path: root/drivers/net/sfc/rx.c
2011-08-11sfc: Move the Solarflare driversJeff Kirsher
Moves the Solarflare drivers into drivers/net/ethernet/sfc/ and make the necessary Kconfig and Makefile changes. CC: Steve Hodgson <shodgson@solarflare.com> CC: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-05-22Add appropriate <linux/prefetch.h> include for prefetch usersPaul Gortmaker
After discovering that wide use of prefetch on modern CPUs could be a net loss instead of a win, net drivers which were relying on the implicit inclusion of prefetch.h via the list headers showed up in the resulting cleanup fallout. Give them an explicit include via the following $0.02 script. ========================================= #!/bin/bash MANUAL="" for i in `git grep -l 'prefetch(.*)' .` ; do grep -q '<linux/prefetch.h>' $i if [ $? = 0 ] ; then continue fi ( echo '?^#include <linux/?a' echo '#include <linux/prefetch.h>' echo . echo w echo q ) | ed -s $i > /dev/null 2>&1 if [ $? != 0 ]; then echo $i needs manual fixup MANUAL="$i $MANUAL" fi done echo ------------------- 8\<---------------------- echo vi $MANUAL ========================================= Signed-off-by: Paul <paul.gortmaker@windriver.com> [ Fixed up some incorrect #include placements, and added some non-network drivers and the fib_trie.c case - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-05sfc: Implement generic features interfaceBen Hutchings
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-04-01sfc: Move test of rx_checksum_enabled from nic.c to rx.cBen Hutchings
This is preparation for using the generic netdev features interface, and should have no effect in itself. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-02-28sfc: Update copyright datesBen Hutchings
2011-02-28sfc: Reduce size of efx_rx_buffer further by removing data memberSteve Hodgson
Instead calculate the KVA of receive data. It's not like it's a hard sum. [bwh: Fixed to work with GRO.] Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-02-28sfc: Reduce size of efx_rx_buffer by unionising skb and pageSteve Hodgson
[bwh: Forward-ported to net-next-2.6.] Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2010-12-10sfc: convert references to LRO to GROstephen hemminger
This driver now uses Generic Receive Offload, not the older LRO. Change references to LRO in names and comments. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-10sfc: Make the dmaq size a run-time setting (rather than compile-time)Steve Hodgson
- Allow the ring size to be specified in non power-of-two sizes (for instance to limit the amount of receive buffers). - Automatically size the event queue. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-10sfc: Refactor channel and queue lookup and iterationBen Hutchings
In preparation for changes to the way channels and queue structures are allocated, revise the macros and functions used to look up and iterator over them. - Replace efx_for_each_tx_queue() with iteration over channels then TX queues - Replace efx_for_each_rx_queue() with iteration over channels then RX queues (with one exception, shortly to be removed) - Introduce efx_get_{channel,rx_queue,tx_queue}() functions to look up channels and queues by index - Introduce efx_channel_get_{rx,tx}_queue() functions to look up a channel's queues Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-10sfc: Abstract channel and index lookup for RX queuesBen Hutchings
2010-09-02drivers/net: avoid some skb->ip_summed initializationsEric Dumazet
fresh skbs have ip_summed set to CHECKSUM_NONE (0) We can avoid setting again skb->ip_summed to CHECKSUM_NONE in drivers. Introduce skb_checksum_none_assert() helper so that we keep this assertion documented in driver sources. Change most occurrences of : skb->ip_summed = CHECKSUM_NONE; by : skb_checksum_none_assert(skb); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-25sfc: Fix reading of inserted hashBen Hutchings
The hash appears immediately before the packet data, not at the beginning of the buffer. This means we can easily use negative offsets from the start of packet data, so adjust the data and length at the top of __efx_rx_packet() instead of wherever we consume the hash. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-24sfc: Record hardware RX hash on each skb where possibleBen Hutchings
2010-06-24sfc: Implement message level controlBen Hutchings
Replace EFX_ERR() with netif_err(), EFX_INFO() with netif_info(), EFX_LOG() with netif_dbg() and EFX_TRACE() and EFX_REGDUMP() with netif_vdbg(). Replace EFX_ERR_RL(), EFX_INFO_RL() and EFX_LOG_RL() using explicit calls to net_ratelimit(). Implement the ethtool operations to get and set message level flags, and add a 'debug' module parameter for the initial value. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02sfc: Allow shared pages to be recycledSteve Hodgson
