Commit 4231d47e6fe69f061f96c98c30eaf9fb4c14b96d(net/usbnet: avoid
recursive locking in usbnet_stop()) fixes the recursive locking
problem by releasing the skb queue lock before unlink, but may
cause skb traversing races:
- after URB is unlinked and the queue lock is released,
the refered skb and skb->next may be moved to done queue,
even be released
- in skb_queue_walk_safe, the next skb is still obtained
by next pointer of the last skb
- so maybe trigger oops or other problems
This patch extends the usage of entry->state to describe 'start_unlink'
state, so always holding the queue(rx/tx) lock to change the state if
the referd skb is in rx or tx queue because we need to know if the
refered urb has been started unlinking in unlink_urbs.
The other part of this patch is based on Huajun's patch:
always traverse from head of the tx/rx queue to get skb which is
to be unlinked but not been started unlinking.
Signed-off-by: Huajun Li <huajun.li.lee@gmail.com>
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Cc: Oliver Neukum <oneukum@suse.de>
Cc: stable@kernel.org
(cherry picked from commit 5b6e9bcdeb65634b4ad604eb4536404bbfc62cfa)
Bug 1040642
Change-Id: I1a8c248016529bebf71d540738ad4726cf3f59b7
Signed-off-by: Steve Lin <stlin@nvidia.com>
Reviewed-on: http://git-master/r/128693
GVS: Gerrit_Virtual_Submit
|kernel BUG at kernel/rtmutex.c:724!
|[<c029599c>] (rt_spin_lock_slowlock+0x108/0x2bc) from [<c01c2330>] (defer_bh+0x1c/0xb4)
|[<c01c2330>] (defer_bh+0x1c/0xb4) from [<c01c3afc>] (rx_complete+0x14c/0x194)
|[<c01c3afc>] (rx_complete+0x14c/0x194) from [<c01cac88>] (usb_hcd_giveback_urb+0xa0/0xf0)
|[<c01cac88>] (usb_hcd_giveback_urb+0xa0/0xf0) from [<c01e1ff4>] (musb_giveback+0x34/0x40)
|[<c01e1ff4>] (musb_giveback+0x34/0x40) from [<c01e2b1c>] (musb_advance_schedule+0xb4/0x1c0)
|[<c01e2b1c>] (musb_advance_schedule+0xb4/0x1c0) from [<c01e2ca8>] (musb_cleanup_urb.isra.9+0x80/0x8c)
|[<c01e2ca8>] (musb_cleanup_urb.isra.9+0x80/0x8c) from [<c01e2ed0>] (musb_urb_dequeue+0xec/0x108)
|[<c01e2ed0>] (musb_urb_dequeue+0xec/0x108) from [<c01cbb90>] (unlink1+0xbc/0xcc)
|[<c01cbb90>] (unlink1+0xbc/0xcc) from [<c01cc2ec>] (usb_hcd_unlink_urb+0x54/0xa8)
|[<c01cc2ec>] (usb_hcd_unlink_urb+0x54/0xa8) from [<c01c2a84>] (unlink_urbs.isra.17+0x2c/0x58)
|[<c01c2a84>] (unlink_urbs.isra.17+0x2c/0x58) from [<c01c2b44>] (usbnet_terminate_urbs+0x94/0x10c)
|[<c01c2b44>] (usbnet_terminate_urbs+0x94/0x10c) from [<c01c2d68>] (usbnet_stop+0x100/0x15c)
|[<c01c2d68>] (usbnet_stop+0x100/0x15c) from [<c020f718>] (__dev_close_many+0x94/0xc8)
defer_bh() takes the lock which is hold during unlink_urbs(). The safe
walk suggest that the skb will be removed from the list and this is done
by defer_bh() so it seems to be okay to drop the lock here.
Reported-by: AnÃbal Almeida Pinto <anibal.pinto@efacec.com>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Acked-by: Oliver Neukum <oliver@neukum.org>
(cherry picked from commit 4231d47e6fe69f061f96c98c30eaf9fb4c14b96d)
net/usbnet: reserve headroom on rx skbs
network drivers should reserve some headroom on incoming skbs so that we
dont need expensive reallocations, eg forwarding packets in tunnels.
