path: root/drivers/net/tulip/interrupt.c
2011-05-09tulip: Convert uses of KERN_DEBUGJoe Perches
Convert logging messages to more current styles. Added -DDEBUG to Makefile to maintain current message logging. This could be converted to a specific CONFIG_TULIP_DEBUG option. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-03tulip: use integrated netdev statsEric Dumazet
struct tulip_private is a bit large (order-1 allocation even on 32bit arch), try to shrink it, remove its net_device_stats field. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-31tulip/interrupt.c: Use dev_<level> and pr_<level>Joe Perches
Convert printks to dev_<level> where a dev is available Convert printks to pr_<level> where not Coalesce format strings Change print formats with %d.dx to %0dx Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-13tulip: Fix for MTU problems with 802.1q tagged framesTomasz Lemiech
The original patch was submitted last year but wasn't discussed or applied because of missing maintainer's CCs. I only fixed some formatting errors, but as I saw tulip is very badly formatted and needs further work. Original description: This patch fixes MTU problem, which occurs when using 802.1q VLANs. We should allow receiving frames of up to 1518 bytes in length, instead of 1514. Based on patch written by Ben McKeegan for 2.4.x kernels. It is archived at http://www.candelatech.com/~greear/vlan/howto.html#tulip I've adjusted a few things to make it apply on 2.6.x kernels. Tested on D-Link DFE-570TX quad-fastethernet card. Signed-off-by: Tomasz Lemiech <szpajder@staszic.waw.pl> Signed-off-by: Ivan Vecera <ivecera@redhat.com> Signed-off-by: Ben McKeegan <ben@netservers.co.uk> Acked-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21net: Remove redundant NAPI functionsBen Hutchings
Following the removal of the unused struct net_device * parameter from the NAPI functions named *netif_rx_* in commit 908a7a1, they are exactly equivalent to the corresponding *napi_* functions and are therefore redundant. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-22net: Remove unused netdev arg from some NAPI interfaces.Neil Horman
When the napi api was changed to separate its 1:1 binding to the net_device struct, the netif_rx_[prep|schedule|complete] api failed to remove the now vestigual net_device structure parameter. This patch cleans up that api by properly removing it.. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-24drivers/net/tulip: update first comment in tulip filesGrant Grundler
Three basic changes to the comments at the top of each file: 1) remove stale "Maintained by" line...I prefer people look in MAINTAINERS. 2) Drop reference to stale sf.net/tulip website (I didn't see anything of value there) 3) Point people at bugzilla.kernel.org to submit bugs...will always get tracked regardless of who the maintainer is. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Acked-by-stale-maintainer: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-01-08[NET]: Do not check netif_running() and carrier state in ->poll()David S. Miller
Drivers do this to try to break out of the ->poll()'ing loop when the device is being brought administratively down. Now that we have a napi_disable() "pending" state we are going to solve that problem generically. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-08[TULIP]: NAPI full quantum bug.Stephen Hemminger
This should fix the kernel warn/oops reported while routing. The tulip driver has a fencepost bug with new NAPI in 2.6.24 It has an off by one bug if a full quantum is reached. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make NAPI polling independent of struct net_device objects.Stephen Hemminger
Several devices have multiple independant RX queues per net device, and some have a single interrupt doorbell for several queues. In either case, it's easier to support layouts like that if the structure representing the poll is independant from the net device itself. The signature of the ->poll() call back goes from: int foo_poll(struct net_device *dev, int *budget) to int foo_poll(struct napi_struct *napi, int budget) The caller is returned the number of RX packets processed (or the number of "NAPI credits" consumed if you want to get abstract). The callee no longer messes around bumping dev->quota, *budget, etc. because that is all handled in the caller upon return. The napi_struct is to be embedded in the device driver private data structures. Furthermore, it is the driver's responsibility to disable all NAPI instances in it's ->stop() device close handler. Since the napi_struct is privatized into the driver's private data structures, only the driver knows how to get at all of the napi_struct instances it may have per-device. With lots of help and suggestions from Rusty Russell, Roland Dreier, Michael Chan, Jeff Garzik, and Jamal Hadi Salim. Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra, Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan. [ Ported to current tree and all drivers converted. Integrated Stephen's follow-on kerneldoc additions, and restored poll_list handling to the old style to fix mutual exclusion issues. -DaveM ] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET]: Kill eth_copy_and_sum().David S. Miller
It hasn't "summed" anything in over 7 years, and it's just a straight mempcy ala skb_copy_to_linear_data() so just get rid of it. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-09Fix occurrences of "the the "Michael Opdenacker
Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-28Fix tulip SytemError typoValerie Henson
Fix an annoying typo - SytemError -> SystemError Signed-off-by: Valerie Henson <val_henson@linux.intel.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-11[PATCH] Change tulip maintainerValerie Henson
Signed-off-by: Valerie Henson <val_henson@linux.intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> MAINTAINERS | 4 ++-- drivers/net/tulip/21142.c | 2 +- drivers/net/tulip/eeprom.c | 2 +- drivers/net/tulip/interrupt.c | 2 +- drivers/net/tulip/media.c | 2 +- drivers/net/tulip/pnic.c | 2 +- drivers/net/tulip/pnic2.c | 2 +- drivers/net/tulip/timer.c | 2 +- drivers/net/tulip/tulip_core.c | 2 +- 9 files changed, 10 insertions(+), 10 deletions(-)
2006-05-26[netdrvr] trim trailing whitespace: 8139*.c, epic100, forcedeth, tulip/*Jeff Garzik
2005-06-28[NET]: Remove gratuitous use of skb->tail in network drivers.David S. Miller
Many drivers use skb->tail unnecessarily. In these situations, the code roughly looks like: dev = dev_alloc_skb(...); [optional] skb_reserve(skb, ...); ... skb->tail ... But even if the skb_reserve() happens, skb->data equals skb->tail. So it doesn't make any sense to use anything other than skb->data in these cases. Another case was the s2io.c driver directly mucking with the skb->data and skb->tail pointers. It really just wanted to do an skb_reserve(), so that's what the code was changed to do instead. Another reason I'm making this change as it allows some SKB cleanups I have planned simpler to merge. In those cleanups, skb->head, skb->tail, and skb->end pointers are removed, and replaced with skb->head_room and skb->tail_room integers. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Jeff Garzik <jgarzik@pobox.com>
