We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to
meet kernel coding style guidelines. This issue was reported by checkpatch.
A simplified version of the semantic patch that makes this change is as
follows (http://coccinelle.lip6.fr/):
// <smpl>
identifier i;
declarer name DEFINE_PCI_DEVICE_TABLE;
initializer z;
- DEFINE_PCI_DEVICE_TABLE(i)
+ const struct pci_device_id i[]
= z;
// </smpl>
[bhelgaas: add semantic patch]
Signed-off-by: Benoit Taine <benoit.taine@lip6.fr>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com>
This patch converts the drivers in drivers/net/wireless/* to use
module_pci_driver() macro which makes the code smaller and a bit simpler.
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: Jiri Slaby <jirislaby@gmail.com>
Cc: Nick Kossifidis <mickflemm@gmail.com>
Cc: "Luis R. Rodriguez" <mcgrof@qca.qualcomm.com>
Cc: Simon Kelley <simon@thekelleys.org.uk>
Cc: Jouni Malinen <j@w1.fi>
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: Christian Lamparter <chunkeey@googlemail.com>
Cc: Ivo van Doorn <IvDoorn@gmail.com>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: linux-wireless@vger.kernel.org
Acked-by: Lennert Buytenhek <buytenh@wantstofly.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section
in every case.
net/mac80211/tx.c: In function ‘ieee80211_tx_h_select_key’:
net/mac80211/tx.c:448: warning: ‘key’ may be used uninitialized in this function
drivers/net/wireless/ath/ath9k/rc.c: In function ‘ath_rc_rate_getidx’:
drivers/net/wireless/ath/ath9k/rc.c:815: warning: ‘nextindex’ may be used uninitialized in this function
drivers/net/wireless/hostap/hostap_plx.c: In function ‘prism2_plx_probe’:
drivers/net/wireless/hostap/hostap_plx.c:438: warning: ‘cor_index’ may be used uninitialized in this function
drivers/net/wireless/hostap/hostap_plx.c:438: warning: ‘cor_offset’ may be used uninitialized in this function
Fix section mismatch by changing variable name to match one of the
whitelisted (allowable) names for pointing into init data:
WARNING: vmlinux.o(.data+0xce618): Section mismatch: reference to .init.data:prism2_plx_id_table (between 'prism2_plx_drv_id' and 'dev_info')
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Remove pointless and never-called enable_wake() hook from pci_driver and
from documentation. Evidently this was introduced in the 2.4.6 kernel,
but there's no evidence it was ever called; and it was rarely implemented.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
The driver version number has not been updated since the driver was
included in the main kernel tree and there is no plan on updating this
in the future either. At this point, the only correct way to refer to
the version is to use the kernel version. The 0.4.4 version is
confusing since there are external version with higher version number
even though they are not actually any newer than the in-tree version.
Let's get rid of the version number in the kernel tree in order to
avoid this kind of confusion.
Signed-off-by: Jouni Malinen <j@w1.fi>
After 13 years of use, it looks like my email address is finally going
to disappear. While this is likely to drop the amount of incoming spam
greatly ;-), it may also affect more appropriate messages, so let's
update my email address in various places. In addition, Host AP mailing
list is subscribers-only and linux-wireless can also be used for
discussing issues related to this driver which is now shown in
MAINTAINERS.
Replace kmalloc+memset with kzalloc
Signed-off-by: Yan Burman <burman.yan@gmail.com>
The length of the manfid CIS should be at least 4, and it's normally 4.
It's incorrect to require it to be at least 5. This breaks support for
most (if not all) cards.
The right place to ensure that we don't access beyond the CIS buffer is
to strengthen another check. Make sure that the next tuple begins at
least at the CIS buffer end (in which case we stop processing) or
before that.
Reported by ph35sm@free.fr
Signed-off-by: Pavel Roskin <proski@gnu.org>
This patch adds device IDs for Symbol LA-4123 and Global Sun Tech
GL24110P to the HostAP PLX driver.
This is not tested with real hardware, but there is no reason why it
shouldn't work.
Please test.