This NET_SKB_PAD padding is done in various helpers, like
__netdev_alloc_skb_ip_align() in this patch, combining NET_SKB_PAD and
NET_IP_ALIGN magic.
Acked-by: Oliver Neukum <oneukum@suse.de>
(cherry picked from commit 7bdd402706cf26bfef9050dfee3f229b7f33ee4f)
usbnet: use netif_tx_wake_queue instead of netif_start_queue
If host is going to autosuspend function with two interfaces and
if IP packet has arrived in-between of two usbnet_suspend() callbacks,
i.e usbnet_resume() is called in-between, tx data flow is stopped.
When autosuspend timer expires and device is put to autosuspend
again, tx queue is waked up and data can be sent again.
This behavior might be repeated several times in a row.
Tested on Intel/ARM.
Reviewed-by: Sjur Brændeland <sjur.brandeland@stericsson.com>
Tested-by: Dmitry Tarnyagin <dmitry.tarnyagin@stericsson.com>
Signed-off-by: Alexey Orishko <alexey.orishko@stericsson.com>
(cherry picked from commit 1aa9bc5b2f4cf8c48944fb9a607bf1dd674e2c10)
usbnet: increase URB reference count before usb_unlink_urb
problem by releasing the skb queue lock, but it makes usb_unlink_urb
racing with defer_bh, and the URB to being unlinked may be freed before
or during calling usb_unlink_urb, so use-after-free problem may be
triggerd inside usb_unlink_urb.
The patch fixes the use-after-free problem by increasing URB
reference count with skb queue lock held before calling
usb_unlink_urb, so the URB won't be freed until return from
usb_unlink_urb.
Reported-by: Dave Jones <davej@redhat.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
(cherry picked from commit 0956a8c20b23d429e79ff86d4325583fc06f9eb4)
usbnet: don't clear urb->dev in tx_complete
URB unlinking is always racing with its completion and tx_complete
may be called before or during running usb_unlink_urb, so tx_complete
must not clear urb->dev since it will be used in unlink path,
otherwise invalid memory accesses or usb device leak may be caused
(cherry picked from commit 5d5440a835710d09f0ef18da5000541ec98b537a)
usbnet: consider device busy at each recieved packet
usbnet should centrally handle busy reporting in the rx path
so subdrivers need not worry. This hurts use cases which do
rx only or predominantly.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
(cherry picked from commit 8a78335442cea429afb2b964318b6e257448ea00)
usbnet: fix leak of transfer buffer of dev->interrupt
The transfer buffer of dev->interrupt is allocated in .probe path,
but not freed in .disconnet path, so mark the interrupt URB as
URB_FREE_BUFFER to free the buffer when the URB is destroyed.
(cherry picked from commit 267a83e8e00dc5a878b24c39883643c20a8b1482)
Bug 1036768
Change-Id: I5d6620c8ff4e6cef52c3f467fb2196658c4d47b1
Reviewed-on: http://git-master/r/125338
Adding FLAG_RMNET to change ncm net device name
for Ericsson modem.
Bug 901367
Change-Id: I4a029cc10a02176035319ed4ac1e7b9af349cbd1
Reviewed-on: http://git-master/r/74912
Reviewed-by: WK Tsai <wtsai@nvidia.com>
Reviewed-by: Steve Lin <stlin@nvidia.com>
Signed-off-by: BH Hsieh <bhsieh@nvidia.com>
Reviewed-on: http://git-master/r/76459
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
b43: fix comment typo reqest -> request
Haavard Skinnemoen has left Atmel
cris: typo in mach-fs Makefile
Kconfig: fix copy/paste-ism for dell-wmi-aio driver
doc: timers-howto: fix a typo ("unsgined")
perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c
md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course').
treewide: fix a few typos in comments
regulator: change debug statement be consistent with the style of the rest
Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations"
audit: acquire creds selectively to reduce atomic op overhead
rtlwifi: don't touch with treewide double semicolon removal
treewide: cleanup continuations and remove logging message whitespace
ath9k_hw: don't touch with treewide double semicolon removal
include/linux/leds-regulator.h: fix syntax in example code
tty: fix typo in descripton of tty_termios_encode_baud_rate
xtensa: remove obsolete BKL kernel option from defconfig
m68k: fix comment typo 'occcured'
arch:Kconfig.locks Remove unused config option.
