commit 6e41e2257f1094acc37618bf6c856115374c6922 upstream.
The syzbot fuzzer found a bug in the p54 USB wireless driver. The
issue involves a race between disconnect and the firmware-loader
callback routine, and it has several aspects.
One big problem is that when the firmware can't be loaded, the
callback routine tries to unbind the driver from the USB _device_ (by
calling device_release_driver) instead of from the USB _interface_ to
which it is actually bound (by calling usb_driver_release_interface).
The race involves access to the private data structure. The driver's
disconnect handler waits for a completion that is signalled by the
firmware-loader callback routine. As soon as the completion is
signalled, you have to assume that the private data structure may have
been deallocated by the disconnect handler -- even if the firmware was
loaded without errors. However, the callback routine does access the
private data several times after that point.
Another problem is that, in order to ensure that the USB device
structure hasn't been freed when the callback routine runs, the driver
takes a reference to it. This isn't good enough any more, because now
that the callback routine calls usb_driver_release_interface, it has
to ensure that the interface structure hasn't been freed.
Finally, the driver takes an unnecessary reference to the USB device
structure in the probe function and drops the reference in the
disconnect handler. This extra reference doesn't accomplish anything,
because the USB core already guarantees that a device structure won't
be deallocated while a driver is still bound to any of its interfaces.
To fix these problems, this patch makes the following changes:
Call usb_driver_release_interface() rather than
device_release_driver().
Don't signal the completion until after the important
information has been copied out of the private data structure,
and don't refer to the private data at all thereafter.
Lock udev (the interface's parent) before unbinding the driver
instead of locking udev->parent.
During the firmware loading process, take a reference to the
USB interface instead of the USB device.
Don't take an unnecessary reference to the device during probe
(and then don't drop it during disconnect).
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-and-tested-by: syzbot+200d4bb11b23d929335f@syzkaller.appspotmail.com
CC: <stable@vger.kernel.org>
Acked-by: Christian Lamparter <chunkeey@gmail.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit 8149069db81853570a665f5e5648c0e526dc0e43 upstream.
The function p54p_probe takes an extra reference count of the PCI
device. However, the extra reference count is not dropped when it fails
to enable the PCI device. This patch fixes the bug.
Cc: stable@vger.kernel.org
Signed-off-by: Pan Bian <bianpan2016@163.com>
commit fc09785de0a364427a5df63d703bae9a306ed116 upstream.
ieee80211_register_hw() in p54_register_common() may fail and leds won't
get initialized. Currently p54_unregister_common() doesn't check that and
always calls p54_unregister_leds(). The fix is to check priv->registered
flag before calling p54_unregister_leds().
Found by syzkaller.
INFO: trying to register non-static key.
the code is fine but needs lockdep annotation.
turning off the locking correctness validator.
CPU: 1 PID: 1404 Comm: kworker/1:1 Not tainted
4.14.0-rc1-42251-gebb2c2437d80-dirty #205
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Workqueue: usb_hub_wq hub_event
Call Trace:
__dump_stack lib/dump_stack.c:16
dump_stack+0x292/0x395 lib/dump_stack.c:52
register_lock_class+0x6c4/0x1a00 kernel/locking/lockdep.c:769
__lock_acquire+0x27e/0x4550 kernel/locking/lockdep.c:3385
lock_acquire+0x259/0x620 kernel/locking/lockdep.c:4002
flush_work+0xf0/0x8c0 kernel/workqueue.c:2886
__cancel_work_timer+0x51d/0x870 kernel/workqueue.c:2961
cancel_delayed_work_sync+0x1f/0x30 kernel/workqueue.c:3081
p54_unregister_leds+0x6c/0xc0 drivers/net/wireless/intersil/p54/led.c:160
p54_unregister_common+0x3d/0xb0 drivers/net/wireless/intersil/p54/main.c:856
p54u_disconnect+0x86/0x120 drivers/net/wireless/intersil/p54/p54usb.c:1073
usb_unbind_interface+0x21c/0xa90 drivers/usb/core/driver.c:423
__device_release_driver drivers/base/dd.c:861
device_release_driver_internal+0x4f4/0x5c0 drivers/base/dd.c:893
device_release_driver+0x1e/0x30 drivers/base/dd.c:918
bus_remove_device+0x2f4/0x4b0 drivers/base/bus.c:565
device_del+0x5c4/0xab0 drivers/base/core.c:1985
usb_disable_device+0x1e9/0x680 drivers/usb/core/message.c:1170
usb_disconnect+0x260/0x7a0 drivers/usb/core/hub.c:2124
hub_port_connect drivers/usb/core/hub.c:4754
hub_port_connect_change drivers/usb/core/hub.c:5009
port_event drivers/usb/core/hub.c:5115
hub_event+0x1318/0x3740 drivers/usb/core/hub.c:5195
process_one_work+0xc7f/0x1db0 kernel/workqueue.c:2119
process_scheduled_works kernel/workqueue.c:2179
worker_thread+0xb2b/0x1850 kernel/workqueue.c:2255
kthread+0x3a1/0x470 kernel/kthread.c:231
ret_from_fork+0x2a/0x40 arch/x86/entry/entry_64.S:431
Signed-off-by: Andrey Konovalov <andreyknvl@google.com>
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
usb_device_id are not supposed to change at runtime. All functions
working with usb_device_id provided by <linux/usb.h> work with
const usb_device_id. So mark the non-const structs as const.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
After commit cf124db566e6 ("net: Fix inconsistent teardown and
release of private netdev state."), setting
'dev->needs_free_netdev' ensures device data is released, and
'dev->destructor' is not used anymore.
