[ Upstream commit d5c7c745f254c6cb98b3b3f15fe789b8bd770c72 ]
When x25_asy_open() fails, it already cleans up by itself,
so its caller doesn't need to free the memory again.
It seems we still have to call x25_asy_free() to clear the SLF_INUSE
bit, so just set these pointers to NULL after kfree().
Reported-and-tested-by: syzbot+5e5e969e525129229052@syzkaller.appspotmail.com
Fixes: 3b780bed3138 ("x25_asy: Free x25_asy on x25_asy_open() failure.")
Lots of overlapping changes, mostly trivial in nature.
The mlxsw conflict was resolving using the example
resolution at:
https://github.com/jpirko/linux_mlxsw/blob/combined_queue/drivers/net/ethernet/mellanox/mlxsw/core_acl_flex_actions.c
Current value for a target abort error is 0x010, however, this value
should in fact be 0x002. As it stands, the range of error is 0..7 so
it is currently never being detected. This bug has been in the driver
since the early 2.6.12 days (or before).
Detected by CoverityScan, CID#744290 ("Logically dead code")
qe_muram_alloc return a unsigned long integer,which should not
compared with zero. check it using IS_ERR_VALUE() to fix this.
Fixes: c19b6d246a35 ("drivers/net: support hdlc function for QE-UCC")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Variable next_rx is being assigned but is never used hence it is
redundant and can be removed.
Cleans up clang warning:
warning: variable 'next_rx' set but not used [-Wunused-but-set-variable]
Variable txq_length is being assigned but is never used hence it is
warning: variable 'txq_length' set but not used [-Wunused-but-set-variable]
The kzalloc() function has a 2-factor argument form, kcalloc(). This
patch replaces cases of:
kzalloc(a * b, gfp)
with:
kcalloc(a * b, gfp)
as well as handling cases of:
kzalloc(a * b * c, gfp)
with:
kzalloc(array3_size(a, b, c), gfp)
as it's slightly less ugly than:
kzalloc_array(array_size(a, b), c, gfp)
This does, however, attempt to ignore constant size factors like:
kzalloc(4 * 1024, gfp)
though any constants defined via macros get caught up in the conversion.
Any factors with a sizeof() of "unsigned char", "char", and "u8" were
dropped, since they're redundant.
The Coccinelle script used for this was:
// Fix redundant parens around sizeof().
type TYPE;
expression THING, E;
kzalloc(
- (sizeof(TYPE)) * E
+ sizeof(TYPE) * E
kzalloc(
- (sizeof(THING)) * E
+ sizeof(THING) * E
// Drop single-byte sizes and redundant parens.
expression COUNT;
typedef u8;
typedef __u8;
kzalloc(
- sizeof(u8) * (COUNT)
+ COUNT
kzalloc(
- sizeof(__u8) * (COUNT)
+ COUNT
kzalloc(
- sizeof(char) * (COUNT)
+ COUNT
kzalloc(
- sizeof(unsigned char) * (COUNT)
+ COUNT
kzalloc(
- sizeof(u8) * COUNT
+ COUNT
kzalloc(
- sizeof(__u8) * COUNT
+ COUNT
kzalloc(
- sizeof(char) * COUNT
+ COUNT
kzalloc(
- sizeof(unsigned char) * COUNT
+ COUNT
// 2-factor product with sizeof(type/expression) and identifier or constant.
type TYPE;
expression THING;
identifier COUNT_ID;
constant COUNT_CONST;
- kzalloc
+ kcalloc
- sizeof(TYPE) * (COUNT_ID)
+ COUNT_ID, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * COUNT_ID
- kzalloc
+ kcalloc
- sizeof(TYPE) * (COUNT_CONST)
+ COUNT_CONST, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * COUNT_CONST
- kzalloc
+ kcalloc
- sizeof(THING) * (COUNT_ID)
+ COUNT_ID, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * COUNT_ID
- kzalloc
+ kcalloc
- sizeof(THING) * (COUNT_CONST)
+ COUNT_CONST, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * COUNT_CONST
// 2-factor product, only identifiers.
identifier SIZE, COUNT;
- kzalloc
+ kcalloc
- SIZE * COUNT
+ COUNT, SIZE
// 3-factor product with 1 sizeof(type) or sizeof(expression), with
// redundant parens removed.
