[ Upstream commit 72d24955b44a4039db54a1c252b5031969eeaac3 ]
When new veth is created, and GSO values have been configured
on one device, clone those values to the peer.
For example:
# ip link add dev vm1 gso_max_size 65530 type veth peer name vm2
This should create vm1 <--> vm2 with both having GSO maximum
size set to 65530.
Signed-off-by: Stephen Hemminger <sthemmin@microsoft.com>
veth does not really transmit packets only moves the skb from one
netdev to another so gso and checksum is not really needed. Add
the features to mpls_features to get the same benefit and performance
with MPLS as without it.
Reported-by: Lennert Buytenhek <buytenh@wantstofly.org>
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
Commit b17c706987fa ("loopback: sctp: add NETIF_F_SCTP_CSUM to device
features") added NETIF_F_SCTP_CRC to device features for lo device to
improve the performance of sctp over lo.
This patch is to add NETIF_F_SCTP_CRC to device features for veth to
improve the performance of sctp over veth.
Before this patch:
ip netns exec cs_client netperf -H 10.167.12.2 -t SCTP_STREAM -- -m 10K
Recv Send Send
Socket Socket Message Elapsed
Size Size Size Time Throughput
bytes bytes bytes secs. 10^6bits/sec
212992 212992 10240 10.00 1117.16
After this patch:
Recv Send Send
212992 212992 10240 10.20 1415.22
Tested-by: Li Shuang <tjlishuang@yeah.net>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
This patch adds support for the checksum enabled versions of UDP and GRE
tunnels. With this change we should be able to send and receive GSO frames
of these types over the veth pair without needing to segment the packets.
Signed-off-by: Alexander Duyck <aduyck@mirantis.com>
The rx headroom for veth dev is the peer device needed_headroom.
Avoid ping-pong updates setting the private flag IFF_PHONY_HEADROOM.
This avoids skb head reallocation when forwarding from a veth dev
towards a device adding some kind of encapsulation.
When transmitting frames below the MTU size towards a vxlan device,
this gives about 10% performance speed-up when OVS is used to connect
the veth and the vxlan device and a little more when using a
plain Linux bridge.
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
as good.
Packets that arrive from real hardware devices have ip_summed ==
CHECKSUM_UNNECESSARY if the hardware verified the checksums, or
CHECKSUM_NONE if the packet is bad or it was unable to verify it. The
current version of veth will replace CHECKSUM_NONE with
CHECKSUM_UNNECESSARY, which causes corrupt packets routed from hardware to
a veth device to be delivered to the application. This caused applications
at Twitter to receive corrupt data when network hardware was corrupting
packets.
We believe this was added as an optimization to skip computing and
verifying checksums for communication between containers. However, locally
generated packets have ip_summed == CHECKSUM_PARTIAL, so the code as
written does nothing for them. As far as we can tell, after removing this
code, these packets are transmitted from one stack to another unmodified
(tcpdump shows invalid checksums on both sides, as expected), and they are
delivered correctly to applications. We didn’t test every possible network
configuration, but we tried a few common ones such as bridging containers,
using NAT between the host and a container, and routing from hardware
devices to containers. We have effectively deployed this in production at
Twitter (by disabling RX checksum offloading on veth devices).
This code dates back to the first version of the driver, commit
<e314dbdc1c0dc6a548ecf> ("[NET]: Virtual ethernet device driver"), so I
suspect this bug occurred mostly because the driver API has evolved
significantly since then. Commit <0b7967503dc97864f283a> ("net/veth: Fix
packet checksumming") (in December 2010) fixed this for packets that get
created locally and sent to hardware devices, by not changing
CHECKSUM_PARTIAL. However, the same issue still occurs for packets coming
in from hardware devices.
