path: root/drivers/net/sunqe.h
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2008-08-29sunqe: Convert to pure OF driver.David S. Miller
2007-10-10[NET] drivers/net: statistics cleanup #1 -- save memory and shrink codeJeff Garzik
We now have struct net_device_stats embedded in struct net_device, and the default ->get_stats() hook does the obvious thing for us. Run through drivers/net/* and remove the driver-local storage of statistics, and driver-local ->get_stats() hook where applicable. This was just the low-hanging fruit in drivers/net; plenty more drivers remain to be updated. [ Resolved conflicts with napi_struct changes and fix sunqe build regression... -DaveM ] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