expression THING;
identifier STRIDE, COUNT;
type TYPE;
kzalloc(
- sizeof(TYPE) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(TYPE))
kzalloc(
- sizeof(TYPE) * (COUNT) * STRIDE
kzalloc(
- sizeof(TYPE) * COUNT * (STRIDE)
kzalloc(
- sizeof(TYPE) * COUNT * STRIDE
kzalloc(
- sizeof(THING) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(THING))
kzalloc(
- sizeof(THING) * (COUNT) * STRIDE
kzalloc(
- sizeof(THING) * COUNT * (STRIDE)
kzalloc(
- sizeof(THING) * COUNT * STRIDE
// 3-factor product with 2 sizeof(variable), with redundant parens removed.
expression THING1, THING2;
identifier COUNT;
type TYPE1, TYPE2;
kzalloc(
- sizeof(TYPE1) * sizeof(TYPE2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2))
kzalloc(
- sizeof(TYPE1) * sizeof(THING2) * (COUNT)
kzalloc(
- sizeof(THING1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(THING1), sizeof(THING2))
kzalloc(
- sizeof(THING1) * sizeof(THING2) * (COUNT)
kzalloc(
- sizeof(TYPE1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(THING2))
kzalloc(
// 3-factor product, only identifiers, with redundant parens removed.
identifier STRIDE, SIZE, COUNT;
kzalloc(
- (COUNT) * STRIDE * SIZE
+ array3_size(COUNT, STRIDE, SIZE)
kzalloc(
- COUNT * (STRIDE) * SIZE
kzalloc(
- COUNT * STRIDE * (SIZE)
kzalloc(
- (COUNT) * (STRIDE) * SIZE
kzalloc(
- COUNT * (STRIDE) * (SIZE)
kzalloc(
- (COUNT) * STRIDE * (SIZE)
kzalloc(
- (COUNT) * (STRIDE) * (SIZE)
kzalloc(
- COUNT * STRIDE * SIZE
// Any remaining multi-factor products, first at least 3-factor products,
// when they're not all constants...
expression E1, E2, E3;
constant C1, C2, C3;
kzalloc(C1 * C2 * C3, ...)
kzalloc(
- (E1) * E2 * E3
+ array3_size(E1, E2, E3)
kzalloc(
- (E1) * (E2) * E3
kzalloc(
- (E1) * (E2) * (E3)
kzalloc(
- E1 * E2 * E3
// And then all remaining 2 factors products when they're not all constants,
// keeping sizeof() as the second factor argument.
expression THING, E1, E2;
type TYPE;
kzalloc(sizeof(THING) * C2, ...)
kzalloc(sizeof(TYPE) * C2, ...)
kzalloc(C1 * C2, ...)
- kzalloc
+ kcalloc
- sizeof(TYPE) * (E2)
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(THING) * (E2)
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * E2
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- (E1) * E2
+ E1, E2
- kzalloc
+ kcalloc
- (E1) * (E2)
+ E1, E2
- kzalloc
+ kcalloc
- E1 * E2
+ E1, E2
Use dma_zalloc_coherent instead of dma_alloc_coherent
followed by memset 0.
Sometimes when physical lines have a just good noise to make the protocol
handshaking fail, but the carrier detect still good. Then after remove of
the noise, nobody will trigger this protocol to be start again to cause
the link to never come back. The fix is when the carrier is still on, not
terminate the protocol handshaking.
Signed-off-by: Denis Du <dudenis2000@yahoo.ca>
Pull poll annotations from Al Viro:
"This introduces a __bitwise type for POLL### bitmap, and propagates
the annotations through the tree. Most of that stuff is as simple as
'make ->poll() instances return __poll_t and do the same to local
variables used to hold the future return value'.
Some of the obvious brainos found in process are fixed (e.g. POLLIN
misspelled as POLL_IN). At that point the amount of sparse warnings is
low and most of them are for genuine bugs - e.g. ->poll() instance
deciding to return -EINVAL instead of a bitmap. I hadn't touched those
in this series - it's large enough as it is.
Another problem it has caught was eventpoll() ABI mess; select.c and
eventpoll.c assumed that corresponding POLL### and EPOLL### were
equal. That's true for some, but not all of them - EPOLL### are
arch-independent, but POLL### are not.
The last commit in this series separates userland POLL### values from
the (now arch-independent) kernel-side ones, converting between them
in the few places where they are copied to/from userland. AFAICS, this
is the least disruptive fix preserving poll(2) ABI and making epoll()
work on all architectures.
