None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com>
Use the new module_pcmcia_driver() macro to remove the boilerplate
module init/exit code in the pcmcia drivers.
Signed-off-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com>
Cards with numeric ID 0x0156:0x0002 and third ID "Version 01.02" can be
assumed to have Intersil firmware. Cards with Agere firmware use
"Version 01.01".
Signed-off-by: Pavel Roskin <proski@gnu.org>
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Saves about 50KB of data.
Old/new size of all objects:
563015 80096 130684 773795 bcea3 (TOTALS)
610916 32256 130632 773804 bceac (TOTALS)
Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> (for drivers/net/can/softing/softing_cs.c)
pcmcia_request_irq() and pcmcia_enable_device() are intended
to be called from process context (first function allocate memory
with GFP_KERNEL, second take a mutex). We can not take spin lock
and call them.
It's safe to move spin lock after pcmcia_enable_device() as we
still hold off IRQ until dev->base_addr is 0 and driver will
not proceed with interrupts when is not ready.
Patch resolves:
https://bugzilla.redhat.com/show_bug.cgi?id=643758
Reported-and-tested-by: rbugz@biobind.com
Cc: stable@kernel.org # 2.6.34+
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
What's worse than no comment? A wrong comment.
Several PCMCIA device drivers contained the same comments, which
were based on how the PCMCIA subsystem worked in the old days of 2.4.,
and which were originally part of a "dummy_cs" driver. These comments
no longer matched at all what is happening now, and therefore should
be removed.
Tested-by: Wolfram Sang <w.sang@pengutronix.de>
Remove this unnecessary message -- this info is either available
in sysfs or by enabling dynamic debug from the PCMCIA core.
CC: netdev@vger.kernel.org
CC: linux-wireless@vger.kernel.org
CC: linux-scsi@vger.kernel.org
CC: linux-usb@vger.kernel.org
When CONF_AUTO_SET_IO or CONF_AUTO_SET_IOMEM are set, the corresponding
fields in struct pcmcia_device *p_dev->resource[0,1,2] are set
accordinly. Drivers wishing to override certain settings may do so in
the callback function, but they no longer need to parse the CIS entries
stored in cistpl_cftable_entry_t themselves.
CC: linux-ide@vger.kernel.org
CC: laforge@gnumonks.org
CC: linux-mtd@lists.infradead.org
CC: linux-bluetooth@vger.kernel.org
CC: alsa-devel@alsa-project.org
CC: linux-serial@vger.kernel.org
CC: Jiri Kosina <jkosina@suse.cz>
Introduce an autoconfiguration feature to set certain values in
pcmcia_loop_config(), instead of copying the same code over and over
in each PCMCIA driver. At first, introduce the following options:
CONF_AUTO_CHECK_VCC check or matching Vcc entry
CONF_AUTO_SET_VPP set Vpp
CONF_AUTO_AUDIO enable the speaker line
Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth)
pcmcia_enable_device() now replaces pcmcia_request_configuration().
Instead of config_req_t, all necessary flags are either passed as
a parameter to pcmcia_enable_device(), or (in rare circumstances)
set in struct pcmcia_device -> flags.
With the last remaining user of include/pcmcia/cs.h gone, remove
all references.
Several drivers prefer to explicitly set config_{base,index,regs},
formerly known as ConfigBase, ConfigIndex and Present. Instead of
passing these values inside config_req_t, store it in struct
pcmcia_device.
IntType was only set to INT_MEMORY (driver pcmciamtd) or INT_MEMORY_AND_IO
(all other drivers). As this flags seems to relate to ioport access, make
it conditional to the driver having requested IO port access. There are two
drivers which do not request IO ports, but did set INT_MEMORY_AND_IO:
ray_cs and b43. For those, we consistently only set INT_MEMORY in future.
The Status (CISREG_CCSR) and ExtStatus (CISREG_ESR) registers were
only accessed to enable audio output for some drivers and IRQ for
serial_cs.c. The former also required setting config_req_t.Attributes
to CONF_ENABLE_SPKR; the latter can be simplified to setting this
field to CONF_ENABLE_ESR.
Some drivers prefer to explicitly set Vpp. Instead of passing the
voltage inside config_req_t, store it in struct pcmcia_device.
Instead of io_req_t, drivers are now requested to fill out
struct pcmcia_device *p_dev->resource[0,1] for up to two ioport
ranges. After a call to pcmcia_request_io(), the ports found there
are reserved, after calling pcmcia_request_configuration(), they may
be used.