treewide: remove extra semicolons
- kenrel -> kernel
- whetehr -> whether
- ttt -> tt
- sss -> ss
drivers/net/tg3.c
This patch makes use of the EVENT_DEV_OPEN flag introduced recently to
fix one out of memory issue, which can be reproduced on omap3/4 based
pandaboard/beagle XM easily with steps below:
- enable runtime pm
echo auto > /sys/devices/platform/usbhs-omap.0/ehci-omap.0/usb1/1-1/1-1.1/power/control
- ifconfig eth0 up
- then out of memroy happened, see [1] for kernel message.
Follows my analysis:
- 'ifconfig eth0 up' brings eth0 out of suspend, and usbnet_resume
is called to schedule dev->bh, then rx urbs are submited to prepare for
recieving data;
- some usbnet devices will produce garbage rx packets flood if
info->reset is not called in usbnet_open.
- so there is no enough chances for usbnet_bh to handle and release
recieved skb buffers since many rx interrupts consumes cpu, so out of memory
for atomic allocation in rx_submit happened.
This patch fixes the issue by simply not allowing schedule of usbnet_bh until device
is opened.
[1], dmesg
[ 234.712005] smsc95xx 1-1.1:1.0: rpm_resume flags 0x4
[ 234.712066] usb 1-1.1: rpm_resume flags 0x0
[ 234.712066] usb 1-1: rpm_resume flags 0x0
[ 234.712097] usb usb1: rpm_resume flags 0x0
[ 234.712127] usb usb1: usb auto-resume
[ 234.712158] ehci-omap ehci-omap.0: resume root hub
[ 234.754028] hub 1-0:1.0: hub_resume
[ 234.754821] hub 1-0:1.0: port 1: status 0507 change 0000
[ 234.756011] hub 1-0:1.0: state 7 ports 3 chg 0000 evt 0000
[ 234.756042] hub 1-0:1.0: rpm_resume flags 0x4
[ 234.756072] usb usb1: rpm_resume flags 0x0
[ 234.756164] usb usb1: rpm_resume returns 1
[ 234.756195] hub 1-0:1.0: rpm_resume returns 0
[ 234.756195] hub 1-0:1.0: rpm_suspend flags 0x4
[ 234.756225] hub 1-0:1.0: rpm_suspend returns 0
[ 234.756256] usb usb1: rpm_resume returns 0
[ 234.757141] usb 1-1: usb auto-resume
[ 234.793151] ehci-omap ehci-omap.0: GetStatus port:1 status 001005 0 ACK POWER sig=se0 PE CONNECT
[ 234.816558] usb 1-1: finish resume
[ 234.817871] hub 1-1:1.0: hub_resume
[ 234.818420] hub 1-1:1.0: port 1: status 0507 change 0000
[ 234.820495] ehci-omap ehci-omap.0: reused qh eec50220 schedule
[ 234.820495] usb 1-1: link qh256-0001/eec50220 start 1 [1/0 us]
[ 234.820587] usb 1-1: rpm_resume returns 0
[ 234.820800] hub 1-1:1.0: state 7 ports 5 chg 0000 evt 0000
[ 234.820800] hub 1-1:1.0: rpm_resume flags 0x4
[ 234.820831] hub 1-1:1.0: rpm_resume returns 0
[ 234.820861] hub 1-1:1.0: rpm_suspend flags 0x4
[ 234.820861] hub 1-1:1.0: rpm_suspend returns 0
[ 234.821777] usb 1-1.1: usb auto-resume
[ 234.868591] hub 1-1:1.0: state 7 ports 5 chg 0000 evt 0002
[ 234.868591] hub 1-1:1.0: rpm_resume flags 0x4
[ 234.868621] hub 1-1:1.0: rpm_resume returns 0
[ 234.868652] hub 1-1:1.0: rpm_suspend flags 0x4
[ 234.868652] hub 1-1:1.0: rpm_suspend returns 0
[ 234.879486] usb 1-1.1: finish resume
[ 234.880279] usb 1-1.1: rpm_resume returns 0
[ 234.880310] smsc95xx 1-1.1:1.0: rpm_resume returns 0
[ 238.880187] ksoftirqd/0: page allocation failure. order:0, mode:0x20