As it is, it's simply broken on sparc - try to give it EPOLLWRNORM and
it will trigger only on what would've triggered EPOLLWRBAND on other
architectures. EPOLLWRBAND and EPOLLRDHUP, OTOH, are never triggered
at all on sparc. With this patch they should work consistently on all
architectures"
* 'misc.poll' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (37 commits)
make kernel-side POLL... arch-independent
eventpoll: no need to mask the result of epi_item_poll() again
eventpoll: constify struct epoll_event pointers
debugging printk in sg_poll() uses %x to print POLL... bitmap
annotate poll(2) guts
9p: untangle ->poll() mess
->si_band gets POLL... bitmap stored into a user-visible long field
ring_buffer_poll_wait() return value used as return value of ->poll()
the rest of drivers/*: annotate ->poll() instances
media: annotate ->poll() instances
fs: annotate ->poll() instances
ipc, kernel, mm: annotate ->poll() instances
net: annotate ->poll() instances
apparmor: annotate ->poll() instances
tomoyo: annotate ->poll() instances
sound: annotate ->poll() instances
acpi: annotate ->poll() instances
crypto: annotate ->poll() instances
block: annotate ->poll() instances
x86: annotate ->poll() instances
Pull networking fixes from David Miller:
1) The forcedeth conversion from pci_*() DMA interfaces to dma_*() ones
missed one spot. From Zhu Yanjun.
2) Missing CRYPTO_SHA256 Kconfig dep in cfg80211, from Johannes Berg.
3) Fix checksum offloading in thunderx driver, from Sunil Goutham.
4) Add SPDX to vm_sockets_diag.h, from Stephen Hemminger.
5) Fix use after free of packet headers in TIPC, from Jon Maloy.
6) "sizeof(ptr)" vs "sizeof(*ptr)" bug in i40e, from Gustavo A R Silva.
7) Tunneling fixes in mlxsw driver, from Petr Machata.
8) Fix crash in fanout_demux_rollover() of AF_PACKET, from Mike
Maloney.
9) Fix race in AF_PACKET bind() vs. NETDEV_UP notifier, from Eric
Dumazet.
10) Fix regression in sch_sfq.c due to one of the timer_setup()
conversions. From Paolo Abeni.
11) SCTP does list_for_each_entry() using wrong struct member, fix from
Xin Long.
12) Don't use big endian netlink attribute read for
IFLA_BOND_AD_ACTOR_SYSTEM, it is in cpu endianness. Also from Xin
Long.
13) Fix mis-initialization of q->link.clock in CBQ scheduler, preventing
adding filters there. From Jiri Pirko.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (67 commits)
ethernet: dwmac-stm32: Fix copyright
net: via: via-rhine: use %p to format void * address instead of %x
net: ethernet: xilinx: Mark XILINX_LL_TEMAC broken on 64-bit
myri10ge: Update MAINTAINERS
net: sched: cbq: create block for q->link.block
atm: suni: remove extraneous space to fix indentation
atm: lanai: use %p to format kernel addresses instead of %x
VSOCK: Don't set sk_state to TCP_CLOSE before testing it
atm: fore200e: use %pK to format kernel addresses instead of %x
ambassador: fix incorrect indentation of assignment statement
vxlan: use __be32 type for the param vni in __vxlan_fdb_delete
bonding: use nla_get_u64 to extract the value for IFLA_BOND_AD_ACTOR_SYSTEM
sctp: use right member as the param of list_for_each_entry
sch_sfq: fix null pointer dereference at timer expiration
cls_bpf: don't decrement net's refcount when offload fails
net/packet: fix a race in packet_bind() and packet_notifier()
packet: fix crash in fanout_demux_rollover()
sctp: remove extern from stream sched
sctp: force the params with right types for sctp csum apis
sctp: force SCTP_ERROR_INV_STRM with __u32 when calling sctp_chunk_fail
Fix coccicheck warning which recommends to use memdup_user():
drivers/net/wan/lmc/lmc_main.c:497:27-34: WARNING opportunity for memdup_user
Generated by: scripts/coccinelle/memdup_user/memdup_user.cocci
Signed-off-by: Vasyl Gomonovych <gomonovych@gmail.com>
This converts all remaining cases of the old setup_timer() API into using
timer_setup(), where the callback argument is the structure already
holding the struct timer_list. These should have no behavioral changes,
since they just change which pointer is passed into the callback with
the same available pointers after conversion. It handles the following
examples, in addition to some other variations.
