path: root/drivers/net/sfc/net_driver.h
2011-08-11sfc: Move the Solarflare driversJeff Kirsher
Moves the Solarflare drivers into drivers/net/ethernet/sfc/ and make the necessary Kconfig and Makefile changes. CC: Steve Hodgson <shodgson@solarflare.com> CC: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-07-14Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/bwh/sfc-next
2011-06-25sfc: Fix mapping of reset reasons and flags to methodsBen Hutchings
There are certain hardware bugs that may occur on Falcon during normal operation, that require a reset to recover from. We try to minimise disruption by keeping the PHY running, following a reset sequence labelled as 'invisible'. Siena does not suffer from these hardware bugs, so we have not implemented an 'invisible' reset sequence. However, if a similar error does occur (due to a hardware fault or software bug) then the code shared with Falcon will wrongly assume that the PHY is not being reset. Since the mapping of reset reasons (internal) and flags (ethtool) to methods must differ significantly between NIC types, move it into per-NIC-type functions (replacing the insufficient reset_world_flags field). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-06-25sfc: Allow resets to be upgraded; use atomic ops for safetyBen Hutchings
Currently an attempt to schedule any reset is ignored if a reset is already pending. This ignores the relative scopes - if the requested reset is greater in scope then the scheduled reset should be upgraded accordingly. There are also some race conditions which could lead to a reset request being lost. Deal with them by using atomic operations on a bitmask. This also makes tests on reset_pending easier to get right. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-06-24net: Remove unneeded version.h includes from drivers/net/Jesper Juhl
It was pointed out by 'make versioncheck' that some includes of linux/version.h are not needed in drivers/net/. This patch removes them. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-17sfc: Don't use enums as a bitmask.David S. Miller
This fixes: drivers/net/sfc/mcdi_mac.c: In function ‘efx_mcdi_set_mac’: drivers/net/sfc/mcdi_mac.c:36:2: warning: case value ‘3’ not in enumerated type ‘enum efx_fc_type’ Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16sfc: Use netif_device_{detach,attach}() around reset and self-testBen Hutchings
We need to keep the TX queues stopped throughout a reset, without triggering the TX watchdog and regardless of the link state. The proper way to do this is to use netif_device_{detach,attach}() just as we do around suspend/resume, rather than the current bodge of faking link-down. Since we also need to do this during an offline self-test and we perform a reset during that, add these function calls outside of efx_reset_down() and efx_reset_up(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-04-19Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x_ethtool.c
2011-04-14sfc: make function tables conststephen hemminger
The phy, mac, and board information structures should be const. Since tables contain function pointer this improves security (at least theoretically). Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-12sfc: Do not use efx_process_channel_now() in online self-testBen Hutchings
During self-tests we use efx_process_channel_now() to handle completion and other events synchronously. This disables interrupts and NAPI processing for the channel in question, but it may still be interrupted by another channel. A single socket may receive packets from multiple net devices or even multiple channels of the same net device, so this can result in deadlock on a socket lock. Receiving packets in process context will also result in incorrect classification by the network cgroup classifier. Therefore, we must only use efx_process_channel_now() in the offline loopback tests (which never deliver packets up the stack) and not for the online interrupt and event tests. For the interrupt test, there is no reason to process events. We only care that an interrupt is raised. For the event test, we want to know whether events have been received, and there may be many events ahead of the one we inject. Therefore remove efx_channel::magic_count and instead test whether efx_channel::eventq_read_ptr advances. This is currently an event queue index and might wrap around to exactly the same value, resulting in a false negative. Therefore move the masking to efx_event() and efx_nic_eventq_read_ack() so that it cannot wrap within the time of the test. The event test also tries to diagnose failures by checking whether an event was delivered without causing an interrupt. Add and use a helper function that only does this. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smsc911x.c
2011-04-05sfc: Implement generic features interfaceBen Hutchings
2011-02-28sfc: Bump version to 3.1Ben Hutchings
All features originally planned for version 3.1 (and some that weren't) have been implemented. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-02-28sfc: Update copyright datesBen Hutchings
2011-02-28sfc: Reduce size of efx_rx_buffer further by removing data memberSteve Hodgson
Instead calculate the KVA of receive data. It's not like it's a hard sum. [bwh: Fixed to work with GRO.] Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-02-28sfc: Reduce size of efx_rx_buffer by unionising skb and pageSteve Hodgson
