path: root/drivers/net/sfc/sfe4001.c
2009-10-24sfc: Merge sfe4001.c into falcon_boards.cBen Hutchings
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-24sfc: Rename Falcon-specific board code and typesBen Hutchings
Siena will require entirely different board code. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-08sfc: Don't specify unexistent IRQJean Delvare
Neither the lm90 driver nor the lm87 driver do support interrupts, so there is no point in specifying one when declaring the devices. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-02sfc: SFT9001/SFN4111T: Check PHY boot status during board initialisationBen Hutchings
During SFN4111T initialisation, check whether the PHY boot status indicates a bad firmware checksum. If so, prepare to reflash rather than continuing with normal initialisation. Remove redundant PHY boot status check from tenxpress_phy_init(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-30Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/e1000/e1000_main.c
2009-01-30sfc: Replace stats_enabled flag with a disable countBen Hutchings
Currently we use a spin-lock to serialise statistics fetches and also to inhibit them for short periods of time, plus a flag to enable/disable statistics fetches for longer periods of time, during online reset. This was apparently insufficient to deal with the several reasons for stats being disabled. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-30sfc: Update board info for hardware monitor on SFN4111T-R5 and laterBen Hutchings
2009-01-30sfc: SFN4111T: Fix GPIO sharing between I2C and FLASH_CFG_1Ben Hutchings
Change sfn4111t_reset() to change only GPIO output enables so that it doesn't break subsequent I2C operations. Update comments to explain exactly what we're doing. Add a short sleep to make sure the FLASH_CFG_1 value is latched before any subsequent I2C operations. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21sfc: Replace LRO with GROHerbert Xu
This patch makes sfc invoke the GRO hooks instead of LRO. As GRO has a compatible external interface to LRO this is a very straightforward replacement. Everything should appear identical to the user except that the offload is now controlled by the GRO ethtool option instead of LRO. I've kept the lro module parameter as is since that's for compatibility only. I have eliminated efx_rx_mk_skb as the GRO layer can take care of all packets regardless of whether GRO is enabled or not. So the only case where we don't call GRO is if the packet checksum is absent. This is to keep the behaviour changes of the patch to a minimum. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-12sfc: Add support for SFN4111TBen Hutchings
Add support code for the SFN4111T 100/1000/10GBASE-T reference design, based in part on the existing code for the SFE4001. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-12sfc: Add support for sub-10G speedsBen Hutchings
The SFC4000 has a separate MAC for use at sub-10G speeds. Introduce an efx_mac_operations structure with implementations for the two MACs. Switch between the MACs as necessary. PHY settings are independent of the MAC, so add get_settings() and set_settings() to efx_phy_operations. Also add macs field to indicate which MACs the PHY is connected to. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-06sfc: Use lm87 and lm90 drivers for board temperature/power monitoringBen Hutchings
Add board monitoring to periodic work whenever link is down. For SFE4001, report when a fault has caused the PHY to turn off. For SFE4002, switch XFP PHY into low-power state in case of a fault. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-24sfc: Remove workaround for old firmware bugBen Hutchings
There was a bug in XAUI synchronisation in early 10Xpress firmware versions. This is fixed in released firmware and we do not need to work around it. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-03sfc: Remove remnants of multi-port abstraction for MAC registersBen Hutchings
2008-09-03sfc: Make PHY flash mode a device attribute, not a module parameterBen Hutchings
This allows updating PHY firmware for one interface without removing all other interfaces handled by the driver. Replace tx_disabled flags and 10Xpress status enumeration with flags in enum efx_phy_mode. Prevent an interface from being brought up while in PHY flash mode. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-03sfc: Reduce delays in SFE4001 initialisationBen Hutchings
Currently the board initialisation includes 2 delays of 1 second each. Usually it is unnecessary to wait that long, so check before doing so. Correct some of the comments and log messages while we're here. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-30sfc: Use kernel I2C system and i2c-algo-bit driverBen Hutchings
Remove our own implementation of I2C bit-banging. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-22sfc: Removed casts to voidBen Hutchings
2008-05-13[netdrvr] sfc: Add phy_flash_cfg module parameter and implementationBen Hutchings
The 10Xpress PHY supports flash upgrades through MDIO, but needs to be put in upgrade mode at power-up. This adds a module parameter and other logic to support that. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29New driver "sfc" for Solarstorm SFC4000 controller.Ben Hutchings
The driver supports the 10Xpress PHY and XFP modules on our reference designs SFE4001 and SFE4002 and the SMC models SMC10GPCIe-XFP and SMC10GPCIe-10BT. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
