path: root/drivers/net/sc92031.c
2011-08-118139*/atp/r8169/sc92031: Move the Realtek driversJeff Kirsher
Move the Realtek drivers into drivers/net/ethernet/realtek/ and make the necessary Kconfig and Makefile changes. CC: Realtek linux nic maintainers <nic_swsd@realtek.com> CC: Francois Romieu <romieu@fr.zoreil.com> CC: Jeff Garzik <jgarzik@pobox.com> CC: Donald Becker <becker@scyld.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-06-06net: remove interrupt.h inclusion from netdevice.hAlexey Dobriyan
* remove interrupt.g inclusion from netdevice.h -- not needed * fixup fallout, add interrupt.h and hardirq.h back where needed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-29ethtool: cosmetic: Use ethtool ethtool_cmd_speed APIDavid Decotigny
This updates the network drivers so that they don't access the ethtool_cmd::speed field directly, but use ethtool_cmd_speed() instead. For most of the drivers, these changes are purely cosmetic and don't fix any problem, such as for those 1GbE/10GbE drivers that indirectly call their own ethtool get_settings()/mii_ethtool_gset(). The changes are meant to enforce code consistency and provide robustness with future larger throughputs, at the expense of a few CPU cycles for each ethtool operation. All drivers compiled with make allyesconfig ion x86_64 have been updated. Tested: make allyesconfig on x86_64 + e1000e/bnx2x work Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-29ethtool: Use full 32 bit speed range in ethtool's set_settingsDavid Decotigny
This makes sure the ethtool's set_settings() callback of network drivers don't ignore the 16 most significant bits when ethtool calls their set_settings(). All drivers compiled with make allyesconfig on x86_64 have been updated. Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-06net: Fix too optimistic NETIF_F_HW_CSUM featuresMichał Mirosław
NETIF_F_HW_CSUM is a superset of NETIF_F_IP_CSUM+NETIF_F_IPV6_CSUM, but some drivers miss the difference. Fix this and also fix UFO dependency on checksumming offload as it makes the same mistake in assumptions. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Acked-by: Jon Mason <jon.mason@exar.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-17ethtool: Provide a default implementation of ethtool_ops::get_drvinfoBen Hutchings
The driver name and bus address for a net_device can normally be found through the driver model now. Instead of requiring drivers to provide this information redundantly through the ethtool_ops::get_drvinfo operation, use the driver model to do so if the driver does not define the operation. Since ETHTOOL_GDRVINFO no longer requires the driver to implement any operations, do not require net_device::ethtool_ops to be set either. Remove implementations of get_drvinfo and ethtool_ops that provide only this information. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-18net: convert multiple drivers to use netdev_for_each_mc_addr, part2Jiri Pirko
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13net: Use netdev_alloc_skb_ip_align()Eric Dumazet
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-20New device ID for sc92031 [1088:2031]Cesar Eduardo Barros
rain_maker@root-forum.org wrote: > Hello cesar, > > In a recent thread in a german linux forum, a user reported his PIC > NIC not being recognized by the kernel. > > Fortunately he provided enough information and I was able to help him > and get the device working with the sc92031 driver. > > The device ID is [1088:2031] (Vendor is called "Microcomputer Systems > (M) Son"), here is the respective thread in "ubuntuusers.de" > > http://forum.ubuntuusers.de/topic/lankarte-unter-xubuntu-wird-nicht-erkannt/ > > (Although you might not speak german, the code provided will show > you, that the device is actually working with your driver). > > It would be nice, if you include this new device ID to the > sc92031-driver. > > Regards, > > Axel Köllhofer (aka Rain_Maker) Cc: rain_maker@root-forum.org Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-21sc92031: add a link to the datasheetCesar Eduardo Barros
2009-01-21sc92031: use device id directly instead of made-up nameCesar Eduardo Barros
Instead of making up a name for the device ids, put them directly in the device id table. Also move the vendor id to pci_ids.h. Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21sc92031: inline SC92031_DESCRIPTIONCesar Eduardo Barros
SC92031_DESCRIPTION is only used in one place. Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21sc92031: remove meaningless version stringCesar Eduardo Barros
The version string makes no sense anymore, since this driver is only maintained within the kernel. Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21sc92031: more useful banner in kernel logCesar Eduardo Barros
The banner currently printed when loading the module is mostly useless. Replace it with a more informative one, printed after probing the device. Output format copied from 8139cp/8139too. Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-11netdev: add missing set_mac_address hookStephen Hemminger
Many drivers lost the ability to set ethernet address accidently during the net_device_ops conversion. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-21sc92031: convert to net_device_opsStephen Hemminger
