path: root/drivers/net/sfc/boards.c
2009-10-24sfc: Rename Falcon-specific board code and typesBen Hutchings
Siena will require entirely different board code. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-08sfc: Don't specify unexistent IRQJean Delvare
Neither the lm90 driver nor the lm87 driver do support interrupts, so there is no point in specifying one when declaring the devices. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-02sfc: Add support for SFN4112F SFP+ reference designBen Hutchings
2009-03-02sfc: Clean up LED controlBen Hutchings
Reinitialise LEDs after overriding them for identification. Rename set_fault_led method to set_id_led since we always use it for NIC identification and not faults. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-02sfc: Delete unused efx_blinker::led_num fieldBen Hutchings
2008-12-12sfc: Add support for SFN4111TBen Hutchings
Add support code for the SFN4111T 100/1000/10GBASE-T reference design, based in part on the existing code for the SFE4001. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-12sfc: Clean up board identificationBen Hutchings
Remove kluge for development boards with unspecified board type. Remove assumption of contiguous board type code assignments. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-06sfc: Use lm87 and lm90 drivers for board temperature/power monitoringBen Hutchings
Add board monitoring to periodic work whenever link is down. For SFE4001, report when a fault has caused the PHY to turn off. For SFE4002, switch XFP PHY into low-power state in case of a fault. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-03sfc: Use explicit bool for boolean variables, parameters and return valuesBen Hutchings
Replace (cond ? 1 : 0) with cond or !!cond as appropriate, and (cond ? 0 : 1) with !cond. Remove some redundant boolean temporaries. Rename one field that looks like a flag but isn't. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-30sfc: Use kernel I2C system and i2c-algo-bit driverBen Hutchings
Remove our own implementation of I2C bit-banging. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-22sfc: Use mod_timer() to set expiry and add_timer() togetherBen Hutchings
2008-04-29New driver "sfc" for Solarstorm SFC4000 controller.Ben Hutchings
The driver supports the 10Xpress PHY and XFP modules on our reference designs SFE4001 and SFE4002 and the SMC models SMC10GPCIe-XFP and SMC10GPCIe-10BT. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
