path: root/drivers/net/sfc/efx.c
2011-08-11sfc: Move the Solarflare driversJeff Kirsher
Moves the Solarflare drivers into drivers/net/ethernet/sfc/ and make the necessary Kconfig and Makefile changes. CC: Steve Hodgson <shodgson@solarflare.com> CC: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-07-14sfc: Remove 'Communications' after 'Solarflare' in references to hardwareBen Hutchings
Branding can now be abbreviated. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-06-25sfc: Fix mapping of reset reasons and flags to methodsBen Hutchings
There are certain hardware bugs that may occur on Falcon during normal operation, that require a reset to recover from. We try to minimise disruption by keeping the PHY running, following a reset sequence labelled as 'invisible'. Siena does not suffer from these hardware bugs, so we have not implemented an 'invisible' reset sequence. However, if a similar error does occur (due to a hardware fault or software bug) then the code shared with Falcon will wrongly assume that the PHY is not being reset. Since the mapping of reset reasons (internal) and flags (ethtool) to methods must differ significantly between NIC types, move it into per-NIC-type functions (replacing the insufficient reset_world_flags field). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-06-25sfc: Allow resets to be upgraded; use atomic ops for safetyBen Hutchings
Currently an attempt to schedule any reset is ignored if a reset is already pending. This ignores the relative scopes - if the requested reset is greater in scope then the scheduled reset should be upgraded accordingly. There are also some race conditions which could lead to a reset request being lost. Deal with them by using atomic operations on a bitmask. This also makes tests on reset_pending easier to get right. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-05-17sfc: Don't use enums as a bitmask.David S. Miller
This fixes: drivers/net/sfc/mcdi_mac.c: In function ‘efx_mcdi_set_mac’: drivers/net/sfc/mcdi_mac.c:36:2: warning: case value ‘3’ not in enumerated type ‘enum efx_fc_type’ Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16sfc: Use netif_device_{detach,attach}() around reset and self-testBen Hutchings
We need to keep the TX queues stopped throughout a reset, without triggering the TX watchdog and regardless of the link state. The proper way to do this is to use netif_device_{detach,attach}() just as we do around suspend/resume, rather than the current bodge of faking link-down. Since we also need to do this during an offline self-test and we perform a reset during that, add these function calls outside of efx_reset_down() and efx_reset_up(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-05-16sfc: Fix TX queue numbering when separate_tx_channels=1Ben Hutchings
This option appears to have been broken by commit 8313aca38b3937947fffebca6e34bac8e24300c8 ('sfc: Allocate each channel separately, along with its RX and TX queues'). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-04-19Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x_ethtool.c
2011-04-14sfc: make function tables conststephen hemminger
The phy, mac, and board information structures should be const. Since tables contain function pointer this improves security (at least theoretically). Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-12sfc: Do not use efx_process_channel_now() in online self-testBen Hutchings
During self-tests we use efx_process_channel_now() to handle completion and other events synchronously. This disables interrupts and NAPI processing for the channel in question, but it may still be interrupted by another channel. A single socket may receive packets from multiple net devices or even multiple channels of the same net device, so this can result in deadlock on a socket lock. Receiving packets in process context will also result in incorrect classification by the network cgroup classifier. Therefore, we must only use efx_process_channel_now() in the offline loopback tests (which never deliver packets up the stack) and not for the online interrupt and event tests. For the interrupt test, there is no reason to process events. We only care that an interrupt is raised. For the event test, we want to know whether events have been received, and there may be many events ahead of the one we inject. Therefore remove efx_channel::magic_count and instead test whether efx_channel::eventq_read_ptr advances. This is currently an event queue index and might wrap around to exactly the same value, resulting in a false negative. Therefore move the masking to efx_event() and efx_nic_eventq_read_ack() so that it cannot wrap within the time of the test. The event test also tries to diagnose failures by checking whether an event was delivered without causing an interrupt. Add and use a helper function that only does this. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-04-12sfc: Stop the TX queues during loopback self-testsNeil Turton
If the TX queues are running during loopback self tests, host traffic gets looped back which causes the test to fail. Avoid restarting the TX queues after the port reset so that any packets sent by the host get held back until after the tests have completed. [bwh: Also wake all TX queues at the end of self-tests.] Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-04-05sfc: Implement generic features interfaceBen Hutchings
2011-04-05sfc: Enable all TSO features on VLANsBen Hutchings
The TSO code already supports IPv6 on VLAN, so enable it. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-03-23sfc: Siena: Disable write-combining when SR-IOV is enabledSteve Hodgson
