path: root/drivers/net/sis190.c
2008-04-27sis190: account for Tx errorsFrancois Romieu
Update the collision counter as well. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2008-04-27sis190: remove needless MII resetFrancois Romieu
It does not help the auto-negotiation process to settle. Added a debug message to give some hindsight when things do not work as expected. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2008-04-27sis190: Rx path updateFrancois Romieu
- remove the function pointer to help gcc optimizing the inline pci_dma functions - pci_dma_sync_single_for_cpu is not needed for a single large packet - convert rtl8169_try_rx_copy to bool b449655ff52ff8a29c66c5fc3fc03617e61182ee did the same for the r8169 driver. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2008-04-27sis190: use netdev_alloc_skbStephen Hemminger
This sets skb->dev and allows arch specific allocation. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Francois Romieu <romieu@fr.zoreil.com>
2008-04-27sis190: hard-code the alignment of tiny packetsStephen Hemminger
There is no DMA involved here. Align the IP header without condition. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Francois Romieu <romieu@fr.zoreil.com>
2008-04-27sis190: use the allocated buffer as a status code in sis190_alloc_rx_skbStephen Hemminger
The local status code does not carry mory information. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Francois Romieu <romieu@fr.zoreil.com>
2008-02-23sis190: read the mac address from the eeprom firstFrancois Romieu
Reading a serie of zero from the cmos sram area do not work well with is_valid_ether_addr(). Let's read the mac address from the eeprom first as it seems more reliable. Fix for http://bugzilla.kernel.org/show_bug.cgi?id=9831 Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11drivers/net/sis190: fix section mismatch warning in sis190_get_mac_addrSergio Luis
Fix following warnings: WARNING: drivers/net/sis190.o(.text+0x103): Section mismatch in reference from the function sis190_get_mac_addr() to the function .devinit.text:sis190_get_mac_addr_from_apc() WARNING: drivers/net/sis190.o(.text+0x10e): Section mismatch in reference from the function sis190_get_mac_addr() to the function .devinit.text:sis190_get_mac_addr_from_eeprom() Annotate sis190_get_mac_addr() with __devinit. Signed-off-by: Sergio Luis <sergio@uece.br> sis190.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-03[netdrvr] sis190: build fixJeff Garzik
Fix PCI table section type conflict, by removing __devinitdata. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-23sis190: scheduling while atomic errorFrancois Romieu
sis190_tx_timeout -> sis190_hw_start -> sis190_soft_reset -> msleep *splat* PCI transactions are correctly flushed here. The msleep() is probably useless. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Cc: K.M. Liu <kmliu@sis.com.tw>
2008-01-23sis190: mdio operation failure is not correctly detectedFrancois Romieu
i ranges from 0 to 100 in the 'for' loop a few lines above. Reported by davem. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Cc: K.M. Liu <kmliu@sis.com.tw>
2008-01-23sis190: remove duplicate INIT_WORKFrancois Romieu
It is already done in sis190_init_one. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Cc: K.M. Liu <kmliu@sis.com.tw>
2008-01-23sis190: add cmos ram access code for the SiS19x/968 chipset pairFrancois Romieu
More work is needed to handle correctly the PHY of the new devices when connected to a 10Mb link but this change already helps some users as is. Fix for: http://bugzilla.kernel.org/show_bug.cgi?id=9467 Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Cc: K.M. Liu <kmliu@sis.com.tw> Cc: J. Gleacher <jgleacher@yahoo.com> Cc: Alexandre Penasso Teixeira <alexandre@keepsoftware.com> Cc: Arliton Rocha <arliton@gmail.com> Cc: Juan Jose Pablos <juanjo@apertus.es> Cc: Wipat Srutiprom <wipat.s@psu.ac.th>
2007-12-17sis190 endiannessAl Viro
Check in sis190_rx_interrupt() is broken on big-endian (desc->status is little-endian and everything else actually uses it correctly, including other checks for OWNbit. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-14drivers/net/sis190.c section fixAdrian Bunk
This patch fixes the following section mismatch with CONFIG_HOTPLUG=n: <-- snip --> ... WARNING: vmlinux.o(.init.text.20+0x4cb25): Section mismatch: reference to .exit.text:sis190_mii_remove (between 'sis190_init_one' and 'read_eeprom') ... <-- snip --> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET] drivers/net: statistics cleanup #1 -- save memory and shrink codeJeff Garzik
