path: root/drivers/net/sfc/ethtool.c
2011-08-11sfc: Move the Solarflare driversJeff Kirsher
Moves the Solarflare drivers into drivers/net/ethernet/sfc/ and make the necessary Kconfig and Makefile changes. CC: Steve Hodgson <shodgson@solarflare.com> CC: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-06-25sfc: Fix mapping of reset reasons and flags to methodsBen Hutchings
There are certain hardware bugs that may occur on Falcon during normal operation, that require a reset to recover from. We try to minimise disruption by keeping the PHY running, following a reset sequence labelled as 'invisible'. Siena does not suffer from these hardware bugs, so we have not implemented an 'invisible' reset sequence. However, if a similar error does occur (due to a hardware fault or software bug) then the code shared with Falcon will wrongly assume that the PHY is not being reset. Since the mapping of reset reasons (internal) and flags (ethtool) to methods must differ significantly between NIC types, move it into per-NIC-type functions (replacing the insufficient reset_world_flags field). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-05-17sfc: Don't use enums as a bitmask.David S. Miller
This fixes: drivers/net/sfc/mcdi_mac.c: In function ‘efx_mcdi_set_mac’: drivers/net/sfc/mcdi_mac.c:36:2: warning: case value ‘3’ not in enumerated type ‘enum efx_fc_type’ Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-14sfc: Fix return value from efx_ethtool_set_rx_ntuple()Ben Hutchings
ethtool_ops::set_rx_ntuple is supposed to return 0 on success, but it currently returns the filter ID when it inserts or modifies a filter. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-04-29ethtool: cosmetic: Use ethtool ethtool_cmd_speed APIDavid Decotigny
This updates the network drivers so that they don't access the ethtool_cmd::speed field directly, but use ethtool_cmd_speed() instead. For most of the drivers, these changes are purely cosmetic and don't fix any problem, such as for those 1GbE/10GbE drivers that indirectly call their own ethtool get_settings()/mii_ethtool_gset(). The changes are meant to enforce code consistency and provide robustness with future larger throughputs, at the expense of a few CPU cycles for each ethtool operation. All drivers compiled with make allyesconfig ion x86_64 have been updated. Tested: make allyesconfig on x86_64 + e1000e/bnx2x work Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-29ethtool: Use full 32 bit speed range in ethtool's set_settingsDavid Decotigny
This makes sure the ethtool's set_settings() callback of network drivers don't ignore the 16 most significant bits when ethtool calls their set_settings(). All drivers compiled with make allyesconfig on x86_64 have been updated. Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-14ethtool: allow custom interval for physical identificationAllan, Bruce W
When physical identification of an adapter is done by toggling the mechanism on and off through software utilizing the set_phys_id operation, it is done with a fixed duration for both on and off states. Some drivers may want to set a custom duration for the on/off intervals. This patch changes the API so the return code from the driver's entry point when it is called with ETHTOOL_ID_ACTIVE can specify the frequency at which to cycle the on/off states, and updates the drivers that have already been converted to use the new set_phys_id and use the synchronous method for identifying an adapter. The physical identification frequency set in the updated drivers is based on how it was done prior to the introduction of set_phys_id. Compile tested only. Also fixes a compiler warning in sfc. v2: drivers do not return -EINVAL for ETHOOL_ID_ACTIVE v3: fold patchset into single patch and cleanup per Ben's feedback Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Cc: Ben Hutchings <bhutchings@solarflare.com> Cc: Sathya Perla <sathya.perla@emulex.com> Cc: Subbu Seetharaman <subbu.seetharaman@emulex.com> Cc: Ajit Khaparde <ajit.khaparde@emulex.com> Cc: Michael Chan <mchan@broadcom.com> Cc: Eilon Greenstein <eilong@broadcom.com> Cc: Divy Le Ray <divy@chelsio.com> Cc: Don Fry <pcnet32@frontier.com> Cc: Jon Mason <jdmason@kudzu.us> Cc: Solarflare linux maintainers <linux-net-drivers@solarflare.com> Cc: Steve Hodgson <shodgson@solarflare.com> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Matt Carlson <mcarlson@broadcom.com> Acked-by: Jon Mason <jdmason@kudzu.us> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-05sfc: Implement ethtool_ops::set_phys_id instead of ethtool_ops::phys_idBen Hutchings
2011-04-05sfc: Implement generic features interfaceBen Hutchings
2011-03-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x.h
2011-02-28sfc: Expose TX push and TSO counters through ethtool statisticsBen Hutchings
2011-02-28sfc: Update copyright datesBen Hutchings
2011-02-28sfc: Read MC firmware version when requested through ethtoolBen Hutchings
We currently make no use of siena_nic_data::fw_{version,build} except to format the firmware version for ethtool_get_drvinfo(). Since we only read the version at start of day, this information is incorrect after an MC firmware update. Remove the cached version information and read it via MCDI whenever it is requested. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-02-22sfc: lower stack usage in efx_ethtool_self_testEric Dumazet
drivers/net/sfc/ethtool.c: In function ‘efx_ethtool_self_test’: drivers/net/sfc/ethtool.c:613: warning: the frame size of 1200 bytes is larger than 1024 bytes Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-15sfc: Distinguish queue lookup from test for queue existenceBen Hutchings