Convert this driver to net_device_ops. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-30sc92031: remove bogus unlikely()Cesar Eduardo Barros
Commit 5a0a92e67b5009a71e011658da04fb92dad8961f mentions len < ETH_ZLEN is true for ARP packets. This obviously is not unlikely. Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-22[SC92031] Using padto turned driver into an IPv6-only interfaceGerrit Renker
IPv4 would work with this driver only with static arp table entries, the patch reverts a padto introduced in commit 26a17b7bbb36a8552d531bc1ad08472fb5aa3007 sc92031: start transmit return value bugfix The padto does not work because the driver code evaluates `len' later on and there are cases where skb->len is not updated accordingly. This was observed with ARP frames (skb->len = 42 bytes, !skb_cloned(), skb_tailroom = 84 bytes). Then in skb_pad(), the first condition is true, where skb->len is not updated. As a consequence, the driver uses 42 bytes instead of the 60 bytes, and the ARP frame never makes it onto the wire. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-16sc92031: use netdev_alloc_skbStephen Hemminger
Use netdev_alloc_skb since it handles any NUMA node memory localtion issues and sets skb->dev. Since device driver was not setting skb->dev, I bet filter rules based on device would not work. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-16sc92031: start transmit return value bugfixStephen Hemminger
Any negative return value from start_xmit is interpreted as NETDEV_TX_LOCK which is not what this driver wants. It should return 0 (NETDEV_TX_OK) when it consumes a packet. Also, use skb_padto() as the generic way to pad small frames. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-16sc92031: use net_device statsStephen Hemminger
Statistics structure is available for use in net_device structure. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-12sc92031: sysfs link missingStephen Hemminger
Add missing sysfs device association. Compile tested only -ENOHW. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=10380 Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Cc: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: <tom@sharkbay.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-10[netdrvr] Stop using legacy hooks ->self_test_count, ->get_stats_countJeff Garzik
These have been superceded by the new ->get_sset_count() hook. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[ETHTOOL] Provide default behaviors for a few ethtool sub-ioctlsJeff Garzik
For the operations get-tx-csum get-sg get-tso get-ufo the default ethtool_op_xxx behavior is fine for all drivers, so we permit op==NULL to imply the default behavior. This provides a more uniform behavior across all drivers, eliminating ethtool(8) "ioctl not supported" errors on older drivers that had not been updated for the latest sub-ioctls. The ethtool_op_xxx() functions are left exported, in case anyone wishes to call them directly from a driver-private implementation -- a not-uncommon case. Should an ethtool_op_xxx() helper remain unused for a while, except by net/core/ethtool.c, we can un-export it at a later date. [ Resolved conflicts with set/get value ethtool patch... -DaveM ] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[NET]: ethtool_perm_addr only has one implementationMatthew Wilcox
All drivers implement ethtool get_perm_addr the same way -- by calling the generic function. So we can inline the generic function into the caller and avoid going through the drivers. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-09[SC92031]: Fix priv->lock contextHerbert Xu
The spin_lock calls made in dev->open and dev->close must disable BH since open/close are made in process context. Conversely, the call in dev->hard_start_xmit does not need to disable BH since it is already executing with BH disabled. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-14[PATCH] Scheduled removal of SA_xxx interrupt flags fixups 2Thomas Gleixner
The obsolete SA_xxx interrupt flags have been used despite the scheduled removal. Fixup the remaining users in -mm. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-05driver for Silan SC92031 netdevCesar Eduardo Barros
This is a driver for the Silan SC92031/Rsltek 8139D NIC chip. This chip is found on at least one counterfeit Encore ENL832-TX-RENT NIC [1], which came with a mini-CD with the 2.4 driver. A slightly older version of the driver was found at [2]. The main difference between them is that the newer one has a small bugfix in the RX path, a lot of gratuitous renaming of functions, all the printable strings changed to show as a "Rsltek 8139D" [sic], and a PCI ID of 8139 instead of 2031. The driver on this patch is a rewrite of the vendor drivers (based mostly on the older one). Changes from the previous patch sent to netdev: - Use MMIO instead of PIO - Changed TX bounce buffers allocation - Use skb_copy_and_csum_dev - Several small bug fixes - Tested for more than just a few minutes each time [1] See http://www.encore-usa.com/faq.php under ENL832-TX-RENT for more information [2] Look for SL_LINUX.ZIP (which is really a .tar.gz) at http://broadbandforum.in/dataone_Intex_LAN_cardlinux-t4207-s15.html [3] To compile on 2.6.17, simply add back the last argument to the interrupt handler in two places, and copy the boolean declarations from 2.6.19 [akpm@osdl.org: build fixes] Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