Signed-off-by: Faidon Liambotis <faidon@cube.gr>
Cc: Jeff Garzik <jeff@garzik.org>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
The Coverity checker (CID: 659, 660) spotted this resource leak on
PCI probe error path. Free private data structure if pci_enable_device()
fails.
Signed-off-by: Jouni Malinen <jkmaline@cc.hut.fi>
The Coverity checker (CID: 452, 453, 454, 455, 456) spotted this
unlikely read overrun of CIS buffer. Abort if CISTPL_CONFIG or
CISTPL_MANFID would not fit in buffer.
This patch removes almost all inclusions of linux/version.h. The 3
#defines are unused in most of the touched files.
A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is
unfortunatly in linux/version.h.
There are also lots of #ifdef for long obsolete kernels, this was not
touched. In a few places, the linux/version.h include was move to where
the LINUX_VERSION_CODE was used.
quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'`
search pattern:
/UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h
Signed-off-by: Olaf Hering <olh@suse.de>
local->hw_priv was being freed and set to NULL just before calling
prism2_free_local_data(). However, this may expose a race condition in
which something ends up trying to use hw_priv during shutdown. I
haven't noticed this happening, but better be safe than sorry, so
let's postpone hw_priv freeing to happen only after
prism2_free_local_data() has returned.
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
Host AP driver used hardware model specific dev_open/close handlers
that were called on dev_open/close if the hardware driver had
registered the handler. These were only used for hostap_cs and only
for tracking whether any of the netdevs were UP. This information is
already available from local->num_dev_open, so there is not need for
the special open/close handler.
Let's get rid of these handlers. In addition to cleaning up the code,
this fixes a module refcounting issue for hostap_cs where ejecting the
card while any of the netdevs were open did not decrement refcount
properly.
hostap_pci and hostap_plx drivers still use PCI driver names
"prism2_pci" and "prism2_plx" respectively. This is unfriendly to
linux-wlan-ng, which uses the same names. So, if e.g. hostap_pci and
prism2_pci are loaded, they will "share" /sys/bus/pci/drivers/prism2_plx
directory.
Change PCI driver names of hostap_pci and hostap_plx to be equal to
their module names.
Replace hardware model specific #ifdef's in struct local_info with
void *hw_priv that is pointing to cs/pci/plx specific data
structure. This removes unneeded #ifdef's and as such, is a step
towards making it possible to share objects for hostap_hw.c and
hostap_download.c with cs/pci/plx drivers without having to compile
and link the same code separately for each one.
Add MODULE_VERSION information for the Host AP kernel modules and
update the version string to indicate which version of the external
Host AP driver is included in the kernel tree.
Create sysfs "device" files for hostap
I was writing some scripts to automatically build kismet source lines,
and I noticed that hostap devices don't have device files, unlike my
prism54 and ipw2200 cards:
$ ls -l /sys/class/net/eth0/device
/sys/class/net/eth0/device -> ../../../devices/pci0000:00/0000:00:1e.0/0000:02:01.0
$ ls -l /sys/class/net/wifi0
ls: /sys/class/net/wifi0/device: No such file or directory
$ ls -l /sys/class/net/wlan0
ls: /sys/class/net/wlan0/device: No such file or directory
The following (quite small) patch makes sure that both the wlan and wifi
net devices have that pointer to the bus device.
This way, I can do things like
for i in /sys/class/net/*; do
if ! [ -e $i/device/drive ]; then
continue;
fi;
driver=$(basename $(readlink $i/device/driver))
case $driver in
hostap*)
echo -- hostap,$i,$i-$driver
break;
ipw2?00)
echo -- $driver,$i,$i-$driver
break;
prism54)
echo prism54g,$i
esac
done
Which should generate a working set of source lines for kismet no matter
what order I plug the cards in.
It might also be handy to have a link between the two net devices, but
that's a patch for another day.
That patch is against 2.6.13-rc1-mm1.
-- Dave
Signed-off-by: Dave Hansen <haveblue@us.ibm.com>
Includes minor cleanups from Adrian Bunk <bunk@stusta.de>.