We now have struct net_device_stats embedded in struct net_device, and the default ->get_stats() hook does the obvious thing for us. Run through drivers/net/* and remove the driver-local storage of statistics, and driver-local ->get_stats() hook where applicable. This was just the low-hanging fruit in drivers/net; plenty more drivers remain to be updated. [ Resolved conflicts with napi_struct changes and fix sunqe build regression... -DaveM ] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make NAPI polling independent of struct net_device objects.Stephen Hemminger
Several devices have multiple independant RX queues per net device, and some have a single interrupt doorbell for several queues. In either case, it's easier to support layouts like that if the structure representing the poll is independant from the net device itself. The signature of the ->poll() call back goes from: int foo_poll(struct net_device *dev, int *budget) to int foo_poll(struct napi_struct *napi, int budget) The caller is returned the number of RX packets processed (or the number of "NAPI credits" consumed if you want to get abstract). The callee no longer messes around bumping dev->quota, *budget, etc. because that is all handled in the caller upon return. The napi_struct is to be embedded in the device driver private data structures. Furthermore, it is the driver's responsibility to disable all NAPI instances in it's ->stop() device close handler. Since the napi_struct is privatized into the driver's private data structures, only the driver knows how to get at all of the napi_struct instances it may have per-device. With lots of help and suggestions from Rusty Russell, Roland Dreier, Michael Chan, Jeff Garzik, and Jamal Hadi Salim. Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra, Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan. [ Ported to current tree and all drivers converted. Integrated Stephen's follow-on kerneldoc additions, and restored poll_list handling to the old style to fix mutual exclusion issues. -DaveM ] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-07sis190 check for ISA bridge on SiS966Neil Muller
sis190 driver assumes to find ISA only on SiS965. similar fix is in sis900 driver, see bug report http://bugs.debian.org/435547 Signed-off-by: maximilian attems <max@stro.at> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-10[NET]: Kill eth_copy_and_sum().David S. Miller
It hasn't "summed" anything in over 7 years, and it's just a straight mempcy ala skb_copy_to_linear_data() so just get rid of it. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-29sis190: new PHY supportFrancois Romieu
Reported to work on the WinFast 761GXK8MB-RS motherboard. Plain 10/100 Mbps. Signed-off-by: Paul Gibbons <paul@pkami.e7even.com> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-20sis190: RTNL and flush_scheduled_work deadlockFrancois Romieu
2007-01-18sis190: failure to set the MAC address from EEPROMFrancois Romieu
Fix from http://bugzilla.kernel.org/show_bug.cgi?id=7747 Signed-off-by: Andrew Morton <akpm@osdl.org> Cc: <sleepy@mike-neko.net> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
2006-09-12Merge branch 'tmp' into upstreamJeff Garzik
2006-09-12[PATCH] Remove more unnecessary driver printk'sAndy Gospodarek
As I promised last week, here is the first pass at removing all unnecessary printk's that exist in network device drivers currently in promiscuous mode. The duplicate messages are not needed so they have been removed. Some of these drivers are quite old and might not need an update, but I did them all anyway. I am currently auditing the remaining conditional printk's and will send out a patch for those soon. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-19drivers/net: Remove deprecated use of pci_module_init()Jeff Garzik
From: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[NET]: Avoid allocating skb in skb_padHerbert Xu
First of all it is unnecessary to allocate a new skb in skb_pad since the existing one is not shared. More importantly, our hard_start_xmit interface does not allow a new skb to be allocated since that breaks requeueing. This patch uses pskb_expand_head to expand the existing skb and linearize it if needed. Actually, someone should sift through every instance of skb_pad on a non-linear skb as they do not fit the reasons why this was originally created. Incidentally, this fixes a minor bug when the skb is cloned (tcpdump, TCP, etc.). As it is skb_pad will simply write over a cloned skb. Because of the position of the write it is unlikely to cause problems but still it's best if we don't do it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-03Massive net driver const-ification.Arjan van de Ven
2006-02-16sis190: early setting of the pci driver private dataFrancois Romieu