Co-authored-by: Evan Jones <ej@evanjones.ca>
Signed-off-by: Evan Jones <ej@evanjones.ca>
Cc: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Cc: Phil Sutter <phil@nwl.cc>
Cc: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp>
Cc: netdev@vger.kernel.org
Signed-off-by: Vijay Pandurangan <vijayp@vijayp.ca>
Acked-by: Cong Wang <cwang@twopensource.com>
Signed-off-by: Phil Sutter <phil@nwl.cc>
Cc: Pavel Emelyanov <xemul@openvz.org>
Veth devices don't need to segment multiple tagged packets.
Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp>
Now that the peer netns is advertised in rtnl messages, we can set this property
so that IFLA_LINK will advertise the peer ifindex. It allows the userland to get
the full veth configuration.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Assign rtnl_link_ops->get_link_net() callback so that IFLA_LINK_NETNSID is
added to rtnetlink messages.
This passes down NET_NAME_USER (or NET_NAME_ENUM) to alloc_netdev(),
for any device created over rtnetlink.
v9: restore reverse-christmas-tree order of local variables
Signed-off-by: Tom Gundersen <teg@jklm.no>
It is trivial to add netpoll support to veth, since
it is not a stacked device, we don't need to setup and
clean up netpoll.
Reported-by: Stefan Priebe <s.priebe@profihost.ag>
Cc: Neil Horman <nhorman@tuxdriver.com>
drivers/net/ethernet/marvell/mvneta.c
The mvneta.c conflict is a case of overlapping changes,
a conversion to devm_ioremap_resource() vs. a conversion
to netdev_alloc_pcpu_stats.
For completeness, turn off vlan rx acceleration in vlan_features so
that it doesn't show up on q-in-q setups.
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
Replace the bh safe variant with the hard irq safe variant.
We need a hard irq safe variant to deal with netpoll transmitting
packets from hard irq context, and we need it in most if not all of
the places using the bh safe variant.
Except on 32bit uni-processor the code is exactly the same so don't
bother with a bh variant, just have a hard irq safe variant that
everyone can use.
drivers/net/wireless/ath/ath9k/recv.c
drivers/net/wireless/mwifiex/pcie.c
net/ipv6/sit.c
The SIT driver conflict consists of a bug fix being done by hand
in 'net' (missing u64_stats_init()) whilst in 'net-next' a helper
was created (netdev_alloc_pcpu_stats()) which takes care of this.
The two wireless conflicts were overlapping changes.
Even if we create a stacked vlan interface such as veth0.10.20, it sends
single tagged frames (tagged with only vid 10).
Because vlan_features of a veth interface has the
NETIF_F_HW_VLAN_[CTAG/STAG]_TX bits, veth0.10 also has that feature, so
dev_hard_start_xmit(veth0.10) doesn't call __vlan_put_tag() and
vlan_dev_hard_start_xmit(veth0.10) overwrites vlan_tci.
This prevents us from using a combination of 802.1ad and 802.1Q
in containers, etc.
Acked-by: Flavio Leitner <fbl@redhat.com>
The only place this is used outside rtnetlink.c is veth. So provide
wrapper function for this usage.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
There are many drivers calling alloc_percpu() to allocate pcpu stats
and then initializing ->syncp. So just introduce a helper function for them.
Pull core locking changes from Ingo Molnar:
"The biggest changes:
- add lockdep support for seqcount/seqlocks structures, this
unearthed both bugs and required extra annotation.
