path: root/drivers/net/s2io.c
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-04tree-wide: fix typos "couter" -> "counter"Uwe Kleine-König
This patch was generated by git grep -E -i -l 'couter' | xargs -r perl -p -i -e 's/couter/counter/' Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-13s2io: fixing a ethtool test that is brokenBreno Leitao
Due commit 4b77b0a2ba27d64f58f16d8d4d48d8319dda36ff, it is not more possible to pci_restore_state() more than once without calling pci_save_state() in the middle. Actually running a ethtool test on s2io makes the card inactive, and it needs to unload/reload the module to fix. This patch just save the state just after it restore in order to keep the old behaviour Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-30s2io: Generate complete messages using single line DBG_PRINTsJoe Perches
Single line log messages should be emitted by a single call where possible. Converted multiple calls to DBG_PRINT to single call form. Removed "s2io:" preface from DBG_PRINTs. The DBG_PRINT macro now emits a log level and is surrounded by a do {...} while (0) All s2io log output is now prefaced with KBUILD_MODNAME ": " via pr_fmt. The DBG_PRINT macro should probably be converted to use the dev_<level> form eventually. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-30s2io.c: Convert skipped nic->config.tx_cfg[i]. to tx_cfg->Joe Perches
Missed doing the conversion in earlier patch. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-30s2io.c: Standardize statistics accessorsJoe Perches
Regularize the declaration and uses of struct config_param *config = &sp->config; struct mac_info *mac_control = &sp->mac_control; and use struct stat_block *stats = mac_control->stats_info; struct swStat *swstats = &stats->sw_stat; struct xpakStat *xstats = &stats->xpak_stat; and convert the longish uses like nic->mac_control.stats_info->sw_stat.<foo> to swstats-><foo> etc. This also makes the statistics code marginally smaller and presumably faster. Old: $ size s2io.o text data bss dec hex filename 114289 516 33360 148165 242c5 s2io.o New: $ size s2io.o text data bss dec hex filename 114097 516 33360 147973 24205 s2io.o Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-30s2io.c: fix spelling explainationJoe Perches
2009-08-30s2io.c: convert printks to pr_<level>Joe Perches
Fixed trivial typo as well Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-30s2io.c: Make more conforming to normal kernel styleJoe Perches
Still has a few long lines. checkpatch was: total: 263 errors, 53 warnings, 8751 lines checked is: total: 4 errors, 35 warnings, 8767 lines checked Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-30s2io.c: use kzallocJoe Perches
2009-08-30s2io.c: Use calculated size in kmallocsJoe Perches
Use consistent style. Don't calculate the kmalloc size multiple times Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-30s2io.c: Shorten code line length by using intermediate pointersJoe Perches
Repeated variable use and line wrapping is hard to read. Use temp variables instead of direct references. struct fifo_info *fifo = &mac_control->fifos[i]; struct ring_info *ring = &mac_control->rings[i]; struct tx_fifo_config *tx_cfg = &config->tx_cfg[i]; struct rx_ring_config *rx_cfg = &config->rx_cfg[i]; Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-30s2io.c: Use const for stringsJoe Perches
2009-08-01s2io: return PCI_ERS_RESULT_DISCONNECT on permanent failureDean Nelson
PCI drivers that implement the struct pci_error_handlers' error_detected callback should return PCI_ERS_RESULT_DISCONNECT if the state passed in is pci_channel_io_perm_failure. This patch fixes the issue for s2io. Signed-off-by: Dean Nelson <dnelson@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08s2io: Remove private boolean definitionsTobias Klauser
Remove the private definition of TRUE/FALSE and use the ones from linux/stddef.h. Also remove the definition of BOOL which is not referenced inside the driver anyway. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29net: dont update dev->trans_start in 10GB driversEric Dumazet
Followup of commits 9d21493b4beb8f918ba248032fefa393074a5e2b and 08baf561083bc27a953aa087dd8a664bb2b88e8e (net: tx scalability works : trans_start) (net: txq_trans_update() helper) Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Multi queue drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers (vxge & tehuti) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-29s2io: Use generic MDIO definitionsBen Hutchings
Compile-tested only. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07dma-mapping: replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)Yang Hongyang
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-17drivers/net/s2io.c: fix sparse warning: symbol shadows an earlier oneHannes Eder
Impact: Remove redundant inner scope variable. Fix this sparse warning: drivers/net/s2io.c:7223:21: warning: symbol 'i' shadows an earlier one drivers/net/s2io.c:7184:13: originally declared here Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-03s2io: Formatting log messageBreno Leitao
S2IO driver is printing dev->name before the name being allocated, which display eth%d instead of eth0, eth1, etc. Example: eth%d: Enabling MSIX failed eth%d: MSI-X requested but failed to enable This patch just change eth%d to s2io. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-27net: Add skb_record_rx_queue() calls to multiqueue capable drivers.David S. Miller
