path: root/drivers/net/wireless/libertas/ethtool.c
2011-04-28libertas: use kernel-doc notation, fix comment styleRandy Dunlap
Convert all libertas/ files to use kernel-doc notation instead of whatever it was (doxygen?). Add or fix function parameters in several places. Use expected style for multi-line comments in lots of places. Remove erroneous /** in multiple places. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-23Libertas: cfg80211 supportKiran Divekar
Holger Schurig's patch (https://patchwork.kernel.org/patch/64286/) is rebased to latest wireless-testing tree. (Includes patches from me originally posted as "libertas: fix build error due to undefined symbol" and "libertas: unmangle capability value". -- JWL) Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Kiran Divekar <dkiran@marvell.com> Tested-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-08libertas: Fix ethtool reporting no WOL options supported if WOL is not ↵Sascha Silbe
already active This patch fixes the libertas driver incorrectly reporting that Wake-on-LAN is not supported if Wake-on-LAN is currently disabled. Signed-off-by: Sascha Silbe <sascha-pgp@silbe.org> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-02libertas: Added callback functions to support SDIO suspend/resume.Amitkumar Karwar
In suspend() host sleep is activated using already configured host sleep parameters through wol command, and in resume() host sleep is cancelled. Earlier priv->fw_ready flag used to reset and set in suspend and resume handler respectively. Since after suspend only host goes into sleep state and firmware is always ready, those changes in flag state are removed. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-22libertas: make mesh configurableHolger Schurig
Mostly for the embedded people that know beforehand that they don't need MESH at all and want to save some bytes, but also helpful for the upcoming cfg80211 transition. text data bss dec hex filename 114264 2308 140 116712 1c7e8 libertas.ko with mesh 105026 2000 140 107166 1a29e libertas.ko without mesh -------------------------------------------------- -9238 -308 -9546 Signed-off-by: Holger Schurig <holgerschurig@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-28libertas: move mesh-only ethtool operations into mesh.cHolger Schurig
2009-11-10Libertas: fix issues while configuring host sleep using ethtool wolBing Zhao
Configuration of wake-on-lan for unicast, multicast, broadcast, physical activity was not working. Kernel panic issue was there when user tries to disable WOL. Fixed them. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-10Libertas: coding style cleanup in ethtool.cBing Zhao
2009-09-02netdev: drivers should make ethtool_ops constStephen Hemminger
No need to put ethtool_ops in data, they should be const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-26libertas: fix misuse of netdev_priv() and dev->ml_privKiran Divekar
The mesh and radiotap interfaces need to use the same private data as the main wifi interface. If the main wifi interface uses netdev_priv(), but the other interfaces ->ml_priv, there's no way to figure out where the private data actually is in the WEXT handlers and netdevice callbacks. So make everything use ->ml_priv. Fixes botched netdev_priv() conversion introduced by "netdevice libertas: Fix directly reference of netdev->priv", though admittedly libertas' use of ->priv was somewhat "special". Signed-off-by: Kiran Divekar <dkiran@marvell.com> Acked-by: Dan Williams <dcbw@redhat.com> Tested-by: Chris Ball <cjb@laptop.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-21libertas: Fine grained configuration of wake-on-lan.Anna Neal
Based on a patch from Shailendra Govardhan <shailen@marvell.com>. This patch allows implementation of more specific wake-on-lan rules than those of ethtool. Please note that only firmware 5.110.22.p20 and above supports this feature. This patch only implements the driver/firmware interface, not the userspace/driver interface. Signed-off-by: Anna Neal <anna@cozybit.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-12netdevice: safe convert to netdev_priv() #part-3Wang Chen
We have some reasons to kill netdev->priv: 1. netdev->priv is equal to netdev_priv(). 2. netdev_priv() wraps the calculation of netdev->priv's offset, obviously netdev_priv() is more flexible than netdev->priv. But we cann't kill netdev->priv, because so many drivers reference to it directly. This patch is a safe convert for netdev->priv to netdev_priv(netdev). Since all of the netdev->priv is only for read. But it is too big to be sent in one mail. I split it to 4 parts and make every part smaller than 100,000 bytes, which is max size allowed by vger. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20libertas: Fix ethtool statisticsDavid Woodhouse
Fix various problems: - We converted MESH_ACCESS to a direct command but missed this caller. - We were trying to access mesh stats even on meshless firmware. - We should really zero the buffer if something goes wrong. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08libertas: remove lbs_get_fwversion()Holger Schurig
It was used only at one place anyway. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08libertas: move association code from join.c into scan.cHolger Schurig
Besides code moving, I did the following changes: * made some functions static * removed some unneeded #include's * made patch checkpatch.pl clean Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-01libertas: convert CMD_802_11_EEPROM_ACCESS to a direct commandHolger Schurig
2008-01-28libertas: add ethtool support for wake-on-lan configurationDavid Woodhouse
Also, check that suspend is refused if HOST_SLEEP_CFG hasn't been done. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28libertas: kill struct lbs_adapterDavid Woodhouse
There seems to be no reason for a separate structure; move it all into struct lbs_private. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28libertas: remove arbitrary typedefsHolger Schurig
New typedefs are usually frowned upon. This patch changes libertas_adapter -> struct libertas_adapter libertas_priv -> struct libertas_priv While passing, make everything checkpatch.pl-clean that gets touches. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28libertas: move to uniform lbs_/LBS_ namespaceHolger Schurig
This patch unifies the namespace of variables, functions defines and structures. It does: - rename libertas_XXX to lbs_XXX - rename LIBERTAS_XXX to lbs_XXX - rename wlan_XXX to lbs_XXX - rename WLAN_XXX to LBS_XXX (but only those that were defined in libertas-local *.h files, e.g. not defines from net/ieee80211.h) While passing, I fixed some checkpatch.pl errors too. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[netdrvr] Stop using legacy hooks ->self_test_count, ->get_stats_countJeff Garzik
These have been superceded by the new ->get_sset_count() hook. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[PATCH] net: Kill some unneeded allocation return value casts in libertasJesper Juhl
kmalloc() and friends return void*, no need to cast it. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] libertas: re-uppercase command defines and other constantsDan Williams
For readability. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-06-11[PATCH] libertas: first pass at fixing up endianness issuesDavid Woodhouse
2007-06-11[PATCH] libertas: indirect all hardware access via hw_XXXX functionsHolger Schurig
This functions makes all libertas_sbi_XXX functions static to the if_usb.c file and renames them to if_usb_XXXX(). The get called from other places of the source code via priv->hw_XXXX(). Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-06-11[PATCH] libertas: added transmission failures to mesh statisticsJavier Cardona
Added transmission failures to mesh statistics. Removed whitespace before newlines. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-06-11[PATCH] libertas: make debug configurableHolger Schurig
The debug output of libertas was either not present or it was overwhelming. This patch adds the possibility to specify a bitmask for the area of interest. One should then only get the desired output. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-28[PATCH] Marvell Libertas 8388 802.11b/g USB driverMarcelo Tosatti
Add the Marvell Libertas 8388 802.11 USB driver. Signed-off-by: Marcelo Tosatti <marcelo@kvack.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