Casting from unsigned long:
void my_callback(unsigned long data)
struct something *ptr = (struct something *)data;
setup_timer(&ptr->my_timer, my_callback, ptr);
and forced object casts:
void my_callback(struct something *ptr)
setup_timer(&ptr->my_timer, my_callback, (unsigned long)ptr);
become:
void my_callback(struct timer_list *t)
struct something *ptr = from_timer(ptr, t, my_timer);
timer_setup(&ptr->my_timer, my_callback, 0);
Direct function assignments:
ptr->my_timer.function = my_callback;
have a temporary cast added, along with converting the args:
ptr->my_timer.function = (TIMER_FUNC_TYPE)my_callback;
And finally, callbacks without a data assignment:
setup_timer(&ptr->my_timer, my_callback, 0);
have their argument renamed to verify they're unused during conversion:
void my_callback(struct timer_list *unused)
The conversion is done with the following Coccinelle script:
spatch --very-quiet --all-includes --include-headers \
-I ./arch/x86/include -I ./arch/x86/include/generated \
-I ./include -I ./arch/x86/include/uapi \
-I ./arch/x86/include/generated/uapi -I ./include/uapi \
-I ./include/generated/uapi --include ./include/linux/kconfig.h \
--dir . \
--cocci-file ~/src/data/timer_setup.cocci
@fix_address_of@
expression e;
setup_timer(
-&(e)
+&e
// Update any raw setup_timer() usages that have a NULL callback, but
// would otherwise match change_timer_function_usage, since the latter
// will update all function assignments done in the face of a NULL
// function initialization in setup_timer().
@change_timer_function_usage_NULL@
expression _E;
identifier _timer;
type _cast_data;
-setup_timer(&_E->_timer, NULL, _E);
+timer_setup(&_E->_timer, NULL, 0);
-setup_timer(&_E->_timer, NULL, (_cast_data)_E);
-setup_timer(&_E._timer, NULL, &_E);
+timer_setup(&_E._timer, NULL, 0);
-setup_timer(&_E._timer, NULL, (_cast_data)&_E);
@change_timer_function_usage@
expression _E;
identifier _timer;
struct timer_list _stl;
identifier _callback;
type _cast_func, _cast_data;
-setup_timer(&_E->_timer, _callback, _E);
+timer_setup(&_E->_timer, _callback, 0);
-setup_timer(&_E->_timer, &_callback, _E);
-setup_timer(&_E->_timer, _callback, (_cast_data)_E);
-setup_timer(&_E->_timer, &_callback, (_cast_data)_E);
-setup_timer(&_E->_timer, (_cast_func)_callback, _E);
-setup_timer(&_E->_timer, (_cast_func)&_callback, _E);
-setup_timer(&_E->_timer, (_cast_func)_callback, (_cast_data)_E);
-setup_timer(&_E->_timer, (_cast_func)&_callback, (_cast_data)_E);
-setup_timer(&_E._timer, _callback, (_cast_data)_E);
+timer_setup(&_E._timer, _callback, 0);
-setup_timer(&_E._timer, _callback, (_cast_data)&_E);
-setup_timer(&_E._timer, &_callback, (_cast_data)_E);
-setup_timer(&_E._timer, &_callback, (_cast_data)&_E);
-setup_timer(&_E._timer, (_cast_func)_callback, (_cast_data)_E);
-setup_timer(&_E._timer, (_cast_func)_callback, (_cast_data)&_E);
-setup_timer(&_E._timer, (_cast_func)&_callback, (_cast_data)_E);
-setup_timer(&_E._timer, (_cast_func)&_callback, (_cast_data)&_E);
_E->_timer@_stl.function = _callback;
_E->_timer@_stl.function = &_callback;
_E->_timer@_stl.function = (_cast_func)_callback;
_E->_timer@_stl.function = (_cast_func)&_callback;
_E._timer@_stl.function = _callback;
_E._timer@_stl.function = &_callback;
_E._timer@_stl.function = (_cast_func)_callback;
_E._timer@_stl.function = (_cast_func)&_callback;
// callback(unsigned long arg)
@change_callback_handle_cast
depends on change_timer_function_usage@
identifier change_timer_function_usage._callback;
identifier change_timer_function_usage._timer;
type _origtype;
identifier _origarg;
type _handletype;
identifier _handle;
void _callback(
-_origtype _origarg
+struct timer_list *t
... when != _origarg
_handletype *_handle =
-(_handletype *)_origarg;
+from_timer(_handle, t, _timer);
-(void *)_origarg;
_handletype *_handle;
... when != _handle
_handle =
... when != _handle
_handle =
-(void *)_origarg;
// callback(unsigned long arg) without existing variable
@change_callback_handle_cast_no_arg
depends on change_timer_function_usage &&
!change_callback_handle_cast@
type _origtype;
type _handletype;
void _callback(
-_origtype _origarg
+ _handletype *_origarg = from_timer(_origarg, t, _timer);
- (_handletype *)_origarg
+ _origarg
// Avoid already converted callbacks.
