Use possibly more efficient ether_addr_equal
instead of memcmp.
Cc: Jouni Malinen <j@w1.fi>
Cc: John W. Linville <linville@tuxdriver.com>
Cc: linux-wireless@vger.kernel.org
Cc: netdev@vger.kernel.org
Signed-off-by: Weilong Chen <chenweilong@huawei.com>
Signed-off-by: Ding Tianhong <dingtianhong@huawei.com>
A device inheriting a random or set address should reflect this in
its addr_assign_type.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Cc: stable@vger.kernel.org
Don't use create_proc_read_entry() as that is deprecated, but rather use
proc_create_data() and seq_file instead.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
cc: Jouni Malinen <j@w1.fi>
cc: John W. Linville <linville@tuxdriver.com>
cc: Johannes Berg <johannes@sipsolutions.net>
cc: linux-wireless@vger.kernel.org
cc: netdev@vger.kernel.org
cc: devel@driverdev.osuosl.org
flush[_delayed]_work_sync() are now spurious. Mark them deprecated
and convert all users to flush[_delayed]_work().
If you're cc'd and wondering what's going on: Now all workqueues are
non-reentrant and the regular flushes guarantee that the work item is
not pending or running on any CPU on return, so there's no reason to
use the sync flushes at all and they're going away.
This patch doesn't make any functional difference.
Cc: Ian Campbell <ian.campbell@citrix.com>
Cc: Mattia Dongili <malattia@linux.it>
Cc: Kent Yoder <key@linux.vnet.ibm.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Karsten Keil <isdn@linux-pingi.de>
Cc: Bryan Wu <bryan.wu@canonical.com>
Cc: Alasdair Kergon <agk@redhat.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Anton Vorontsov <cbou@mail.ru>
Cc: Sangbeom Kim <sbkim73@samsung.com>
Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com>
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Petr Vandrovec <petr@vandrovec.name>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Avi Kivity <avi@redhat.com>
Pull trivial tree from Jiri Kosina:
"It's indeed trivial -- mostly documentation updates and a bunch of
typo fixes from Masanari.
There are also several linux/version.h include removals from Jesper."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (101 commits)
kcore: fix spelling in read_kcore() comment
constify struct pci_dev * in obvious cases
Revert "char: Fix typo in viotape.c"
init: fix wording error in mm_init comment
usb: gadget: Kconfig: fix typo for 'different'
Revert "power, max8998: Include linux/module.h just once in drivers/power/max8998_charger.c"
writeback: fix fn name in writeback_inodes_sb_nr_if_idle() comment header
writeback: fix typo in the writeback_control comment
Documentation: Fix multiple typo in Documentation
tpm_tis: fix tis_lock with respect to RCU
Revert "media: Fix typo in mixer_drv.c and hdmi_drv.c"
Doc: Update numastat.txt
qla4xxx: Add missing spaces to error messages
compiler.h: Fix typo
security: struct security_operations kerneldoc fix
Documentation: broken URL in libata.tmpl
Documentation: broken URL in filesystems.tmpl
mtd: simplify return logic in do_map_probe()
mm: fix comment typo of truncate_inode_pages_range
power: bq27x00: Fix typos in comment
Correct spelling "reseting" to "resetting" in
drivers/net/wireless/hostap/hostap_hw.c
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
alloc failures use dump_stack so emitting an additional
out-of-memory message is an unnecessary duplication.
Remove the allocation failure messages.
flush_scheduled_work() is on its way out. Drop flush_scheduled_work()
from prism2_free_local_data() and replace it with explicit flushing of
work items on the respective free functions. Work items in ap_data
are flushed from hostap_free_data() and the ones in local_info from
prism2_free_local_data().
Flush is used instead of cancel as some process and free items from
queue.
Cc: Jes Sorensen <jes@trained-monkey.org>
Signed-off-by: Thomas Weber <weber@corscience.de>
The patch below fixes a typo in a comment.