If SR-IOV is enabled by firmware, even if it is not enabled in the PCI capability, TX pushes using write-combining may be corrupted. We want to know whether it is enabled before mapping the NIC registers, and even if PCI extended capabilities are not accessible. Therefore, we look for the MSI capability, which is removed if SR-IOV is enabled. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-03-04sfc: Use write-combining to reduce TX latencyBen Hutchings
Based on work by Neil Turton <nturton@solarflare.com> and Kieran Mansley <kmansley@solarflare.com>. The BIU has now been verified to handle 3- and 4-dword writes within a single 128-bit register correctly. This means we can enable write- combining and only insert write barriers between writes to distinct registers. This has been observed to save about 0.5 us when pushing a TX descriptor to an empty TX queue. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-02-28sfc: Update copyright datesBen Hutchings
2011-02-17sfc: Implement hardware acceleration of RFSBen Hutchings
Use the existing filter management functions to insert TCP/IPv4 and UDP/IPv4 4-tuple filters for Receive Flow Steering. For each channel, track how many RFS filters are being added during processing of received packets and scan the corresponding number of table entries for filters that may be reclaimed. Do this in batches to reduce lock overhead. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-02-15sfc: Add TX queues for high-priority trafficBen Hutchings
Implement the ndo_setup_tc() operation with 2 traffic classes. Current Solarstorm controllers do not implement TX queue priority, but they do allow queues to be 'paced' with an enforced delay between packets. Paced and unpaced queues are scheduled in round-robin within two separate hardware bins (paced queues with a large delay may be placed into a third bin temporarily, but we won't use that). If there are queues in both bins, the TX scheduler will alternate between them. If we make high-priority queues unpaced and best-effort queues paced, and high-priority queues are mostly empty, a single high-priority queue can then instantly take 50% of the packet rate regardless of how many of the best-effort queues have descriptors outstanding. We do not actually want an enforced delay between packets on best- effort queues, so we set the pace value to a reserved value that actually results in a delay of 0. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-02-15sfc: Distinguish queue lookup from test for queue existenceBen Hutchings
efx_channel_get_{rx,tx}_queue() currently return NULL if the channel isn't used for traffic in that direction. In most cases this is a bug, but some callers rely on it as an existence test. Add existence test functions efx_channel_has_{rx_queue,tx_queues}() and use them as appropriate. Change efx_channel_get_{rx,tx}_queue() to assert that the requested queue exists. Remove now-redundant initialisation from efx_set_channels(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-02-15sfc: Move TX queue core queue mapping into tx.cBen Hutchings
efx_hard_start_xmit() needs to implement a mapping which is the inverse of tx_queue::core_txq. Move the initialisation of tx_queue::core_txq next to efx_hard_start_xmit() to make the connection more obvious. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-01-13sfc: Restore the effect of the rss_cpus module parameterBen Hutchings
Commit a4900ac ("sfc: Create multiple TX queues") accidentally disabled the rss_cpus module parameter. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-01-13sfc: Make efx_get_tx_queue() an inline functionBen Hutchings
2010-12-10sfc: Remove ancient support for nesting of TX stopBen Hutchings
Long before this driver went into mainline, it had support for multiple TX queues per port, with lockless TX enabled. Since Linux did not know anything of this, filling up any hardware TX queue would stop the core TX queue and multiple hardware TX queues could fill up before the scheduler reacted. Thus it was necessary to keep a count of how many TX queues were stopped and to wake the core TX queue only when all had free space again. The driver also previously (ab)used the per-hardware-queue stopped flag as a counter to deal with various things that can inhibit TX, but it no longer does that. Remove the per-channel tx_stop_count, tx_stop_lock and per-hardware-queue stopped count and just use the networking core queue state directly. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2010-12-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/ath/ath9k/ar9003_eeprom.c net/llc/af_llc.c
2010-12-07sfc: Fix NAPI list corruption during ring reallocationBen Hutchings
Call netif_napi_{add,del}() on the NAPI contexts in the new and old channels, respectively. Since efx_init_napi() cannot fail, make its return type void. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2010-12-07sfc: Fix crash in legacy onterrupt handler during ring reallocationBen Hutchings
If we are using a legacy interrupt, our IRQ may be shared and our interrupt handler may be called even though interrupts are disabled on the NIC. When we change ring sizes, we reallocate the event queue and the interrupt handler may use an invalid pointer when called for another device's interrupt. Maintain a legacy_irq_enabled flag and test that at the top of the interrupt handler. Note that this problem results from the need to work around broken INT_ISR0 reads, and does not affect the legacy interrupt handler for Falcon A1. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2010-12-03sfc: Store MAC address from NVRAM in net_device::perm_addrBen Hutchings
For some reason we failed to make this change when perm_addr was introduced. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03sfc: Move mdio_lock to struct falcon_nic_dataBen Hutchings
We only have direct access to MDIO on Falcon, so move this out of struct efx_nic. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03sfc: Move SPI state to struct falcon_nic_dataBen Hutchings