@match_callback_converted
!change_callback_handle_cast &&
!change_callback_handle_cast_no_arg@
identifier t;
void _callback(struct timer_list *t)
// callback(struct something *handle)
@change_callback_handle_arg
!match_callback_converted &&
type _handletype;
identifier _handle;
void _callback(
-_handletype *_handle
+ _handletype *_handle = from_timer(_handle, t, _timer);
// If change_callback_handle_arg ran on an empty function, remove
// the added handler.
@unchange_callback_handle_arg
change_callback_handle_arg@
type _handletype;
identifier _handle;
identifier t;
- _handletype *_handle = from_timer(_handle, t, _timer);
// We only want to refactor the setup_timer() data argument if we've found
// the matching callback. This undoes changes in change_timer_function_usage.
@unchange_timer_function_usage
!change_callback_handle_cast_no_arg &&
!change_callback_handle_arg@
expression change_timer_function_usage._E;
type change_timer_function_usage._cast_data;
-timer_setup(&_E->_timer, _callback, 0);
+setup_timer(&_E->_timer, _callback, (_cast_data)_E);
-timer_setup(&_E._timer, _callback, 0);
+setup_timer(&_E._timer, _callback, (_cast_data)&_E);
// If we fixed a callback from a .function assignment, fix the
// assignment cast now.
@change_timer_function_assignment
(change_callback_handle_cast ||
change_callback_handle_cast_no_arg ||
change_callback_handle_arg)@
type _cast_func;
typedef TIMER_FUNC_TYPE;
_E->_timer.function =
-_callback
+(TIMER_FUNC_TYPE)_callback
-&_callback
-(_cast_func)_callback;
-(_cast_func)&_callback
_E._timer.function =
-_callback
-&_callback;
// Sometimes timer functions are called directly. Replace matched args.
@change_timer_function_calls
expression _E;
type _cast_data;
_callback(
-(_cast_data)_E
+&_E->_timer
-(_cast_data)&_E
+&_E._timer
-_E
+&_E->_timer
// If a timer has been configured without a data argument, it can be
// converted without regard to the callback argument, since it is unused.
@match_timer_function_unused_data@
expression _E;
identifier _timer;
-setup_timer(&_E->_timer, _callback, 0);
-setup_timer(&_E->_timer, _callback, 0L);
-setup_timer(&_E->_timer, _callback, 0UL);
-setup_timer(&_E._timer, _callback, 0);
-setup_timer(&_E._timer, _callback, 0L);
-setup_timer(&_E._timer, _callback, 0UL);
-setup_timer(&_timer, _callback, 0);
+timer_setup(&_timer, _callback, 0);
-setup_timer(&_timer, _callback, 0L);
-setup_timer(&_timer, _callback, 0UL);
-setup_timer(_timer, _callback, 0);
+timer_setup(_timer, _callback, 0);
-setup_timer(_timer, _callback, 0L);
-setup_timer(_timer, _callback, 0UL);
@change_callback_unused_data
depends on match_timer_function_unused_data@
identifier match_timer_function_unused_data._callback;
type _origtype;
void _callback(
-_origtype _origarg
+struct timer_list *unused
In preparation to enabling -Wimplicit-fallthrough, mark switch cases
where we are expecting to fall through.
Addresses-Coverity-ID: 114928
Signed-off-by: Gustavo A. R. Silva <garsilva@embeddedor.com>
Files removed in 'net-next' had their license header updated
in 'net'. We take the remove from 'net-next'.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull initial SPDX identifiers from Greg KH:
"License cleanup: add SPDX license identifiers to some files
Update the files which contain no license information with the
'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally
binding shorthand, which can be used instead of the full boiler plate
text.
This patch is based on work done by Thomas Gleixner and Kate Stewart
and Philippe Ombredanne.
How this work was done:
Patches were generated and checked against linux-4.14-rc6 for a subset
of the use cases:
where non-standard license headers were used, and references to
license had to be inferred by heuristics based on keywords.
The analysis to determine which SPDX License Identifier to be applied
to a file was done in a spreadsheet of side by side results from of
the output of two independent scanners (ScanCode & Windriver)
producing SPDX tag:value files created by Philippe Ombredanne.
Philippe prepared the base worksheet, and did an initial spot review
of a few 1000 files.
The 4.13 kernel was the starting point of the analysis with 60,537
files assessed. Kate Stewart did a file by file comparison of the
scanner results in the spreadsheet to determine which SPDX license
identifier(s) to be applied to the file. She confirmed any
determination that was not immediately clear with lawyers working with
the Linux Foundation.
- Make and config files were included as candidates if they contained
>5 lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
Linux-syscall-note" otherwise it was "GPL-2.0". Results of that
was:
- when the two scanners agreed on the detected license(s), that
became the concluded license(s).