[bwh: Forward-ported to net-next-2.6.] Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-02-17sfc: Implement hardware acceleration of RFSBen Hutchings
Use the existing filter management functions to insert TCP/IPv4 and UDP/IPv4 4-tuple filters for Receive Flow Steering. For each channel, track how many RFS filters are being added during processing of received packets and scan the corresponding number of table entries for filters that may be reclaimed. Do this in batches to reduce lock overhead. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-02-15sfc: Add TX queues for high-priority trafficBen Hutchings
Implement the ndo_setup_tc() operation with 2 traffic classes. Current Solarstorm controllers do not implement TX queue priority, but they do allow queues to be 'paced' with an enforced delay between packets. Paced and unpaced queues are scheduled in round-robin within two separate hardware bins (paced queues with a large delay may be placed into a third bin temporarily, but we won't use that). If there are queues in both bins, the TX scheduler will alternate between them. If we make high-priority queues unpaced and best-effort queues paced, and high-priority queues are mostly empty, a single high-priority queue can then instantly take 50% of the packet rate regardless of how many of the best-effort queues have descriptors outstanding. We do not actually want an enforced delay between packets on best- effort queues, so we set the pace value to a reserved value that actually results in a delay of 0. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-02-15sfc: Distinguish queue lookup from test for queue existenceBen Hutchings
efx_channel_get_{rx,tx}_queue() currently return NULL if the channel isn't used for traffic in that direction. In most cases this is a bug, but some callers rely on it as an existence test. Add existence test functions efx_channel_has_{rx_queue,tx_queues}() and use them as appropriate. Change efx_channel_get_{rx,tx}_queue() to assert that the requested queue exists. Remove now-redundant initialisation from efx_set_channels(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-01-24net: change netdev->features to u32Michał Mirosław
Quoting Ben Hutchings: we presumably won't be defining features that can only be enabled on 64-bit architectures. Occurences found by `grep -r` on net/, drivers/net, include/ [ Move features and vlan_features next to each other in struct netdev, as per Eric Dumazet's suggestion -DaveM ] Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-13sfc: Make efx_get_tx_queue() an inline functionBen Hutchings
2010-12-10sfc: Remove ancient support for nesting of TX stopBen Hutchings
Long before this driver went into mainline, it had support for multiple TX queues per port, with lockless TX enabled. Since Linux did not know anything of this, filling up any hardware TX queue would stop the core TX queue and multiple hardware TX queues could fill up before the scheduler reacted. Thus it was necessary to keep a count of how many TX queues were stopped and to wake the core TX queue only when all had free space again. The driver also previously (ab)used the per-hardware-queue stopped flag as a counter to deal with various things that can inhibit TX, but it no longer does that. Remove the per-channel tx_stop_count, tx_stop_lock and per-hardware-queue stopped count and just use the networking core queue state directly. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2010-12-10sfc: Remove unused field and comment on a previously removed fieldBen Hutchings
2010-12-10Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/bwh/sfc-next-2.6
2010-12-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/ath/ath9k/ar9003_eeprom.c net/llc/af_llc.c
2010-12-07sfc: Fix crash in legacy onterrupt handler during ring reallocationBen Hutchings
If we are using a legacy interrupt, our IRQ may be shared and our interrupt handler may be called even though interrupts are disabled on the NIC. When we change ring sizes, we reallocate the event queue and the interrupt handler may use an invalid pointer when called for another device's interrupt. Maintain a legacy_irq_enabled flag and test that at the top of the interrupt handler. Note that this problem results from the need to work around broken INT_ISR0 reads, and does not affect the legacy interrupt handler for Falcon A1. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2010-12-06sfc: Use TX push whenever adding descriptors to an empty queueBen Hutchings
Whenever we add DMA descriptors to a TX ring and update the ring pointer, the TX DMA engine must first read the new DMA descriptors and then start reading packet data. However, all released Solarflare 10G controllers have a 'TX push' feature that allows us to reduce latency by writing the first new DMA descriptor along with the pointer update. This is only useful when the queue is empty. The hardware should ignore the pushed descriptor if the queue is not empty, but this check is buggy, so we must do it in software. In order to tell whether a TX queue is empty, we need to compare the previous transmission count (write_count) and completion count (read_count). However, if we do that every time we update the ring pointer then read_count may ping-pong between the caches of two CPUs running the transmission and completion paths for the queue. Therefore, we split the check for an empty queue between the completion path and the transmission path: - Add an empty_read_count field representing a point at which the completion path saw the TX queue as empty. - Add an old_write_count field for use on the completion path. - On the completion path, whenever read_count reaches or passes old_write_count the TX queue may be empty. We then read write_count, set empty_read_count if read_count == write_count, and update old_write_count. - On the transmission path, we read empty_read_count. If it's set, we compare it with the value of write_count before the current set of descriptors was added. If they match, the queue really is empty and we can use TX push. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2010-12-06sfc: Reorder struct efx_nic to separate fields by volatilityBen Hutchings