[ 238.880218] Backtrace:
[ 238.880249] [<c01b9800>] (dump_backtrace+0x0/0xf8) from [<c065e1dc>] (dump_stack+0x18/0x1c)
[ 238.880249] r6:00000000 r5:00000000 r4:00000020 r3:00000002
[ 238.880310] [<c065e1c4>] (dump_stack+0x0/0x1c) from [<c026ece4>] (__alloc_pages_nodemask+0x620/0x724)
[ 238.880340] [<c026e6c4>] (__alloc_pages_nodemask+0x0/0x724) from [<c02986d4>] (kmem_getpages.clone.34+0x34/0xc8)
[ 238.880371] [<c02986a0>] (kmem_getpages.clone.34+0x0/0xc8) from [<c02988f8>] (cache_grow.clone.42+0x84/0x154)
[ 238.880371] r6:ef871aa4 r5:ef871a80 r4:ef81fd40 r3:00000020
[ 238.880401] [<c0298874>] (cache_grow.clone.42+0x0/0x154) from [<c0298b64>] (cache_alloc_refill+0x19c/0x1f0)
[ 238.880432] [<c02989c8>] (cache_alloc_refill+0x0/0x1f0) from [<c0299804>] (kmem_cache_alloc+0x90/0x190)
[ 238.880462] [<c0299774>] (kmem_cache_alloc+0x0/0x190) from [<c052e260>] (__alloc_skb+0x34/0xe8)
[ 238.880493] [<c052e22c>] (__alloc_skb+0x0/0xe8) from [<bf0509f4>] (rx_submit+0x2c/0x1d4 [usbnet])
[ 238.880523] [<bf0509c8>] (rx_submit+0x0/0x1d4 [usbnet]) from [<bf050d38>] (rx_complete+0x19c/0x1b0 [usbnet])
[ 238.880737] [<bf050b9c>] (rx_complete+0x0/0x1b0 [usbnet]) from [<bf006fd0>] (usb_hcd_giveback_urb+0xa8/0xf4 [usbcore])
[ 238.880737] r8:eeeced34 r7:eeecec00 r6:eeecec00 r5:00000000 r4:eec2dd20
[ 238.880767] r3:bf050b9c
[ 238.880859] [<bf006f28>] (usb_hcd_giveback_urb+0x0/0xf4 [usbcore]) from [<bf03c8f8>] (ehci_urb_done+0xb0/0xbc [ehci_hcd])
[ 238.880859] r6:00000000 r5:eec2dd20 r4:eeeced44 r3:eec2dd34
[ 238.880920] [<bf03c848>] (ehci_urb_done+0x0/0xbc [ehci_hcd]) from [<bf040204>] (qh_completions+0x308/0x3bc [ehci_hcd])
[ 238.880920] r7:00000000 r6:eeda21a0 r5:ffdfe3c0 r4:eeda21ac
[ 238.880981] [<bf03fefc>] (qh_completions+0x0/0x3bc [ehci_hcd]) from [<bf040ef8>] (scan_async+0xb0/0x16c [ehci_hcd])
[ 238.881011] [<bf040e48>] (scan_async+0x0/0x16c [ehci_hcd]) from [<bf040fec>] (ehci_work+0x38/0x90 [ehci_hcd])
[ 238.881042] [<bf040fb4>] (ehci_work+0x0/0x90 [ehci_hcd]) from [<bf042940>] (ehci_irq+0x300/0x34c [ehci_hcd])
[ 238.881072] r4:eeeced34 r3:00000001
[ 238.881134] [<bf042640>] (ehci_irq+0x0/0x34c [ehci_hcd]) from [<bf006828>] (usb_hcd_irq+0x40/0xac [usbcore])
[ 238.881195] [<bf0067e8>] (usb_hcd_irq+0x0/0xac [usbcore]) from [<c0239764>] (handle_irq_event_percpu+0xb8/0x240)
[ 238.881225] r6:eec504e0 r5:0000006d r4:eec504e0 r3:bf0067e8
[ 238.881256] [<c02396ac>] (handle_irq_event_percpu+0x0/0x240) from [<c0239930>] (handle_irq_event+0x44/0x64)
[ 238.881256] [<c02398ec>] (handle_irq_event+0x0/0x64) from [<c023bbd0>] (handle_level_irq+0xe0/0x114)
[ 238.881286] r6:0000006d r5:c080c14c r4:c080c100 r3:00020000
[ 238.881317] [<c023baf0>] (handle_level_irq+0x0/0x114) from [<c01ab090>] (asm_do_IRQ+0x90/0xd0)
[ 238.881317] r5:00000000 r4:0000006d
[ 238.881347] [<c01ab000>] (asm_do_IRQ+0x0/0xd0) from [<c06624d0>] (__irq_svc+0x50/0x134)
[ 238.881378] Exception stack(0xef837e20 to 0xef837e68)
[ 238.881378] 7e20: 00000001 00185610 016cc000 c00490c0 eb380000 ef800540 00000020 00004ae0
[ 238.881408] 7e40: 00000020 bf0509f4 60000013 ef837e9c ef837e40 ef837e68 c0226f0c c0298ca0
