path: root/drivers/net/sunhme.c
2008-08-31sparc: Annotate of_device_id arrays with const or __initdata.David S. Miller
As suggested by Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sunhme: Convert to pure OF driver.David S. Miller
2008-08-29sparc: Move SBUS DMA attribute interfaces out of asm/sbus.hDavid S. Miller
This is in preparation for the subsequent asm/sbus.h removal. Also, make these routines take a "struct device" or no arguments, as appropriate. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc: Convert all SBUS drivers to dma_*() interfaces.David S. Miller
And all the SBUS dma interfaces are deleted. A private implementation remains inside of the 32-bit sparc port which exists only for the sake of the implementation of dma_*(). Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc: Make SBUS DMA interfaces take struct device.David S. Miller
This is the first step in converting all the SBUS drivers over to generic dma_*(). Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-21sunhme: Remove stop/wake TX queue calls in set-multicast-list handler.David S. Miller
Based upon a bug report by Alexander Beregalov and commentary from Ben Hutchings. These are totally unnecessary, in particular because this driver's ->hard_start_xmit() handler takes the same driver spinlock that the set-multicast-list handler uses. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-04sunhme: Cleanup use of deprecated calls to save_and_cli and restore_flags.Mark Asselstine
Make use of local_irq_save and local_irq_restore rather then the deprecated save_and_cli and restore_flags calls. Signed-off-by: Mark Asselstine <mark.asselstine@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28NULL noise in drivers/netAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28sunhme endianness annotationsAl Viro
This one is interesting - SBUS and PCI variants have opposite endianness in descriptors (SBUS is sparc-only, so there host-endian == big-endian). Solution: declare a bitwise type (hme32) and in accessor helpers do typechecking and force-casts (once we know that the type is right). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-15[SUNHME]: VLAN support for sunhmeChris Poon
This patch enables VLAN support on sunhme by increasing BMAC_TXMAX/BMAC_RXMAX and allocating extra space via skb_put for the VLAN header. Signed-off-by: Chris Poon <dev-null@telus.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-05SUNHME: Fix missing NETIF_F_VLAN_CHALLENGED on PCI happy mealsDavid Miller
No HME parts can do VLANs correctly. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-10sunhme.c:quattro_pci_find() must be __devinitAdrian Bunk
This patch fixes the following section mismatch: <-- snip --> ... MODPOST vmlinux WARNING: drivers/built-in.o(.text+0x272f8b): Section mismatch: reference to .init.text:quattro_pci_find (between 'happy_meal_pci_probe' and 'happy_meal_pci_remove') ... <-- snip --> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-27Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: (67 commits) [SCSI] SUNESP: Complete driver rewrite to version 2.0 [SPARC64]: Convert PCI over to generic struct iommu/strbuf. [SPARC]: device_node name constification fallout [SPARC64]: Convert SBUS over to generic iommu/strbuf structs. [SPARC64]: Add generic iommu and strbuf structs to iommu.h [SPARC64]: Consolidate {sbus,pci}_iommu_arena. [SPARC]: Make device_node name and type const [SPARC64]: constify some paramaters of OF routines [TIGON3]: of_get_property() returns const. [SPARC64]: Fix PCI rework to adhere to of_get_property() const return. [SPARC64]: Document and fix calculation of pages_avail. [SPARC64]: Make sure pbm->prom_node is setup easly enough in psycho.c [SPARC64]: Use bootmem_bootmap_pages() in choose_bootmap_pfn(). [SPARC64]: Add proper header file extern for cmdline_memory_size. [SPARC64]: Kill sparc_ultra_dump_{i,d}tlb() [SPARC64]: Use DECLARE_BITMAP and BITS_TO_LONGS in mm/init.c [SPARC64]: Give move verbose show_mem() output just like i386. [SPARC64]: Mark show_mem() printk's with KERN_INFO. [SPARC64]: Kill kvaddr_to_phys() and friends. [SPARC64]: Privatize sun4u_get_pte() and fix name. ...