- when there was disagreement between the two scanners (one detected
a license but the other didn't, or they both detected different
resulted in a clear resolution of the license that should apply
(and which scanner probably needed to revisit its heuristics).
in time.
source files by Kate, Philippe, Thomas and, in some cases,
confirmation by lawyers working with the Linux Foundation.
disagreed against that SPDX file, to see if there was new insights.
The Windriver scanner is based on an older version of FOSSology in
part, so they are related.
files he inspected. For the non-uapi files Thomas did random spot
checks in about 15000 files.
copy/paste license identifier errors, and have been fixed to reflect
the correct identifier.
inspection and review of the 12,461 patched files from the initial
patch version early this week with:
license ids and scores
- reviewing anything where there was no detection but the patch
license was not GPL-2.0 WITH Linux-syscall-note to ensure that the
generate the patches.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'spdx_identifiers-4.14-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
License cleanup: add SPDX license identifier to uapi header files with a license
License cleanup: add SPDX license identifier to uapi header files with no license
License cleanup: add SPDX GPL-2.0 license identifier to files with no license
the use cases:
lines of source
lines).
GPL-2.0 11139
in time.
they are related.
correct identifier.
stat set to zero and the value is never read, instead stat is
set again in the do-loop. Hence the setting to zero is redundant
and can be removed. Cleans up clang warning:
drivers/net/wan/wanxl.c:737:2: warning: Value stored to 'stat'
is never read
Smooth Cong Wang's bug fix into 'net-next'. Basically put
the bulk of the tcf_block_put() logic from 'net' into
tcf_block_put_ext(), but after the offload unbind.
The function netdev_priv() returns the private data of the device. The
memory to store the private data is allocated in alloc_netdev() and is
released in netdev_free(). Calling kfree() on the return value of
netdev_priv() after netdev_free() results in a double free bug.
Signed-off-by: Pan Bian <bianpan2016@163.com>
In preparation for unconditionally passing the struct timer_list pointer to
all timer callbacks, switch to using the new timer_setup() and from_timer()
to pass the timer pointer explicitly.
Cc: Allen Pais <allen.lkml@gmail.com>
Cc: Tobias Klauser <tklauser@distanz.ch>
Cc: netdev@vger.kernel.org
This removes an entirely unused timer, which avoids needing to convert it
to timer_setup().
Cc: Francois Romieu <romieu@fr.zoreil.com>
to pass the timer pointer explicitly. This adds a pointer back to the
net_device, and drops needless open-coded resetting of the .function and
.data fields.
Cc: Krzysztof Halasa <khc@pm.waw.pl>
Use setup_timer function instead of initializing timer with the
function and data fields.
Signed-off-by: Allen Pais <allen.lkml@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull gcc plugins update from Kees Cook:
"This finishes the porting work on randstruct, and introduces a new
option to structleak, both noted below:
- For the randstruct plugin, enable automatic randomization of
structures that are entirely function pointers (along with a couple
designated initializer fixes).
- For the structleak plugin, provide an option to perform zeroing
initialization of all otherwise uninitialized stack variables that
are passed by reference (Ard Biesheuvel)"
* tag 'gcc-plugins-v4.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
gcc-plugins: structleak: add option to init all vars used as byref args
randstruct: Enable function pointer struct detection
drivers/net/wan/z85230.c: Use designated initializers
drm/amd/powerplay: rv: Use designated initializers
Make use the dma_*() interfaces rather than the pci_*() interfaces.
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
The driver does not check if mapping dma memory succeed.
The patch adds the checks and failure handling.
Found by Linux Driver Verification project (linuxtesting.org).
In preparation for the randstruct gcc plugin performing randomization of
structures that are entirely function pointers, use designated initializers
so the compiler doesn't get angry.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions return void * and remove all the casts across
the tree, adding a (u8 *) cast only where the unsigned char pointer
was used directly, all done with the following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = {
skb_pull,
__skb_pull,
skb_pull_inline,
__pskb_pull_tail,
__pskb_pull,
pskb_pull
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
identifier fn = {
skb_pull,
__skb_pull,
skb_pull_inline,
__pskb_pull_tail,
__pskb_pull,
pskb_pull
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
Make these functions (skb_put, __skb_put and pskb_put) return void *
and remove all the casts across the tree, adding a (u8 *) cast only
where the unsigned char pointer was used directly, all done with the
following spatch:
typedef u8;
identifier fn = { skb_put, __skb_put };
- *(fn(SKB, LEN))
type T;
+ E = fn(SKB, LEN)
which actually doesn't cover pskb_put since there are only three
users overall.
