[ Upstream commit 15718ea0d844e4816dbd95d57a8a0e3e264ba90e ]
The recent fix d9bf5f1309 "tun: compare with 0 instead of total_len" is
not totally correct. Because "len" and "sizeof()" are size_t type, that
means they are never less than zero.
Acked-by: Michael S. Tsirkin <mst@redhat.com>
[ Upstream commit f8af75f3517a24838a36eb5797a1a3e60bf9e276 ]
Dave reported following crash :
general protection fault: 0000 [#1] SMP
CPU 2
Pid: 25407, comm: qemu-kvm Not tainted 3.7.9-205.fc18.x86_64 #1 Hewlett-Packard HP Z400 Workstation/0B4Ch
RIP: 0010:[<ffffffffa0399bd5>] [<ffffffffa0399bd5>] destroy_conntrack+0x35/0x120 [nf_conntrack]
RSP: 0018:ffff880276913d78 EFLAGS: 00010206
RAX: 50626b6b7876376c RBX: ffff88026e530d68 RCX: ffff88028d158e00
RDX: ffff88026d0d5470 RSI: 0000000000000011 RDI: 0000000000000002
RBP: ffff880276913d88 R08: 0000000000000000 R09: ffff880295002900
R10: 0000000000000000 R11: 0000000000000003 R12: ffffffff81ca3b40
R13: ffffffff8151a8e0 R14: ffff880270875000 R15: 0000000000000002
FS: 00007ff3bce38a00(0000) GS:ffff88029fc40000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00007fd1430bd000 CR3: 000000027042b000 CR4: 00000000000027e0
Process qemu-kvm (pid: 25407, threadinfo ffff880276912000, task ffff88028c369720)
Stack:
ffff880156f59100 ffff880156f59100 ffff880276913d98 ffffffff815534f7
ffff880276913db8 ffffffff8151a74b ffff880270875000 ffff880156f59100
ffff880276913dd8 ffffffff8151a5a6 ffff880276913dd8 ffff88026d0d5470
Call Trace:
[<ffffffff815534f7>] nf_conntrack_destroy+0x17/0x20
[<ffffffff8151a74b>] skb_release_head_state+0x7b/0x100
[<ffffffff8151a5a6>] __kfree_skb+0x16/0xa0
[<ffffffff8151a666>] kfree_skb+0x36/0xa0
[<ffffffff8151a8e0>] skb_queue_purge+0x20/0x40
[<ffffffffa02205f7>] __tun_detach+0x117/0x140 [tun]
[<ffffffffa022184c>] tun_chr_close+0x3c/0xd0 [tun]
[<ffffffff8119669c>] __fput+0xec/0x240
[<ffffffff811967fe>] ____fput+0xe/0x10
[<ffffffff8107eb27>] task_work_run+0xa7/0xe0
[<ffffffff810149e1>] do_notify_resume+0x71/0xb0
[<ffffffff81640152>] int_signal+0x12/0x17
Code: 00 00 04 48 89 e5 41 54 53 48 89 fb 4c 8b a7 e8 00 00 00 0f 85 de 00 00 00 0f b6 73 3e 0f b7 7b 2a e8 10 40 00 00 48 85 c0 74 0e <48> 8b 40 28 48 85 c0 74 05 48 89 df ff d0 48 c7 c7 08 6a 3a a0
RIP [<ffffffffa0399bd5>] destroy_conntrack+0x35/0x120 [nf_conntrack]
RSP <ffff880276913d78>
This is because tun_net_xmit() needs to call nf_reset()
before queuing skb into receive_queue
Reported-by: Dave Jones <davej@redhat.com>
commit 66d1b9263a371abd15806c53f486f0645ef31a8f upstream.
This is a fix for bug, introduced in 3.4 kernel by commit
1ab5ecb90cb6a3df1476e052f76a6e8f6511cb3d ("tun: don't hold network
namespace by tun sockets"), which, among other things, replaced simple
sock_put() by sk_release_kernel(). Below is sequence, which leads to
oops for non-persistent devices:
tun_chr_close()
tun_detach() <== tun->socket.file = NULL
tun_free_netdev()
sk_release_sock()
sock_release(sock->file == NULL)
iput(SOCK_INODE(sock)) <== dereference on NULL pointer
This patch just removes zeroing of socket's file from __tun_detach().
sock_release() will do this.