- move the various kernel locking primitives to the new
kernel/locking/ directory"
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits)
block: Use u64_stats_init() to initialize seqcounts
locking/lockdep: Mark __lockdep_count_forward_deps() as static
lockdep/proc: Fix lock-time avg computation
locking/doc: Update references to kernel/mutex.c
ipv6: Fix possible ipv6 seqlock deadlock
cpuset: Fix potential deadlock w/ set_mems_allowed
seqcount: Add lockdep functionality to seqcount/seqlock structures
net: Explicitly initialize u64_stats_sync structures for lockdep
locking: Move the percpu-rwsem code to kernel/locking/
locking: Move the lglocks code to kernel/locking/
locking: Move the rwsem code to kernel/locking/
locking: Move the rtmutex code to kernel/locking/
locking: Move the semaphore core to kernel/locking/
locking: Move the spinlock code to kernel/locking/
locking: Move the lockdep code to kernel/locking/
locking: Move the mutex code to kernel/locking/
hung_task debugging: Add tracepoint to report the hang
x86/locking/kconfig: Update paravirt spinlock Kconfig description
lockstat: Report avg wait and hold times
lockdep, x86/alternatives: Drop ancient lockdep fixup message
In order to enable lockdep on seqcount/seqlock structures, we
must explicitly initialize any locks.
The u64_stats_sync structure, uses a seqcount, and thus we need
to introduce a u64_stats_init() function and use it to initialize
the structure.
This unfortunately adds a lot of fairly trivial initialization code
to a number of drivers. But the benefit of ensuring correctness makes
this worth while.
Because these changes are required for lockdep to be enabled, and the
changes are quite trivial, I've not yet split this patch out into 30-some
separate patches, as I figured it would be better to get the various
maintainers thoughts on how to best merge this change along with
the seqcount lockdep enablement.
Feedback would be appreciated!
Signed-off-by: John Stultz <john.stultz@linaro.org>
Acked-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Jesse Gross <jesse@nicira.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Mirko Lindner <mlindner@marvell.com>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Roger Luethi <rl@hellgate.ch>
Cc: Simon Horman <horms@verge.net.au>
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Wensong Zhang <wensong@linux-vs.org>
Link: http://lkml.kernel.org/r/1381186321-4906-2-git-send-email-john.stultz@linaro.org
While investigating on a recent vxlan regression, I found veth
was using a zero features set for vxlan tunnels.
We have to segment GSO frames, copy the payload, and do the checksum.
This patch brings a ~200% performance increase
We probably have to add hw_enc_features support
on other virtual devices.
Cc: Alexei Starovoitov <ast@plumgrid.com>
We can only setup multicast address for network device when
net_device_ops->ndo_set_rx_mode is not null.
Some configurations need to add multicast address for net
device, such as netfilter cluster match module.
Add a fake ndo_set_rx_mode function to allow this operation.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
This reverts commit 612c337306f00dc8d396830212de51c475844791.
As per Stephen Hemminger, the layout of the netlink attribute
is not implemented correctly so revert this for now.
ip link has ability to show extra information of net work device if
kernel provides sunh information. With this patch veth driver can
provide its peer ifindex information to ip command via netlink
interface.
Signed-off-by: Masatake YAMATO <yamato@redhat.com>
The veth device doesn't provide the vlan features,
so TSO for example is disabled and that causes
performance issues when using tagged traffic.
The test topology looks like this:
br0 br1
vnet veth0.10 ----- veth1.10 vnet
VM VM
The netperf results with current veth driver:
MIGRATED TCP STREAM TEST from 192.168.1.1 ()
port 0 AF_INET to 192.168.1.2 () port 0 AF_INET
Recv Send Send
87380 16384 16384 10.01 2210.22
Now after applying the proposed patch:
Recv Send Send
87380 16384 16384 10.00 13067.47
Signed-off-by: Flavio Leitner <fbl@redhat.com>
it's called in the following register_netdevice. No need to call it
here.
Tested with "ip link add type veth" and "ip link add xxx%d type veth".
Signed-off-by: Hong Zhiguo <honkiko@gmail.com>
- macvlan: propagate STAG filtering capabilities from underlying device
- ifb: announce STAG tagging support in addition to CTAG tagging support
- veth: announce STAG tagging/stripping support in addition to CTAG support
Rename the hardware VLAN acceleration features to include "CTAG" to indicate
that they only support CTAGs. Follow up patches will introduce 802.1ad
server provider tagging (STAGs) and require the distinction for hardware not
supporting acclerating both.
commit d0e2c55e7c940 (veth: avoid a NULL deref in veth_stats_one)
added another NULL deref in veth_dellink().