CC: Michael Buesch <mb@bu3sch.de>
Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/)
After pcmcia_request_io(), do not make use of the values stored in
io_req_t, but instead use those found in struct pcmcia_device->resource[].
Use pcmcia_read_config_byte and pcmcia_write_config_byte instead
of pcmcia_access_configuration_register.
Remove cs_types.h which is no longer needed: Most definitions aren't
used at all, a few can be made away with, and two remaining definitions
(typedefs, unfortunatley) may be moved to more specific places.
Use an irq spinlock to hold off the IRQ handler until
enough early card init is complete such that the handler
can run without faulting.
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
dev_node_t was only used to transport some minor/major numbers
from the PCMCIA device drivers to deprecated userspace helpers.
However, only a few drivers made use of it, and the userspace
helpers are deprecated anyways. Therefore, get rid of dev_node_t .
As a first step, remove any usage of dev_node_t from drivers which
only wrote to this typedef/struct, but did not make use of it.
CC: Harald Welte <laforge@gnumonks.org>
Instead of the old pcmcia_request_irq() interface, drivers may now
choose between:
- calling request_irq/free_irq directly. Use the IRQ from *p_dev->irq.
- use pcmcia_request_irq(p_dev, handler_t); the PCMCIA core will
clean up automatically on calls to pcmcia_disable_device() or
device ejection.
- drivers still not capable of IRQF_SHARED (or not telling us so) may
use the deprecated pcmcia_request_exclusive_irq() for the time
being; they might receive a shared IRQ nonetheless.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
...and use it in hostap_cs and orinoco_cs.
Another PCMCIA device with Intersil Prism chipset has been reported:
Socket 0:
product info: "Gigabyte", "GN-WLM01_P25L_ADAPTER", "ISL37300P", "Eval-RevA"
manfid: 0x02e0, 0x1011
function: 6 (network)
As it's the case with some other Prism based devices, the third ID
string contains a design name that should be sufficient to identify the
card as having Intersil Prism chipset and thus compatible with both
orinoco_cs and hostap_cs.
Introduce PCMCIA_DEVICE_PROD_ID3 that matches the third ID string only.
Use it in orinoco_cs and hostap_cs to match cards with the third ID
string indicating Prism chipset. Remove corresponding entries that use
PCMCIA_DEVICE_PROD_ID123.
Reported-by: Ozzy <ozzymud@gmail.com>
Most of the irq_req_t typedef'd struct can be re-worked quite
easily:
(1) IRQInfo2 was unused in any case, so drop it.
(2) IRQInfo1 was used write-only, so drop it.
(3) Instance (private data to be passed to the IRQ handler):
Most PCMCIA drivers using pcmcia_request_irq() to actually
register an IRQ handler set the "dev_id" to the same pointer
as the "priv" pointer in struct pcmcia_device. Modify the two
exceptions (ipwireless, ibmtr_cs) to also work this waym and
set the IRQ handler's "dev_id" to p_dev->priv unconditionally.
(4) Handler is to be of type irq_handler_t.
(5) Handler != NULL already tells whether an IRQ handler is present.
Therefore, we do not need the IRQ_HANDLER_PRESENT flag in
irq_req_t.Attributes.
CC: Jaroslav Kysela <perex@perex.cz>
CC: Karsten Keil <isdn@linux-pingi.de>
for the Bluetooth parts: Acked-by: Marcel Holtmann <marcel@holtmann.org>
Update remaining users and remove deprecated handle_to_dev() macro
Convert PCMCIA drivers to use the dynamic debug infrastructure, instead of
requiring manual settings of PCMCIA_DEBUG.
Also, remove all usages of the CS_CHECK macro and replace them with proper
Linux style calling and return value checking. The extra error reporting may
be dropped, as the PCMCIA core already complains about any (non-driver-author)
errors.
A few PCMCIA network drivers can make use of values provided by the pcmcia
core, instead of tedious, independent CIS parsing.
xirc32ps_cs.c: manf_id
hostap_cs.c: multifunction count
b43/pcmcia.c: ConfigBase address and "Present"
smc91c92_cs.c: By default, mhz_setup() can use VERS_1 as it is stored
in struct pcmcia_device. Only some cards require workarounds, such as
reading out VERS_1 twice.
CC: David S. Miller <davem@davemloft.net>
Acked-by: John W. Linville <linville@tuxdriver.com>
The hostap_cs driver is programmed for exclusive rather that shared
interrupts.
Reported-and-Tested-by: Jack Schneider <puck@dp-indexing.com>
Since we're just parsing the tuple being passed to this function, we don't
need any device-specific information.
Also, remove the call to pcmcia_validate_cis() from pcmciamtd.c, since it
is already called by the PCMCIA core.