Reported-by: Ruan Zhijie <ruanzhijie@hotmail.com>
Tested-by: Ruan Zhijie <ruanzhijie@hotmail.com>
Acked-by: Al Viro <viro@ZenIV.linux.org.uk>
Acked-by: Yuchung Cheng <ycheng@google.com>
Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com>
[ Upstream commits a117dacde0288f3ec60b6e5bcedae8fa37ee0dfc
and 8bbb181308bc348e02bfdbebdedd4e4ec9d452ce ]
The tun module leaks up to 36 bytes of memory by not fully initializing
a structure located on the stack that gets copied to user memory by the
TUNGETIFF and SIOCGIFHWADDR ioctl()s.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
commit b09e786bd1dd66418b69348cb110f3a64764626a upstream.
This patch fixes a crash
tun_chr_close -> netdev_run_todo -> tun_free_netdev -> sk_release_kernel ->
sock_release -> iput(SOCK_INODE(sock))
introduced by commit 1ab5ecb90cb6a3df1476e052f76a6e8f6511cb3d
The problem is that this socket is embedded in struct tun_struct, it has
no inode, iput is called on invalid inode, which modifies invalid memory
and optionally causes a crash.
sock_release also decrements sockets_in_use, this causes a bug that
"sockets: used" field in /proc/*/net/sockstat keeps on decreasing when
creating and closing tun devices.
This patch introduces a flag SOCK_EXTERNALLY_ALLOCATED that instructs
sock_release to not free the inode and not decrement sockets_in_use,
fixing both memory corruption and sockets_in_use underflow.
It should be backported to 3.3 an 3.4 stabke.
Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
v3: added previously removed sock_put() to the tun_release() callback, because
sk_release_kernel() doesn't drop the socket reference.
v2: sk_release_kernel() used for socket release. Dummy tun_release() is
required for sk_release_kernel() ---> sock_release() ---> sock->ops->release()
call.
TUN was designed to destroy it's socket on network namesapce shutdown. But this
will never happen for persistent device, because it's socket holds network
namespace.
This patch removes of holding network namespace by TUN socket and replaces it
by creating socket in init_net and then changing it's net it to desired one. On
shutdown socket is moved back to init_net prior to final put.
Replace usage of random_ether_addr() with eth_hw_addr_random()
to set addr_assign_type correctly to NET_ADDR_RANDOM.
Change the trivial cases.
v2: adapt to renamed eth_hw_addr_random()
Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de>
number of drivers
Per discussion with Ben Hutchings and David Miller, go through and
remove assignments of "N/A" to fw_version in various drivers'
.get_drvinfo routines. While there clean-up some use of bare
constants and such.
Signed-off-by: Rick Jones <rick.jones2@hp.com>
v2: add couple missing conversions in drivers
split unexporting netdev_fix_features()
implemented %pNF
convert sock::sk_route_(no?)caps
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Convert some remaining straglers' .get_drvinfo routines to use strlcpy
rather than strcpy/strncpy.
replace it by ndo_set_rx_mode
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
After the last patch, We are left in a state in which only drivers calling
ether_setup have IFF_TX_SKB_SHARING set (we assume that drivers touching real
hardware call ether_setup for their net_devices and don't hold any state in
their skbs. There are a handful of drivers that violate this assumption of
course, and need to be fixed up. This patch identifies those drivers, and marks
them as not being able to support the safe transmission of skbs by clearning the
IFF_TX_SKB_SHARING flag in priv_flags
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Karsten Keil <isdn@linux-pingi.de>
CC: "David S. Miller" <davem@davemloft.net>
CC: Jay Vosburgh <fubar@us.ibm.com>
CC: Andy Gospodarek <andy@greyhouse.net>
CC: Patrick McHardy <kaber@trash.net>
CC: Krzysztof Halasa <khc@pm.waw.pl>
CC: "John W. Linville" <linville@tuxdriver.com>
CC: Greg Kroah-Hartman <gregkh@suse.de>
CC: Marcel Holtmann <marcel@holtmann.org>
CC: Johannes Berg <johannes@sipsolutions.net>
drivers/net/wireless/iwlwifi/iwl-agn-rxon.c
drivers/net/wireless/rtlwifi/pci.c
net/netfilter/ipvs/ip_vs_core.c
Commit 8d8fc29d02a33e4bd5f4fa47823c1fd386346093 changed the behavior of slave
devices in regards to netpoll. Specifically it created a mutually exclusive
relationship between being a slave and a netpoll-capable device. This creates
problems for KVM because guests relied on needing netconsole active on a slave
device to a bridge. Ideally libvirtd could just attach netconsole to the bridge
device instead, but thats currently infeasible, because while the bridge device
supports netpoll, it requires that all slave interface also support it, but the
tun/tap driver currently does not. The most direct solution is to teach tun/tap
to support netpoll, which is implemented by the patch below.