2009-01-21net: Remove redundant NAPI functionsBen Hutchings
Following the removal of the unused struct net_device * parameter from the NAPI functions named *netif_rx_* in commit 908a7a1, they are exactly equivalent to the corresponding *napi_* functions and are therefore redundant. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-26net: Fix warning fallout from recent NAPI interface changes.David S. Miller
When we removed the network device argument from several NAPI interfaces in 908a7a16b852ffd618a9127be8d62432182d81b4 ("net: Remove unused netdev arg from some NAPI interfaces.") several drivers now started getting unused variable warnings. This fixes those up. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-25drivers/net: fix sparse warnings: make symbols staticHannes Eder
Fix this sparse warnings: drivers/net/3c523.c:350:6: warning: symbol 'alloc586' was not declared. Should it be static? drivers/net/cs89x0.c:1029:14: warning: symbol 'reset_chip' was not declared. Should it be static? drivers/net/eepro.c:1399:1: warning: symbol 'read_eeprom' was not declared. Should it be static? drivers/net/plip.c:1020:5: warning: symbol 'plip_hard_header_cache' was not declared. Should it be static? drivers/net/s2io.c:5116:6: warning: symbol 'do_s2io_store_unicast_mc' was not declared. Should it be static? drivers/net/smc9194.c:767:12: warning: symbol 'smc_findirq' was not declared. Should it be static? Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-22net: Remove unused netdev arg from some NAPI interfaces.Neil Horman
When the napi api was changed to separate its 1:1 binding to the net_device struct, the netif_rx_[prep|schedule|complete] api failed to remove the now vestigual net_device structure parameter. This patch cleans up that api by properly removing it.. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25s2io: fix warning in drivers/net/s2io.cIngo Molnar
this warning: drivers/net/s2io.c: In function ‘rx_intr_handler’: drivers/net/s2io.c:7369: warning: ‘lro’ may be used uninitialized in this function triggers because GCC does not recognize the (correct) error flow between: - s2io_club_tcp_session()and 'lro' Annotate it. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-21s2io: convert to net_device_opsStephen Hemminger
Convert this driver to network device ops. Compile teseted only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12netdevice: safe convert to netdev_priv() #part-2Wang Chen
We have some reasons to kill netdev->priv: 1. netdev->priv is equal to netdev_priv(). 2. netdev_priv() wraps the calculation of netdev->priv's offset, obviously netdev_priv() is more flexible than netdev->priv. But we cann't kill netdev->priv, because so many drivers reference to it directly. This patch is a safe convert for netdev->priv to netdev_priv(netdev). Since all of the netdev->priv is only for read. But it is too big to be sent in one mail. I split it to 4 parts and make every part smaller than 100,000 bytes, which is max size allowed by vger. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31pci: use pci_ioremap_bar() in drivers/netArjan van de Ven
Use the newly introduced pci_ioremap_bar() function in drivers/net. pci_ioremap_bar() just takes a pci device and a bar number, with the goal of making it really hard to get wrong, while also having a central place to stick sanity checks. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-24drivers/net: replace __FUNCTION__ with __func__Harvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-24s2io: Fix enabling VLAN tag stripping at driver initializationBreno Leitao
VLAN doesn't work except if you'd opened the interface in promiscuous mode before. This happens because VLAN tag stripping is not correctly marked as enabled at device startup Also, the vlan_strip_flag field was moved to the private network structure. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-03s2io: reindented misleading for loopIlpo Järvinen
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-29S2io: fix statistics flush after a MTU changeBreno Leitao
On s2io driver, when you change the interface MTU, it invokes a card reset, which flush some statistics. This patch solves this problem, and also set the net_device->stats as the default statistics structure, instead of s2io_nic->stats. To do that, s2io_nic->stats turned into a staging area, where is saved statistics of the last hardware statistics query. So, the difference between the current hardware statistics and s2io_nic->stats, is the value that should be summed up, in order to get the correct statistics value, even after a reset. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-26dma-mapping: add the device argument to dma_mapping_error()FUJITA Tomonori