Use an irq spinlock to hold off the IRQ handler until
enough early card init is complete such that the handler
can run without faulting.
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Cc: stable@kernel.org
This reverts commit 15920d8afc87861672e16fa95ae2764b065d6dd3.
This patch was discovered to cause some hostap devices to fail to
initialized.
https://bugzilla.kernel.org/show_bug.cgi?id=16111
BugLink: https://bugs.launchpad.net/ubuntu/+bug/254837
Spurious shared interrupts or early probing interrupts can cause the
hostap interrupt handler to oops before the driver has fully configured
the IO base port addresses. In some cases the oops can be because
the hardware shares an interrupt line, on other cases it is due to a
race condition between probing for the hardware and configuring
the IO base port. The latter occurs because the probing is required to
determin the hardware port address which is only determined when the probe
can interrupt the hardware (catch 22).
This patch catches this pre-configured condition to avoid the oops.
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
Acked-by: Tim Gardner <tim.gardner@canonical.com>
Acked-by: Stefan Bader <stefan.bader@canonical.com>
Patch fixes issues with dev->dev_addr changing from array to pointer.
Hopefully there are no others.
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Use pre-existing net_device_stats in network_device struct.
So that net/ieee80211.h can be made private to ipw2x00 in a follow-up.
Signed-off-by: Dan Williams <dcbw@redhat.com>
These bits are shared already between ipw2x00 and hostap, and could
probably be shared both more cleanly and with other drivers. This
commit simply relocates the code to lib80211 and adjusts the drivers
appropriately.
This converts pretty much everything to print_mac. There were
a few things that had conflicts which I have just dropped for
now, no harm done.
I've built an allyesconfig with this and looked at the files
that weren't built very carefully, but it's a huge patch.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
The new address list lock needs to handle the same device layering
issues that the _xmit_lock one does.
This integrates work done by Patrick McHardy.
alloc_netdev_mq() now allocates an array of netdev_queue
structures for TX, based upon the queue_count argument.
Furthermore, all accesses to the TX queues are now vectored
through the netdev_get_tx_queue() and netdev_for_each_tx_queue()
interfaces. This makes it easy to grep the tree for all
things that want to get to a TX queue of a net device.
Problem spots which are not really multiqueue aware yet, and
only work with one queue, can easily be spotted by grepping
for all netdev_get_tx_queue() calls that pass in a zero index.
Accesses are mostly structured such that when there are multiple TX
queues the code transformations will be a little bit simpler.
Signed-off-by: Pavel Roskin <proski@gnu.org>
Documentation/feature-removal-schedule.txt
drivers/net/wan/hdlc_fr.c
drivers/net/wireless/iwlwifi/iwl-4965.c
drivers/net/wireless/iwlwifi/iwl3945-base.c
Rewrite AID calculation in handle_pspoll() to avoid truncating bits.
Make hostap_80211_header_parse() static, don't export it. Avoid
shadowing variables.
The "registers" entry was incorrectly created in the procfs root instead
of the device specific directory. Move "registers" registration
immediately after the containing procfs directory is created.
Signed-off-by: Mathieu Chouquet-Stringer <mchouque@free.fr>
Just leave hfa384x_info_frame as-is, don't convert in place.
it's le32, not le16...
* use irq_handler_t where appropriate
* no need to use 'irq' function arg, its already stored in a data struct
* rename irq handler 'irq' argument to 'dummy', where the function
has been analyzed and proven not to use its first argument.
* remove always-false "dev_id == NULL" test from irq handlers
* remove pointless casts from void*
* declance: irq argument is not const
* add KERN_xxx printk prefix
* fix minor whitespace weirdness
As detailed at https://bugs.gentoo.org/159646 hostap with hostapd confuses
udev by presenting 2 interfaces with the same MAC address. Also, at the time
of detection, the 'type' attribute is 1, identical to other hostap interfaces.
The AP interface is supposed to have type ARPHRD_IEEE80211 (801), but this is
not set until after registration.