A handful of stragglers were converted manually, notably a macro in
drivers/isdn/i4l/isdn_bsdcomp.c and, oddly enough, one of the many
instances in net/bluetooth/hci_sock.c. In the former file, I also
had to fix one whitespace problem spatch introduced.
A common pattern with skb_put() is to just want to memcpy()
some data into the new space, introduce skb_put_data() for
this.
An spatch similar to the one for skb_put_zero() converts many
of the places using it:
identifier p, p2;
expression len, skb, data;
type t, t2;
-p = skb_put(skb, len);
+p = skb_put_data(skb, data, len);
-p = (t)skb_put(skb, len);
p2 = (t2)p;
-memcpy(p2, data, len);
-memcpy(p, data, len);
type t, t2;
identifier p, p2;
expression skb, data;
t *p;
-p = skb_put(skb, sizeof(t));
+p = skb_put_data(skb, data, sizeof(t));
-p = (t *)skb_put(skb, sizeof(t));
p2 = (t2)p;
-memcpy(p2, data, sizeof(*p));
-memcpy(p, data, sizeof(*p));
expression skb, len, data;
-memcpy(skb_put(skb, len), data, len);
+skb_put_data(skb, data, len);
(again, manually post-processed to retain some comments)
Reviewed-by: Stephen Hemminger <stephen@networkplumber.org>
The conflicts were two cases of overlapping changes in
batman-adv and the qed driver.
Network devices can allocate reasources and private memory using
netdev_ops->ndo_init(). However, the release of these resources
can occur in one of two different places.
Either netdev_ops->ndo_uninit() or netdev->destructor().
The decision of which operation frees the resources depends upon
whether it is necessary for all netdev refs to be released before it
is safe to perform the freeing.
netdev_ops->ndo_uninit() presumably can occur right after the
NETDEV_UNREGISTER notifier completes and the unicast and multicast
address lists are flushed.
netdev->destructor(), on the other hand, does not run until the
netdev references all go away.
Further complicating the situation is that netdev->destructor()
almost universally does also a free_netdev().
This creates a problem for the logic in register_netdevice().
Because all callers of register_netdevice() manage the freeing
of the netdev, and invoke free_netdev(dev) if register_netdevice()
fails.
If netdev_ops->ndo_init() succeeds, but something else fails inside
of register_netdevice(), it does call ndo_ops->ndo_uninit(). But
it is not able to invoke netdev->destructor().
This is because netdev->destructor() will do a free_netdev() and
then the caller of register_netdevice() will do the same.
However, this means that the resources that would normally be released
by netdev->destructor() will not be.
Over the years drivers have added local hacks to deal with this, by
invoking their destructor parts by hand when register_netdevice()
fails.
Many drivers do not try to deal with this, and instead we have leaks.
Let's close this hole by formalizing the distinction between what
private things need to be freed up by netdev->destructor() and whether
the driver needs unregister_netdevice() to perform the free_netdev().
netdev->priv_destructor() performs all actions to free up the private
resources that used to be freed by netdev->destructor(), except for
free_netdev().
netdev->needs_free_netdev is a boolean that indicates whether
free_netdev() should be done at the end of unregister_netdevice().
Now, register_netdevice() can sanely release all resources after
ndo_ops->ndo_init() succeeds, by invoking both ndo_ops->ndo_uninit()
and netdev->priv_destructor().
And at the end of unregister_netdevice(), we invoke
netdev->priv_destructor() and optionally call free_netdev().
sizeof(priv->ucc_pram) is 4 as it is the size of a pointer, but we want
to reserve space for the struct ucc_hdlc_param.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
Cc: Zhao Qiang <qiang.zhao@nxp.com>
This adds support for hdlc-bus mode to the fsl_ucc_hdlc driver. This can
be enabled with the "fsl,hdlc-bus" property in the DTS node of the
corresponding ucc.
This aligns the configuration of the UPSMR and GUMR registers to what is
done in our ucc_hdlc driver (that only support hdlc-bus mode) and with
the QuickEngine's documentation for hdlc-bus mode.
GUMR/SYNL is set to AUTO for the busmode as in this case the CD signal
is ignored. The brkpt_support is enabled to set the HBM1 bit in the
CMXUCR register to configure an open-drain connected HDLC bus.
We can't assume that we are always in loopback mode if rx and tx clock
have the same clock source. If we want to use HDLC busmode we also have
the same clock source but we are not in loopback mode. So move the
setting of the baudrate generator after the check for property for the
loopback mode.
We need space for the struct qe_bd and not for a pointer to this struct.
