* remove interrupt.g inclusion from netdevice.h -- not needed
* fixup fallout, add interrupt.h and hardirq.h back where needed.
Use the current logging styles.
Convert logging messages to more current styles.
Added -DDEBUG to Makefile to maintain current message logging.
This could be converted to a specific CONFIG_TULIP_DEBUG option.
Use the current more descriptive logging styles.
Add pr_fmt and remove PFX where appropriate.
Use netif_<level>, netdev_<level>
Indent a few blocks in xircom_cb where appropriate.
Initial driver reported different speeds depending on the port being
used. This advertises the speed to be 10Mbps in any case, which is
what it actually is on the wire.
Signed-off-by: David Decotigny <decot@google.com>
This updates the network drivers so that they don't access the
ethtool_cmd::speed field directly, but use ethtool_cmd_speed()
instead.
For most of the drivers, these changes are purely cosmetic and don't
fix any problem, such as for those 1GbE/10GbE drivers that indirectly
call their own ethtool get_settings()/mii_ethtool_gset(). The changes
are meant to enforce code consistency and provide robustness with
future larger throughputs, at the expense of a few CPU cycles for each
ethtool operation.
All drivers compiled with make allyesconfig ion x86_64 have been
updated.
Tested: make allyesconfig on x86_64 + e1000e/bnx2x work
This makes sure the ethtool's set_settings() callback of network
drivers don't ignore the 16 most significant bits when ethtool calls
their set_settings().
All drivers compiled with make allyesconfig on x86_64 have been
updated.
Using static const generally increases object text and decreases data size.
It also generally decreases overall object size.
Its now illegal to call netif_stop_queue() before register_netdev()
net/ipv4/Kconfig
net/ipv4/tcp_timer.c
Print media debug messages only when HW debug is enabled.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
Acked-by: Jeff Garzik <jgarzik@redhat.com>
When the interface is up, using ethtool breaks it because:
a) link is put down but media_timer interval is not shortened to NO_LINK
b) rxtx is stopped but not restarted
Also manual 10baseT-HD (and probably FD too - untested) mode does not work -
the link is forced up, packets are transmitted but nothing is received.
Changing CSR14 value to match documentation (not disabling link check) fixes this.
Compex FreedomLine 32 PnP-PCI2 cards have only TP and BNC connectors but the
SROM contains AUI port too. When TP loses link, the driver switches to
non-existing AUI port (which reports that carrier is always present).
Connecting TP back generates LinkPass interrupt but de_media_interrupt() is
broken - it only updates the link state of currently connected media, ignoring
the fact that LinkPass and LinkFail bits of MacStatus register belong to the
TP port only (the chip documentation says that).
This patch changes de_media_interrupt() to switch media to TP when link goes
up (and media type is not locked) and also to update the link state only when
the TP port is used.
Also the NonselPortActive (and also SelPortActive) bits of SIAStatus register
need to be cleared (by writing 1) after reading or they're useless.
At least my 21041 cards come out of suspend with bus mastering disabled so
they did not work after resume(no data transferred).
After adding pci_set_master(), the driver oopsed immediately on resume -
because de_clean_rings() is called on suspend but de_init_rings() call
was missing in resume.
Also disable link (reset SIA) before sleep (de4x5 does this too).
At least on older 21041-AA chips (mine is rev. 11), TP duplex autonegotiation
causes the card not to work at all (link is up but no packets are transmitted).
de4x5 disables autonegotiation completely. But it seems to work on newer
(21041-PA rev. 21) so disable it only on rev<20 chips.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1443 commits)
phy/marvell: add 88ec048 support
igb: Program MDICNFG register prior to PHY init
e1000e: correct MAC-PHY interconnect register offset for 82579
hso: Add new product ID
can: Add driver for esd CAN-USB/2 device
l2tp: fix export of header file for userspace
can-raw: Fix skb_orphan_try handling
Revert "net: remove zap_completion_queue"
net: cleanup inclusion
phy/marvell: add 88e1121 interface mode support
u32: negative offset fix
net: Fix a typo from "dev" to "ndev"
igb: Use irq_synchronize per vector when using MSI-X
ixgbevf: fix null pointer dereference due to filter being set for VLAN 0
e1000e: Fix irq_synchronize in MSI-X case
e1000e: register pm_qos request on hardware activation
ip_fragment: fix subtracting PPPOE_SES_HLEN from mtu twice
net: Add getsockopt support for TCP thin-streams
cxgb4: update driver version
cxgb4: add new PCI IDs
Manually fix up conflicts in:
- drivers/net/e1000e/netdev.c: due to pm_qos registration
infrastructure changes
- drivers/net/phy/marvell.c: conflict between adding 88ec048 support
and cleaning up the IDs
- drivers/net/wireless/ipw2x00/ipw2100.c: trivial ipw2100_pm_qos_req
conflict (registration change vs marking it static)
This patch fixes a missing read memory barrier that is needed for the
driver to readout the MAC address correctly from the on-board ROM.
Also it replaces the use of the deprecated functions readl()/writel().
Signed-off-by: Morten H. Larsen <m-larsen@post6.tele.dk>
Signed-off-by: Matt Turner <mattst88@gmail.com>
cleanup patch.
Use new __packed annotation in drivers/net/
Now that core network takes care of trans_start updates, dont do it
in drivers themselves, if possible. Drivers can avoid one cache miss
(on dev->trans_start) in their start_xmit() handler.
Exceptions are NETIF_F_LLTX drivers
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
also bug in de2104x.c was corrected:
for (i = 0; i < 32; i++) loop should be outside mc_list iteration.
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss
anything). Used spatch and did small tweaks and conding style changes when
it was suitable.
