path: root/drivers/net/smc91x.c
2011-08-10smsc: Move the SMC (SMSC) driversJeff Kirsher
Moves the SMC (SMSC) drivers into drivers/net/ethernet/smsc/ and the necessary Kconfig and Makefile changes. Also did some cleanup of NET_VENDOR_SMC Kconfig tag for the 8390 based drivers. CC: Nicolas Pitre <nico@fluxnic.net> CC: Donald Becker <becker@scyld.com> CC: Erik Stahlman <erik@vt.edu> CC: Dustin McIntire <dustin@sensoria.com> CC: Steve Glendinning <steve.glendinning@smsc.com> CC: David Hinds <dahinds@users.sourceforge.net> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-07-08drivers/net: Omit check for multicast bit in netdev_for_each_mc_addrTobias Klauser
There is no need to check for the address being a multicast address in the netdev_for_each_mc_addr loop, so remove it. This patch covers all remaining network drivers still containing such a check. Cc: Joe Perches <joe@perches.com> Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-05net: fix smc91x.c device tree supportGrant Likely
Fix missing semicolon at end of smc91x.c match tabledevice driver. Also remove unnecessary #ifdef around of_match_table pointer. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-29ethtool: cosmetic: Use ethtool ethtool_cmd_speed APIDavid Decotigny
This updates the network drivers so that they don't access the ethtool_cmd::speed field directly, but use ethtool_cmd_speed() instead. For most of the drivers, these changes are purely cosmetic and don't fix any problem, such as for those 1GbE/10GbE drivers that indirectly call their own ethtool get_settings()/mii_ethtool_gset(). The changes are meant to enforce code consistency and provide robustness with future larger throughputs, at the expense of a few CPU cycles for each ethtool operation. All drivers compiled with make allyesconfig ion x86_64 have been updated. Tested: make allyesconfig on x86_64 + e1000e/bnx2x work Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-25smc91x: add devicetree supportThomas Chou
Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-07smc91x: Add missing #inclusion of <linux/irq.h>David Howells
Add missing #inclusion of <linux/irq.h>. Without it, the following error can occur with the irqflags fixup patches applied: drivers/net/smc91x.c: In function 'smc_probe': drivers/net/smc91x.c:1987:2: error: implicit declaration of function 'irq_canonicalize' Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Nicolas Pitre <nico@fluxnic.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-24net/smc91xx: remove trailing space in messagesFrans Pop
Includes a few whitespace fixes to placate checkpatch. Signed-off-by: Frans Pop <elendil@planet.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-26net: convert multiple drivers to use netdev_for_each_mc_addr, part6Jiri Pirko
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-11net: smc91x: Fix up type mismatch in smc_drv_resume().Paul Mundt
smc_drv_resume() takes a struct device, while smc_enable_device() takes a platform device. This fixes up the smc_enable_device() callsite with the proper pointer. It's not obvious when this change was introduced, as git history doesn't go back that far. Presumably the resume code has always been broken in this fashion. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-11smc91x: fix unused flags warnings on UP systemsMike Frysinger
Local flags variables will be declared whenever these functions get used, but obviously on UP systems the flags parameter won't be touched. So add some dummy ops that get optimized away anyways to satisfy gcc's warnings. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-01Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/mac80211/ht.c
2009-11-29NET: smc91x: Fix irq flagsRussell King - ARM Linux
smc91x.h defines SMC_IRQ_FLAGS to be -1 when it wants the interrupt flags to be taken from the resource structure. However, d280ead changed this to checking for non-zero resource flags. Unfortunately, this means that on some platforms, we end up passing '-1' to request_irq rather than the desired result. Combine the two conditions into one so that the IRQ flags are taken from the resource if either SMC_IRQ_FLAGS is -1 or the resource flags specify an interrupt trigger. This restores network on at least the Versatile platform. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29NET: smc91x: convert to dev_pm_opsKevin Hilman
Convert smc91x driver from legacy PM hooks over to using dev_pm_ops. Tested on OMAP3 platform. Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Acked-by: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18drivers/net: request_irq - Remove unnecessary leading & from second argJoe Perches