Fixes: cf124db566e6 ("net: Fix inconsistent teardown and release of private netdev state.")
Signed-off-by: Stefano Brivio <sbrivio@redhat.com>
Pull networking updates from David Miller:
"Reasonably busy this cycle, but perhaps not as busy as in the 4.12
merge window:
1) Several optimizations for UDP processing under high load from
Paolo Abeni.
2) Support pacing internally in TCP when using the sch_fq packet
scheduler for this is not practical. From Eric Dumazet.
3) Support mutliple filter chains per qdisc, from Jiri Pirko.
4) Move to 1ms TCP timestamp clock, from Eric Dumazet.
5) Add batch dequeueing to vhost_net, from Jason Wang.
6) Flesh out more completely SCTP checksum offload support, from
Davide Caratti.
7) More plumbing of extended netlink ACKs, from David Ahern, Pablo
Neira Ayuso, and Matthias Schiffer.
8) Add devlink support to nfp driver, from Simon Horman.
9) Add RTM_F_FIB_MATCH flag to RTM_GETROUTE queries, from Roopa
Prabhu.
10) Add stack depth tracking to BPF verifier and use this information
in the various eBPF JITs. From Alexei Starovoitov.
11) Support XDP on qed device VFs, from Yuval Mintz.
12) Introduce BPF PROG ID for better introspection of installed BPF
programs. From Martin KaFai Lau.
13) Add bpf_set_hash helper for TC bpf programs, from Daniel Borkmann.
14) For loads, allow narrower accesses in bpf verifier checking, from
Yonghong Song.
15) Support MIPS in the BPF selftests and samples infrastructure, the
MIPS eBPF JIT will be merged in via the MIPS GIT tree. From David
Daney.
16) Support kernel based TLS, from Dave Watson and others.
17) Remove completely DST garbage collection, from Wei Wang.
18) Allow installing TCP MD5 rules using prefixes, from Ivan
Delalande.
19) Add XDP support to Intel i40e driver, from Björn Töpel
20) Add support for TC flower offload in nfp driver, from Simon
Horman, Pieter Jansen van Vuuren, Benjamin LaHaise, Jakub
Kicinski, and Bert van Leeuwen.
21) IPSEC offloading support in mlx5, from Ilan Tayari.
22) Add HW PTP support to macb driver, from Rafal Ozieblo.
23) Networking refcount_t conversions, From Elena Reshetova.
24) Add sock_ops support to BPF, from Lawrence Brako. This is useful
for tuning the TCP sockopt settings of a group of applications,
currently via CGROUPs"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1899 commits)
net: phy: dp83867: add workaround for incorrect RX_CTRL pin strap
dt-bindings: phy: dp83867: provide a workaround for incorrect RX_CTRL pin strap
cxgb4: Support for get_ts_info ethtool method
cxgb4: Add PTP Hardware Clock (PHC) support
cxgb4: time stamping interface for PTP
nfp: default to chained metadata prepend format
nfp: remove legacy MAC address lookup
nfp: improve order of interfaces in breakout mode
net: macb: remove extraneous return when MACB_EXT_DESC is defined
bpf: add missing break in for the TCP_BPF_SNDCWND_CLAMP case
bpf: fix return in load_bpf_file
mpls: fix rtm policy in mpls_getroute
net, ax25: convert ax25_cb.refcount from atomic_t to refcount_t
net, ax25: convert ax25_route.refcount from atomic_t to refcount_t
net, ax25: convert ax25_uid_assoc.refcount from atomic_t to refcount_t
net, sctp: convert sctp_ep_common.refcnt from atomic_t to refcount_t
net, sctp: convert sctp_transport.refcnt from atomic_t to refcount_t
net, sctp: convert sctp_chunk.refcnt from atomic_t to refcount_t
net, sctp: convert sctp_datamsg.refcnt from atomic_t to refcount_t
net, sctp: convert sctp_auth_bytes.refcnt from atomic_t to refcount_t
Rename:
wait_queue_t => wait_queue_entry_t
'wait_queue_t' was always a slight misnomer: its name implies that it's a "queue",
but in reality it's a queue *entry*. The 'real' queue is the wait queue head,
which had to carry the name.