I've not tested this yet, but its pretty straightforward.
Reported-by: Rik van Riel <riel@redhat.com>
CC: Rik van Riel <riel@redhat.com>
CC: Maxim Krasnyansky <maxk@qualcomm.com>
CC: Cong Wang <amwang@redhat.com>
Tested-by: Rik van Riel <riel@redhat.com>
Reviewed-by: WANG Cong <amwang@redhat.com>
Signed-off-by: David S. Miller <davem@conan.davemloft.net>
There's no need for the guest to validate the checksum if it have been
validated by host nics. So this patch introduces a new flag -
VIRTIO_NET_HDR_F_DATA_VALID which is used to bypass the checksum
examing in guest. The backend (tap/macvtap) may set this flag when
met skbs with CHECKSUM_UNNECESSARY to save cpu utilization.
No feature negotiation is needed as old driver just ignore this flag.
Iperf shows 12%-30% performance improvement for UDP traffic. For TCP,
when gro is on no difference as it produces skb with partial
checksum. But when gro is disabled, 20% or even higher improvement
could be measured by netperf.
Signed-off-by: Jason Wang <jasowang@redhat.com>
Perf shows a relatively high rate (about 8%) race in
spin_lock_irqsave() when doing netperf between external host and
guest. It's mainly becuase the lock contention between the
tun_do_read() and tun_xmit_skb(), so this patch do not put self into
waitqueue to reduce this kind of race. After this patch, it drops to
4%.
Signed-off-by: Amos Kong <akong@redhat.com>
Current standard practice is to not mark most functions as inline
and let compiler decide instead.
The tun driver allocates skb's to hold data from user and then passes
the data into the network stack as received data. Most network devices
allocate the receive skb with routines like dev_alloc_skb() that reserves
additional space for use by network protocol stack but tun does not.
Because of the lack of padding, when the packet is passed through bridge
netfilter a new skb has to be allocated.
Semicolons are not necessary after switch/while/for/if braces
so remove them.
Force dev_alloc_name() to be called from register_netdevice() by
dev_get_valid_name(). That allows to remove multiple explicit
dev_alloc_name() calls.
The possibility to call dev_alloc_name in advance remains.
This also fixes veth creation regresion caused by
84c49d8c3e4abefb0a41a77b25aa37ebe8d6b743
This updates the network drivers so that they don't access the
ethtool_cmd::speed field directly, but use ethtool_cmd_speed()
instead.
For most of the drivers, these changes are purely cosmetic and don't
fix any problem, such as for those 1GbE/10GbE drivers that indirectly
call their own ethtool get_settings()/mii_ethtool_gset(). The changes
are meant to enforce code consistency and provide robustness with
future larger throughputs, at the expense of a few CPU cycles for each
ethtool operation.
All drivers compiled with make allyesconfig ion x86_64 have been
updated.
Tested: make allyesconfig on x86_64 + e1000e/bnx2x work
Signed-off-by: David Decotigny <decot@google.com>
This changes offload setting behaviour to what I think is correct:
- offloads set via ethtool mean what admin wants to use (by default
he wants 'em all)
- offloads set via ioctl() mean what userspace is expecting to get
(this limits which admin wishes are granted)
- TUN_NOCHECKSUM is ignored, as it might cause broken packets when
forwarded (ip_summed == CHECKSUM_UNNECESSARY means that checksum
was verified, not that it can be ignored)
If TUN_NOCHECKSUM is implemented, it should set skb->csum_* and
skb->ip_summed (= CHECKSUM_PARTIAL) for known protocols and let others
be verified by kernel when necessary.
