This converts the drivers in drivers/net/* to use the
module_usb_driver() macro which makes the code smaller and a bit
simpler.
Added bonus is that it removes some unneeded kernel log messages about
drivers loading and/or unloading.
Cc: Wolfgang Grandegger <wg@grandegger.com>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: Oliver Neukum <oliver@neukum.name>
Cc: Peter Korsgaard <jacmet@sunsite.dk>
Cc: Petko Manolov <petkan@users.sourceforge.net>
Cc: Steve Glendinning <steve.glendinning@smsc.com>
Cc: Christian Lamparter <chunkeey@googlemail.com>
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: Dan Williams <dcbw@redhat.com>
Cc: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Cc: Ivo van Doorn <IvDoorn@gmail.com>
Cc: Gertjan van Wingerde <gwingerde@gmail.com>
Cc: Helmut Schaa <helmut.schaa@googlemail.com>
Cc: Herton Ronaldo Krzesinski <herton@canonical.com>
Cc: Hin-Tak Leung <htl10@users.sourceforge.net>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: Chaoming Li <chaoming_li@realsil.com.cn>
Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi>
Cc: Roel Kluin <roel.kluin@gmail.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Jiri Pirko <jpirko@redhat.com>
Cc: Pavel Roskin <proski@gnu.org>
Cc: Yoann DI-RUZZA <y.diruzza@lim.eu>
Cc: George <george0505@realtek.com>
My changes in commit 4d42d417be75d750b82798922b6e775915e11bce were
written some time before the introduction of FLAG_POINTTOPOINT, so
didn't include that flag in the new driver_info. Change the new
driver_info to be consistent.
Some RNDIS devices don't respond on the control channel until polled
on the status channel. In particular, this was reported to be the
case for the 2Wire HomePortal 1000SW and for some Windows Mobile
devices.
This is roughly based on a patch by John Carr <john.carr@unrouted.co.uk>
which is currently applied by Mandriva.
Reported-by: Mark Glassberg <vzeeaxwl@myfairpoint.net>
The documentation for the USB ethernet devices suggests that
only some devices are supposed to use usb0 as the network interface
name instead of eth0. The logic used there, and documented in
Kconfig for CDC is that eth0 will be used when the mac address
is a globally assigned one, but usb0 is used for the locally
managed range that is typically used on point-to-point links.
Unfortunately, this has caused a lot of pain on the smsc95xx
device that is used on the popular pandaboard without an
EEPROM to store the MAC address, which causes the driver to
call random_ether_address().
Obviously, there should be a proper MAC addressed assigned to
the device, and discussions are ongoing about how to solve
this, but this patch at least makes sure that the default
interface naming gets a little saner and matches what the
user can expect based on the documentation, including for
new devices.
The approach taken here is to flag whether a device might be a
point-to-point link with the new FLAG_POINTTOPOINT setting in
the usbnet driver_info. A driver can set both FLAG_POINTTOPOINT
and FLAG_ETHER if it is not sure (e.g. cdc_ether), or just one
of the two. The usbnet framework only looks at the MAC address
for device naming if both flags are set, otherwise it trusts the
flag.
Signed-off-by: Arnd Bergmann <arnd.bergmann@linaro.org>
Tested-by: Andy Green <andy.green@linaro.org>
This reverts commit c17b274dc2aa538b68c1f02b01a3c4e124b435ba.
That change was reported to break rndis_wlan support for the WUSB54GS.
Reported-by: Luís Picciochi Oliveira <pitxyoki@gmail.com>
case for the 2Wire HomePortal 1000SW.
which is reported to be needed for use with some Windows Mobile devices
and which is currently applied by Mandriva.
Tested-by: Mark Glassberg <vzeeaxwl@myfairpoint.net>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Convert from:
if (netif_msg_<foo>(priv))
dev_<level>(dev...
to
netif_<level>(priv, foo, dev...
Also convert a few:
if (i < REG_TIMEOUT) {
etc...
return ret;
to
if (i >= REG_TIMEOUT)
goto fail;
etc...
return ret;
These macros are too similar to the dev_<level> equivalents
but take a usbnet * argument. Convert them to the recently
introduced netdev_<level> macros and remove the old macros.
The old macros had "\n" appended to the format string.
Add the "\n" to the converted uses.
Some existing uses of the dev<foo> macros in cdc_eem.c
probably mistakenly had trailing "\n". No "\n" added there.
Fix net1080 this/other log message inversion.
Only files where David Miller is the primary git-signer.
wireless, wimax, ixgbe, etc are not modified.
Compile tested x86 allyesconfig only
Not all files compiled (not x86 compatible)
Added a few > 80 column lines, which I ignored.
Existing checkpatch complaints ignored.
The MTU throttle-down if a RNDIS device doesn't support a particular
packet size is being incorrectly logged. The attempted packet size is
being clobbered before it gets logged.
First patch; please inform if I'm doing this incorrectly. Diff'd
against latest official source as per the FAQ; forward port to current
git version is straightforward.