Start sorting this out by renaming it to 'wait_queue_entry_t'.
This also allows the real structure name 'struct __wait_queue' to
lose its double underscore and become 'struct wait_queue_entry',
which is the more canonical nomenclature for such data types.
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions return void * and remove all the casts across
the tree, adding a (u8 *) cast only where the unsigned char pointer
was used directly, all done with the following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = { skb_push, __skb_push, skb_push_rcsum };
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
- fn(SKB, LEN)[0]
Note that the last part there converts from push(...)[0] to the
more idiomatic *(u8 *)push(...).
Make these functions (skb_put, __skb_put and pskb_put) return void *
and remove all the casts across the tree, adding a (u8 *) cast only
where the unsigned char pointer was used directly, all done with the
following spatch:
typedef u8;
identifier fn = { skb_put, __skb_put };
- *(fn(SKB, LEN))
type T;
+ E = fn(SKB, LEN)
which actually doesn't cover pskb_put since there are only three
users overall.
A handful of stragglers were converted manually, notably a macro in
drivers/isdn/i4l/isdn_bsdcomp.c and, oddly enough, one of the many
instances in net/bluetooth/hci_sock.c. In the former file, I also
had to fix one whitespace problem spatch introduced.
A common pattern with skb_put() is to just want to memcpy()
some data into the new space, introduce skb_put_data() for
this.
An spatch similar to the one for skb_put_zero() converts many
of the places using it:
identifier p, p2;
expression len, skb, data;
type t, t2;
-p = skb_put(skb, len);
+p = skb_put_data(skb, data, len);
-p = (t)skb_put(skb, len);
p2 = (t2)p;
-memcpy(p2, data, len);
-memcpy(p, data, len);
type t, t2;
identifier p, p2;
expression skb, data;
t *p;
-p = skb_put(skb, sizeof(t));
+p = skb_put_data(skb, data, sizeof(t));
-p = (t *)skb_put(skb, sizeof(t));
p2 = (t2)p;
-memcpy(p2, data, sizeof(*p));
-memcpy(p, data, sizeof(*p));
expression skb, len, data;
-memcpy(skb_put(skb, len), data, len);
+skb_put_data(skb, data, len);
(again, manually post-processed to retain some comments)
Reviewed-by: Stephen Hemminger <stephen@networkplumber.org>
There were many places that my previous spatch didn't find,
as pointed out by yuan linyu in various patches.
The following spatch found many more and also removes the
now unnecessary casts:
identifier p, p2;
expression len;
expression skb;
type t, t2;
+p = skb_put_zero(skb, len);
... when != p
p2 = (t2)p;
-memset(p2, 0, len);
-memset(p, 0, len);
type t, t2;
identifier p, p2;
expression skb;
t *p;
+p = skb_put_zero(skb, sizeof(t));
... when != p
p2 = (t2)p;
-memset(p2, 0, sizeof(*p));
-memset(p, 0, sizeof(*p));
expression skb, len;
-memset(skb_put(skb, len), 0, len);
+skb_put_zero(skb, len);
Apply it to the tree (with one manual fixup to keep the
comment in vxlan.c, which spatch removed.)
The conflicts were two cases of overlapping changes in
batman-adv and the qed driver.
Network devices can allocate reasources and private memory using
netdev_ops->ndo_init(). However, the release of these resources
can occur in one of two different places.
Either netdev_ops->ndo_uninit() or netdev->destructor().
The decision of which operation frees the resources depends upon
whether it is necessary for all netdev refs to be released before it
is safe to perform the freeing.
netdev_ops->ndo_uninit() presumably can occur right after the
NETDEV_UNREGISTER notifier completes and the unicast and multicast
address lists are flushed.
netdev->destructor(), on the other hand, does not run until the
netdev references all go away.
Further complicating the situation is that netdev->destructor()
almost universally does also a free_netdev().
This creates a problem for the logic in register_netdevice().
Because all callers of register_netdevice() manage the freeing
of the netdev, and invoke free_netdev(dev) if register_netdevice()
fails.
If netdev_ops->ndo_init() succeeds, but something else fails inside
of register_netdevice(), it does call ndo_ops->ndo_uninit(). But
it is not able to invoke netdev->destructor().