Not as fancy as coccinelle. Checkpatch errors ignored. Compile tested allyesconfig x86, not all files compiled. grep -rPl --include=*.[ch] "\brequest_irq\s*\([^,\)]+,\s*\&" drivers/net | while read file ; do \ perl -i -e 'local $/; while (<>) { s@(\brequest_irq\s*\([^,\)]+,\s*)\&@\1@g ; print ; }' $file ;\ done Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-15Nicolas Pitre has a new email addressNicolas Pitre
Due to problems at cam.org, my nico@cam.org email address is no longer valid. FRom now on, nico@fluxnic.net should be used instead. Signed-off-by: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-02Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/yellowfin.c
2009-08-26smc91x: fix compilation on SMPAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-23smc91x: let smc91x work well under netpollDongdong Deng
The NETPOLL requires that interrupts remain disabled in its callbacks. Using *_irq_save()/irq_restore() to replace *_irq_disable()/irq_enable() functions in NETPOLL's callbacks of smc91x, so that it doesn't enable interrupts when already disabled, and kgdboe/netconsole would work properly over smc91x. Signed-off-by: Dongdong Deng <dongdong.deng@windriver.com> Acked-by: Nicolas Pitre <nico@cam.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-16Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/orinoco/main.c
2009-07-12netdev: restore MTU change operationBen Hutchings
alloc_etherdev() used to install a default implementation of this operation, but it must now be explicitly installed in struct net_device_ops. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-26smc91x: struct net_device_opsMagnus Damm
Convert the smc91x driver to use struct net_device_ops. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-26net: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21smc91x: enable ethtool EEPROM interfaceVernon Sauder
Signed-off-by: Vernon Sauder <vsauder@inhand.com> Acked-by: Nicolas Pitre <nico@cam.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-03smc91x: remove isa stuff from smc91x driverLuotao Fu
ISA support in smc91x is incomplete. I doubt there're any smc91x isa card. This driver is greatly used on arm pxa platforms. Hence we remove the isa stuff from smc91x driver. Signed-off-by: Luotao Fu <lfu@pengutronix.de> Acked-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-02Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ixgbe/ixgbe_main.c drivers/net/smc91x.c
2008-11-30section errors in smc911x/smc91xAl Viro
a) ->probe() can be __devinit; no need to put it into .text b) calling __init stuff from it, OTOH, is wrong c) ->remove() is __devexit fodder Acked-by: rmk+kernel@arm.linux.org.uk Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/ath5k/base.c net/8021q/vlan_core.c
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03SMC91x: Fix compilation on some platforms.David S. Miller
This reverts 51ac3beffd4afaea4350526cf01fe74aaff25eff ('SMC91x: delete unused local variable "lp"') and adds __maybe_unused markers to these (potentially) unused variables. The issue is that in some configurations SMC_IO_SHIFT evaluates to '(lp->io_shift)', but in some others it's plain '0'. Based upon a build failure report from Manuel Lauss. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-02smc91x: add __init markings to smc_drv_probe()Mike Frysinger
The smc_drv_probe() is the platform_driver probe function and it is only called during init. Further, it calls smc_probe() which is marked as __init already. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-31Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/p54/p54common.c
2008-10-31SMC91x: delete unused local variable "lp"Mike Frysinger
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-11Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (236 commits) [ARM] 5300/1: fixup spitz reset during boot [ARM] 5295/1: make ZONE_DMA optional [ARM] 5239/1: Palm Zire 72 power management support [ARM] 5298/1: Drop desc_handle_irq() [ARM] 5297/1: [KS8695] Fix two compile-time warnings [ARM] 5296/1: [KS8695] Replace macro's with trailing underscores. [ARM] pxa: allow multi-machine PCMCIA builds [ARM] pxa: add preliminary CPUFREQ support for PXA3xx [ARM] pxa: add missing ACCR bit definitions to pxa3xx-regs.h [ARM] pxa: rename cpu-pxa.c to cpufreq-pxa2xx.c [ARM] pxa/zylonite: add support for USB OHCI [ARM] ohci-pxa27x: use ioremap() and offset for register access [ARM] ohci-pxa27x: introduce pxa27x_clear_otgph() [ARM] ohci-pxa27x: use platform_get_{irq,resource} for the resource [ARM] ohci-pxa27x: move OHCI controller specific registers into the driver [ARM] ohci-pxa27x: introduce flags to avoid direct access to OHCI registers [ARM] pxa: move I2S register and bit definitions into pxa2xx-i2s.c [ARM] pxa: simplify DMA register definitions [ARM] pxa: make additional DCSR bits valid for PXA3xx [ARM] pxa: move i2c register and bit definitions into i2c-pxa.c ... Fixed up conflicts in arch/arm/mach-versatile/core.c sound/soc/pxa/pxa2xx-ac97.c sound/soc/pxa/pxa2xx-i2s.c manually.