TUN_NOCHECKSUM handling was introduced by commit
f43798c27684ab925adde7d8acc34c78c6e50df8:
tun: Allow GSO using virtio_net_hdr
Use the current logging forms with pr_fmt.
Convert DBG macro to tun_debug, use netdev_printk as well.
Add printf verification when TUN_DEBUG not defined.
Miscellaneous comment typo fix.
Quoting Ben Hutchings: we presumably won't be defining features that
can only be enabled on 64-bit architectures.
Occurences found by `grep -r` on net/, drivers/net, include/
[ Move features and vlan_features next to each other in
struct netdev, as per Eric Dumazet's suggestion -DaveM ]
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
Replace skb->csum_start - skb_headroom(skb) with skb_checksum_start_offset().
Note for usb/smsc95xx: skb->data - skb->head == skb_headroom(skb).
"gadget", "through", "command", "maintain", "maintain", "controller", "address",
"between", "initiali[zs]e", "instead", "function", "select", "already",
"equal", "access", "management", "hierarchy", "registration", "interest",
"relative", "memory", "offset", "already",
Currently, only ethtool can get accurate link state of a tap device.
With this patch, IFF_RUNNING and IF_OPER_UP/DOWN are kept up to date as
well.
Signed-off-by: Nolan Leake <nolan@cumulusnetworks.com>
There are still some LRO cards that cause GSO errors in tun,
and BUG on this is an unfriendly way to tell the admin
to disable LRO.
Further, experience shows we might have more GSO bugs lurking.
See https://bugzilla.kernel.org/show_bug.cgi?id=16413
as a recent example.
dumping a packet will make it easier to figure it out.
Replace BUG with warning+dump+drop the packet to make
GSO errors in tun less critical and easier to debug.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Tested-by: Alex Unigovsky <unik@compot.ru>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (63 commits)
drivers/net/usb/asix.c: Fix pointer cast.
be2net: Bug fix to avoid disabling bottom half during firmware upgrade.
proc_dointvec: write a single value
hso: add support for new products
Phonet: fix potential use-after-free in pep_sock_close()
ath9k: remove VEOL support for ad-hoc
ath9k: change beacon allocation to prefer the first beacon slot
sock.h: fix kernel-doc warning
cls_cgroup: Fix build error when built-in
macvlan: do proper cleanup in macvlan_common_newlink() V2
be2net: Bug fix in init code in probe
net/dccp: expansion of error code size
ath9k: Fix rx of mcast/bcast frames in PS mode with auto sleep
wireless: fix sta_info.h kernel-doc warnings
wireless: fix mac80211.h kernel-doc warnings
iwlwifi: testing the wrong variable in iwl_add_bssid_station()
ath9k_htc: rare leak in ath9k_hif_usb_alloc_tx_urbs()
ath9k_htc: dereferencing before check in hif_usb_tx_cb()
rt2x00: Fix rt2800usb TX descriptor writing.
rt2x00: Fix failed SLEEP->AWAKE and AWAKE->SLEEP transitions.
This adds:
alias: devname:<name>
to some common kernel modules, which will allow the on-demand loading
of the kernel module when the device node is accessed.
Ideally all these modules would be compiled-in, but distros seems too
much in love with their modularization that we need to cover the common
cases with this new facility. It will allow us to remove a bunch of pretty
useless init scripts and modprobes from init scripts.