2007-04-26[SUNHME]: Use pci_device_to_OF_node().David S. Miller
2007-04-26[SPARC/64] constify of_get_property return: driversStephen Rothwell
The only unfortunate bit here is that the name field of struct map_info is not const, so for now we put a cast on the assignment of it. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[SK_BUFF]: Introduce skb_transport_offset()Arnaldo Carvalho de Melo
For the quite common 'skb->h.raw - skb->data' sequence. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-21[SUNHME]: Fix module unload.Marcel van Nies
Signed-off-by: Marcel van Nies <morcles@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-04Merge branch 'for-linus4' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/viro/bird * 'for-linus4' of master.kernel.org:/pub/scm/linux/kernel/git/viro/bird: [PATCH] severing poll.h -> mm.h [PATCH] severing skbuff.h -> mm.h [PATCH] severing skbuff.h -> poll.h [PATCH] severing skbuff.h -> highmem.h [PATCH] severing uaccess.h -> sched.h [PATCH] severing fs.h, radix-tree.h -> sched.h [PATCH] severing module.h->sched.h
2006-12-04[PATCH] severing skbuff.h -> mm.hAl Viro
2006-12-03[SUNHME]: Fix for sunhme failures on x86Jurij Smakov
The following patch fixes the failure of sunhme drivers on x86 hosts due to missing pci_enable_device() and pci_set_master() calls, lost during code refactoring. It has been filed as bugzilla bug #7502 [0] and Debian bug #397460 [1]. [0] http://bugzilla.kernel.org/show_bug.cgi?id=7502 [1] http://bugs.debian.org/397460 Signed-off-by: Jurij Smakov <jurij@wooyd.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Split skb->csumAl Viro
... into anonymous union of __wsum and __u32 (csum and csum_offset resp.) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-06drivers/net: eliminate irq handler impossible checks, needless castsJeff Garzik
- Eliminate check for irq handler 'dev_id==NULL' where the condition never occurs. - Eliminate needless casts to/from void* Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-24Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (217 commits) net/ieee80211: fix more crypto-related build breakage [PATCH] Spidernet: add ethtool -S (show statistics) [NET] GT96100: Delete bitrotting ethernet driver [PATCH] mv643xx_eth: restrict to 32-bit PPC_MULTIPLATFORM [PATCH] Cirrus Logic ep93xx ethernet driver r8169: the MMIO region of the 8167 stands behin BAR#1 e1000, ixgb: Remove pointless wrappers [PATCH] Remove powerpc specific parts of 3c509 driver [PATCH] s2io: Switch to pci_get_device [PATCH] gt96100: move to pci_get_device API [PATCH] ehea: bugfix for register access functions [PATCH] e1000 disable device on PCI error drivers/net/phy/fixed: #if 0 some incomplete code drivers/net: const-ify ethtool_ops declarations [PATCH] ethtool: allow const ethtool_ops [PATCH] sky2: big endian [PATCH] sky2: fiber support [PATCH] sky2: tx pause bug fix drivers/net: Trim trailing whitespace [PATCH] ehea: IBM eHEA Ethernet Device Driver ... Manually resolved conflicts in drivers/net/ixgb/ixgb_main.c and drivers/net/sky2.c related to CHECKSUM_HW/CHECKSUM_PARTIAL changes by commit 84fa7933a33f806bbbaae6775e87459b1ec584c0 that just happened to be next to unrelated changes in this update.
2006-09-22[NET]: Replace CHECKSUM_HW by CHECKSUM_PARTIAL/CHECKSUM_COMPLETEPatrick McHardy
Replace CHECKSUM_HW by CHECKSUM_PARTIAL (for outgoing packets, whose checksum still needs to be completed) and CHECKSUM_COMPLETE (for incoming packets, device supplied full checksum). Patch originally from Herbert Xu, updated by myself for 2.6.18-rc3. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-07-21[NET]: sun happymeal, little pci cleanupJiri Slaby
Use pci_register_driver instead of pci_module_init. Use PCI_DEVICE macro. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[SUNHME]: Mark SBUS probing routines as __devinit.David S. Miller
2006-06-23[NET] sunhme: Kill useless loop over sdevs in quattro_sbus_find().David S. Miller
2006-06-23[NET] sunhme: Convert to new SBUS driver framework.David S. Miller
And make it a real PCI driver too. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-23[NET] sunhme: Kill __sparc__ and __sparc_v9__ ifdefs.David S. Miller
Use CONFIG_SPARC and CONFIG_SPARC64 instead. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-23[SPARC]: Port sparc64 in-kernel device tree code to sparc32.David S. Miller
2006-06-23[SPARC64]: Convert sparc64 PCI layer to in-kernel device tree.David S. Miller
One thing this change pointed out was that we really should pull the "get 'local-mac-address' property" logic into a helper function all the network drivers can call. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-20[SPARC]: Kill __irq_itoa().David S. Miller
This ugly hack was long overdue to die. It was a way to print out Sparc interrupts in a more freindly format, since IRQ numbers were arbitrary opaque 32-bit integers which vectored into PIL levels. These 32-bit integers were not necessarily in the 0-->NR_IRQS range, but the PILs they vectored to were. The idea now is that we will increase NR_IRQS a little bit and use a virtual<-->real IRQ number mapping scheme similar to PowerPC. That makes this IRQ printing hack irrelevant, and furthermore only a handful of drivers actually used __irq_itoa() making it even less useful. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-11[PATCH] Sun HME: enable and map PCI ROM properlyWilly Tarreau
This ports the Sun GEM ROM mapping/enable fixes it sunhme (which used the same PCI ROM mapping code). Without this, I get NULL MAC addresses for all 4 ports (it's a SUN QFE). With it, I get the correct addresses (the ones printed on the label on the card). Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-24[SPARC]: module version cleanupsTom 'spot' Callaway
Minor cleanups for sparc specific drivers (sunbmac, sunqe, sunlance, sunhme, esp) so that they have a full module version definition that is consistent with other upstream drivers. Signed-off-by: Tom 'spot' Callaway <tcallawa@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