Place the regularly updated fields (locks, MAC stats, etc.) on a separate cache-line from fields which are mostly constant. This should reduce cache misses for access to the latter on the data path. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2010-12-03sfc: Store MAC address from NVRAM in net_device::perm_addrBen Hutchings
For some reason we failed to make this change when perm_addr was introduced. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03sfc: Update kernel-doc to match earlier move of Toeplitz hash keyBen Hutchings
2010-12-03sfc: Move xmac_poll_required into struct falcon_nic_dataBen Hutchings
2010-12-03sfc: Move Falcon global event handling to falcon.cBen Hutchings
2010-12-03sfc: Move mdio_lock to struct falcon_nic_dataBen Hutchings
We only have direct access to MDIO on Falcon, so move this out of struct efx_nic. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03sfc: Move SPI state to struct falcon_nic_dataBen Hutchings
We only have direct access to SPI on Falcon, so move all this state out of struct efx_nic. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21sfc: make functions staticstephen hemminger
Make local functions and variable static. Do some rearrangement of the string table stuff to put it where it gets used. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-26drivers/net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-22sfc: Remove support for SFN4111T, SFT9001 and Falcon GMACBen Hutchings
SFN4111T never reached production and is not being used for internal or customer testing. Since we have no production Falcon boards using the SFT9001 or the GMAC, remove support for them as well. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-21sfc: Fix build due to lack of vmalloc.h include.David S. Miller
drivers/net/sfc/filter.c: In function ‘efx_probe_filters’: drivers/net/sfc/filter.c:422: error: implicit declaration of function ‘vmalloc’ drivers/net/sfc/filter.c:422: warning: assignment makes pointer from integer without a cast drivers/net/sfc/filter.c: In function ‘efx_remove_filters’: drivers/net/sfc/filter.c:442: error: implicit declaration of function ‘vfree’ Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-21sfc: Add filter table managementBen Hutchings
2010-09-13sfc: Fix order of channel_name array dimensionsBen Hutchings
2010-09-10sfc: Allow changing the DMA ring sizes dynamically via ethtoolBen Hutchings
This requires some reorganisation of channel setup and teardown to ensure that we can always roll-back a failed change. Based on work by Steve Hodgson <shodgson@solarflare.com> Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-10sfc: Make the dmaq size a run-time setting (rather than compile-time)Steve Hodgson
- Allow the ring size to be specified in non power-of-two sizes (for instance to limit the amount of receive buffers). - Automatically size the event queue. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-10sfc: Allocate each channel separately, along with its RX and TX queuesBen Hutchings
This will allow for reallocation of channel structures and rings. Change module parameter separate_tx_channels to be read-only, since we now require its value to be constant. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-10sfc: Refactor channel and queue lookup and iterationBen Hutchings
In preparation for changes to the way channels and queue structures are allocated, revise the macros and functions used to look up and iterator over them. - Replace efx_for_each_tx_queue() with iteration over channels then TX queues - Replace efx_for_each_rx_queue() with iteration over channels then RX queues (with one exception, shortly to be removed) - Introduce efx_get_{channel,rx_queue,tx_queue}() functions to look up channels and queues by index - Introduce efx_channel_get_{rx,tx}_queue() functions to look up a channel's queues Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-10sfc: Abstract channel and index lookup for RX queuesBen Hutchings
2010-07-08sfc: Remove unused field left from mis-mergeBen Hutchings
Commit eedc765ca4b19a41cf0b921a492ac08d640060d1 merged changes from net-2.6 that added and then removed efx_nic::port_num, which was also added in net-next-2.6. The end result should be that it is removed, since it is now unused. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-30sfc: Add support for RX flow hash controlBen Hutchings
Allow ethtool to query the number of RX rings, the fields used in RX flow hashing and the hash indirection table. Allow ethtool to update the RX flow hash indirection table. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-25sfc: Move siena_nic_data::ipv6_rss_key to efx_nic::rx_hash_keyBen Hutchings
We will use this hash key for Toeplitz IPv4 hashing too. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-24sfc: Record hardware RX hash on each skb where possibleBen Hutchings