This is because netdev->destructor() will do a free_netdev() and
then the caller of register_netdevice() will do the same.
However, this means that the resources that would normally be released
by netdev->destructor() will not be.
Over the years drivers have added local hacks to deal with this, by
invoking their destructor parts by hand when register_netdevice()
fails.
Many drivers do not try to deal with this, and instead we have leaks.
Let's close this hole by formalizing the distinction between what
private things need to be freed up by netdev->destructor() and whether
the driver needs unregister_netdevice() to perform the free_netdev().
netdev->priv_destructor() performs all actions to free up the private
resources that used to be freed by netdev->destructor(), except for
free_netdev().
netdev->needs_free_netdev is a boolean that indicates whether
free_netdev() should be done at the end of unregister_netdevice().
Now, register_netdevice() can sanely release all resources after
ndo_ops->ndo_init() succeeds, by invoking both ndo_ops->ndo_uninit()
and netdev->priv_destructor().
And at the end of unregister_netdevice(), we invoke
netdev->priv_destructor() and optionally call free_netdev().
We have the number of longs, but we should be calculating the number of
bytes needed.
refcount_t type and corresponding API should be
used instead of atomic_t when the variable is used as
a reference counter. This allows to avoid accidental
refcounter overflows that might lead to use-after-free
situations.
Signed-off-by: Elena Reshetova <elena.reshetova@intel.com>
Signed-off-by: Hans Liljestrand <ishkamiel@gmail.com>
Signed-off-by: David Windsor <dwindsor@gmail.com>
situations.
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
Johannes Berg says:
Another set of patches for -next:
* API support for concurrent scheduled scan requests
* API changes for roaming reporting
* BSS max idle support in mac80211
* API changes for TX status reporting in mac80211
* API changes for RX rate reporting in mac80211
* rewrite monitor logic to prepare for BPF filters
* bugfix for rare devices without 2.4 GHz support
* a bugfix for recent DFS changes
* some further cleanups
The API changes are actually at a nice time, since it's
typically quiet just before the merge window, and trees
can be synchronized easily during it.
In preparation for adding support for HE rates, clean up
the driver report encoding for rate/bandwidth reporting
on RX frames.
Much of this patch was done with the following spatch:
expression status;
-status->flag & (RX_FLAG_HT | RX_FLAG_VHT)
+status->enc_flags & (RX_ENC_FLAG_HT | RX_ENC_FLAG_VHT)
assignment operator op;
expression status;
-status->flag op RX_FLAG_SHORTPRE
+status->enc_flags op RX_ENC_FLAG_SHORTPRE
expression status;
-status->flag & RX_FLAG_SHORTPRE
+status->enc_flags & RX_ENC_FLAG_SHORTPRE
expression status;
-status->flag op RX_FLAG_HT
+status->enc_flags op RX_ENC_FLAG_HT
expression status;
-status->flag & RX_FLAG_HT
+status->enc_flags & RX_ENC_FLAG_HT
expression status;
-status->flag op RX_FLAG_40MHZ
+status->enc_flags op RX_ENC_FLAG_40MHZ
expression status;
-status->flag & RX_FLAG_40MHZ
+status->enc_flags & RX_ENC_FLAG_40MHZ
expression status;
-status->flag op RX_FLAG_SHORT_GI
+status->enc_flags op RX_ENC_FLAG_SHORT_GI
expression status;
-status->flag & RX_FLAG_SHORT_GI
+status->enc_flags & RX_ENC_FLAG_SHORT_GI
expression status;
-status->flag op RX_FLAG_HT_GF
+status->enc_flags op RX_ENC_FLAG_HT_GF
expression status;
-status->flag & RX_FLAG_HT_GF
+status->enc_flags & RX_ENC_FLAG_HT_GF
expression status;
-status->flag op RX_FLAG_VHT
+status->enc_flags op RX_ENC_FLAG_VHT
expression status;
-status->flag & RX_FLAG_VHT
+status->enc_flags & RX_ENC_FLAG_VHT
expression status;
-status->flag op RX_FLAG_STBC_MASK
+status->enc_flags op RX_ENC_FLAG_STBC_MASK
expression status;