We only have direct access to SPI on Falcon, so move all this state out of struct efx_nic. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03sfc: Remove unnecessary inclusion of various private header filesBen Hutchings
2010-10-21sfc: make functions staticstephen hemminger
Make local functions and variable static. Do some rearrangement of the string table stuff to put it where it gets used. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-27sfc: Use netif_set_real_num_{rx,tx}_queues()Ben Hutchings
2010-09-21sfc: Clean up and correct comments on efx_monitor()Ben Hutchings
2010-09-21sfc: Add filter table managementBen Hutchings
2010-09-10sfc: Allow changing the DMA ring sizes dynamically via ethtoolBen Hutchings
This requires some reorganisation of channel setup and teardown to ensure that we can always roll-back a failed change. Based on work by Steve Hodgson <shodgson@solarflare.com> Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-10sfc: Make the dmaq size a run-time setting (rather than compile-time)Steve Hodgson
- Allow the ring size to be specified in non power-of-two sizes (for instance to limit the amount of receive buffers). - Automatically size the event queue. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-10sfc: Allocate each channel separately, along with its RX and TX queuesBen Hutchings
This will allow for reallocation of channel structures and rings. Change module parameter separate_tx_channels to be read-only, since we now require its value to be constant. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-10sfc: Refactor channel and queue lookup and iterationBen Hutchings
In preparation for changes to the way channels and queue structures are allocated, revise the macros and functions used to look up and iterator over them. - Replace efx_for_each_tx_queue() with iteration over channels then TX queues - Replace efx_for_each_rx_queue() with iteration over channels then RX queues (with one exception, shortly to be removed) - Introduce efx_get_{channel,rx_queue,tx_queue}() functions to look up channels and queues by index - Introduce efx_channel_get_{rx,tx}_queue() functions to look up a channel's queues Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-10sfc: Fix failure paths in efx_probe_port()Ben Hutchings
2010-09-10sfc: Accumulate RX_NODESC_DROP count in rx_dropped, not rx_over_errorsBen Hutchings
rx_over_errors appears to be intended as a count of packets that overflow a packet buffer in the NIC. Given that we implement a cut-through receive path, this should always be 0. rx_dropped appears to be the correct counter for packets dropped due to lack of host buffers. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-07net: fix 64 bit counters on 32 bit archesEric Dumazet
There is a small possibility that a reader gets incorrect values on 32 bit arches. SNMP applications could catch incorrect counters when a 32bit high part is changed by another stats consumer/provider. One way to solve this is to add a rtnl_link_stats64 param to all ndo_get_stats64() methods, and also add such a parameter to dev_get_stats(). Rule is that we are not allowed to use dev->stats64 as a temporary storage for 64bit stats, but a caller provided area (usually on stack) Old drivers (only providing get_stats() method) need no changes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-30sfc: Add support for RX flow hash controlBen Hutchings
Allow ethtool to query the number of RX rings, the fields used in RX flow hashing and the hash indirection table. Allow ethtool to update the RX flow hash indirection table. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-25sfc: Move siena_nic_data::ipv6_rss_key to efx_nic::rx_hash_keyBen Hutchings
We will use this hash key for Toeplitz IPv4 hashing too. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-24sfc: Record hardware RX hash on each skb where possibleBen Hutchings
2010-06-24sfc: Replace EFX_DRIVER_NAME with KBUILD_MODNAMEBen Hutchings
2010-06-24sfc: Implement message level controlBen Hutchings
Replace EFX_ERR() with netif_err(), EFX_INFO() with netif_info(), EFX_LOG() with netif_dbg() and EFX_TRACE() and EFX_REGDUMP() with netif_vdbg(). Replace EFX_ERR_RL(), EFX_INFO_RL() and EFX_LOG_RL() using explicit calls to net_ratelimit(). Implement the ethtool operations to get and set message level flags, and add a 'debug' module parameter for the initial value. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-12sfc: Implement 64-bit net device statistics on all architecturesBen Hutchings
2010-06-02sfc: Only count bad packets in rx_errorsBen Hutchings
rx_errors is defined as 'bad packets received', but we are currently including various overflow errors as well. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02sfc: Allow shared pages to be recycledSteve Hodgson
Insert a structure at the start of the shared page that tracks the dma mapping refcnt. DMA into the next cache line of the (shared) page (plus EFX_PAGE_IP_ALIGN). When recycling a page, check the page refcnt. If the page is otherwise unused, then resurrect the other receive buffer that previously referenced the page. Be careful not to overflow the receive ring, since we can now resurrect n receive buffers in a row. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02sfc: Remove efx_rx_queue::add_lockSteve Hodgson
Ensure that efx_fast_push_rx_descriptors() must only run from efx_process_channel() [NAPI], or when napi_disable() has been executed. Reimplement the slow fill by sending an event to the channel, so that NAPI runs, and hanging the subsequent fast fill off the event handler. Replace the sfc_refill workqueue and delayed work items with a timer. We do not need to stop this timer in efx_flush_all() because it's safe to send the event always; receiving it will be delayed until NAPI is restarted. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
