kaweth_control() never frees the buffer that it allocates for the USB
control message. Test case:
while :; do ifconfig eth2 down ; ifconfig eth2 up ; done
This is a tiny buffer so it is a slow leak. If you want to speed up the
process, you can change the allocation size to e.g. 16384 bytes, and it
will consume several megabytes within a few minutes.
Signed-off-by: Kevin Cernekee <cernekee@gmail.com>
Acked-by: Oliver Neukum <oliver@neukum.org>
No need to put ethtool_ops in data, they should be const.
drivers/net/wireless/orinoco/main.c
alloc_etherdev() used to install a default implementation of this
operation, but it must now be explicitly installed in struct
net_device_ops.
alloc_etherdev() used to install default implementations of these
operations, but they must now be explicitly installed in struct
net_device_ops.
This patch is the result of an automatic spatch transformation to convert
all ndo_start_xmit() return values of 0 to NETDEV_TX_OK.
Some occurences are missed by the automatic conversion, those will be
handled in a seperate patch.
The driver kaweth yields a -EBUSY error when starting, and a -ETIME
error when shutting down. These errors are avoided, and the RX status
is further checked for other potential errors.
On an SMP system, the following message is printed. The patch below gets
fixes the problem.
[ INFO: inconsistent lock state ]
2.6.29-Linus-05093-gc31f403 #57
inconsistent {hardirq-on-W} -> {in-hardirq-W} usage.
bash/4105 [HC1[1]:SC0[0]:HE0:SE1] takes:
(&kaweth->device_lock){+...}, at: [<ffffffffa01aa286>]
kaweth_usb_receive+0x77/0x1af [kaw eth]
{hardirq-on-W} state was registered at:
[<ffffffff80260503>] __lock_acquire+0x753/0x1685
[<ffffffff8026148a>] lock_acquire+0x55/0x71
[<ffffffff80461ba6>] _spin_lock+0x31/0x3d
[<ffffffffa01aaa0c>] kaweth_start_xmit+0x2b/0x1e1 [kaweth]
[<ffffffff803eccd3>] dev_hard_start_xmit+0x22e/0x2ad
[<ffffffff803fe120>] __qdisc_run+0xf2/0x203
[<ffffffff803ed0cd>] dev_queue_xmit+0x263/0x39b
[<ffffffffa03a47cb>] packet_sendmsg_spkt+0x1c4/0x20a [af_packet]
[<ffffffff803de0c2>] sock_sendmsg+0xe4/0xfd
[<ffffffff803dec8f>] sys_sendto+0xe4/0x10c
[<ffffffff8020bccb>] system_call_fastpath+0x16/0x1b
[<ffffffffffffffff>] 0xffffffffffffffff
irq event stamp: 1280
hardirqs last enabled at (1279): [<ffffffff80461a71>]
_spin_unlock_irqrestore+0x44/0x4c
hardirqs last disabled at (1280): [<ffffffff8020bad7>]
save_args+0x67/0x70
softirqs last enabled at (660): [<ffffffff8024192c>]
__do_softirq+0x14d/0x15d
softirqs last disabled at (651): [<ffffffff8020ce9c>]
call_softirq+0x1c/0x28
This converts the kaweth ethernet USB driver to netdevops.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
There's no need to take the address of the function params or local variables
when the direct value byteswapping routines are available.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
USB is going to switch the signature of the callbacks to
void callback(struct urb *urb, int status)
This patch will ease the transition.
USB should not be having it's own printk macros, so remove info() and
use the system-wide standard of dev_info() wherever possible.
Cc: Jeff Garzik <jgarzik@pobox.com>
USB should not be having it's own printk macros, so remove warn() and
use the system-wide standard of dev_warn() wherever possible. In the
few places that will not work out, use a basic printk().
If the RTNL is held when we invoke flush_scheduled_work() we could
deadlock. One such case is linkwatch, it is a work struct which tries
to grab the RTNL semaphore.
The most common case are net driver ->stop() methods. The
simplest conversion is to instead use cancel_{delayed_}work_sync()
explicitly on the various work struct the driver uses.
This is an OK transformation because these work structs are doing
things like resetting the chip, restarting link negotiation, and so
forth. And if we're bringing down the device, we're about to turn the
chip off and reset it anways. So if we cancel a pending work event,
that's fine here.
Some drivers were working around this deadlock by using a msleep()
polling loop of some sort, and those cases are converted to instead
use cancel_{delayed_}work_sync() as well.
None of these files use any of the functionality promised by
asm/semaphore.h. It's possible that they rely on it dragging in some
unrelated header file, but I can't build all these files, so we'll have
fix any build failures as they come up.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Back in 2.6.12-pre, usb_start_wait_urb was switched over to take
milliseconds instead of jiffies. kaweth.c was never updated to match.
Signed-off-by: Russ Dill <Russ.Dill@asu.edu>
It's been a useless no-op for long enough in 2.6 so I figured it's time to
remove it. The number of people that could object because they're
maintaining unified 2.4 and 2.6 drivers is probably rather small.
[ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ]
Signed-off-by: Jeff Garzik <jeff@garzik.org>
It hasn't "summed" anything in over 7 years, and it's
just a straight mempcy ala skb_copy_to_linear_data()
so just get rid of it.
It is preferable to group drivers by usage (net, scsi, ATA, ...) than
by bus. When reviewing drivers, the [PCI|USB|PCMCIA|...] maintainer
is probably less qualified on networking issues than a networking
maintainer. Also, from a practical standpoint, chips often
appear on multiple buses, which is why we do not put drivers into
drivers/pci/net.
