This patch fixes a bug in RX path, the frequency was wrongly set in the
ieee80211_rx_status. This bug led to an empty scan list in A band.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
This patch reverses the hw_crypto logic and makes HW crypto a default.
Giving swcrypto=1 as parameter to the module disables HW crypto.
This patch increases the max possible number of Tx queues, but leaves
current used number of queues as HW dependent
Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com>
This patch run rxon associated command from hcmd handler
Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
This patch adds place holder for host command handlers
for supporting different implementations per HW
This patch moves the HW device registration from the iwl-4965.c file, which
implies a HW specific support, to a more general location.
This patch moves creation of LQ host command to iwlcore
from previous location in rate scaling.
This patch adds infrastructure for supporting different
number of tx and rx antennas
1. This patch renames hw_setting to hw_params
2. Align names of the structure and variables
3. set_hw_params is called from libs_ops
This patch does 3 things
1) It removes the statistics work. The request statistics command is
sent in ASYNC mode in this flow, the mutex is uneeded, so the request
statistics function can't go to sleep. No need for a workqueue anymore.
2) iwl4965_send_statistics_request has been renamed to
iwl_send_statistics_request and moved to iwl-core.c
3) A request for statistics is sent in alive_notify, the makes the uCode
sends statistics notification periodically starting from association.
This patch fix byte count table update. Table must be updated for each
fragment
This patch creates handlers to support
iwlwifi init flow for multiple HWs
This patch replaces ieee80211chan2mhz from radiotap with
ieee80211_frequency_to_channel provided by mac80211
This patch moves inline functions into iwl-core.h
This patch make some cleanup in HW names
This fixes all kinds of warnings in iwlwifi.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
This patch removes association from beacon
using bss_info_change handler for association
Signed-off-by: Gregory Greenman <gregory.greenman@intel.com>
drivers/net/wireless/ath5k/base.c: In function `ath5k_check_ibss_tsf':
drivers/net/wireless/ath5k/base.c:1740: warning: long long unsigned int format, u64 arg (arg 5)
drivers/net/wireless/ath5k/base.c:1740: warning: long long unsigned int format, u64 arg (arg 6)
drivers/net/wireless/ath5k/base.c:1740: warning: long long int format, u64 arg (arg 7)
drivers/net/wireless/ath5k/base.c:1740: warning: long long unsigned int format, u64 arg (arg 8)
drivers/net/wireless/ath5k/base.c:1757: warning: long long unsigned int format, u64 arg (arg 5)
drivers/net/wireless/ath5k/base.c:1757: warning: long long unsigned int format, u64 arg (arg 6)
drivers/net/wireless/iwlwifi/iwl4965-base.c: In function `iwl4965_tx_status_reply_tx':
drivers/net/wireless/iwlwifi/iwl4965-base.c:3105: warning: long long unsigned int format, u64 arg (arg 6)
drivers/net/wireless/iwlwifi/iwl-4965.c: In function `iwl4965_rx_reply_rx':
drivers/net/wireless/iwlwifi/iwl-4965.c:3978: warning: long long unsigned int format, u64 arg (arg 7)
This patch replaces static variable from send_cmd_sync
with flag in priv->status. It was used for reentrance protection
but clearly made it impossible to stuck more cards into the same machine
In addition it force check of return values of synchronous commands
commands that doesn't requires return value async commands have to be used
Signed-off-by: Yi Zhu <yi.zhu@intel.com>
Having rate registration during module load enables the use of
error checking as well as reliable registration/unregistration
pairing. Previously this was not possible as rate registration
was done during _probe where _probe could be run for more than
one device on the system.
This patch hook IWL with Linux rfkill.
Signed-off-by: Mohamed Abbas <mabbas@linux.intel.com>
This patch renames iwl-4965-io.h back to iw-io.h
it also remove 4965 from all functions it supplies
This patch add LEDS support to 3965 and 4965 drivers. It is based on
led trigger and class. For our drivers we needed to avoid two things.
1- We receive led trigger on/off on each Rx\Tx frame. In our driver
we can not call led command like that. In this driver once driver
receive a start of traffic it call the led command to start blinking
then we count all bytes of Tx and Rx frame, after two second we count the
blink rate of last two second then id blink rate changed we call the led
commands
2- Since we can call led command very often, we make sure we call the
led command after we receive the statistics notification so
we don't need to wake up the ucode id it is in sleep state.
This patch was tested with 4965 and 3945.
Signed-off-by: Ian Schram<ischram@telenet.be>
This patch completes the changes regarding the packaging of user
parameters.
Signed-off-by: Assaf Krauss <assaf.krauss@intel.com>
1. Host command sending functions moved from iwl4965-base.c to iwl-hcmd.c
in iwlcore module
2. enqueue_hcmd function currently stays in iwl4965-base.c. It is invoked
through the new 'utils' field in priv's ops.
iwl4965_get_channel_info was moved to iwlcore module
4965 needs to be stripped off
This patch adds translation for the RX status of an incoming packet.
