Signed-off-by: Pavel Roskin <proski@gnu.org>
Both ath5k_hw and ath5k_softc represent one instance of the hardware.
This duplication is historical and is not needed anymore.
Keep the name "ath5k_hw" for the merged structure and "ah" for the
variable pointing to it. "ath5k_hw" is shorter than "ath5k_softc", more
descriptive and more widely used.
Put the combined structure to ath5k.h where the old ath5k_softc used to
be. Move some code from base.h to ath5k.h as needed.
Remove memory allocation for struct ath5k_hw and the corresponding error
handling. Merge iobase and ah_iobase fields.
Acked-by: Nick Kossifidis <mickflemm@gmail.com>
AR2413 uses the same reference clock as AR5413
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Might fix some stability issues on newer chips
rfgain probe is only necessary for OFDM operation on AR5111 and AR5112.
Fast channel change fixes:
a) Always set OFDM timings
b) Don't re-activate PHY
c) Enable only NF calibration, not AGC
https://bugzilla.kernel.org/show_bug.cgi?id=27382
Signed-off-by: Nick Kossifidis <mickflemm@gmail.com>
Correct channel setting function must be used for AR2317.
When I tested ahb patch on bullet2 all seemed to work fine,
but it couldn't connect another host (using ibss for example).
During an analysis I observed that it's transmitting on another
channel. I looked into madwifi code and understood that
the problem is in channel setting function. So atheros RF2317 not
fully handled in the current ath5k version and must be patched.
Signed-off-by: Nikolay Ledovskikh <nledovskikh@gmail.com>
Acked-by: Bob Copeland <me@bobcopeland.com>
ath5k_eeprom_mode_from_channel() returns -1 on error but we're storing
the result in "ee_mode" which is an unsigned char. This breaks the
error handling. This patch makes "ee_mode" an int.
Introduce a helper function to get the EEPROM mode from channel and remove
multiple similar switch statements. Also since it's now easy to get the EEPROM
mode from the channel, use them inside the functions which need it, instead of
passing a redundant ee_mode parameter.
Signed-off-by: Bruno Randolf <br1@einfach.org>
Remove redundant defines.
Add a new variable to keep track of the currently configured tx power. Before
max_pwr was re-used for keeping the maximum allowed power as well as the
current configuration. Doing a min() on it allows you to lower the txpower, but
how would you be able to make it higher again?
This patch fixes that by adding a new variable ah_cur_pwr which is used instead
of txp_max_pwr to keep the current configuration. txp_max_pwr is used to check
if we are within the limits.
Another problem fixed by this patch is that it avoids setting a zero txpower
when things are initialized first and the current power is not yet set.
And rename functions which write the powertable to make it clearer.
Let ath5k_hw_txpower() decide if it can re-use the powertable or if it has to
be recalculated instead of passing a 'fast' flag from the outside.
* By skipping tx power table calibration we also skip setting
tx power table on hw. Make sure we always write tx power table
on hw since it gets cleared on reset.
Tested-by: Sedat Dilek <sedat.dilek@gmail.com>
* A diff between rfbuffer settings of turbo and non-turbo
modes indicates there is a bit on bank 2 related to turbo operation
(it's set on turbo modes). This bit is present on all radios except
RF5413 that seems to have a completely different bank 2. Also
since 2317 has the same rf-registers locations with 2425 and
since the bit exists on 2317 I assume it also exists on 2425/2417).
So in case we use turbo mode (40MHz) enable it on bank modification.
* Clean up CHANNEL_T(URBO), use AR5K_BWMODE_40MHZ instead
* Use correct clock value when setting OFDM timings on
non-default bwmodes.
* Don't return -EINVAL when trying to set tx power
on RF5110 because AR5210 reset will fail. We need to
add support for RF5110 and AR5210 eeprom in the future
but for now just skip it.
* Tweak phy activation -> rx delay for different bwmodes
* Add synth-only channel change for AR2413/5413. When we call
ath5k_reset with a channel ath5k_hw_reset will first try to
set channel on PHY while PHY is running instead of doing a normal
full reset. To do this phy_init has to change to implement this
functionality.
* Clean up change_channel flag, what it really did was skip PCU
registers when setting initvals. This is done because on reset
PCU registers are not affected (except the registers we set
in pcu init and -due to hw problems- TSF). Use a new skip_pcu
flag that's not misleading instead. In the future we might use
that to also skip PCU reset and save us the TSF etc problems
(needs testing because standard practice is to reset everything).
* Use fast channel change only when setting channel, and set skip_pcu
to false only on init. When we reset the card due to DMA or PHY
problems skip pcu but never do a fast channel change.
* Only set power table if we are changing channel/mode
there is no need to recalculate and reset the power table
all the time.
* Add spur mitigation filter support for half/quarter and turbo.
* Tweak power detector delays on AR5111/AR5112 when
using half/quarter modes.