Signed-off-by: George Nassar <george.nassar@gmail.com>
Allow rndis_wlan to see all indications. Currently rndis_host lets rndis_wlan to
know about link state changes only, but there is whole set of other
802.11-specific indications that rndis_wlan should handle properly. So rename
link_change() to indication() and convert rndis_wlan to use it.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Now that netdev has its own stats structure we should use that
instead.
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Use cpu_to_le32 directly as it handles constant folding now, replace direct
uses of __constant_cpu_to_{endian} as well.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
This patch allows Windows Mobile 6 devices to be used for
tethering -- that is, used as modems. It was requested by
AdamW in kernel bugzilla:
http://bugzilla.kernel.org/show_bug.cgi?id=11119
and Mandriva kernel-discuss list. It is tested and confirmed
to work by Peterl:
http://forum.eeeuser.com/viewtopic.php?pid=323543#p323543
This patch is based on the patch in the above kernel bugzilla,
which is from the usb-rndis-lite tree.
[ dbrownell@users.sourceforge.net: misc fixes ]
Signed-off-by: Thomas Backlund <tmb@mandriva.org>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Pass buffer length to rndis_command so that rndis_command can read full
response buffer from device instead of max CONTROL_BUFFER_SIZE bytes.
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
Some devices running some WinCE firmware (with SC_* Samsung processors
according to the SynCE project, verified on a HTC P3600 device) fail to
register because they apparently need extra time to respond correctly to
requests. Increase the existing delay to satisfy them. Based on code
from the SynCE project, on a suggestion of David Brownell.
This patch Works For Me(tm).
Signed-off-by: Pierre Ynard <linkfanel@yahoo.fr>
Acked-by: David Brownell <david-b@pacbell.net>
Cc: Greg KH <greg@kroah.com>
Cc: Jeff Garzik <jeff@garzik.org>
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6
drivers/net/usb/rndis_host.c
drivers/net/wireless/b43/dma.c
net/ipv6/ndisc.c
Signed-off-by: Jeff Garzik <jeff@garzik.org>
When query for OID_GEN_PHYSICAL_MEDIUM fails, uninitialized pointer
'phym' is being accessed in generic_rndis_bind(), resulting OOPS.
Patch fixes phym to be initialized and setup correctly when
rndis_query() for physical medium fails.
Bug was introduced by following commit:
commit 039ee17d1baabaa21783a0d5ab3e8c6d8c794bdf
Author: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Date: Sun Jan 27 23:34:33 2008 +0200
Reported-by: Dmitri Monakhov <dmonakhov@openvz.org>
This patch should resolve a problem that's troubled support for
some RNDIS peripherals. It seems to have boiled down to using a
variable to establish transfer size limits before it was assigned,
which caused those devices to fallback to a default "jumbogram"
mode we don't support. Fix by assigning it earlier for RNDIS.
Signed-off-by: Jean-Christophe Dubois <jcd@tribudubois.net>
[ cleanups ]
Move headers usbnet.h and rndis_host.h to include/linux/usb and fix includes
for drivers/net/usb modules. Headers are moved because rndis_wlan will be
outside drivers/net/usb in drivers/net/wireless and yet need these headers.
Add RNDIS physical medium checking into generic_rndis_bind() and also make
rndis_host to be only bind on every medium except wireless.
Callback to signal link state changes from minidriver to
'subminidrivers'.
Function pointer is for 'subminidrivers' that need to do work on device
right after minidriver has initialized hardware.
For example, rndis_wlan setting device specific configuration parameters
with OID_GEN_RNDIS_CONFIG_PARAMETER right after rndis_host has
initialized hardware with RNDIS_INIT.
Export rndis_host functions and also rename rndis_bind() to
generic_rndis_bind() for modules using rndis_host as base.
Split up rndis_host.c into rndis_host.h and rndis_base.c. This is done so
that rndis_wlan can reuse common parts with rndis_host.
RNDIS packet filter flags are not exactly the same as CDC flags
so we cannot reuse them.
Signed-off-by: Bjorge Dijkstra <bjd@jooz.net>
When bind fails after device was initialized, shutdown device properly
by sending RNDIS_MSG_HALT.
rndis_command requires the caller to pass in a buffer of at least 1KB.
rndis_unbind and usbnet_cdc_unbind don't return anything.
packet size
This patch makes the host RNDIS driver talk to RNDIS devices with an MTU
less than 1.5k, instead of refusing to talk to such a device.
Signed-Off-by: Thomas Sailer <t.sailer@alumni.ethz.ch>
Hi Jeff,
are you the right person to send this to?
Nobody else seems to be wanting to forward this to Linus...
Thanks,
Tom
Workaround another device firmware bug, wherein CDC descriptors get
placed in a wrong place never previously observed in the wild.
Fix a bug where a seeming RNDIS device returns a bogus response during
device initialization.
It is preferable to group drivers by usage (net, scsi, ATA, ...) than
by bus. When reviewing drivers, the [PCI|USB|PCMCIA|...] maintainer
is probably less qualified on networking issues than a networking
maintainer. Also, from a practical standpoint, chips often
appear on multiple buses, which is why we do not put drivers into
drivers/pci/net.