This fixes the following compiler warnings:
drivers/net/wan/fsl_ucc_hdlc.c: In function 'ucc_hdlc_poll':
warning: 'skb' may be used uninitialized in this function
[-Wmaybe-uninitialized]
skb->mac_header = skb->data - skb->head;
and
drivers/net/wan/fsl_ucc_hdlc.c: In function 'ucc_hdlc_probe':
drivers/net/wan/fsl_ucc_hdlc.c:1127:3: warning: 'utdm' may be used
uninitialized in this function [-Wmaybe-uninitialized]
kfree(utdm);
Some of the tracing seems to be remaining traces for basic driver
development. They can be removed now, as they cause noisy printouts.
4 billion packet queue is something unthinkable so use 32-bit value
for now.
Space savings on x86_64:
add/remove: 0/0 grow/shrink: 3/70 up/down: 16/-131 (-115)
function old new delta
change_tx_queue_len 94 108 +14
qdisc_create 1176 1177 +1
alloc_netdev_mqs 1124 1125 +1
xenvif_alloc 533 532 -1
x25_asy_setup 167 166 -1
tun_queue_resize 945 940 -5
pfifo_fast_enqueue 167 162 -5
qfq_init_qdisc 168 158 -10
tap_queue_resize 810 799 -11
transmit 719 698 -21
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs
Pull hw lockdown support from David Howells:
"Annotation of module parameters that configure hardware resources
including ioports, iomem addresses, irq lines and dma channels.
This allows a future patch to prohibit the use of such module
parameters to prevent that hardware from being abused to gain access
to the running kernel image as part of locking the kernel down under
UEFI secure boot conditions.
Annotations are made by changing:
module_param(n, t, p)
module_param_named(n, v, t, p)
module_param_array(n, t, m, p)
to:
module_param_hw(n, t, hwtype, p)
module_param_hw_named(n, v, t, hwtype, p)
module_param_hw_array(n, t, hwtype, m, p)
where the module parameter refers to a hardware setting
hwtype specifies the type of the resource being configured. This can
be one of:
ioport Module parameter configures an I/O port
iomem Module parameter configures an I/O mem address
ioport_or_iomem Module parameter could be either (runtime set)
irq Module parameter configures an I/O port
dma Module parameter configures a DMA channel
dma_addr Module parameter configures a DMA buffer address
other Module parameter configures some other value
Note that the hwtype is compile checked, but not currently stored (the
lockdown code probably won't require it). It is, however, there for
future use.
A bonus is that the hwtype can also be used for grepping.
The intention is for the kernel to ignore or reject attempts to set
annotated module parameters if lockdown is enabled. This applies to
options passed on the boot command line, passed to insmod/modprobe or
direct twiddling in /sys/module/ parameter files.
The module initialisation then needs to handle the parameter not being
set, by (1) giving an error, (2) probing for a value or (3) using a
reasonable default.
What I can't do is just reject a module out of hand because it may
take a hardware setting in the module parameters. Some important
modules, some ipmi stuff for instance, both probe for hardware and
allow hardware to be manually specified; if the driver is aborts with
any error, you don't get any ipmi hardware.
Further, trying to do this entirely in the module initialisation code
doesn't protect against sysfs twiddling.
[!] Note that in and of itself, this series of patches should have no
effect on the the size of the kernel or code execution - that is
left to a patch in the next series to effect. It does mark
annotated kernel parameters with a KERNEL_PARAM_FL_HWPARAM flag in
an already existing field"
* tag 'hwparam-20170420' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs: (38 commits)
Annotate hardware config module parameters in sound/pci/
Annotate hardware config module parameters in sound/oss/
Annotate hardware config module parameters in sound/isa/
Annotate hardware config module parameters in sound/drivers/
Annotate hardware config module parameters in fs/pstore/
Annotate hardware config module parameters in drivers/watchdog/
Annotate hardware config module parameters in drivers/video/
Annotate hardware config module parameters in drivers/tty/
Annotate hardware config module parameters in drivers/staging/vme/
Annotate hardware config module parameters in drivers/staging/speakup/
Annotate hardware config module parameters in drivers/staging/media/
Annotate hardware config module parameters in drivers/scsi/
Annotate hardware config module parameters in drivers/pcmcia/
Annotate hardware config module parameters in drivers/pci/hotplug/
Annotate hardware config module parameters in drivers/parport/
Annotate hardware config module parameters in drivers/net/wireless/
Annotate hardware config module parameters in drivers/net/wan/
Annotate hardware config module parameters in drivers/net/irda/
Annotate hardware config module parameters in drivers/net/hamradio/
Annotate hardware config module parameters in drivers/net/ethernet/