Instead of using own error or success codes, the PCMCIA code should rely on
the generic return values. Therefore, replace all occurrences of CS_SUCCESS
with 0.
By passing the current Vcc setting to the pcmcia_config_loop callback
function, we can remove pcmcia_get_configuration_info() calls from many
drivers.
Many drivers use the default CIS entry within their pcmcia_config_loop()
callback function. Therefore, factor the default CIS entry handling out.
Almost all drivers set p_dev->conf.ConfigIndex to cfg->index in
the pcmcia_config_loop() callback function. Therefore, factor it out.
Use the config loop helper in (some) net pcmcia drivers.
This corrects this kernel.org bug:
http://bugzilla.kernel.org/show_bug.cgi?id=9701
Rewrite AID calculation in handle_pspoll() to avoid truncating bits.
Make hostap_80211_header_parse() static, don't export it. Avoid
shadowing variables.
Reported by Santiago Garcia Mantinan <hostap@manty.net>
Card reported by Ångström user:
http://bugs.openembedded.net/show_bug.cgi?id=3236
Socket 1:
product info: "Wireless LAN", "11Mbps PC Card", "Version 01.02", ""
manfid: 0x0156, 0x0002
Signed-off-by: Marcin Juszkiewicz <openembedded@haerwu.biz>
If the third PCMCIA ID string specifies the MAC chip, the fourth ID
string doesn't need to be matched. Even if it's different, it will be
compatible with the driver.
This ensures that other different revisions of the card will be
supported.
Socket 1:
product info: "The Linksys Group, Inc.", "Wireless Network CF Card", "ISL37300P", "RevA"
manfid: 0x0274, 0x3301
This adds the PCMCIA device ID for the Deutsche Telekom T-Sinus 111card to
hostap_cs.
$ /sbin/lspcmcia -v
Socket 0 Device 0: [hostap_cs] (bus ID: 0.0)
Configuration: state: on
Product Name: T-Sinus 111card 2.0.0
Identification: manf_id: 0x01bf card_id: 0x3301
prod_id(1): "T-Sinus" (0x8c389dc1)
prod_id(2): "111card" (0x6a23ac17)
prod_id(3): --- (---)
prod_id(4): "2.0.0" (0x92b9effb)
Signed-off-by: Stefan Lippers-Hollmann <s.l-h@gmx.de>
Replacing accesses to dev->priv to netdev_priv(dev). The replacment
is safe when netdev_priv is used to access a private structure that is
right next to the net_device structure in memory. Cf
http://groups.google.com/group/comp.os.linux.development.system/browse_thread/thread/de19321bcd94dbb8/0d74a4adcd6177bd
This is the case when the net_device structure was allocated with
a call to alloc_netdev or one of its derivative.
Signed-off-by: Yoann Padioleau <padator@wanadoo.fr>
Cc: mcgrof@gmail.com
Cc: linux-wireless@vger.kernel.org
Cc: akpm@linux-foundation.org
The driver version number has not been updated since the driver was
included in the main kernel tree and there is no plan on updating this
in the future either. At this point, the only correct way to refer to
the version is to use the kernel version. The 0.4.4 version is
confusing since there are external version with higher version number
even though they are not actually any newer than the in-tree version.
Let's get rid of the version number in the kernel tree in order to
avoid this kind of confusion.
Signed-off-by: Jouni Malinen <j@w1.fi>
Add ADLINK 345 CF card into hostap_cs
product info: "ADLINK 345 CF"
manfid 0xd601, 0x0005
Signed-off-by: Marcin Juszkiewicz <openembedded@hrw.one.pl>
After 13 years of use, it looks like my email address is finally going
to disappear. While this is likely to drop the amount of incoming spam
greatly ;-), it may also affect more appropriate messages, so let's
update my email address in various places. In addition, Host AP mailing
list is subscribers-only and linux-wireless can also be used for
discussing issues related to this driver which is now shown in
MAINTAINERS.
It looks like some of the PC Card manfid/product strings were lost
when Host AP driver was converted to use PCMCIA_DEVICE_* helpers. This
patch adds back D-Link DWL-650 Rev. P1 using the same product ID
string match as the pcmcia-cs/cardmgr configuration used before.
Signed-off-by: Jouni Malinen <jkmaline@cc.hut.fi>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into upstream
drivers/net/wireless/zd1211rw/zd_mac.h
net/ieee80211/softmac/ieee80211softmac_assoc.c
Replace kmalloc+memset with kzalloc
Signed-off-by: Yan Burman <burman.yan@gmail.com>
