Add a new ethtool operation (get_rxfh_indir_size) to get the
indirectional table size. Use this to validate the user buffer size
before calling get_rxfh_indir or set_rxfh_indir. Use get_rxnfc to get
the number of RX rings, and validate the contents of the new
indirection table before calling set_rxfh_indir. Remove this
validation from drivers.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Acked-by: Dimitris Michailidis <dm@chelsio.com>
There are certain hardware bugs that may occur on Falcon during normal
operation, that require a reset to recover from. We try to minimise
disruption by keeping the PHY running, following a reset sequence
labelled as 'invisible'.
Siena does not suffer from these hardware bugs, so we have not
implemented an 'invisible' reset sequence. However, if a similar
error does occur (due to a hardware fault or software bug) then the
code shared with Falcon will wrongly assume that the PHY is not being
reset.
Since the mapping of reset reasons (internal) and flags (ethtool) to
methods must differ significantly between NIC types, move it into
per-NIC-type functions (replacing the insufficient reset_world_flags
field).
This fixes:
drivers/net/sfc/mcdi_mac.c: In function ‘efx_mcdi_set_mac’:
drivers/net/sfc/mcdi_mac.c:36:2: warning: case value ‘3’ not in enumerated type ‘enum efx_fc_type’
ethtool_ops::set_rx_ntuple is supposed to return 0 on success, but it
currently returns the filter ID when it inserts or modifies a filter.
This updates the network drivers so that they don't access the
ethtool_cmd::speed field directly, but use ethtool_cmd_speed()
instead.
For most of the drivers, these changes are purely cosmetic and don't
fix any problem, such as for those 1GbE/10GbE drivers that indirectly
call their own ethtool get_settings()/mii_ethtool_gset(). The changes
are meant to enforce code consistency and provide robustness with
future larger throughputs, at the expense of a few CPU cycles for each
ethtool operation.
All drivers compiled with make allyesconfig ion x86_64 have been
updated.
Tested: make allyesconfig on x86_64 + e1000e/bnx2x work
Signed-off-by: David Decotigny <decot@google.com>
This makes sure the ethtool's set_settings() callback of network
drivers don't ignore the 16 most significant bits when ethtool calls
their set_settings().
All drivers compiled with make allyesconfig on x86_64 have been
updated.
When physical identification of an adapter is done by toggling the
mechanism on and off through software utilizing the set_phys_id operation,
it is done with a fixed duration for both on and off states. Some drivers
may want to set a custom duration for the on/off intervals. This patch
changes the API so the return code from the driver's entry point when it
is called with ETHTOOL_ID_ACTIVE can specify the frequency at which to
cycle the on/off states, and updates the drivers that have already been
converted to use the new set_phys_id and use the synchronous method for
identifying an adapter.
The physical identification frequency set in the updated drivers is based
on how it was done prior to the introduction of set_phys_id.
Compile tested only. Also fixes a compiler warning in sfc.
v2: drivers do not return -EINVAL for ETHOOL_ID_ACTIVE
v3: fold patchset into single patch and cleanup per Ben's feedback
Signed-off-by: Bruce Allan <bruce.w.allan@intel.com>
Cc: Ben Hutchings <bhutchings@solarflare.com>
Cc: Sathya Perla <sathya.perla@emulex.com>
Cc: Subbu Seetharaman <subbu.seetharaman@emulex.com>
Cc: Ajit Khaparde <ajit.khaparde@emulex.com>
Cc: Michael Chan <mchan@broadcom.com>
Cc: Eilon Greenstein <eilong@broadcom.com>
Cc: Divy Le Ray <divy@chelsio.com>
Cc: Don Fry <pcnet32@frontier.com>
Cc: Jon Mason <jdmason@kudzu.us>
Cc: Solarflare linux maintainers <linux-net-drivers@solarflare.com>
Cc: Steve Hodgson <shodgson@solarflare.com>
Cc: Stephen Hemminger <shemminger@linux-foundation.org>
Cc: Matt Carlson <mcarlson@broadcom.com>
Acked-by: Jon Mason <jdmason@kudzu.us>
Acked-by: Ben Hutchings <bhutchings@solarflare.com>
drivers/net/bnx2x/bnx2x.h
We currently make no use of siena_nic_data::fw_{version,build} except
to format the firmware version for ethtool_get_drvinfo(). Since we
only read the version at start of day, this information is incorrect
after an MC firmware update. Remove the cached version information
and read it via MCDI whenever it is requested.
drivers/net/sfc/ethtool.c: In function ‘efx_ethtool_self_test’:
drivers/net/sfc/ethtool.c:613: warning: the frame size of 1200 bytes
is larger than 1024 bytes
efx_channel_get_{rx,tx}_queue() currently return NULL if the channel
isn't used for traffic in that direction. In most cases this is a
bug, but some callers rely on it as an existence test.
Add existence test functions efx_channel_has_{rx_queue,tx_queues}()
and use them as appropriate.
Change efx_channel_get_{rx,tx}_queue() to assert that the requested
queue exists.
Remove now-redundant initialisation from efx_set_channels().
Quoting Ben Hutchings: we presumably won't be defining features that
can only be enabled on 64-bit architectures.
Occurences found by `grep -r` on net/, drivers/net, include/
[ Move features and vlan_features next to each other in
struct netdev, as per Eric Dumazet's suggestion -DaveM ]
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Various drivers are using implementations of ethtool_ops::get_link
that are equivalent to the default ethtool_op_get_link(). Change
them to use that instead.
Move search_depth arrays into per-table state.
Define initialisation function efx_filter_init_rx() which sets
everything apart from the match fields.
Define efx_filter_set_{ipv4_local,ipv4_full,eth_local}() to set the
match fields. This allows some simplification of callers and later
support for additional protocols and more flexible matching using
multiple calls to these functions.