Insert a structure at the start of the shared page that tracks the dma mapping refcnt. DMA into the next cache line of the (shared) page (plus EFX_PAGE_IP_ALIGN). When recycling a page, check the page refcnt. If the page is otherwise unused, then resurrect the other receive buffer that previously referenced the page. Be careful not to overflow the receive ring, since we can now resurrect n receive buffers in a row. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02sfc: Recycle discarded rx buffers back onto the queueSteve Hodgson
The cut-through design of the receive path means that packets that fail to match the appropriate MAC filter are not discarded at the MAC but are flagged in the completion event as 'to be discarded'. On networks with heavy multicast traffic, this can account for a significant proportion of received packets, so it is worthwhile to recycle the buffer immediately in this case rather than freeing it and then reallocating it shortly after. The only complication here is dealing with a page shared between two receive buffers. In that case, we need to be careful to free the dma mapping when both buffers have been free'd by the kernel. This means that we can only recycle such a page if both receive buffers are discarded. Unfortunately, in an environment with 1500mtu, rx_alloc_method=PAGE, and a mixture of discarded and not-discarded frames hitting the same receive queue, buffer recycling won't always be possible. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02sfc: Support only two rx buffers per pageSteve Hodgson
- Pull the loop handling into efx_init_rx_buffers_(skb|page) - Remove rx_queue->buf_page, and associated clean up code - Remove unmap_addr, since unmap_addr is trivially calculable This will allow us to recycle discarded buffers directly from efx_rx_packet(), since will never be in the middle of splitting a page. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02sfc: Remove efx_rx_queue::add_lockSteve Hodgson
Ensure that efx_fast_push_rx_descriptors() must only run from efx_process_channel() [NAPI], or when napi_disable() has been executed. Reimplement the slow fill by sending an event to the channel, so that NAPI runs, and hanging the subsequent fast fill off the event handler. Replace the sfc_refill workqueue and delayed work items with a timer. We do not need to stop this timer in efx_flush_all() because it's safe to send the event always; receiving it will be delayed until NAPI is restarted. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-29sfc: Update version, copyright dates, authorsBen Hutchings
This driver has been mostly rewritten since Michael Brown's initial work, so swap the order of the authors. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Rename falcon.h to nic.hBen Hutchings
nic.h is no longer specific to Falcon. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Separate shared NIC code from Falcon-specific and rename accordinglyBen Hutchings
2009-11-24sfc: Combine high-level header filesBen Hutchings
All files that include ethtool.h, rx.h or tx.h are also including efx.h, and there is no good reason to separate out the few declarations they contain. Therefore fold them into efx.h. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-24sfc: Record RX queue number on GRO pathBen Hutchings
2009-11-24sfc: Move assertions and buffer cleanup earlier in efx_rx_packet_lro()Ben Hutchings
This removes the need to use a label and goto, and makes the two branches mirror each other more closely. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-24sfc: Remove ridiculously paranoid assertionsBen Hutchings
2009-11-24sfc: Remove redundant gotos from __efx_rx_packet()Ben Hutchings
This function no longer has any common cleanup code. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29sfc: Enable heuristic selection between page and skb RX buffersBen Hutchings
Now that we can tell whether GRO is being applied, this heuristic is effective once more. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29sfc: Feed GRO result into RX allocation policy and interrupt moderationBen Hutchings
When GRO is successfully merging received packets, we should allocate raw page buffers rather than skbs that will be discarded by GRO. Otherwise, we should allocate skbs. GRO also benefits from higher interrupt moderation, so increase the score for mergeable RX packets. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29Merge branch 'master' of ↵David S. Miller
2009-10-28sfc: Set ip_summed correctly for page buffers passed to GROBen Hutchings
Page buffers containing packets with an incorrect checksum or using a protocol not handled by hardware checksum offload were previously not passed to LRO. The conversion to GRO changed this, but did not set the ip_summed value accordingly. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-24sfc: Eliminate indirect lookups of queue size constantsBen Hutchings
Move size and mask definitions into efx.h; calculate page orders in falcon.c. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-16gro: New frags interface to avoid copying shinfoHerbert Xu
It turns out that copying a 16-byte area at ~800k times a second can be really expensive :) This patch redesigns the frags GRO interface to avoid copying that area twice. The two disciples of the frags interface have been converted. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-27net: Add skb_record_rx_queue() calls to multiqueue capable drivers.David S. Miller
