCNEWUNIT). In particular existing ioctls work the same
way, no matter how the PPP device was created.
The rtnl callbacks are also assigned to ioctl based PPP devices. This
way, rtnl messages have the same effect on any PPP devices.
The immediate effect is that all PPP devices, even ioctl-based
ones, can now be removed with "ip link del".
A minor difference still exists between ioctl and rtnl based PPP
interfaces: in the device name, the number following the "ppp" prefix
corresponds to the PPP unit number for ioctl based devices, while it is
just an unrelated incrementing index for rtnl ones.
Move PPP device initialisation and registration out of
ppp_create_interface().
This prepares code for device registration with rtnetlink.
While there, simplify the prototype of ppp_create_interface():
* Since ppp_dev_configure() takes care of setting file->private_data,
there's no need to return a ppp structure to ppp_unattached_ioctl()
anymore.
* The unit parameter is made read/write so that ppp_create_interface()
can tell which unit number has been assigned.
Let channels hold a reference on their network namespace.
Some channel types, like ppp_async and ppp_synctty, can have their
userspace controller running in a different namespace. Therefore they
can't rely on them to preclude their netns from being removed from
under them.
BUG: KASAN: use-after-free in ppp_unregister_channel+0x372/0x3a0 at
addr ffff880064e217e0
Read of size 8 by task syz-executor/11581
BUG net_namespace (Not tainted): kasan: bad access detected
Disabling lock debugging due to kernel taint
INFO: Allocated in copy_net_ns+0x6b/0x1a0 age=92569 cpu=3 pid=6906
[< none >] ___slab_alloc+0x4c7/0x500 kernel/mm/slub.c:2440
[< none >] __slab_alloc+0x4c/0x90 kernel/mm/slub.c:2469
[< inline >] slab_alloc_node kernel/mm/slub.c:2532
[< inline >] slab_alloc kernel/mm/slub.c:2574
[< none >] kmem_cache_alloc+0x23a/0x2b0 kernel/mm/slub.c:2579
[< inline >] kmem_cache_zalloc kernel/include/linux/slab.h:597
[< inline >] net_alloc kernel/net/core/net_namespace.c:325
[< none >] copy_net_ns+0x6b/0x1a0 kernel/net/core/net_namespace.c:360
[< none >] create_new_namespaces+0x2f6/0x610 kernel/kernel/nsproxy.c:95
[< none >] copy_namespaces+0x297/0x320 kernel/kernel/nsproxy.c:150
[< none >] copy_process.part.35+0x1bf4/0x5760 kernel/kernel/fork.c:1451
[< inline >] copy_process kernel/kernel/fork.c:1274
[< none >] _do_fork+0x1bc/0xcb0 kernel/kernel/fork.c:1723
[< inline >] SYSC_clone kernel/kernel/fork.c:1832
[< none >] SyS_clone+0x37/0x50 kernel/kernel/fork.c:1826
[< none >] entry_SYSCALL_64_fastpath+0x16/0x7a kernel/arch/x86/entry/entry_64.S:185
INFO: Freed in net_drop_ns+0x67/0x80 age=575 cpu=2 pid=2631
[< none >] __slab_free+0x1fc/0x320 kernel/mm/slub.c:2650
[< inline >] slab_free kernel/mm/slub.c:2805
[< none >] kmem_cache_free+0x2a0/0x330 kernel/mm/slub.c:2814
[< inline >] net_free kernel/net/core/net_namespace.c:341
[< none >] net_drop_ns+0x67/0x80 kernel/net/core/net_namespace.c:348
[< none >] cleanup_net+0x4e5/0x600 kernel/net/core/net_namespace.c:448
[< none >] process_one_work+0x794/0x1440 kernel/kernel/workqueue.c:2036