Jirka
Convert printks to dev_<level> where a dev is available
Convert printks to pr_<level> where not
Coalesce format strings
Change print formats with %d.dx to %0dx
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section
in every case.
Only files where David Miller is the primary git-signer.
wireless, wimax, ixgbe, etc are not modified.
Compile tested x86 allyesconfig only
Not all files compiled (not x86 compatible)
Added a few > 80 column lines, which I ignored.
Existing checkpatch complaints ignored.
arch/microblaze/include/asm/socket.h
Commit 5fd29d6ccbc98884569d6f3105aeca70858b3e0f ("printk: clean up
handling of log-levels and newlines") changed printk semantics. printk
lines with multiple KERN_<level> prefixes are no longer emitted as
before the patch.
<level> is now included in the output on each additional use.
Remove all uses of multiple KERN_<level>s in formats.
This patch is the result of an automatic spatch transformation to convert
all ndo_start_xmit() return values of 0 to NETDEV_TX_OK.
Some occurences are missed by the automatic conversion, those will be
handled in a seperate patch.
Convert magic values 1 and -1 to NETDEV_TX_BUSY and NETDEV_TX_LOCKED respectively.
0 (NETDEV_TX_OK) is not changed to keep the noise down, except in very few cases
where its in direct proximity to one of the other values.
Add a configurable Descriptor Skip Length for systems that lack cache
coherence.
(akpm: I think this should be done as a module parameter, not a
compile-tinme option)
Signed-off-by: Risto Suominen <Risto.Suominen@gmail.com>
Cc: Grant Grundler <grundler@parisc-linux.org>
DescOwn should not be set, thus allowing the chip to use the
descriptor, before everything else is set up correctly.
while (timeout--) { ... }
timeout becomes -1 if the loop isn't ended otherwise, not 0.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Fix this sparse warnings:
drivers/net/tulip/de2104x.c:1695:4: warning: do-while statement is not a compound statement
drivers/net/tulip/tulip_core.c:1433:5: warning: do-while statement is not a compound statement
Signed-off-by: Hannes Eder <hannes@hanneseder.net>
We have some reasons to kill netdev->priv:
1. netdev->priv is equal to netdev_priv().
2. netdev_priv() wraps the calculation of netdev->priv's offset, obviously
netdev_priv() is more flexible than netdev->priv.
But we cann't kill netdev->priv, because so many drivers reference to it
directly.
This patch is a safe convert for netdev->priv to netdev_priv(netdev).
Since all of the netdev->priv is only for read.
But it is too big to be sent in one mail.
I split it to 4 parts and make every part smaller than 100,000 bytes,
which is max size allowed by vger.
Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com>
The generic packet receive code takes care of setting
netdev->last_rx when necessary, for the sake of the
bonding ARP monitor.
Drivers need not do it any more.
Some cases had to be skipped over because the drivers
were making use of the ->last_rx value themselves.
This converts pretty much everything to print_mac. There were
a few things that had conflicts which I have just dropped for
now, no harm done.
I've built an allyesconfig with this and looked at the files
that weren't built very carefully, but it's a huge patch.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
The de2104x returns sometimes a wrong MAC address. The wrong one is
like the original one, but it comes with an one byte shift. I found
this bug on an older alpha ev5 cpu. More details are available in Gentoo
bugreport #240718.
It seems the hardware is sometimes a little bit too slow for an
immediate access. This patch solves the problem by introducing a small
udelay.
Signed-off-by: Martin Langer <martin-langer@gmx.de>
The de2104x did a pci_disable_device() in it's close function, but
the open function never does a pci_enable_device() and assumes that
the device is already enabled. Considering that downing the interface
is just a temporary thing the pci_disable_device() isn't a pretty good
idea and removing it from the close function just fixes the bug.
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Acked-by: Grant Grundler <grundler@parisc-linux.org>
DE_UNALIGNED_16 is always being passed a u16 *, no need to have the
wrapper with two casts in it, just call get_unaligned directly.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
This untested patch _should_ fix:
"(net de2104x) Kernel panic with de2104x tulip driver on boot"
http://bugzilla.kernel.org/show_bug.cgi?id=3156
But the bug submitter isn't responding. Same fix has been applied
to tulip.c (several years ago) and uli526x.c (Feb 2008) drivers.
[ The panic reported in the bug report was removed in a recently
(march 2008) accepted patch from Ondrej Zary. ]
Signed-off-by: Grant Grundler <grundler@parisc-linux.org>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
When the chip dies (probably because of a bug somewhere in the driver),
de_stop_rxtx() fails and changing the media type crashes the whole machine.
Replace BUG_ON() in de_set_media() with a warning.
This is nicer than the MAC_FMT stuff.
For the operations
get-tx-csum
get-sg
get-tso
get-ufo
the default ethtool_op_xxx behavior is fine for all drivers, so we
permit op==NULL to imply the default behavior.
This provides a more uniform behavior across all drivers, eliminating
ethtool(8) "ioctl not supported" errors on older drivers that had
not been updated for the latest sub-ioctls.
The ethtool_op_xxx() functions are left exported, in case anyone
wishes to call them directly from a driver-private implementation --
a not-uncommon case. Should an ethtool_op_xxx() helper remain unused
for a while, except by net/core/ethtool.c, we can un-export it at a
later date.
[ Resolved conflicts with set/get value ethtool patch... -DaveM ]
It's been a useless no-op for long enough in 2.6 so I figured it's time to
remove it. The number of people that could object because they're
maintaining unified 2.4 and 2.6 drivers is probably rather small.
[ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ]
Recent gcc versions emit warnings when unsigned variables are compared < 0 or >= 0.
Signed-off-by: Bill Nottingham <notting@redhat.com>