The static device node aliases will be carried in the module itself. The
program depmod will extract this information to a file in the module directory:
$ cat /lib/modules/2.6.34-00650-g537b60d-dirty/modules.devname
# Device nodes to trigger on-demand module loading.
microcode cpu/microcode c10:184
fuse fuse c10:229
ppp_generic ppp c108:0
tun net/tun c10:200
dm_mod mapper/control c10:235
Udev will pick up the depmod created file on startup and create all the
static device nodes which the kernel modules specify, so that these modules
get automatically loaded when the device node is accessed:
$ /sbin/udevd --debug
static_dev_create_from_modules: mknod '/dev/cpu/microcode' c10:184
static_dev_create_from_modules: mknod '/dev/fuse' c10:229
static_dev_create_from_modules: mknod '/dev/ppp' c108:0
static_dev_create_from_modules: mknod '/dev/net/tun' c10:200
static_dev_create_from_modules: mknod '/dev/mapper/control' c10:235
udev_rules_apply_static_dev_perms: chmod '/dev/net/tun' 0666
udev_rules_apply_static_dev_perms: chmod '/dev/fuse' 0666
A few device nodes are switched to statically allocated numbers, to allow
the static nodes to work. This might also useful for systems which still run
a plain static /dev, which is completely unsafe to use with any dynamic minor
numbers.
Note:
The devname aliases must be limited to the *common* and *single*instance*
device nodes, like the misc devices, and never be used for conceptually limited
systems like the loop devices, which should rather get fixed properly and get a
control node for losetup to talk to, instead of creating a random number of
device nodes in advance, regardless if they are ever used.
This facility is to hide the mess distros are creating with too modualized
kernels, and just to hide that these modules are not compiled-in, and not to
paper-over broken concepts. Thanks! :)
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Alasdair G Kergon <agk@redhat.com>
Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk>
Cc: Ian Kent <raven@themaw.net>
Signed-Off-By: Kay Sievers <kay.sievers@vrfy.org>
This patch makes tun update its socket classid every time we
inject a packet into the network stack. This is so that any
updates made by the admin to the process writing packets to
tun is effected.
switch and while statements don't need semicolons at end of statement
[ Fixup minor conflicts with recent wimax merge... -DaveM ]
This patch removes from drivers/net/ all the unnecessary
return; statements that precede the last closing brace of
void functions.
It does not remove the returns that are immediately
preceded by a label as gcc doesn't like that.
It also does not remove null void functions with return.
Done via:
$ grep -rP --include=*.[ch] -l "return;\n}" net/ | \
xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }'
with some cleanups by hand.
Compile tested x86 allmodconfig only.
Now that core network takes care of trans_start updates, dont do it
in drivers themselves, if possible. Drivers can avoid one cache miss
(on dev->trans_start) in their start_xmit() handler.
Exceptions are NETIF_F_LLTX drivers
virtio added mergeable buffers mode where 2 bytes of extra info is put
after vnet header but before actual data (tun does not need this data).
In hindsight, it would have been better to add the new info *before* the
packet: as it is, users need a lot of tricky code to skip the extra 2
bytes in the middle of the iovec, and in fact applications seem to get
it wrong, and only work with specific iovec layout. The fact we might
need to split iovec also means we might in theory overflow iovec max
size.
This patch adds a simpler way for applications to handle this,
and future proofs the interface against further extensions,
by making the size of the virtio net header configurable
from userspace. As a result, tun driver will simply
skip the extra 2 bytes on both input and output.
sk_callback_lock rwlock actually protects sk->sk_sleep pointer, so we
need two atomic operations (and associated dirtying) per incoming
packet.
RCU conversion is pretty much needed :
1) Add a new structure, called "struct socket_wq" to hold all fields
that will need rcu_read_lock() protection (currently: a
wait_queue_head_t and a struct fasync_struct pointer).
[Future patch will add a list anchor for wakeup coalescing]
2) Attach one of such structure to each "struct socket" created in
sock_alloc_inode().
3) Respect RCU grace period when freeing a "struct socket_wq"
4) Change sk_sleep pointer in "struct sock" by sk_wq, pointer to "struct
socket_wq"
5) Change sk_sleep() function to use new sk->sk_wq instead of
sk->sk_sleep
6) Change sk_has_sleeper() to wq_has_sleeper() that must be used inside
a rcu_read_lock() section.
7) Change all sk_has_sleeper() callers to :
- Use rcu_read_lock() instead of read_lock(&sk->sk_callback_lock)
- Use wq_has_sleeper() to eventually wakeup tasks.
- Use rcu_read_unlock() instead of read_unlock(&sk->sk_callback_lock)
8) sock_wake_async() is modified to use rcu protection as well.