[ 238.881408] 7e60: 20000013 ffffffff
[ 238.881408] r5:fa240100 r4:ffffffff
[ 238.881439] [<c0298bb8>] (__kmalloc_track_caller+0x0/0x1d0) from [<c052e284>] (__alloc_skb+0x58/0xe8)
[ 238.881469] [<c052e22c>] (__alloc_skb+0x0/0xe8) from [<bf0509f4>] (rx_submit+0x2c/0x1d4 [usbnet])
[ 238.881500] [<bf0509c8>] (rx_submit+0x0/0x1d4 [usbnet]) from [<bf0513d8>] (usbnet_bh+0x1b4/0x250 [usbnet])
[ 238.881530] [<bf051224>] (usbnet_bh+0x0/0x250 [usbnet]) from [<c01f912c>] (tasklet_action+0xb0/0x1f8)
[ 238.881530] r6:00000000 r5:ef9757f0 r4:ef9757ec r3:bf051224
[ 238.881561] [<c01f907c>] (tasklet_action+0x0/0x1f8) from [<c01f97ac>] (__do_softirq+0x140/0x290)
[ 238.881561] r8:00000006 r7:00000101 r6:00000000 r5:c0806098 r4:00000001
[ 238.881591] r3:c01f907c
[ 238.881622] [<c01f966c>] (__do_softirq+0x0/0x290) from [<c01f99cc>] (run_ksoftirqd+0xd0/0x1f4)
[ 238.881622] [<c01f98fc>] (run_ksoftirqd+0x0/0x1f4) from [<c02113b0>] (kthread+0x90/0x98)
[ 238.881652] r7:00000013 r6:c01f98fc r5:00000000 r4:ef831efc
[ 238.881683] [<c0211320>] (kthread+0x0/0x98) from [<c01f62f4>] (do_exit+0x0/0x374)
[ 238.881713] r6:c01f62f4 r5:c0211320 r4:ef831efc
[ 238.881713] Mem-info:
[ 238.881744] Normal per-cpu:
[ 238.881744] CPU 0: hi: 186, btch: 31 usd: 38
[ 238.881744] CPU 1: hi: 186, btch: 31 usd: 169
[ 238.881774] HighMem per-cpu:
[ 238.881774] CPU 0: hi: 90, btch: 15 usd: 66
[ 238.881774] CPU 1: hi: 90, btch: 15 usd: 86
[ 238.881805] active_anon:544 inactive_anon:71 isolated_anon:0
[ 238.881805] active_file:926 inactive_file:2538 isolated_file:0
[ 238.881805] unevictable:0 dirty:10 writeback:0 unstable:0
[ 238.881805] free:57782 slab_reclaimable:864 slab_unreclaimable:186898
[ 238.881805] mapped:632 shmem:144 pagetables:50 bounce:0
[ 238.881835] Normal free:1328kB min:3532kB low:4412kB high:5296kB active_anon:0kB inactive_anon:0kB active_file:880kB inactive_file:848kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:780288kB mlocked:0kB dirty:36kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:3456kB slab_unreclaimable:747592kB kernel_stack:392kB pagetables:200kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[ 238.881866] lowmem_reserve[]: 0 1904 1904
[ 238.881896] HighMem free:229800kB min:236kB low:508kB high:784kB active_anon:2176kB inactive_anon:284kB active_file:2824kB inactive_file:9304kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:243712kB mlocked:0kB dirty:4kB writeback:0kB mapped:2528kB shmem:576kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[ 238.881927] lowmem_reserve[]: 0 0 0
[ 238.881958] Normal: 0*4kB 4*8kB 6*16kB 0*32kB 1*64kB 1*128kB 0*256kB 2*512kB 0*1024kB 0*2048kB 0*4096kB = 1344kB
[ 238.882019] HighMem: 6*4kB 2*8kB 4*16kB 4*32kB 1*64kB 1*128kB 0*256kB 2*512kB 3*1024kB 0*2048kB 55*4096kB = 229800kB
[ 238.882080] 3610 total pagecache pages
[ 238.882080] 0 pages in swap cache
[ 238.882080] Swap cache stats: add 0, delete 0, find 0/0
[ 238.882110] Free swap = 0kB
[ 238.882110] Total swap = 0kB
[ 238.933776] 262144 pages of RAM
[ 238.933776] 58240 free pages