efx_channel_get_{rx,tx}_queue() currently return NULL if the channel isn't used for traffic in that direction. In most cases this is a bug, but some callers rely on it as an existence test. Add existence test functions efx_channel_has_{rx_queue,tx_queues}() and use them as appropriate. Change efx_channel_get_{rx,tx}_queue() to assert that the requested queue exists. Remove now-redundant initialisation from efx_set_channels(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-01-24net: change netdev->features to u32Michał Mirosław
Quoting Ben Hutchings: we presumably won't be defining features that can only be enabled on 64-bit architectures. Occurences found by `grep -r` on net/, drivers/net, include/ [ Move features and vlan_features next to each other in struct netdev, as per Eric Dumazet's suggestion -DaveM ] Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-10netdev: Use default implementation of ethtool_ops::get_link where possibleBen Hutchings
Various drivers are using implementations of ethtool_ops::get_link that are equivalent to the default ethtool_op_get_link(). Change them to use that instead. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-07sfc: Generalise filter spec initialisationBen Hutchings
Move search_depth arrays into per-table state. Define initialisation function efx_filter_init_rx() which sets everything apart from the match fields. Define efx_filter_set_{ipv4_local,ipv4_full,eth_local}() to set the match fields. This allows some simplification of callers and later support for additional protocols and more flexible matching using multiple calls to these functions. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2010-12-07sfc: Remove filter table IDs from filter functionsBen Hutchings
The separation between filter tables is largely an internal detail and it may be removed in future hardware. To prepare for that: - Merge table ID with filter index to make an opaque filter ID - Wrap efx_filter_table_clear() with a function that clears filters from both RX tables, which is all that the current caller requires Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2010-12-07sfc: Log start and end of ethtool self-test at INFO levelBen Hutchings
Add message at start of self-test and increase log level of message at end of self-test, so that any other messages produced during the test are clearly associated with it. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2010-12-03sfc: Remove unnecessary inclusion of various private header filesBen Hutchings
2010-12-03sfc: Expose Falcon BootROM config through MTD, not ethtoolBen Hutchings
The ethtool EEPROM interface is really meant for exposing chip configuration, not BootROM configuration. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21sfc: make functions staticstephen hemminger
Make local functions and variable static. Do some rearrangement of the string table stuff to put it where it gets used. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-21sfc: Implement the ethtool RX n-tuple control functionsBen Hutchings
2010-09-10sfc: Allow changing the DMA ring sizes dynamically via ethtoolBen Hutchings
This requires some reorganisation of channel setup and teardown to ensure that we can always roll-back a failed change. Based on work by Steve Hodgson <shodgson@solarflare.com> Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-10sfc: Refactor channel and queue lookup and iterationBen Hutchings
In preparation for changes to the way channels and queue structures are allocated, revise the macros and functions used to look up and iterator over them. - Replace efx_for_each_tx_queue() with iteration over channels then TX queues - Replace efx_for_each_rx_queue() with iteration over channels then RX queues (with one exception, shortly to be removed) - Introduce efx_get_{channel,rx_queue,tx_queue}() functions to look up channels and queues by index - Introduce efx_channel_get_{rx,tx}_queue() functions to look up a channel's queues Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-07net: fix 64 bit counters on 32 bit archesEric Dumazet
There is a small possibility that a reader gets incorrect values on 32 bit arches. SNMP applications could catch incorrect counters when a 32bit high part is changed by another stats consumer/provider. One way to solve this is to add a rtnl_link_stats64 param to all ndo_get_stats64() methods, and also add such a parameter to dev_get_stats(). Rule is that we are not allowed to use dev->stats64 as a temporary storage for 64bit stats, but a caller provided area (usually on stack) Old drivers (only providing get_stats() method) need no changes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-30sfc: Add support for RX flow hash controlBen Hutchings
Allow ethtool to query the number of RX rings, the fields used in RX flow hashing and the hash indirection table. Allow ethtool to update the RX flow hash indirection table. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-30ethtool: Change ethtool_op_set_flags to validate flagsBen Hutchings
ethtool_op_set_flags() does not check for unsupported flags, and has no way of doing so. This means it is not suitable for use as a default implementation of ethtool_ops::set_flags. Add a 'supported' parameter specifying the flags that the driver and hardware support, validate the requested flags against this, and change all current callers to pass this parameter. Change some other trivial implementations of ethtool_ops::set_flags to call ethtool_op_set_flags(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-24sfc: Record hardware RX hash on each skb where possibleBen Hutchings