[< none >] worker_thread+0xdb/0xfc0 kernel/kernel/workqueue.c:2170
[< none >] kthread+0x23f/0x2d0 kernel/drivers/block/aoe/aoecmd.c:1303
[< none >] ret_from_fork+0x3f/0x70 kernel/arch/x86/entry/entry_64.S:468
INFO: Slab 0xffffea0001938800 objects=3 used=0 fp=0xffff880064e20000
flags=0x5fffc0000004080
INFO: Object 0xffff880064e20000 @offset=0 fp=0xffff880064e24200
CPU: 1 PID: 11581 Comm: syz-executor Tainted: G B 4.4.0+
rel-1.8.2-0-g33fbe13 by qemu-project.org 04/01/2014
00000000ffffffff ffff8800662c7790 ffffffff8292049d ffff88003e36a300
ffff880064e20000 ffff880064e20000 ffff8800662c77c0 ffffffff816f2054
ffff88003e36a300 ffffea0001938800 ffff880064e20000 0000000000000000
Call Trace:
[< inline >] __dump_stack kernel/lib/dump_stack.c:15
[<ffffffff8292049d>] dump_stack+0x6f/0xa2 kernel/lib/dump_stack.c:50
[<ffffffff816f2054>] print_trailer+0xf4/0x150 kernel/mm/slub.c:654
[<ffffffff816f875f>] object_err+0x2f/0x40 kernel/mm/slub.c:661
[< inline >] print_address_description kernel/mm/kasan/report.c:138
[<ffffffff816fb0c5>] kasan_report_error+0x215/0x530 kernel/mm/kasan/report.c:236
[< inline >] kasan_report kernel/mm/kasan/report.c:259
[<ffffffff816fb4de>] __asan_report_load8_noabort+0x3e/0x40 kernel/mm/kasan/report.c:280
[< inline >] ? ppp_pernet kernel/include/linux/compiler.h:218
[<ffffffff83ad71b2>] ? ppp_unregister_channel+0x372/0x3a0 kernel/drivers/net/ppp/ppp_generic.c:2392
[< inline >] ppp_pernet kernel/include/linux/compiler.h:218
[<ffffffff83ad71b2>] ppp_unregister_channel+0x372/0x3a0 kernel/drivers/net/ppp/ppp_generic.c:2392
[< inline >] ? ppp_pernet kernel/drivers/net/ppp/ppp_generic.c:293
[<ffffffff83ad6f26>] ? ppp_unregister_channel+0xe6/0x3a0 kernel/drivers/net/ppp/ppp_generic.c:2392
[<ffffffff83ae18f3>] ppp_asynctty_close+0xa3/0x130 kernel/drivers/net/ppp/ppp_async.c:241
[<ffffffff83ae1850>] ? async_lcp_peek+0x5b0/0x5b0 kernel/drivers/net/ppp/ppp_async.c:1000
[<ffffffff82c33239>] tty_ldisc_close.isra.1+0x99/0xe0 kernel/drivers/tty/tty_ldisc.c:478
[<ffffffff82c332c0>] tty_ldisc_kill+0x40/0x170 kernel/drivers/tty/tty_ldisc.c:744
[<ffffffff82c34943>] tty_ldisc_release+0x1b3/0x260 kernel/drivers/tty/tty_ldisc.c:772
[<ffffffff82c1ef21>] tty_release+0xac1/0x13e0 kernel/drivers/tty/tty_io.c:1901
[<ffffffff82c1e460>] ? release_tty+0x320/0x320 kernel/drivers/tty/tty_io.c:1688
[<ffffffff8174de36>] __fput+0x236/0x780 kernel/fs/file_table.c:208
[<ffffffff8174e405>] ____fput+0x15/0x20 kernel/fs/file_table.c:244
[<ffffffff813595ab>] task_work_run+0x16b/0x200 kernel/kernel/task_work.c:115
[< inline >] exit_task_work kernel/include/linux/task_work.h:21
[<ffffffff81307105>] do_exit+0x8b5/0x2c60 kernel/kernel/exit.c:750
[<ffffffff813fdd20>] ? debug_check_no_locks_freed+0x290/0x290 kernel/kernel/locking/lockdep.c:4123
[<ffffffff81306850>] ? mm_update_next_owner+0x6f0/0x6f0 kernel/kernel/exit.c:357
[<ffffffff813215e6>] ? __dequeue_signal+0x136/0x470 kernel/kernel/signal.c:550
[<ffffffff8132067b>] ? recalc_sigpending_tsk+0x13b/0x180 kernel/kernel/signal.c:145
[<ffffffff81309628>] do_group_exit+0x108/0x330 kernel/kernel/exit.c:880
[<ffffffff8132b9d4>] get_signal+0x5e4/0x14f0 kernel/kernel/signal.c:2307