The separation between filter tables is largely an internal detail
and it may be removed in future hardware. To prepare for that:
- Merge table ID with filter index to make an opaque filter ID
- Wrap efx_filter_table_clear() with a function that clears filters
from both RX tables, which is all that the current caller requires
Add message at start of self-test and increase log level of message at
end of self-test, so that any other messages produced during the
test are clearly associated with it.
The ethtool EEPROM interface is really meant for exposing chip
configuration, not BootROM configuration.
Make local functions and variable static. Do some rearrangement
of the string table stuff to put it where it gets used.
This requires some reorganisation of channel setup and teardown to
ensure that we can always roll-back a failed change.
Based on work by Steve Hodgson <shodgson@solarflare.com>
In preparation for changes to the way channels and queue structures
are allocated, revise the macros and functions used to look up and
iterator over them.
- Replace efx_for_each_tx_queue() with iteration over channels then TX
queues
- Replace efx_for_each_rx_queue() with iteration over channels then RX
queues (with one exception, shortly to be removed)
- Introduce efx_get_{channel,rx_queue,tx_queue}() functions to look up
channels and queues by index
- Introduce efx_channel_get_{rx,tx}_queue() functions to look up a
channel's queues
There is a small possibility that a reader gets incorrect values on 32
bit arches. SNMP applications could catch incorrect counters when a
32bit high part is changed by another stats consumer/provider.
One way to solve this is to add a rtnl_link_stats64 param to all
ndo_get_stats64() methods, and also add such a parameter to
dev_get_stats().
Rule is that we are not allowed to use dev->stats64 as a temporary
storage for 64bit stats, but a caller provided area (usually on stack)
Old drivers (only providing get_stats() method) need no changes.
Allow ethtool to query the number of RX rings, the fields used in RX
flow hashing and the hash indirection table.
Allow ethtool to update the RX flow hash indirection table.
ethtool_op_set_flags() does not check for unsupported flags, and has
no way of doing so. This means it is not suitable for use as a
default implementation of ethtool_ops::set_flags.
Add a 'supported' parameter specifying the flags that the driver and
hardware support, validate the requested flags against this, and
change all current callers to pass this parameter.
Change some other trivial implementations of ethtool_ops::set_flags to
call ethtool_op_set_flags().
Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com>
Acked-by: Jeff Garzik <jgarzik@redhat.com>
Replace EFX_ERR() with netif_err(), EFX_INFO() with netif_info(),
EFX_LOG() with netif_dbg() and EFX_TRACE() and EFX_REGDUMP() with
netif_vdbg().
Replace EFX_ERR_RL(), EFX_INFO_RL() and EFX_LOG_RL() using explicit
calls to net_ratelimit().
Implement the ethtool operations to get and set message level flags,
and add a 'debug' module parameter for the initial value.
Create a core TX queue and 2 hardware TX queues for each channel.
If separate_tx_channels is set, create equal numbers of RX and TX
channels instead.
Rewrite the channel and queue iteration macros accordingly.
Eliminate efx_channel::used_flags as redundant.
This makes no immediate difference, but we definitely do not want
to test all TX queues once we allocate a pair of TX queues to each
channel.
In particular, the comment about EVQ_RPTR_REG is based on inconsistent
preliminary hardware documentation, though the following code was
fixed long before release.
SFC9000-family boards do not all use MDIO PHYs, so we need a different
test for PHY aliveness.
Introduce a PHY operation test_alive(). For PHYs attached to Falcon,
use a common implementation based on the existing PHY MDIO test.
For PHYs managed through MCDI, use the appropriate MCDI request.
Change test name in ethtool from 'core mdio' to 'phy alive'.
Rename test_results::mdio to phy_alive and test_results::phy to phy_ext.
This driver has been mostly rewritten since Michael Brown's initial
work, so swap the order of the authors.
This integrates support for the SFC9000 family of 10G Ethernet
controllers and LAN-on-motherboard chips, starting with the SFL9021
'Siena' and SFC9020 'Bethpage'.
Credit for this code is largely due to my colleagues at Solarflare:
Guido Barzini
Steve Hodgson
Kieran Mansley
Matthew Slattery
Neil Turton
nic.h is no longer specific to Falcon.
In new NICs flash is managed by firmware and we will use high-level
operations on partitions rather than direct SPI commands. Add support
for multiple MTD partitions per flash device and remove the direct
link between MTD and SPI devices. Maintain a list of MTD partitions
in struct efx_nic.
New NICs have firmware managing the PHY, and we will discover the PHY
capabilities at run-time. Replace the static data with probe() and
test_name() operations.
Refactor efx_reset_down() and efx_reset_up() accordingly.
Wake-on-LAN is a stub for Falcon, but will be implemented fully for
new NICs.
Refactor PHY, MAC and NIC configuration operations so that the
existing link configuration can be re-pushed with:
efx->phy_op->reconfigure(efx);
efx->mac_op->reconfigure(efx);
and a new configuration with:
efx->nic_op->reconfigure_port(efx);
(plus locking and error-checking).
We have not held the link settings in software (aside from flow
control), and have relied on asking the hardware what they are. This
is a problem because in some cases the hardware may no longer be in a
state to tell us. In particular, if an entire multi-port board is
reset through one port, the driver bindings to other ports have no
chance to save settings before recovering.
We only actually need to keep track of the autonegotiation settings,
so add an ethtool advertising mask to struct efx_nic, initialise it
in PHY init and update it as necessary.
Remove now-unneeded uses of efx_phy_op::{get,set}_settings() and
struct ethtool_cmd.
Much of this was done by Steve Hodgson <shodgson@solarflare.com>.
