path: root/drivers/net/wireless/libertas/ethtool.c
2008-05-20libertas: Fix ethtool statisticsDavid Woodhouse
Fix various problems: - We converted MESH_ACCESS to a direct command but missed this caller. - We were trying to access mesh stats even on meshless firmware. - We should really zero the buffer if something goes wrong. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08libertas: remove lbs_get_fwversion()Holger Schurig
It was used only at one place anyway. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08libertas: move association code from join.c into scan.cHolger Schurig
Besides code moving, I did the following changes: * made some functions static * removed some unneeded #include's * made patch checkpatch.pl clean Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-01libertas: convert CMD_802_11_EEPROM_ACCESS to a direct commandHolger Schurig
2008-01-28libertas: add ethtool support for wake-on-lan configurationDavid Woodhouse
Also, check that suspend is refused if HOST_SLEEP_CFG hasn't been done. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28libertas: kill struct lbs_adapterDavid Woodhouse
There seems to be no reason for a separate structure; move it all into struct lbs_private. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28libertas: remove arbitrary typedefsHolger Schurig
New typedefs are usually frowned upon. This patch changes libertas_adapter -> struct libertas_adapter libertas_priv -> struct libertas_priv While passing, make everything checkpatch.pl-clean that gets touches. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28libertas: move to uniform lbs_/LBS_ namespaceHolger Schurig
This patch unifies the namespace of variables, functions defines and structures. It does: - rename libertas_XXX to lbs_XXX - rename LIBERTAS_XXX to lbs_XXX - rename wlan_XXX to lbs_XXX - rename WLAN_XXX to LBS_XXX (but only those that were defined in libertas-local *.h files, e.g. not defines from net/ieee80211.h) While passing, I fixed some checkpatch.pl errors too. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[netdrvr] Stop using legacy hooks ->self_test_count, ->get_stats_countJeff Garzik
These have been superceded by the new ->get_sset_count() hook. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[PATCH] net: Kill some unneeded allocation return value casts in libertasJesper Juhl
kmalloc() and friends return void*, no need to cast it. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] libertas: re-uppercase command defines and other constantsDan Williams
For readability. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-06-11[PATCH] libertas: first pass at fixing up endianness issuesDavid Woodhouse
2007-06-11[PATCH] libertas: indirect all hardware access via hw_XXXX functionsHolger Schurig
This functions makes all libertas_sbi_XXX functions static to the if_usb.c file and renames them to if_usb_XXXX(). The get called from other places of the source code via priv->hw_XXXX(). Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-06-11[PATCH] libertas: added transmission failures to mesh statisticsJavier Cardona
Added transmission failures to mesh statistics. Removed whitespace before newlines. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-06-11[PATCH] libertas: make debug configurableHolger Schurig
The debug output of libertas was either not present or it was overwhelming. This patch adds the possibility to specify a bitmask for the area of interest. One should then only get the desired output. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-28[PATCH] Marvell Libertas 8388 802.11b/g USB driverMarcelo Tosatti
Add the Marvell Libertas 8388 802.11 USB driver. Signed-off-by: Marcelo Tosatti <marcelo@kvack.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