[< inline >] ? kretprobe_table_lock kernel/kernel/kprobes.c:1113
[<ffffffff8151d355>] ? kprobe_flush_task+0xb5/0x450 kernel/kernel/kprobes.c:1158
[<ffffffff8115f7d3>] do_signal+0x83/0x1c90 kernel/arch/x86/kernel/signal.c:712
[<ffffffff8151d2a0>] ? recycle_rp_inst+0x310/0x310 kernel/include/linux/list.h:655
[<ffffffff8115f750>] ? setup_sigcontext+0x780/0x780 kernel/arch/x86/kernel/signal.c:165
[<ffffffff81380864>] ? finish_task_switch+0x424/0x5f0 kernel/kernel/sched/core.c:2692
[< inline >] ? finish_lock_switch kernel/kernel/sched/sched.h:1099
[<ffffffff81380560>] ? finish_task_switch+0x120/0x5f0 kernel/kernel/sched/core.c:2678
[< inline >] ? context_switch kernel/kernel/sched/core.c:2807
[<ffffffff85d794e9>] ? __schedule+0x919/0x1bd0 kernel/kernel/sched/core.c:3283
[<ffffffff81003901>] exit_to_usermode_loop+0xf1/0x1a0 kernel/arch/x86/entry/common.c:247
[< inline >] prepare_exit_to_usermode kernel/arch/x86/entry/common.c:282
[<ffffffff810062ef>] syscall_return_slowpath+0x19f/0x210 kernel/arch/x86/entry/common.c:344
[<ffffffff85d88022>] int_ret_from_sys_call+0x25/0x9f kernel/arch/x86/entry/entry_64.S:281
Memory state around the buggy address:
ffff880064e21680: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff880064e21700: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
>ffff880064e21780: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff880064e21800: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff880064e21880: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
Fixes: 273ec51dd7ce ("net: ppp_generic - introduce net-namespace functionality v2")
Reported-by: Baozeng Ding <sploving1@gmail.com>
Pull networking updates from David Miller:
"Highlights:
1) Support more Realtek wireless chips, from Jes Sorenson.
2) New BPF types for per-cpu hash and arrap maps, from Alexei
Starovoitov.
3) Make several TCP sysctls per-namespace, from Nikolay Borisov.
4) Allow the use of SO_REUSEPORT in order to do per-thread processing
of incoming TCP/UDP connections. The muxing can be done using a
BPF program which hashes the incoming packet. From Craig Gallek.
5) Add a multiplexer for TCP streams, to provide a messaged based
interface. BPF programs can be used to determine the message
boundaries. From Tom Herbert.
6) Add 802.1AE MACSEC support, from Sabrina Dubroca.
7) Avoid factorial complexity when taking down an inetdev interface
with lots of configured addresses. We were doing things like
traversing the entire address less for each address removed, and
flushing the entire netfilter conntrack table for every address as
well.
8) Add and use SKB bulk free infrastructure, from Jesper Brouer.
9) Allow offloading u32 classifiers to hardware, and implement for
ixgbe, from John Fastabend.
10) Allow configuring IRQ coalescing parameters on a per-queue basis,
from Kan Liang.
11) Extend ethtool so that larger link mode masks can be supported.
From David Decotigny.
12) Introduce devlink, which can be used to configure port link types
(ethernet vs Infiniband, etc.), port splitting, and switch device
level attributes as a whole. From Jiri Pirko.
13) Hardware offload support for flower classifiers, from Amir Vadai.