Setting it before register_netdev() is called allows us to avoid this
confusion. We can do this by propogating the HOSTAP_INTERFACE type through
to hostap_setup_dev().
Signed-off-by: Daniel Drake <dsd@gentoo.org>
Since hardware header operations are part of the protocol class
not the device instance, make them into a separate object and
save memory.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
This is nicer than the MAC_FMT stuff.
Replacing accesses to dev->priv to netdev_priv(dev). The replacment
is safe when netdev_priv is used to access a private structure that is
right next to the net_device structure in memory. Cf
http://groups.google.com/group/comp.os.linux.development.system/browse_thread/thread/de19321bcd94dbb8/0d74a4adcd6177bd
This is the case when the net_device structure was allocated with
a call to alloc_netdev or one of its derivative.
Signed-off-by: Yoann Padioleau <padator@wanadoo.fr>
Cc: mcgrof@gmail.com
Cc: akpm@linux-foundation.org
The Host AP driver uses a semaphore as mutex. Use the mutex API
instead of the (binary) semaphore.
Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com>
Acked-by: Satyam Sharma <satyam@infradead.org>
After 13 years of use, it looks like my email address is finally going
to disappear. While this is likely to drop the amount of incoming spam
greatly ;-), it may also affect more appropriate messages, so let's
update my email address in various places. In addition, Host AP mailing
list is subscribers-only and linux-wireless can also be used for
discussing issues related to this driver which is now shown in
MAINTAINERS.
Signed-off-by: Jouni Malinen <j@w1.fi>
To clearly state the intent of copying from linear sk_buffs, _offset being a
overly long variant but interesting for the sake of saving some bytes.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
For the common, open coded 'skb->mac.raw = skb->data' operation, so that we can
later turn skb->mac.raw into a offset, reducing the size of struct sk_buff in
64bit land while possibly keeping it as a pointer on 32bit.
This one touches just the most simple case, next will handle the slightly more
"complex" cases.
Run this:
#!/bin/sh
for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do
echo "De-casting $f..."
perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f
done
And then go through and reinstate those cases where code is casting pointers
to non-pointers.
And then drop a few hunks which conflicted with outstanding work.
Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Greg KH <greg@kroah.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Paul Fulghum <paulkf@microgate.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Karsten Keil <kkeil@suse.de>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Ian Kent <raven@themaw.net>
Cc: Steven French <sfrench@us.ibm.com>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Cc: Jaroslav Kysela <perex@suse.cz>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into upstream
drivers/net/wireless/zd1211rw/zd_mac.h
net/ieee80211/softmac/ieee80211softmac_assoc.c
Replace kmalloc+memset with kzalloc
Signed-off-by: Yan Burman <burman.yan@gmail.com>
Fix up for make allyesconfig.
Signed-Off-By: David Howells <dhowells@redhat.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Intersil firmware 1.7.4 (and possibly others) loses the antenna
selection settings when the port is reset.
Signed-off-by: David Acker <dacker@roinet.com>
On Fri, 2006-06-30 at 15:45 -0700, Miles Lane wrote:
> Okay, I rebuilt my kernel with your combo patch applied.
> Then, I inserted my US Robotics USR2210 PCMCIA wifi card,
> ran "pccardutil eject", popped out the card and then inserted
> a Compaq iPaq wifi card. This triggered the following.
> [ INFO: possible circular locking dependency detected ]
> syslogd/1886 is trying to acquire lock:
> (&dev->queue_lock){-+..}, at: [<c11a50b5>] dev_queue_xmit+0x120/0x24b
> but task is already holding lock:
> (&dev->_xmit_lock){-+..}, at: [<c11a5118>] dev_queue_xmit+0x183/0x24b
> which lock already depends on the new lock.
ok this appears to be hostap playing games... it has 2 network devices
for one piece of hardware and one calls the other via the networking
layer; there is thankfully a natural ordering between the two, so just
making the slave one a separate type ought to make this work.
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: "John W. Linville" <linville@tuxdriver.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