Below this point, the error path will proceed through sis190_release_board(). It will happily oops if pci_set_drvdata() has not been issued. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2006-01-10[PATCH] turn "const static" into "static const"Jesper Juhl
ICC likes to complain about storage class not being first, GCC doesn't care much (except for cases like "inline static"). have a hard time seeing how it could break anything. Thanks to Gabriel A. Devenyi for pointing out http://linuxicc.sourceforge.net/ which is what made me create this patch. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] sis190.c: fix multicast MAC filterAurelien Jarno
Here is a patch that changes the way the MAC filter is computed for the multicast addresses. The computation is taken from the SiS GPL driver. This patch is necessary to get IPv6 working. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-05[PATCH] sis190: basic sis191 supportFrancois Romieu
The sis191 is the gigabit brother of the sis190. SiS's driver suggests that the register set is backward compatible: this should hopefully give a basic driver. The device should allow the usual features from a modern ethernet adapter (802.1q, SG, Jumbo frames, TSO, checksum offload). So far the relevant register layout is not documented. SiS's driver does not provide these features either (at least not for Linux). Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-05[PATCH] sis190: RGMII Tx internal delay fiddlingFrancois Romieu
Don't ask. The patch is based on SiS's GPLed driver. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-05[PATCH] sis190: make 10Mbps the default when handling the StationControl ↵Francois Romieu
register This patch does three things: - widen the access to the StationControl register (note the SIS_W16 versus SIS_W32 change); - default to 10Mbps half duplex when the LPA can not be evaluated (reg31->ctl is identical for both). It can be argued that it makes sense as the lowest common denominator when everything else failed. Btw it works better than the current code. :o) - remove some enums: they do not document anymore. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-05[PATCH] sis190: recent chipsets from SiS include a RGMIIFrancois Romieu
Extracted from SiS's GPLed driver. From the few pdf available at SiS's, it seems that the 965 and the 966 south bridge include this interface whereas the 965L (and anything below) does not. It is expected to be a sis191 related feature and should not hurt the existing sis190 driver. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-05[PATCH] sis190: unmask the link change eventsFrancois Romieu
link changes reporting does not work when the driver masks its irq event Signed-off-by: Arnaud Patard <apatard@mandriva.com> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-26[PATCH] sis190: complete the mii probe before registering the netdeviceFrancois Romieu
The userspace must not be able to issue ethtool command and manage the mii before it is completely initialized. Avoid some pesky "eth%d" messages. Signed-off-by: Arnaud Patard <apatard@mandriva.com> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-07-30[PATCH] sis190: compare the lpa to the local advertisementFrancois Romieu
The station control register must depend on both the advertisement and the lpa The link partner ability has better be intersected with the current advertised value before it is feed to the station control register. Sight-catched-by: Lars Vahlenberg <lars.vahlenberg@gmail.com> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-07-30[PATCH] sis190: PHY identifier for the K8S-MX motherboard.Francois Romieu
Added PHY identifier for the Asus K8S-MX motherboard Note: the same ID appears in the sis900 driver. Signed-off-by: Lars Vahlenberg <lars.vahlenberg@gmail.com> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-07-30[PATCH] sis190: new PHY detection code.Francois Romieu
New PHY detection code. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-07-30[PATCH] sis190: dummy read is required by the status registerFrancois Romieu
Add a dummy read before accessing the status register SiS driver suggests it. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-07-30[PATCH] sis190: allow a non-hardcoded ID for the PHY.Francois Romieu
Allow a non-hardcoded ID for the PHY This is the first step before the driver probes for the PHY address. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-07-30[PATCH] sis190: add endian annotations.Francois Romieu
Add endian annotations. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-07-30[PATCH] sis190: extract bits definition from SiS driver.Francois Romieu
extract bits definition from SiS driver - fix the Rx stats; - minor pieces of documentation. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