The incoming status has to be translated to the old scheme in order to know
if the decryption has been done, MIC failure has occured, TTAK is valid etc...
This translation is mandatory for all RX packets when using 5300 and for
all HT packets using 4965.
1. Extracting hw and priv initialization from probe function.
2. Moving some initialization functions to core module.
This patch defines a package struct for iwlwifi parameters, and uses a
single instance of this struct to group all iwl4965 module parameters
together.
This patch re-orders the iwl4965_pci_probe function.
This patch supports collecting of TX and RX statistics in the driver.
This patch renames iwl4965_priv to iwl_priv. iwl_priv will
be shared by more hw.
This patch removes iwl-4965-debug.h to iwl-debug.h
It will be used by more NICs
This patch fix debug print out endianity issue for bitmap
Since u64 and le64 variables are casted to unsigned long long,
after patch 'wireless: correct warnings from using '%llx' for type 'u64'
also bitmaps need to be converted to native endianity
This patch puts in use eeprom from iwlcore module
Also fix a copy and paste error in header of iwl-core.c. This file
is not dual licensed.
This patch removes iwlYYY_BROADCAST_ID from run time usage.
hw_setting.sta_bcast_id is used instead.
drivers/net/wireless/ath5k/debug.c: In function 'read_file_tsf': drivers/net/wireless/ath5k/debug.c:203: warning: format '%016llx'
expects type 'long long unsigned int', but argument 4 has type 'u64' drivers/net/wireless/ath5k/debug.c:203: warning: format '%016llx'
expects type 'long long unsigned int', but argument 4 has type 'u64' drivers/net/wireless/ath5k/debug.c: In function 'read_file_beacon':
drivers/net/wireless/ath5k/debug.c:274: warning: format '%016llx' expects type 'long long unsigned int', but argument 4 has type 'u64'
drivers/net/wireless/iwlwifi/iwl-4965.c: In function 'iwl4965_tx_status_reply_compressed_ba':
drivers/net/wireless/iwlwifi/iwl-4965.c:3907: warning: format '%llx' expects type 'long long unsigned int', but argument 4 has type 'u64'
drivers/net/wireless/iwlwifi/iwl-4965.c: In function 'iwl4965_rx_reply_compressed_ba':
drivers/net/wireless/iwlwifi/iwl-4965.c:4039: warning: format '%llx' expects type 'long long unsigned int', but argument 6 has type '__le64'
drivers/net/wireless/iwlwifi/iwl-4965.c:4046: warning: format '%llx' expects type 'long long unsigned int', but argument 5 has type 'u64'
drivers/net/wireless/iwlwifi/iwl4965-base.c: In function 'iwl4965_tx_status_reply_tx':
drivers/net/wireless/iwlwifi/iwl4965-base.c:3661: warning: format '%llx' expects type 'long long unsigned int', but argument 6 has type 'u64'
This patch grabs NIC access inside iwl4965_tx_queue_agg_disable, instead of the
caller doing it.
The caller must still hold priv->lock when calling the function.
Signed-off-by: Max Stepanov <max.stepanov@intel.com>
This patch adds fw_name to iwl_cfg. This allows run time selection
of needed fw/ucode file
This patch introduces struct iwl_cfg. struct iwl_cfg defines static
configuration for each device type and sku. It is passed as driver_data
to the bus probe function.
This patch also introduce new common header file iwl-core.h
which will represent core functionality of iwlwifi driver
3945ABG uses separate iwl-3945-dev.h header file for now
This patch extract CSR Register definition into separate
header files as most of the definition are commons to both
3945 and 4965.
Definitions specific for 3945 and 4965 are properly prefixed
This patch makes use of the new mac80211_tx_control_flags and tx_rate to
pass Tx data, regular and 11n, from the HW tx response into the rate scaling.
This patch adapts to 802.11 patch and remove AUTO offset for FAT
channel
Signed-off-by: Guy Cohen <guy.cohen@intel.com>
This patch fixes reporting rate in RX packets in 52 band.
The rate was updated from CCK rate index instead of OFDM rate 6M
Most of the patch is collateral clean up
This patch removes twice defined CSR register. It was confusing
Added tx_ant_num variable into hw_setting
This will be used for scanning TX antenna toggling
On the way removed ac_queue_num unused
channels/bitrates patch
This patch fixes compilation breakage caused by 'cfg80211 API for
channels/bitrates' patch.
however it doesn't fix the driver's functional problems caused by that
patch.
rate_idx is derived from plcp information
Signed-off-by: Mohamed Abbas <mohamed.abbas@intel.com>