* Handle all usec parameters in one function. It's much cleaner
this way.
* Prepare for half/quarter/turbo support, introduce a new
ah_bwmode parameter and get rid of ah_turbo. Bwmode stands
for "bandwidth mode" and can have 4 values, default (20MHz),
turbo (40MHz), half rate (10MHz), and quarter rate (5MHz).
* No functional changes
* Clean up reset:
Introduce init functions for each unit and call them instead
of having everything inside ath5k_hw_reset (it's just c/p for
now so nothing changes except calling order -I tested it with
various cards and it's ok-)
* Further cleanups:
ofdm_timings belongs to phy.c
rate_duration belongs to pcu.c
clock functions are general and belong to reset.c (more to follow)
* Reorder functions for better organization:
We start with helpers and other functions follow in categories,
init functions are last
This patch moves code out from wireless drivers where two different
functions are defined in three code locations for the same purpose and
provides a common function to sign extend a 32-bit value.
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
As reported by Ryan Niemi, some bitmasks in the register definition for the PCU
Diagnostic register (DIAG_SW) were missing a zero at the end. While at it fix
some typos and add more comments.
Don't generate calibration errors messages when not needed.
Signed-off-by: Fabio Rossi <rossi.f@inwind.it>
Acked-by: Bruno Randolf <br1@einfach.org>
If the symbol offset is 46, it will be counted in both
the third and fourth bytes of the mask, and in this
case the shift will be negative which can pollute
high order bits in the mask. This may negatively impact
OFDM symbol detection.
Signed-off-by: Bob Copeland <me@bobcopeland.com>
Fix some comments:
s/transmition/transmission/
s/puting/putting/
This fixes a few misspellings, word repetitions, and some grammar
nits in ath5k comments. No code changes.
In commit 39d5b2c83ca8904b6826a0713263a4e5a9c0730a "ath5k: update
AR5K_PHY_RESTART_DIV_GC values to match masks" i introduced a regression on PHY
chips older than AR5K_SREV_PHY_5413, which caused signal values to be about
10dB less that before. This patch reverts the AR5K_PHY_RESTART_DIV_GC values to
the same values which were effectively used before (without the bitmask
mistake). This brings signal levels back to normal on these PHY chips.
Collect all pieces concering the antenna switch table into one function.
Previously it was split up between ath5k_hw_reset() and
ath5k_hw_commit_eeprom_settings().
Also we need to set the antenna switch table when ath5k_hw_set_antenna_mode()
is called manually (by "iw phy0 antenna set", for example).
I'm not sure if we need to set the switchtable at the same place in
ath5k_hw_reset() as it was before - it is set later thru
ath5k_hw_set_antenna_mode() anyways - but i leave it there to avoid
problems(?).
Plus print switchtable registers in the debugfs file.
#define AR5K_PHY_RESTART_DIV_GC 0x001c0000
is 3 bit wide.
The previous values of 0xc and 0x8 are 4bit wide and bigger than the mask.
Writing 0 and 1 to AR5K_PHY_RESTART_DIV_GC is consistent with the comments and
initvals we have in the HAL.
drivers/net/wireless/iwlwifi/iwl-core.h
If the channel is not set yet and we configure the antennas just store the
setting. It will be activated during the next reset, when the channel is set.
Now that we have ftrace, it is not needed any more.
Seperate noise floor calibration from other PHY calibration and move it to the
tasklet. This is the first step to more separation of different calibrations.
Also move out ath5k_hw_request_rfgain_probe(ah) so we have one clean function
for I/Q calibration on 5111x parts.
This patch removes from drivers/net/ all the unnecessary
return; statements that precede the last closing brace of
void functions.
It does not remove the returns that are immediately
preceded by a label as gcc doesn't like that.
It also does not remove null void functions with return.
Done via:
$ grep -rP --include=*.[ch] -l "return;\n}" net/ | \
xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }'
with some cleanups by hand.
Compile tested x86 allmodconfig only.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
Documentation/feature-removal-schedule.txt
drivers/net/wireless/ath/ath5k/phy.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
Resolution of a merge conflict upstream accidentally removed a hunk of
"ath5k: IQ calibration for AR5211 is slightly different", so restore it.
We check the bounds on pdadc once when correcting for
negative curves but not when we later copy values from
from the pdadc_tmp array, leading to a potential overrun.
Although we shouldn't hit this case in practice, let's
be consistent.
Reported-by: Dan Carpenter <error27@gmail.com>
These channels aren't selectable anyway, but our calculations
for 2.5 mhz frequencies are incorrect. The value is supposed to
be:
(frequency - reference) * (10/25)
i.e., divide by 2.5, but we were instead doing:
(10 * frequency - reference) / 25.
Additionally, the check for (frequency % 5 == 2) had an extra
subtraction that wasn't in madwifi HAL.
