path: root/drivers/net/wireless/mwifiex/sdio.h
2011-10-12mwifiex: add support for Marvell pcie8766 chipsetAmitkumar Karwar
This patch supports 88W8766P chipset with a PCIe interface. The corresponding firmware image file is located at: "mrvl/pcie8766_uapsta.bin" Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Ramesh Radhakrishnan <rramesh@marvell.com> Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: Kiran Divekar <dkiran@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: Frank Huang <frankh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-06mwifiex: modify SDIO aggregation Tx/Rx buffer sizeAmitkumar Karwar
The SDIO aggregation buffer size has been modified to an optimum value which gives good throughput results. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-01mwifiex: remove support for old chipsets W0/W1Amitkumar Karwar
For SD8787 A0/A1 chipsets we use the default firmware image file 'mrvl/sd8787_uapsta.bin'. So the chip rev id variable is removed. The global variable fw_name is moved to adapter structure so that we can support a different interface, such as PCIe, in future. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-26mwifiex: correct event header lengthYogesh Ashok Powar
While decoding received event packet from firmware, 4 bytes of interface header are already removed unconditionally. So for handling event only 4 more bytes needs to be pulled. This is achieved by changing event header length to 4. Almost all the events, except BA stream related and AMSDU aggregation control events, do not have the payload in their event skb. Such events handling depends only on the event ID. This event ID is the first four bytes of the event skb, which is copied to a separate variable before pulling the skb header. Hence event handling worked only for those events that didn't have payload in event skb. This patch fixes the broken event path of the events with payload in their event skb without harming existing working event path for the events without payload. Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: Kiran Divekar <dkiran@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30wireless: mwifiex: initial commit for Marvell mwifiex driverBing Zhao
This driver adds WiFi support for Marvell 802.11n based chipsets with SDIO interface. Currently only SD8787 is supported. More chipsets will be supported later. drivers/net/wireless/mwifiex/ Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Kiran Divekar <dkiran@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: Marc Yang <yangyang@marvell.com> Signed-off-by: Ramesh Radhakrishnan <rramesh@marvell.com> Signed-off-by: Frank Huang <frankh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