14) Add "Local Checksum Offload". Basically, for a tunneled packet
the checksum of the outer header is 'constant' (because with the
checksum field filled into the inner protocol header, the payload
of the outer frame checksums to 'zero'), and we can take advantage
of that in various ways. From Edward Cree"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1548 commits)
bonding: fix bond_get_stats()
net: bcmgenet: fix dma api length mismatch
net/mlx4_core: Fix backward compatibility on VFs
phy: mdio-thunder: Fix some Kconfig typos
lan78xx: add ndo_get_stats64
lan78xx: handle statistics counter rollover
RDS: TCP: Remove unused constant
RDS: TCP: Add sysctl tunables for sndbuf/rcvbuf on rds-tcp socket
net: smc911x: convert pxa dma to dmaengine
team: remove duplicate set of flag IFF_MULTICAST
bonding: remove duplicate set of flag IFF_MULTICAST
net: fix a comment typo
ethernet: micrel: fix some error codes
ip_tunnels, bpf: define IP_TUNNEL_OPTS_MAX and use it
bpf, dst: add and use dst_tclassid helper
bpf: make skb->tc_classid also readable
net: mvneta: bm: clarify dependencies
cls_bpf: reset class and reuse major in da
ldmvsw: Checkpatch sunvnet.c and sunvnet_common.c
ldmvsw: Add ldmvsw.c driver code
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Pull crypto update from Herbert Xu:
"Here is the crypto update for 4.6:
API:
- Convert remaining crypto_hash users to shash or ahash, also convert
blkcipher/ablkcipher users to skcipher.
- Remove crypto_hash interface.
- Remove crypto_pcomp interface.
- Add crypto engine for async cipher drivers.
- Add akcipher documentation.
- Add skcipher documentation.
Algorithms:
- Rename crypto/crc32 to avoid name clash with lib/crc32.
- Fix bug in keywrap where we zero the wrong pointer.
Drivers:
- Support T5/M5, T7/M7 SPARC CPUs in n2 hwrng driver.
- Add PIC32 hwrng driver.
- Support BCM6368 in bcm63xx hwrng driver.
- Pack structs for 32-bit compat users in qat.
- Use crypto engine in omap-aes.
- Add support for sama5d2x SoCs in atmel-sha.
- Make atmel-sha available again.
- Make sahara hashing available again.
- Make ccp hashing available again.
- Make sha1-mb available again.
- Add support for multiple devices in ccp.
- Improve DMA performance in caam.
- Add hashing support to rockchip"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (116 commits)
crypto: qat - remove redundant arbiter configuration
crypto: ux500 - fix checks of error code returned by devm_ioremap_resource()
crypto: atmel - fix checks of error code returned by devm_ioremap_resource()
crypto: qat - Change the definition of icp_qat_uof_regtype
hwrng: exynos - use __maybe_unused to hide pm functions
crypto: ccp - Add abstraction for device-specific calls
crypto: ccp - CCP versioning support
crypto: ccp - Support for multiple CCPs
crypto: ccp - Remove check for x86 family and model
crypto: ccp - memset request context to zero during import
lib/mpi: use "static inline" instead of "extern inline"
lib/mpi: avoid assembler warning
hwrng: bcm63xx - fix non device tree compatibility
crypto: testmgr - allow rfc3686 aes-ctr variants in fips mode.
crypto: qat - The AE id should be less than the maximal AE number
lib/mpi: Endianness fix
crypto: rockchip - add hash support for crypto engine in rk3288
crypto: xts - fix compile errors
crypto: doc - add skcipher API documentation
crypto: doc - update AEAD AD handling
Locking ppp_mutex must be done before dereferencing file->private_data,
otherwise it could be modified before ppp_unattached_ioctl() takes the
lock. This could lead ppp_unattached_ioctl() to override ->private_data,
thus leaking reference to the ppp_file previously pointed to.
v2: lock all ppp_ioctl() instead of just checking private_data in
ppp_unattached_ioctl(), to avoid ambiguous behaviour.
Fixes: f3ff8a4d80e8 ("ppp: push BKL down into the driver")
Several cases of overlapping changes, as well as one instance
(vxlan) of a bug fix in 'net' overlapping with code movement
in 'net-next'.
Add missing rtnl_unlock() in the error path of ppp_create_interface().
Fixes: 58a89ecaca53 ("ppp: fix lockdep splat in ppp_dev_uninit()")
ppp_read() and ppp_poll() can be called concurrently with ppp_ioctl().
In this case, ppp_ioctl() might call ppp_ccp_closed(), which may update
ppp->flags while ppp_read() or ppp_poll() is reading it.