Add per-device dma_mapping_ops support for CONFIG_X86_64 as POWER architecture does: This enables us to cleanly fix the Calgary IOMMU issue that some devices are not behind the IOMMU (http://lkml.org/lkml/2008/5/8/423). I think that per-device dma_mapping_ops support would be also helpful for KVM people to support PCI passthrough but Andi thinks that this makes it difficult to support the PCI passthrough (see the above thread). So I CC'ed this to KVM camp. Comments are appreciated. A pointer to dma_mapping_ops to struct dev_archdata is added. If the pointer is non NULL, DMA operations in asm/dma-mapping.h use it. If it's NULL, the system-wide dma_ops pointer is used as before. If it's useful for KVM people, I plan to implement a mechanism to register a hook called when a new pci (or dma capable) device is created (it works with hot plugging). It enables IOMMUs to set up an appropriate dma_mapping_ops per device. The major obstacle is that dma_mapping_error doesn't take a pointer to the device unlike other DMA operations. So x86 can't have dma_mapping_ops per device. Note all the POWER IOMMUs use the same dma_mapping_error function so this is not a problem for POWER but x86 IOMMUs use different dma_mapping_error functions. The first patch adds the device argument to dma_mapping_error. The patch is trivial but large since it touches lots of drivers and dma-mapping.h in all the architecture. This patch: dma_mapping_error() doesn't take a pointer to the device unlike other DMA operations. So we can't have dma_mapping_ops per device. Note that POWER already has dma_mapping_ops per device but all the POWER IOMMUs use the same dma_mapping_error function. x86 IOMMUs use device argument. [akpm@linux-foundation.org: fix sge] [akpm@linux-foundation.org: fix svc_rdma] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix bnx2x] [akpm@linux-foundation.org: fix s2io] [akpm@linux-foundation.org: fix pasemi_mac] [akpm@linux-foundation.org: fix sdhci] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix sparc] [akpm@linux-foundation.org: fix ibmvscsi] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-17net: Use queue aware tests throughout.David S. Miller
This effectively "flips the switch" by making the core networking and multiqueue-aware drivers use the new TX multiqueue structures. Non-multiqueue drivers need no changes. The interfaces they use such as netif_stop_queue() degenerate into an operation on TX queue zero. So everything "just works" for them. Code that really wants to do "X" to all TX queues now invokes a routine that does so, such as netif_tx_wake_all_queues(), netif_tx_stop_all_queues(), etc. pktgen and netpoll required a little bit more surgery than the others. In particular the pktgen changes, whilst functional, could be largely improved. The initial check in pktgen_xmit() will sometimes check the wrong queue, which is mostly harmless. The thing to do is probably to invoke fill_packet() earlier. The bulk of the netpoll changes is to make the code operate solely on the TX queue indicated by by the SKB queue mapping. Setting of the SKB queue mapping is entirely confined inside of net/core/dev.c:dev_pick_tx(). If we end up needing any kind of special semantics (drops, for example) it will be implemented here. Finally, we now have a "real_num_tx_queues" which is where the driver indicates how many TX queues are actually active. With IGB changes from Jeff Kirsher. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17netdev: Kill NETIF_F_MULTI_QUEUE.David S. Miller
There is no need for a feature bit for something that can be tested by simply checking the TX queue count. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-11S2io: Version update for IOMMU overflow checking and enable msi-x link ↵Sreenivasa Honnur
interrupts patches. - Updated version number Signed-off-by: Santosh Rastapur <santosh.rastapur@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-11S2io: Enable msi-x link interrupts.Sreenivasa Honnur
- Enable msi-x link interrupts because the timer based scheduler was getting cancelled causing the link state to be lost with repetitive card up/downs when changing the mtu. - Unmask mac_rmac_link interrupts only for Xframe I and prevent a spurious link interrupt in Xframe II. - Stop the tx queue and indicate link down when card is down Signed-off-by: Santosh Rastapur <santosh.rastapur@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-11S2io: Fix IOMMU overflow checking.Sreenivasa Honnur
- Fix IOMMU overflow checking. As reported by Andi Kleen <ak@linux.intel.com> removed check for zero dma address. Signed-off-by: Santosh Rastapur <santosh.rastapur@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-08net: Delete NETDEVICES_MULTIQUEUE kconfig option.David S. Miller
Multiple TX queue support is a core networking feature. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-28Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl4965-base.c
2008-06-27[netdrvr] Fix IOMMU overflow checking in s2io.cAndi Kleen
s2io has IOMMU overflow checking, but unfortunately it is wrong. It didn't use the standard macros, which meant that it only worked on POWER and SPARC because only those define DMA_ERROR_CODE. Convert it to use the standard macros instead. I also commented two more bugs in the IOMMU handling. It assumes that 0 DMA addresses cannot happen, but that's not true in all IOMMU setups. The information if a buffer has been already mapped needs to be stored elsewhere. Didn't fix those because it needs careful checking of the buffer handling by the maintainers. Cc: ram.vepa@neterion.com Cc: santosh.rastapur@neterion.com Cc: sivakumar.subramani@neterion.com Cc: sreenivasa.honnur@neterion.com Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-13Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smc911x.c
2008-06-04s2io iomem annotationsAl Viro
2008-05-30net/s2io: set_rxd_buffer_pointer returns -ENOMEM, not ENOMEMMarcin Slusarz
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Ramkrishna Vepa <ram.vepa@neterion.com> Cc: Rastapur Santosh <santosh.rastapur@neterion.com> Cc: Sivakumar Subramani <sivakumar.subramani@neterion.com> Cc: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