2008-10-09Merge branch 'ptebits' into develRussell King
Conflicts: arch/arm/Kconfig
2008-09-24drivers/net: replace __FUNCTION__ with __func__Harvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-24smc91x: fix nowait printoutMagnus Damm
Commit c4f0e76747e80578a8f7fddd82fd0ce8127bd2f8 added nowait platform data support. The printout code was however not updated, so the value of SMC_NOWAIT is still used. This patch makes sure that nowait is printed accordingly to platform data. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-07[NET] smc91x: provide configurable ledsRussell King
This patch provides a mechanism for platforms to be able to supply the LED configuration via platform data, rather than having to hard code it in smc91x.h. Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Nicolas Pitre <nico@cam.org> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-27[netdrvr] smc91x: fix resource removal (null ptr deref)Jeff Garzik
Properly handle resource cleanup on unplug/exit. Spotted by Jonathan Cameron Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-12[NET] smc91x: prepare SMC_USE_PXA_DMA to be specified in platform dataEric Miao
Now that the original SMC_USE_PXA_DMA specific code will always being built if CONFIG_ARCH_PXA is defined, so to make this part of the code to be PXA public, and still prevent it from being built if support of PXA is not selected. A SMC91X_USE_DMA flag is added to the platform data to allow platform to choose its usage of DMA. Note this flag itself is so named to be generic enough (assuming other platforms can also use DMA). It keeps backward compatibility to set the SMC91X_USE_DMA flag if SMC_USE_PXA_DMA is still defined. Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Nicolas Pitre <nico@cam.org> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-12[NET] smc91x: prepare for SMC_IO_SHIFT to be a platform configurable variableEric Miao
Now one can use the following code #define SMC_IO_SHIFT lp->io_shift to make SMC_IO_SHIFT a variable. This, however, will slightly increase the CPU overhead and have negative impact on the network performance. The tradeoff is, this can be specified in the smc91x platform data so that multiple boards support can be built in a single zImage. Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Nicolas Pitre <nico@cam.org> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-12[NET] smc91x: add SMC91X_NOWAIT flag to platform dataEric Miao
And also favors the usage of SMC91X_NOWAIT over the hardcoded SMC_NOWAIT by converting "nowait" (module parameter overridable) to platform flag. There are several possibilities: 1. platform data present - preferred and use as is 2. platform data absent - use "nowait", it can be: a. SMC_NOWAIT if defined b. default to 0 if SMC_NOWAIT isn't defined c. overriden by module parameter Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Nicolas Pitre <nico@cam.org> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-12[NET] smc91x: favor the use of SMC91X_USE_* instead of SMC_CAN_USE_*Eric Miao
Let's simplify the logic and avoid confusion, the use of SMC91X_USE_* is favored than SMC_CAN_USE_*, if platform data isn't given, convert the hardcoded SMC_CAN_USE_* to SMC91X_USE_*. Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Nicolas Pitre <nico@cam.org> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-12[NET] smc91x: remove "irq_flags" from "struct smc91x_platdata"Eric Miao
IRQ trigger type can be specified in the IRQ resource definition by IORESOURCE_IRQ_*, we need only one way to specify this. This also fixes the following small issue: To allow dynamic support for multiple platforms, when those relevant macros are not defined for one specific platform, the default case will be: - SMC_DYNAMIC_BUS_CONFIG defined - and SMC_IRQ_FLAGS = IRQF_TRIGGER_RISING While if "irq_flags" is missing when defining the smc91x_platdata, usually as follows: static struct smc91x_platdata xxxx_smc91x_data = { .flags = SMC91X_USE_XXBIT, }; The lp->cfg.irq_flags will always be overriden by the above structure (due to a memcpy), thus rendering lp->cfg.irq_flags to be "0" always. (regardless of the default SMC_IRQ_FLAGS or IORESOURCE_IRQ_* flags) Fixes this by forcing to use IORESOURCE_IRQ_* flags if present, and make the only user of smc91x_platdata.irq_flags (renesas/migor) to use IORESOURCE_IRQ_*. Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Nicolas Pitre <nico@cam.org> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