The update done by ppp_ccp_closed() isn't atomic due to the bit mask
operation ('ppp->flags &= ~(SC_CCP_OPEN | SC_CCP_UP)'), so concurrent
readers might get transient values.
Reading incorrect ppp->flags may disturb the 'ppp->flags & SC_LOOP_TRAFFIC'
test in ppp_read() and ppp_poll(), which in turn can lead to improper
decision on whether the PPP unit file is ready for reading or not.
Since ppp_ccp_closed() is protected by the Rx and Tx locks (with
ppp_lock()), taking the Rx lock is enough for ppp_read() and ppp_poll()
to guarantee that ppp_ccp_closed() won't update ppp->flags
concurrently.
The same reasoning applies to ppp->n_channels. The 'n_channels' field
can also be written to concurrently by ppp_ioctl() (through
ppp_connect_channel() or ppp_disconnect_channel()). These writes aren't
atomic (simple increment/decrement), but are protected by both the Rx
and Tx locks (like in the ppp->flags case). So holding the Rx lock
before reading ppp->n_channels also prevents concurrent writes.
* Split big conditional statement.
* Check (data.length <= CCP_MAX_OPTION_LENGTH) only once.
* Don't read ccp_option[1] if not initialised.
Reading uninitialised ccp_option[1] was harmless, because this could
only happen when data.length was 0 or 1. So even then, we couldn't pass
the (ccp_option[1] < 2 || ccp_option[1] > data.length) test anyway.
Drop reference on the relay_po socket when __pppoe_xmit() succeeds.
This is already handled correctly in the error path.
This patch replaces uses of blkcipher with skcipher, and the long
obsolete hash interface with ahash. This is a bug-for-bug conversion
and no attempt has been made to fix bugs such as the ignored return
values of the crypto operations.
Several times already this has been reported as kasan reports caused by
syzkaller and trinity and people always looked at RCU races, but it is
much more simple. :)
In case we bind a pptp socket multiple times, we simply add it to
the callid_sock list but don't remove the old binding. Thus the old
socket stays in the bucket with unused call_id indexes and doesn't get
cleaned up. This causes various forms of kasan reports which were hard
to pinpoint.
Simply don't allow multiple binds and correct error handling in
pptp_bind. Also keep sk_state bits in place in pptp_connect.
Fixes: 00959ade36acad ("PPTP: PPP over IPv4 (Point-to-Point Tunneling Protocol)")
Cc: Dmitry Kozlov <xeb@mail.ru>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Dave Jones <davej@codemonkey.org.uk>
Reported-by: Dave Jones <davej@codemonkey.org.uk>
drivers/net/geneve.c
Here we had an overlapping change, where in 'net' the extraneous stats
bump was being removed whilst in 'net-next' the final argument to
udp_tunnel6_xmit_skb() was being changed.
Reported-by: Dmitry Vyukov <dvyukov@gmail.com>
Let user space be aware of the naming scheme used by ppp interfaces
(visible in /sys/class/net/<iface>/name_assign_type).
Let PPP devices be identified as such in /sys/class/net/<iface>/uevent.
pppoe_connect() mustn't touch the padt_work field of pppoe sockets
because that work could be already pending.