-status->flag & RX_FLAG_STBC_MASK
+status->enc_flags & RX_ENC_FLAG_STBC_MASK
expression status;
-status->flag op RX_FLAG_LDPC
+status->enc_flags op RX_ENC_FLAG_LDPC
expression status;
-status->flag & RX_FLAG_LDPC
+status->enc_flags & RX_ENC_FLAG_LDPC
expression status;
-status->flag op RX_FLAG_10MHZ
+status->enc_flags op RX_ENC_FLAG_10MHZ
expression status;
-status->flag & RX_FLAG_10MHZ
+status->enc_flags & RX_ENC_FLAG_10MHZ
expression status;
-status->flag op RX_FLAG_5MHZ
+status->enc_flags op RX_ENC_FLAG_5MHZ
expression status;
-status->flag & RX_FLAG_5MHZ
+status->enc_flags & RX_ENC_FLAG_5MHZ
expression status;
-status->vht_flag op RX_VHT_FLAG_80MHZ
+status->enc_flags op RX_ENC_FLAG_80MHZ
expression status;
-status->vht_flag & RX_VHT_FLAG_80MHZ
+status->enc_flags & RX_ENC_FLAG_80MHZ
expression status;
-status->vht_flag op RX_VHT_FLAG_160MHZ
+status->enc_flags op RX_ENC_FLAG_160MHZ
expression status;
-status->vht_flag & RX_VHT_FLAG_160MHZ
+status->enc_flags & RX_ENC_FLAG_160MHZ
expression status;
-status->vht_flag op RX_VHT_FLAG_BF
+status->enc_flags op RX_ENC_FLAG_BF
expression status;
-status->vht_flag & RX_VHT_FLAG_BF
+status->enc_flags & RX_ENC_FLAG_BF
expression status, STBC;
-status->flag op STBC << RX_FLAG_STBC_SHIFT
+status->enc_flags op STBC << RX_ENC_FLAG_STBC_SHIFT
expression status;
-status.flag op RX_FLAG_SHORTPRE
+status.enc_flags op RX_ENC_FLAG_SHORTPRE
expression status;
-status.flag & RX_FLAG_SHORTPRE
+status.enc_flags & RX_ENC_FLAG_SHORTPRE
expression status;
-status.flag op RX_FLAG_HT
+status.enc_flags op RX_ENC_FLAG_HT
expression status;
-status.flag & RX_FLAG_HT
+status.enc_flags & RX_ENC_FLAG_HT
expression status;
-status.flag op RX_FLAG_40MHZ
+status.enc_flags op RX_ENC_FLAG_40MHZ
expression status;
-status.flag & RX_FLAG_40MHZ
+status.enc_flags & RX_ENC_FLAG_40MHZ
expression status;
-status.flag op RX_FLAG_SHORT_GI
+status.enc_flags op RX_ENC_FLAG_SHORT_GI
expression status;
-status.flag & RX_FLAG_SHORT_GI
+status.enc_flags & RX_ENC_FLAG_SHORT_GI
expression status;
-status.flag op RX_FLAG_HT_GF
+status.enc_flags op RX_ENC_FLAG_HT_GF
expression status;
-status.flag & RX_FLAG_HT_GF
+status.enc_flags & RX_ENC_FLAG_HT_GF
expression status;
-status.flag op RX_FLAG_VHT
+status.enc_flags op RX_ENC_FLAG_VHT
expression status;
-status.flag & RX_FLAG_VHT
+status.enc_flags & RX_ENC_FLAG_VHT
expression status;
-status.flag op RX_FLAG_STBC_MASK
+status.enc_flags op RX_ENC_FLAG_STBC_MASK
expression status;
-status.flag & RX_FLAG_STBC_MASK
+status.enc_flags & RX_ENC_FLAG_STBC_MASK
expression status;
-status.flag op RX_FLAG_LDPC
+status.enc_flags op RX_ENC_FLAG_LDPC
expression status;
-status.flag & RX_FLAG_LDPC
+status.enc_flags & RX_ENC_FLAG_LDPC
expression status;
-status.flag op RX_FLAG_10MHZ
+status.enc_flags op RX_ENC_FLAG_10MHZ
expression status;
-status.flag & RX_FLAG_10MHZ
+status.enc_flags & RX_ENC_FLAG_10MHZ
expression status;
-status.flag op RX_FLAG_5MHZ
+status.enc_flags op RX_ENC_FLAG_5MHZ
expression status;
-status.flag & RX_FLAG_5MHZ
+status.enc_flags & RX_ENC_FLAG_5MHZ
expression status;
-status.vht_flag op RX_VHT_FLAG_80MHZ
+status.enc_flags op RX_ENC_FLAG_80MHZ
expression status;
-status.vht_flag & RX_VHT_FLAG_80MHZ
+status.enc_flags & RX_ENC_FLAG_80MHZ
expression status;
-status.vht_flag op RX_VHT_FLAG_160MHZ
+status.enc_flags op RX_ENC_FLAG_160MHZ
expression status;
-status.vht_flag & RX_VHT_FLAG_160MHZ
+status.enc_flags & RX_ENC_FLAG_160MHZ
expression status;
-status.vht_flag op RX_VHT_FLAG_BF
+status.enc_flags op RX_ENC_FLAG_BF
expression status;
-status.vht_flag & RX_VHT_FLAG_BF
+status.enc_flags & RX_ENC_FLAG_BF
-status.flag op STBC << RX_FLAG_STBC_SHIFT
+status.enc_flags op STBC << RX_ENC_FLAG_STBC_SHIFT
-RX_FLAG_STBC_SHIFT
+RX_ENC_FLAG_STBC_SHIFT
Allocate buffer on HEAP instead of STACK for a local variable
that is to be sent using usb_control_msg().