2009-01-21sfc: Replace LRO with GROHerbert Xu
This patch makes sfc invoke the GRO hooks instead of LRO. As GRO has a compatible external interface to LRO this is a very straightforward replacement. Everything should appear identical to the user except that the offload is now controlled by the GRO ethtool option instead of LRO. I've kept the lro module parameter as is since that's for compatibility only. I have eliminated efx_rx_mk_skb as the GRO layer can take care of all packets regardless of whether GRO is enabled or not. So the only case where we don't call GRO is if the packet checksum is absent. This is to keep the behaviour changes of the patch to a minimum. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-03sfc: Remove some unreachable error pathsBen Hutchings
Some functions return an error code which is always 0. Change their return types to void and simplify their callers accordingly. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-03sfc: Cleanup RX queue informationBen Hutchings
Rename efx_nic::rss_queues to the more obvious n_rx_queues Remove efx_rx_queue::used and other stuff that's redundant with it. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-03sfc: Removed forced inlining of long functionsBen Hutchings
gcc will automatically inline static functions with only one caller, and may inline other functions depending on the kernel configuration and size of the intermediate code. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-03sfc: Use explicit bool for boolean variables, parameters and return valuesBen Hutchings
Replace (cond ? 1 : 0) with cond or !!cond as appropriate, and (cond ? 0 : 1) with !cond. Remove some redundant boolean temporaries. Rename one field that looks like a flag but isn't. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-26dma-mapping: add the device argument to dma_mapping_error()FUJITA Tomonori
Add per-device dma_mapping_ops support for CONFIG_X86_64 as POWER architecture does: This enables us to cleanly fix the Calgary IOMMU issue that some devices are not behind the IOMMU (http://lkml.org/lkml/2008/5/8/423). I think that per-device dma_mapping_ops support would be also helpful for KVM people to support PCI passthrough but Andi thinks that this makes it difficult to support the PCI passthrough (see the above thread). So I CC'ed this to KVM camp. Comments are appreciated. A pointer to dma_mapping_ops to struct dev_archdata is added. If the pointer is non NULL, DMA operations in asm/dma-mapping.h use it. If it's NULL, the system-wide dma_ops pointer is used as before. If it's useful for KVM people, I plan to implement a mechanism to register a hook called when a new pci (or dma capable) device is created (it works with hot plugging). It enables IOMMUs to set up an appropriate dma_mapping_ops per device. The major obstacle is that dma_mapping_error doesn't take a pointer to the device unlike other DMA operations. So x86 can't have dma_mapping_ops per device. Note all the POWER IOMMUs use the same dma_mapping_error function so this is not a problem for POWER but x86 IOMMUs use different dma_mapping_error functions. The first patch adds the device argument to dma_mapping_error. The patch is trivial but large since it touches lots of drivers and dma-mapping.h in all the architecture. This patch: dma_mapping_error() doesn't take a pointer to the device unlike other DMA operations. So we can't have dma_mapping_ops per device. Note that POWER already has dma_mapping_ops per device but all the POWER IOMMUs use the same dma_mapping_error function. x86 IOMMUs use device argument. [akpm@linux-foundation.org: fix sge] [akpm@linux-foundation.org: fix svc_rdma] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix bnx2x] [akpm@linux-foundation.org: fix s2io] [akpm@linux-foundation.org: fix pasemi_mac] [akpm@linux-foundation.org: fix sdhci] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix sparc] [akpm@linux-foundation.org: fix ibmvscsi] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-22sfc: Remove redundant casts to and from void *Ben Hutchings
2008-05-22sfc: Merged efx_page_offset() into efx_rx_buf_offset()Ben Hutchings
2008-05-22sfc: Replaced various macros with inline functionsBen Hutchings
2008-05-22sfc: Added and removed braces to comply with kernel styleBen Hutchings
2008-05-13[netdrvr] sfc: sfc: Add self-test supportBen Hutchings
Add a set of self-tests accessible thorugh ethtool. Add hardware loopback and TX disable control code to support them. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-13[netdrvr] sfc: Removed bogus 'fall-thru' commentsBen Hutchings
Fall-through is expected outside a switch statement. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29New driver "sfc" for Solarstorm SFC4000 controller.Ben Hutchings
The driver supports the 10Xpress PHY and XFP modules on our reference designs SFE4001 and SFE4002 and the SMC models SMC10GPCIe-XFP and SMC10GPCIe-10BT. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