[ 238.933776] 10503 reserved pages
[ 238.933776] 187773 slab pages
[ 238.933807] 2475 pages shared
[ 238.933807] 0 pages swap cached
Resubmit interrupt URB if device is open. Use a flag set in
usbnet_open() to determine this state. Also kill and free
interrupt URB in usbnet_disconnect().
[Rebased off git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git]
Signed-off-by: Paul Stewart <pstew@chromium.org>
Signed-off-by: Thiago Farina <tfransosi@gmail.com>
The documentation for the USB ethernet devices suggests that
only some devices are supposed to use usb0 as the network interface
name instead of eth0. The logic used there, and documented in
Kconfig for CDC is that eth0 will be used when the mac address
is a globally assigned one, but usb0 is used for the locally
managed range that is typically used on point-to-point links.
Unfortunately, this has caused a lot of pain on the smsc95xx
device that is used on the popular pandaboard without an
EEPROM to store the MAC address, which causes the driver to
call random_ether_address().
Obviously, there should be a proper MAC addressed assigned to
the device, and discussions are ongoing about how to solve
this, but this patch at least makes sure that the default
interface naming gets a little saner and matches what the
user can expect based on the documentation, including for
new devices.
The approach taken here is to flag whether a device might be a
point-to-point link with the new FLAG_POINTTOPOINT setting in
the usbnet driver_info. A driver can set both FLAG_POINTTOPOINT
and FLAG_ETHER if it is not sure (e.g. cdc_ether), or just one
of the two. The usbnet framework only looks at the MAC address
for device naming if both flags are set, otherwise it trusts the
flag.
Signed-off-by: Arnd Bergmann <arnd.bergmann@linaro.org>
Tested-by: Andy Green <andy.green@linaro.org>
This adds a driver for the CDC Ethernet part of this modem. The
device's ID is blacklisted in cdc_ether.c and is white-listed in
this new driver because of the quirks needed to make it useful.
The modem's firmware exposes a CDC ACM port for modem control and a
CDC Ethernet port for network data. The descriptors look fine but
both ports actually are some sort of multiplexers requiring non-
standard headers added/removed from every packet or they get
ignored. All information is based on a usb traffic log from a
Windows machine.
On the Verizon 4G network I've seen speeds up to 1.1MB/s so far with
this driver, a speed-o-meter site reports 16.2Mbps/10.5Mbps.
Userspace scripts are required to talk to the CDC ACM port.
Signed-off-by: Andrzej Zaborowski <balrogg@gmail.com>
returns less than zero in kevent().
We'll leak the memory allocated to 'urb' in
drivers/net/usb/usbnet.c:kevent() when we 'goto fail_lowmem' and the 'urb'
variable goes out of scope while still completely unused.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
flush_scheduled_work() is on its way out. This patch contains simple
conversions to replace flush_scheduled_work() usage with direct
cancels and flushes.