Signed-off-by: Maksim Salau <maksim.salau@gmail.com>
trivial fix to spelling mistake in dbg_dbg message
Instead passing both flags, which can be NULL, and vif_params,
which are never NULL, move the flags into the vif_params and
use BIT(0), which is invalid from userspace, to indicate that
the flags were changed.
While updating all drivers, fix a small bug in wil6210 where
it was setting the flags to 0 instead of leaving them unchanged.
<linux/sched.h> into <linux/sched/signal.h>
Fix up affected files that include this signal functionality via sched.h.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Instead of using a private copy of struct net_device_stats in
struct orinoco_private, use stats from struct net_device. Also remove
the now unnecessary .ndo_get_stats function.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
git://git.kernel.org/pub/scm/linux/kernel/git/kvalo/wireless-drivers-next
Kalle Valo says:
wireless-drivers-next patches for 4.11
The most notable change here is the inclusion of airtime fairness
scheduling to ath9k. It prevents slow clients from hogging all the
airtime and unfairly slowing down faster clients.
Otherwise smaller changes and cleanup.
Major changes:
ath9k
* cleanup eeprom endian handling
* add airtime fairness scheduling
ath10k
* fix issues for new QCA9377 firmware version
* support dev_coredump() for firmware crash dump
* enable channel 169 on 5 GHz band
Eric Biggers pointed out that the orinoco driver pointed scatterlists
at the stack.
Fix it by switching from ahash to shash. The result should be
simpler, faster, and more correct.
Cc: stable@vger.kernel.org # 4.9 only
Reported-by: Eric Biggers <ebiggers3@gmail.com>
Signed-off-by: Andy Lutomirski <luto@kernel.org>
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
That's the default now, no need for makefiles to set it.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Kalle Valo <kvalo@codeaurora.org>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Acked-by: Marc Kleine-Budde <mkl@pengutronix.de>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Arend van Spriel <arend.vanspriel@broadcom.com>
The hostap_80211_rx() function is supposed to set up the mac addresses
for four possible cases, based on two bits of input data. For
some reason, gcc decides that it's possible that none of the these
four cases apply and the addresses remain uninitialized:
drivers/net/wireless/intersil/hostap/hostap_80211_rx.c: In function ‘hostap_80211_rx’:
arch/x86/include/asm/string_32.h:77:14: warning: ‘src’ may be used uninitialized in this function [-Wmaybe-uninitialized]
drivers/net/wireless/intel/ipw2x00/libipw_rx.c: In function ‘libipw_rx’:
arch/x86/include/asm/string_32.h:77:14: error: ‘dst’ may be used uninitialized in this function [-Werror=maybe-uninitialized]
arch/x86/include/asm/string_32.h:78:22: error: ‘*((void *)&dst+4)’ may be used uninitialized in this function [-Werror=maybe-uninitialized]
This warning is clearly nonsense, but changing the last case into
'default' makes it obvious to the compiler too, which avoids the
warning and probably leads to better object code too.
The same code is duplicated several times in the kernel, so this
patch uses the same workaround for all copies. The exact configuration
was hit only very rarely in randconfig builds and I only saw it
in three drivers, but I assume that all of them are potentially
affected, and it's better to keep the code consistent.
gcc 7 complains:
drivers/net/wireless/intersil/p54/fwio.c: In function 'p54_scan':
drivers/net/wireless/intersil/p54/fwio.c:491:4: warning: 'memset' used with length equal to number of elements without multiplication by element size [-Wmemset-elt-size]
Fix that by passing the correct size to memset.