[ 21.473147] BUG: unable to handle kernel NULL pointer dereference at 00000004
[ 21.474523] IP: [<c1043177>] process_one_work+0x29/0x31c
[ 21.475164] *pde = 00000000
[ 21.475513] Oops: 0000 [#1] SMP
[ 21.475910] Modules linked in: pppoe pppox ppp_generic slhc crc32c_intel aesni_intel virtio_net xts aes_i586 lrw gf128mul ablk_helper cryptd evdev acpi_cpufreq processor serio_raw button ext4 crc16 mbcache jbd2 virtio_blk virtio_pci virtio_ring virtio
[ 21.476168] CPU: 2 PID: 164 Comm: kworker/2:2 Not tainted 4.4.0-rc1 #1
[ 21.476168] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Debian-1.8.2-1 04/01/2014
[ 21.476168] task: f5f83c00 ti: f5e28000 task.ti: f5e28000
[ 21.476168] EIP: 0060:[<c1043177>] EFLAGS: 00010046 CPU: 2
[ 21.476168] EIP is at process_one_work+0x29/0x31c
[ 21.484082] EAX: 00000000 EBX: f678b2a0 ECX: 00000004 EDX: 00000000
[ 21.484082] ESI: f6c69940 EDI: f5e29ef0 EBP: f5e29f0c ESP: f5e29edc
[ 21.484082] DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068
[ 21.484082] CR0: 80050033 CR2: 000000a4 CR3: 317ad000 CR4: 00040690
[ 21.484082] Stack:
[ 21.484082] 00000000 f6c69950 00000000 f6c69940 c0042338 f5e29f0c c1327945 00000000
[ 21.484082] 00000008 f678b2a0 f6c69940 f678b2b8 f5e29f30 c1043984 f5f83c00 f6c69970
[ 21.484082] f678b2a0 c10437d3 f6775e80 f678b2a0 c10437d3 f5e29fac c1047059 f5e29f74
[ 21.484082] Call Trace:
[ 21.484082] [<c1327945>] ? _raw_spin_lock_irq+0x28/0x30
[ 21.484082] [<c1043984>] worker_thread+0x1b1/0x244
[ 21.484082] [<c10437d3>] ? rescuer_thread+0x229/0x229
[ 21.484082] [<c1047059>] kthread+0x8f/0x94
[ 21.484082] [<c1327a32>] ? _raw_spin_unlock_irq+0x22/0x26
[ 21.484082] [<c1327ee9>] ret_from_kernel_thread+0x21/0x38
[ 21.484082] [<c1046fca>] ? kthread_parkme+0x19/0x19
[ 21.496082] Code: 5d c3 55 89 e5 57 56 53 89 c3 83 ec 24 89 d0 89 55 e0 8d 7d e4 e8 6c d8 ff ff b9 04 00 00 00 89 45 d8 8b 43 24 89 45 dc 8b 45 d8 <8b> 40 04 8b 80 e0 00 00 00 c1 e8 05 24 01 88 45 d7 8b 45 e0 8d
[ 21.496082] EIP: [<c1043177>] process_one_work+0x29/0x31c SS:ESP 0068:f5e29edc
[ 21.496082] CR2: 0000000000000004
[ 21.496082] ---[ end trace e362cc9cf10dae89 ]---
Reported-by: Andrew <nitr0@seti.kr.ua>
Fixes: 287f3a943fef ("pppoe: Use workqueue to die properly when a PADT is received")
* Register PF_PPPOX with pppox module rather than with pppoe,
so that pppoe doesn't get loaded for any PF_PPPOX socket.
* Register PX_PROTO_* with standard MODULE_ALIAS_NET_PF_PROTO()
instead of using pppox's own naming scheme.
* While there, add auto-loading feature for pptp.
PPPOX_ZOMBIE is never set anymore.
Since 287f3a943fef ("pppoe: Use workqueue to die properly when a PADT
is received"), pppoe_disc_rcv() disconnects the socket by scheduling
pppoe_unbind_sock_work(). This is enough to stop socket transmission
and makes the PPPOX_ZOMBIE state uncessary.
Minor overlapping changes in net/ipv4/ipmr.c, in 'net' we were
fixing the "BH-ness" of the counter bumps whilst in 'net-next'
the functions were modified to take an explicit 'net' parameter.
Currently slhc_init() treats out-of-range values of rslots and tslots
as equivalent to 0, except that if tslots is too large it will
dereference a null pointer (CVE-2015-7799).
Add a range-check at the top of the function and make it return an
ERR_PTR() on error instead of NULL. Change the callers accordingly.
Compile-tested only.
Reported-by: 郭永刚 <guoyonggang@360.cn>
References: http://article.gmane.org/gmane.comp.security.oss.general/17908
net/ipv6/xfrm6_output.c
net/openvswitch/flow_netlink.c
net/openvswitch/vport-gre.c
net/openvswitch/vport-vxlan.c
net/openvswitch/vport.c
net/openvswitch/vport.h
The openvswitch conflicts were overlapping changes. One was
the egress tunnel info fix in 'net' and the other was the
vport ->send() op simplification in 'net-next'.
The xfrm6_output.c conflicts was also a simplification
overlapping a bug fix.