# ip link add name veth1 type veth peer name veth0
# rmmod veth
We crash because veth_dellink() is called twice, so we must
take care of NULL peer.
In commit d0e2c55e7c94 (veth: avoid a NULL deref in veth_stats_one)
we now clear the peer pointers in veth_dellink()
veth_close() must therefore make sure the peer pointer is set.
Reported-by: Tom Parkin <tom.parkin@gmail.com>
commit 2681128f0ced8a (veth: extend device features) added a NULL deref
in veth_stats_one(), as veth_get_stats64() was not testing if the peer
device was setup or not.
At init time, we call dev_get_stats() before veth pair is fully setup.
[ 178.854758] [<ffffffffa00f5677>] veth_get_stats64+0x47/0x70 [veth]
[ 178.861013] [<ffffffff814f0a2d>] dev_get_stats+0x6d/0x130
[ 178.866486] [<ffffffff81504efc>] rtnl_fill_ifinfo+0x47c/0x930
[ 178.872299] [<ffffffff81505b93>] rtmsg_ifinfo+0x83/0x100
[ 178.877678] [<ffffffff81505cc6>] rtnl_configure_link+0x76/0xa0
[ 178.883580] [<ffffffffa00f52fa>] veth_newlink+0x16a/0x350 [veth]
[ 178.889654] [<ffffffff815061cc>] rtnl_newlink+0x4dc/0x5e0
[ 178.895128] [<ffffffff81505e1e>] ? rtnl_newlink+0x12e/0x5e0
[ 178.900769] [<ffffffff8150587d>] rtnetlink_rcv_msg+0x11d/0x310
[ 178.906669] [<ffffffff81505760>] ? __rtnl_unlock+0x20/0x20
[ 178.912225] [<ffffffff81521f89>] netlink_rcv_skb+0xa9/0xd0
[ 178.917779] [<ffffffff81502d55>] rtnetlink_rcv+0x25/0x40
[ 178.923159] [<ffffffff815218d1>] netlink_unicast+0x1b1/0x230
[ 178.928887] [<ffffffff81521c4e>] netlink_sendmsg+0x2fe/0x3b0
[ 178.934615] [<ffffffff814dbe22>] sock_sendmsg+0xd2/0xf0
So we must check if peer was setup in veth_get_stats64()
As pointed out by Ben Hutchings, priv->peer is missing proper
synchronization. Adding RCU protection is a safe and well documented
way to make sure we don't access about to be freed or already
freed data.
Reported-by: Tom Parkin <tparkin@katalix.com>
CC: Ben Hutchings <bhutchings@solarflare.com>
veth is lacking most modern facilities, like SG, checksums, TSO.
It makes sense to extend dev->features to get them, or GRO aggregation
is defeated by a forced segmentation.
Reported-by: Andrew Vagin <avagin@parallels.com>
Cc: Michał Mirosław <mirq-linux@rere.qmqm.pl>
veth stats are a bit bloated. There is no need to account transmit
and receive stats, since they are absolutely symmetric.
Also use a per device atomic64_t for the dropped counter, as it
should never be used in fast path.
This patch removes an unused parameter (src_net) from rtnl_create_link()
method and from the method single invocation, in veth.
This parameter was used in the past when calling
ops->get_tx_queues(src_net, tb) in rtnl_create_link().
The get_tx_queues() member of rtnl_link_ops was replaced by two methods,
get_num_tx_queues() and get_num_rx_queues(), which do not get any
parameter. This was done in commit d40156aa5ecbd51fed932ed4813df82b56e5ff4d by
Jiri Pirko ("rtnl: allow to specify different num for rx and tx queue count").