Cc: Christian Lamparter <chunkeey@googlemail.com>
Cc: Kalle Valo <kvalo@codeaurora.org>
Cc: linux-wireless@vger.kernel.org
Cc: netdev@vger.kernel.org
- set max_mtu in wil6210 driver
- set max_mtu in atmel driver
- set min/max_mtu in cisco airo driver, remove airo_change_mtu
- set min/max_mtu in ipw2100/ipw2200 drivers, remove libipw_change_mtu
- set min/max_mtu in p80211netdev, remove wlan_change_mtu
- set min/max_mtu in net/mac80211/iface.c and remove ieee80211_change_mtu
- set min/max_mtu in wimax/i2400m and remove i2400m_change_mtu
- set min/max_mtu in intersil/hostap and remove prism2_change_mtu
- set min/max_mtu in intersil/orinoco
- set min/max_mtu in tty/n_gsm and remove gsm_change_mtu
CC: netdev@vger.kernel.org
CC: linux-wireless@vger.kernel.org
CC: Maya Erez <qca_merez@qca.qualcomm.com>
CC: Simon Kelley <simon@thekelleys.org.uk>
CC: Stanislav Yakovlev <stas.yakovlev@gmail.com>
CC: Johannes Berg <johannes@sipsolutions.net>
CC: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
Signed-off-by: Jarod Wilson <jarod@redhat.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
With centralized MTU checking, there's nothing productive done by
eth_change_mtu that isn't already done in dev_set_mtu, so mark it as
deprecated and remove all usage of it in the kernel. All callers have been
audited for calls to alloc_etherdev* or ether_setup directly, which means
they all have a valid dev->min_mtu and dev->max_mtu. Now eth_change_mtu
prints out a netdev_warn about being deprecated, for the benefit of
out-of-tree drivers that might be utilizing it.
Of note, dvb_net.c actually had dev->mtu = 4096, while using
eth_change_mtu, meaning that if you ever tried changing it's mtu, you
couldn't set it above 1500 anymore. It's now getting dev->max_mtu also set
to 4096 to remedy that.
v2: fix up lantiq_etop, missed breakage due to drive not compiling on x86
Fix coccicheck warning which recommends to
use memdup_user() instead of reimplementing its
code.
This patch fixes below coccicheck warnings:
drivers/net/wireless/intersil/hostap/hostap_ioctl.c:3044:9-16: WARNING
opportunity for memdup_user
drivers/net/wireless/intersil/hostap/hostap_ioctl.c:3806:9-16: WARNING
Signed-off-by: Rajan Vaja <rajan.vaja@gmail.com>
Reviewed-by: Julian Calaby <julian.calaby@gmail.com>
allocating urb fails
kmalloc will print enough information in case of failure.
Signed-off-by: Wolfram Sang <wsa-dev@sang-engineering.com>
Beacon report radio measurement requires reporting observed BSSs
on the channels specified in the beacon request. If the measurement
mode is set to passive or active, it requires actually performing a
scan (passive or active, accordingly), and reporting the time that
the scan was started and the time each beacon/probe was received
(both in terms of TSF of the BSS of the requesting AP). If the
request mode is table, this information is optional.
In addition, the radio measurement request specifies the channel
dwell time for the measurement.
In order to use scan for beacon report when the mode is active or
passive, add a parameter to scan request that specifies the
channel dwell time, and add scan start time and beacon received time
to scan results information.
Supporting beacon report is required for Multi Band Operation (MBO).
Signed-off-by: Assaf Krauss <assaf.krauss@intel.com>
Signed-off-by: David Spinadel <david.spinadel@intel.com>
Signed-off-by: Avraham Stern <avraham.stern@intel.com>
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
Replace all trans_start updates with netif_trans_update helper.
change was done via spatch:
struct net_device *d;
- d->trans_start = jiffies
+ netif_trans_update(d)
Compile tested only.
Cc: user-mode-linux-devel@lists.sourceforge.net
Cc: linux-xtensa@linux-xtensa.org
Cc: linux1394-devel@lists.sourceforge.net
Cc: linux-rdma@vger.kernel.org
Cc: MPT-FusionLinux.pdl@broadcom.com
Cc: linux-scsi@vger.kernel.org
Cc: linux-can@vger.kernel.org
Cc: linux-parisc@vger.kernel.org
Cc: linux-omap@vger.kernel.org
Cc: linux-hams@vger.kernel.org
Cc: linux-usb@vger.kernel.org
Cc: linux-s390@vger.kernel.org
Cc: devel@driverdev.osuosl.org
Cc: b.a.t.m.a.n@lists.open-mesh.org
Cc: linux-bluetooth@vger.kernel.org
Acked-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
Acked-by: Antonio Quartulli <a@unstable.cc>
'struct timeval' uses a 32-bit seconds field which will overflow in
year 2038 and beyond. This patch is part of a larger effort to remove
all instances of 'struct timeval' from the kernel and replace them
with 64-bit timekeeping variables.
The patch also fixes the debug printf specifier to avoid the
seconds value being truncated.
The patch was build-tested / debugged by removing the
"if VERBOSE > SHOW_ERROR_MESSAGES" guards.