9) Exceptions :
macvtap, drivers/net/tun.c, af_unix use integrated "struct socket_wq"
instead of dynamically allocated ones. They dont need rcu freeing.
Some cleanups or followups are probably needed, (possible
sk_callback_lock conversion to a spinlock for example...).
Define a new function to return the waitqueue of a "struct sock".
static inline wait_queue_head_t *sk_sleep(struct sock *sk)
return sk->sk_sleep;
Change all read occurrences of sk_sleep by a call to this function.
Needed for a future RCU conversion. sk_sleep wont be a field directly
available.
The following situation was observed in the field:
tap1 sends packets, tap2 does not consume them, as a result
tap1 can not be closed. This happens because
tun/tap devices can hang on to skbs undefinitely.
As noted by Herbert, possible solutions include a timeout followed by a
copy/change of ownership of the skb, or always copying/changing
ownership if we're going into a hostile device.
This patch implements the second approach.
Note: one issue still remaining is that since skbs
keep reference to tun socket and tun socket has a
reference to tun device, we won't flush backlog,
instead simply waiting for all skbs to get transmitted.
At least this is not user-triggerable, and
this was not reported in practice, my assumption is
other devices besides tap complete an skb
within finite time after it has been queued.
A possible solution for the second issue
would not to have socket reference the device,
instead, implement dev->destructor for tun, and
wait for all skbs to complete there, but this
needs some thought, probably too risky for 2.6.34.
Tested-by: Yan Vugenfirer <yvugenfi@redhat.com>
Documentation/filesystems/proc.txt
arch/arm/mach-u300/include/mach/debug-macro.S
drivers/net/qlge/qlge_ethtool.c
drivers/net/qlge/qlge_main.c
drivers/net/typhoon.c
This patch adds Linux Socket Filter support to
tun driver.
In particular, several occurances of funny versions of 'success',
'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address',
'beginning', 'desirable', 'separate' and 'necessary' are fixed.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Joe Perches <joe@perches.com>
Cc: Junio C Hamano <gitster@pobox.com>
Tun device looks similar to a packet socket
in that both pass complete frames from/to userspace.
This patch fills in enough fields in the socket underlying tun driver
to support sendmsg/recvmsg operations, and message flags
MSG_TRUNC and MSG_DONTWAIT, and exports access to this socket
to modules. Regular read/write behaviour is unchanged.
This way, code using raw sockets to inject packets
into a physical device, can support injecting
packets into host network stack almost without modification.
First user of this interface will be vhost virtualization
accelerator.
Using macro tun_sk is more clear and shorter. However tun.c has tun_sk,
but doesn't use it.
Signed-off-by: Vitaliy Gusev <vgusev@openvz.org>
The tun driver is the only code in the kernel that operates
on a character device with struct ifreq. Change the driver
to handle the conversion itself so we can contain the
remaining ifreq handling in the socket layer.
This also fixes a bug in the handling of invalid ioctl
numbers on an unbound tun device. The driver treats this
as a TUNSETIFF in native mode, but there is no way for
the generic compat_ioctl() function to emulate this
behaviour. Possibly the driver was only doing this
accidentally anyway, but if any code relies on this
misfeature, it now also works in compat mode.
The lock_kernel/unlock_kernel() in cycle_kernel_lock() which is called
in tun_chr_open() is not serializing against anything and safe to
remove.
tun_chr_fasync() is serialized by get/put_tun() and fasync_helper()
has no dependency on BKL. The modification of tun->flags is racy with
and without the BKL so removing it does not make it worse.
drivers/staging/Kconfig
drivers/staging/Makefile
drivers/staging/cpc-usb/TODO
drivers/staging/cpc-usb/cpc-usb_drv.c
drivers/staging/cpc-usb/cpc.h
drivers/staging/cpc-usb/cpc_int.h
drivers/staging/cpc-usb/cpcusb.h
After commit 2b980dbd77d229eb60588802162c9659726b11f4
("lsm: Add hooks to the TUN driver") tun_set_iff doesn't
return -EINVAL though neither IFF_TUN nor IFF_TAP is set.
Signed-off-by: Kusanagi Kouichi <slash@ma.neweb.ne.jp>
Reviewed-by: Paul Moore <paul.moore@hp.com>