Signed-off-by: Rami Rosen <ramirose@gmail.com>
The ifinfomsg is in there (thanks kaber@ for foreseeing this long time ago),
so take the given ifidex and register netdev with it.
Ben noticed, that this code path previously ignored ifmp->ifi_index and
userland could be passing in garbage. Thus it may now fail occasionally
because the value clashes with an existing interface.
To address this it's assumed that if the caller specifies the ifindex for
the veth master device, then it's aware of this possibility and should
explicitly specify (or set to 0 for auto-assignment) the peer's ifindex as
well. With this the compatibility with old tools not setting ifindex is
preserved.
Signed-off-by: Pavel Emelyanov <xemul@parallels.com>
drivers/net/ethernet/broadcom/bnx2x/bnx2x_stats.c
Small minor conflict in bnx2x, wherein one commit changed how
statistics were stored in software, and another commit
fixed endianness bugs wrt. reading the values provided by
the chip in memory.
Replace usage of random_ether_addr() with eth_hw_addr_random()
to set addr_assign_type correctly to NET_ADDR_RANDOM.
Change the trivial cases.
v2: adapt to renamed eth_hw_addr_random()
Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de>
VETH_INFO_PEER carries struct ifinfomsg plus optional IFLA
attributes. A minimal size of sizeof(struct ifinfomsg) must be
enforced or we may risk accessing that struct beyond the limits
of the netlink message.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
number of drivers
Per discussion with Ben Hutchings and David Miller, go through and
remove assignments of "N/A" to fw_version in various drivers'
.get_drvinfo routines. While there clean-up some use of bare
constants and such.
Signed-off-by: Rick Jones <rick.jones2@hp.com>
Only distinct use is checking if NETIF_F_NOCACHE_COPY should be
enabled by default. The check heuristics is altered a bit here,
so it hits other people than before. The default shouldn't be
trusted for performance-critical cases anyway.
For all other uses NETIF_F_NO_CSUM is equivalent to NETIF_F_HW_CSUM.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Convert some remaining straglers' .get_drvinfo routines to use strlcpy
rather than strcpy/strncpy.
Tunnels can force an alignment of their percpu data to reduce number of
cache lines used in fast path, or read in .ndo_get_stats()
percpu_alloc() is a very fine grained allocator, so any small hole will
be used anyway.
The device.h header was including module.h, making it present for
most of these drivers. But we want to clean that up. Call out the
include of module.h in the modular network drivers.
After the last patch, We are left in a state in which only drivers calling
ether_setup have IFF_TX_SKB_SHARING set (we assume that drivers touching real
hardware call ether_setup for their net_devices and don't hold any state in
their skbs. There are a handful of drivers that violate this assumption of
course, and need to be fixed up. This patch identifies those drivers, and marks
them as not being able to support the safe transmission of skbs by clearning the
IFF_TX_SKB_SHARING flag in priv_flags
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Karsten Keil <isdn@linux-pingi.de>
CC: "David S. Miller" <davem@davemloft.net>
CC: Jay Vosburgh <fubar@us.ibm.com>
CC: Andy Gospodarek <andy@greyhouse.net>
CC: Patrick McHardy <kaber@trash.net>
CC: Krzysztof Halasa <khc@pm.waw.pl>
CC: "John W. Linville" <linville@tuxdriver.com>
CC: Greg Kroah-Hartman <gregkh@suse.de>
CC: Marcel Holtmann <marcel@holtmann.org>
CC: Johannes Berg <johannes@sipsolutions.net>
Followup to commit f82528bc13a (Exclude duplicated checking for
iface-up) : We no longer need percpu tx_dropped field.
'is_skb_forwardable' function, which is subroutine of 'dev_forward_skb'.
Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com>
Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com>
Using 64bit stats on 32bit arches must use a synchronization or readers
can get transient values.
Fixes bug introduced in commit 6311cc44a2 (veth: convert to 64 bit
statistics)