Signed-off-by: Tina Ruchandani <ruchandani.tina@gmail.com>
Suggested-by: Arnd Bergmann <arnd@arndb.de>
This enum is already perfectly aliased to enum nl80211_band, and
the only reason for it is that we get IEEE80211_NUM_BANDS out of
it. There's no really good reason to not declare the number of
bands in nl80211 though, so do that and remove the cfg80211 one.
"Highlights:
1) Support more Realtek wireless chips, from Jes Sorenson.
2) New BPF types for per-cpu hash and arrap maps, from Alexei
Starovoitov.
3) Make several TCP sysctls per-namespace, from Nikolay Borisov.
4) Allow the use of SO_REUSEPORT in order to do per-thread processing
of incoming TCP/UDP connections. The muxing can be done using a
BPF program which hashes the incoming packet. From Craig Gallek.
5) Add a multiplexer for TCP streams, to provide a messaged based
interface. BPF programs can be used to determine the message
boundaries. From Tom Herbert.
6) Add 802.1AE MACSEC support, from Sabrina Dubroca.
7) Avoid factorial complexity when taking down an inetdev interface
with lots of configured addresses. We were doing things like
traversing the entire address less for each address removed, and
flushing the entire netfilter conntrack table for every address as
well.
8) Add and use SKB bulk free infrastructure, from Jesper Brouer.
9) Allow offloading u32 classifiers to hardware, and implement for
ixgbe, from John Fastabend.
10) Allow configuring IRQ coalescing parameters on a per-queue basis,
from Kan Liang.
11) Extend ethtool so that larger link mode masks can be supported.
From David Decotigny.
12) Introduce devlink, which can be used to configure port link types
(ethernet vs Infiniband, etc.), port splitting, and switch device
level attributes as a whole. From Jiri Pirko.
13) Hardware offload support for flower classifiers, from Amir Vadai.
14) Add "Local Checksum Offload". Basically, for a tunneled packet
the checksum of the outer header is 'constant' (because with the
checksum field filled into the inner protocol header, the payload
of the outer frame checksums to 'zero'), and we can take advantage
of that in various ways. From Edward Cree"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1548 commits)
bonding: fix bond_get_stats()
net: bcmgenet: fix dma api length mismatch
net/mlx4_core: Fix backward compatibility on VFs
phy: mdio-thunder: Fix some Kconfig typos
lan78xx: add ndo_get_stats64
lan78xx: handle statistics counter rollover
RDS: TCP: Remove unused constant
RDS: TCP: Add sysctl tunables for sndbuf/rcvbuf on rds-tcp socket
net: smc911x: convert pxa dma to dmaengine
team: remove duplicate set of flag IFF_MULTICAST
bonding: remove duplicate set of flag IFF_MULTICAST
net: fix a comment typo
ethernet: micrel: fix some error codes
ip_tunnels, bpf: define IP_TUNNEL_OPTS_MAX and use it
bpf, dst: add and use dst_tclassid helper
bpf: make skb->tc_classid also readable
net: mvneta: bm: clarify dependencies
cls_bpf: reset class and reuse major in da
ldmvsw: Checkpatch sunvnet.c and sunvnet_common.c
ldmvsw: Add ldmvsw.c driver code
The driver reads a value from hfa384x_from_bap(), which may fail,
and then assigns the value to a local variable. gcc detects that
in in the failure case, the 'rlen' variable now contains
uninitialized data:
In file included from ../drivers/net/wireless/intersil/hostap/hostap_pci.c:220:0:
drivers/net/wireless/intersil/hostap/hostap_hw.c: In function 'hfa384x_get_rid':
drivers/net/wireless/intersil/hostap/hostap_hw.c:842:5: warning: 'rec' may be used uninitialized in this function [-Wmaybe-uninitialized]
if (le16_to_cpu(rec.len) == 0) {
This restructures the function as suggested by Russell King, to
make it more readable and get more reliable error handling, by
handling each failure mode using a goto.
This patch replaces uses the long obsolete hash interface with ahash.
prism54 checks for dma mapping errors by comparison returned address
with zero, while pci_dma_mapping_error() should be used.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Move constants to the right of binary operators.
Generated by: scripts/coccinelle/misc/compare_const_fl.cocci
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Julia Lawall <julia.lawall@lip6.fr>
This code was supposed to trigger a BUG() if we truncate the output but
it's off by one so it allows one character to be truncated. Really
drivers shouldn't call BUG_ON() and especially for something minor like
this so I've changed it to a WARN_ON().
The current code returns success if prism2_init_local_data() fails, but
we want to return an error code. Also we can remove the bogus
ret initializer because it is wrong and never used.
Part of reorganising wireless drivers directory and Kconfig.