Directly cancel the used works on driver detach and flush them in
other cases.
The conversions are mostly straight forward and the only dangers are,
* Forgetting to cancel/flush one or more used works.
* Cancelling when a work should be flushed (ie. the work must be
executed once scheduled whether the driver is detaching or not).
I've gone over the changes multiple times but it would be much
appreciated if you can review with the above points in mind.
Cc: Jay Cliburn <jcliburn@gmail.com>
Cc: Michael Chan <mchan@broadcom.com>
Cc: Divy Le Ray <divy@chelsio.com>
Cc: e1000-devel@lists.sourceforge.net
Cc: Vasanthy Kolluri <vkolluri@cisco.com>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: Andrew Gallatin <gallatin@myri.com>
Cc: Francois Romieu <romieu@fr.zoreil.com>
Cc: Ramkrishna Vepa <ramkrishna.vepa@exar.com>
Cc: Matt Carlson <mcarlson@broadcom.com>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Shreyas Bhatewara <sbhatewara@vmware.com>
Cc: netdev@vger.kernel.org
Changes:
include/linux/usb/usbnet.h:
- a new flag to indicate driver's capability to accumulate IP packets in Tx
direction and extract several packets from single skb in Rx direction.
- the procedure of counting packets in usbnet was updated due to the
accumulating of IP packets in the driver
- no short packets are sent if indicated by the flag in driver_info
structure
Since usbnet already took usb runtime pm, we have to
enable runtime pm for usb interface of usbnet, otherwise
usb_autopm_get_interface may return failure and cause
'ifconfig usb0 up' failed if USB_SUSPEND(RUNTIME_PM) is
enabled.
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Joe Perches <joe@perches.com>
Cc: Oliver Neukum <oliver@neukum.org>
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
This patch makes rx_submit() return an error code, and makes some call sites
that care check the return value. This is important because it lets us properly
handle cases where the device isn't ready to handle URB submissions (e.g., when
it is autosuspended under some drivers); previously, we would attempt and fail
to submit URBs and reschedule ourselves to try and fail again. This patch is
against Linus's 2.6 repo commit 45d7f32c7a43cbb9592886d38190e379e2eb2226.
Signed-Off-By: Elizabeth Jones <ellyjones@google.com>
With turned on hspa modem (Dell 5530 internal card) and activated usb auto
suspend, my system gets up 100 "usbnet_resume has delayed data" per
minute. I didnt noticed any pathological behaviour, so just drop
this message. if any objections, please at least change it to _DEBUG.
Signed-off-by: Christian Samsel <christian.samsel@rwth-aachen.de>
usbnet_terminate_urbs() uses schedule_timeout() with argument 3 msecs.
schedule_timeout() uses jiffies as argument, so convert msecs to jiffies
with msecs_to_jiffies().
Signed-off-by: Kulikov Vasiliy <segooon@gmail.com>
Signed-off-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Cc: linux-usb@vger.kernel.org
netdev_printk() follows the net_device's parent device pointer, so
we must set that earlier than we previously did.
Reported-by: Luís Picciochi Oliveira <pitxyoki@gmail.com>
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
This patch adds setting of the urb transfer flag URB_ZERO_PACKET before
submitting an urb for drivers that have requested it (by advertising flag
FLAG_SEND_ZLP).
The modification is in usbnet.c function usbnet_start_xmit().
This patch only adds the zero length flag.
A subsequent patch will address the buggy code we found when devices do not
advertise FLAG_SEND_ZLP in which case there is a possibility of transferring
packets with non-deterministic length.
This patch has been tested on kernel-2.6.34-rc3.
This patch has been checked against net-2.6 tree.
Signed-off-by: Elina Pasheva <epasheva@sierrawireless.com>
Signed-off-by: Rory Filer <rfiler@sierrawireless.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Convert from:
if (netif_msg_<foo>(priv))
dev_<level>(dev...
to
netif_<level>(priv, foo, dev...