2010-06-24sfc: Disable setting feature flags that are not implementedBen Hutchings
2010-06-24sfc: Replace EFX_DRIVER_NAME with KBUILD_MODNAMEBen Hutchings
2010-06-24sfc: Implement message level controlBen Hutchings
Replace EFX_ERR() with netif_err(), EFX_INFO() with netif_info(), EFX_LOG() with netif_dbg() and EFX_TRACE() and EFX_REGDUMP() with netif_vdbg(). Replace EFX_ERR_RL(), EFX_INFO_RL() and EFX_LOG_RL() using explicit calls to net_ratelimit(). Implement the ethtool operations to get and set message level flags, and add a 'debug' module parameter for the initial value. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-24sfc: Implement ethtool register dump operationBen Hutchings
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-28sfc: Create multiple TX queuesBen Hutchings
Create a core TX queue and 2 hardware TX queues for each channel. If separate_tx_channels is set, create equal numbers of RX and TX channels instead. Rewrite the channel and queue iteration macros accordingly. Eliminate efx_channel::used_flags as redundant. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-28sfc: Test only the first pair of TX queuesBen Hutchings
This makes no immediate difference, but we definitely do not want to test all TX queues once we allocate a pair of TX queues to each channel. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-03sfc: Fix some incorrect or redundant commentsBen Hutchings
In particular, the comment about EVQ_RPTR_REG is based on inconsistent preliminary hardware documentation, though the following code was fixed long before release. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-03sfc: Replace PHY MDIO test with an 'alive' testBen Hutchings
SFC9000-family boards do not all use MDIO PHYs, so we need a different test for PHY aliveness. Introduce a PHY operation test_alive(). For PHYs attached to Falcon, use a common implementation based on the existing PHY MDIO test. For PHYs managed through MCDI, use the appropriate MCDI request. Change test name in ethtool from 'core mdio' to 'phy alive'. Rename test_results::mdio to phy_alive and test_results::phy to phy_ext. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Update version, copyright dates, authorsBen Hutchings
This driver has been mostly rewritten since Michael Brown's initial work, so swap the order of the authors. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Implement TSO for TCP/IPv6Ben Hutchings
2009-11-29sfc: Add support for SFC9000 family (2)Ben Hutchings
This integrates support for the SFC9000 family of 10G Ethernet controllers and LAN-on-motherboard chips, starting with the SFL9021 'Siena' and SFC9020 'Bethpage'. Credit for this code is largely due to my colleagues at Solarflare: Guido Barzini Steve Hodgson Kieran Mansley Matthew Slattery Neil Turton Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Rename falcon.h to nic.hBen Hutchings
nic.h is no longer specific to Falcon. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Allow for additional checksum offload featuresBen Hutchings
2009-11-29sfc: Extend MTD driver for use with new NICsBen Hutchings
In new NICs flash is managed by firmware and we will use high-level operations on partitions rather than direct SPI commands. Add support for multiple MTD partitions per flash device and remove the direct link between MTD and SPI devices. Maintain a list of MTD partitions in struct efx_nic. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Remove static PHY data and enumerationsBen Hutchings
New NICs have firmware managing the PHY, and we will discover the PHY capabilities at run-time. Replace the static data with probe() and test_name() operations. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Separate shared NIC code from Falcon-specific and rename accordinglyBen Hutchings
2009-11-29sfc: Add efx_nic_type operation for identity LED controlBen Hutchings
2009-11-29sfc: Implement ethtool reset operationBen Hutchings
Refactor efx_reset_down() and efx_reset_up() accordingly. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Add power-management and wake-on-LAN supportBen Hutchings
Wake-on-LAN is a stub for Falcon, but will be implemented fully for new NICs. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Refactor link configurationBen Hutchings
Refactor PHY, MAC and NIC configuration operations so that the existing link configuration can be re-pushed with: efx->phy_op->reconfigure(efx); efx->mac_op->reconfigure(efx); and a new configuration with: efx->nic_op->reconfigure_port(efx); (plus locking and error-checking). We have not held the link settings in software (aside from flow control), and have relied on asking the hardware what they are. This is a problem because in some cases the hardware may no longer be in a state to tell us. In particular, if an entire multi-port board is reset through one port, the driver bindings to other ports have no chance to save settings before recovering. We only actually need to keep track of the autonegotiation settings, so add an ethtool advertising mask to struct efx_nic, initialise it in PHY init and update it as necessary. Remove now-unneeded uses of efx_phy_op::{get,set}_settings() and struct ethtool_cmd. Much of this was done by Steve Hodgson <shodgson@solarflare.com>. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