Also convert a few:
if (i < REG_TIMEOUT) {
etc...
return ret;
to
if (i >= REG_TIMEOUT)
goto fail;
etc...
return ret;
These macros are too similar to the dev_<level> equivalents
but take a usbnet * argument. Convert them to the recently
introduced netdev_<level> macros and remove the old macros.
The old macros had "\n" appended to the format string.
Add the "\n" to the converted uses.
Some existing uses of the dev<foo> macros in cdc_eem.c
probably mistakenly had trailing "\n". No "\n" added there.
Fix net1080 this/other log message inversion.
Using remote wakeup and delayed transmission to allow
online device to go into usb autosuspend.
Minimal alternate support for devices that don't support
remote wakeup.
Signed-off-by: Oliver Neukum <oliver@neukum.org>
Only files where David Miller is the primary git-signer.
wireless, wimax, ixgbe, etc are not modified.
Compile tested x86 allyesconfig only
Not all files compiled (not x86 compatible)
Added a few > 80 column lines, which I ignored.
Existing checkpatch complaints ignored.
Some usbnet drivers update link state while others do not due to
hardware limitations. Add a flag to distinguish those that do, and
set the link down initially for their devices.
This is intended to fix this bug: http://bugs.debian.org/444043
For usbnet devices with FLAG_WLAN and FLAG_WWAN set the proper device
type so that uevent contains the correct value. This then allows an easy
identification of the actual underlying technology of the Ethernet device.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Add support for usbnet based devices like CDC-Ether to indicate that they
are actually mobile broadband devices. In that case use wwan%d as default
interface name.
Usbnet framework assumes USB hardware doesn't handle zero length
packets, but SMSC LAN95xx requires these to be sent for correct
operation.
This patch fixes an easily reproducible tx lockup when sending a frame
that results in exactly 512 bytes in a USB transmission (e.g. a UDP
frame with 458 data bytes, due to IP headers and our USB headers). It
adds an extra flag to usbnet for the hardware driver to indicate that
it can handle and requires the zero length packets.
This patch should not affect other usbnet users, please also consider
for -stable.
Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com>
No need to put ethtool_ops in data, they should be const.
Add rx queue pausing to usbnet. This is needed by rndis_wlan so that it can
control rx queue and prevent received packets from being send forward before
rndis_wlan receives and handles 'media connect'-indication. Without this
establishing WPA connections is hard and fail often.
[v2] - removed unneeded use of skb_clone
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
rndis_wlan devices freeze after running usbnet_stop several times. It appears
that firmware freezes in state where it does not respond to any RNDIS commands
and device have to be physically unplugged/replugged. This patch lets
minidrivers to disable unlink_urbs on usbnet_stop through new info flag.
Allow minidriver to know that netdev has stopped. This is to let
wireless turn off radio when usbnet dev is stopped.
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Now that netdev has its own stats structure we should use that
instead.
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Documentation/feature-removal-schedule.txt
drivers/scsi/fcoe/fcoe.c
net/core/drop_monitor.c
net/core/net-traces.c
fix ETIMEOUT -> ETIMEDOUT typos
because of using the same function get_ethernet_addr as cdc_ether.c
i export usbnet_get_ethernet_addr from usbnet and fixed cdc_ether
(suggested by Oliver Neukum).
Signed-off-by: Peter Holik <peter@holik.at>
Since all usb network drivers are already converted to net_device_ops
this code is useless.
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)
Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com>
Use net_device_ops for usbnet device, and export for use
by other derived drivers.
Default handler for net_device_stats already does same thing.
Make usbnet_get_link() fall back to ethtool_op_get_link() instead of
defaulting to 1.
This makes usbnet_get_link return valid results without the need for a
driver specific check_connect or mii ops as long as the driver calls
netif_carrier_{on,off}() as appropriate. cdc_ether is an example of
such a driver.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
This converts pretty much everything to print_mac. There were
a few things that had conflicts which I have just dropped for
now, no harm done.
I've built an allyesconfig with this and looked at the files
that weren't built very carefully, but it's a huge patch.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Move headers usbnet.h and rndis_host.h to include/linux/usb and fix includes
for drivers/net/usb modules. Headers are moved because rndis_wlan will be
outside drivers/net/usb in drivers/net/wireless and yet need these headers.
