commit 4010fe21a315b4223c25376714c6a2b61b722e5c upstream.
This patch adds USBIDs for:
- DrayTek Vigor 530
- Zoom 4410a
It also adds a note about Gemtek WUBI-100GW
and SparkLAN WL-682 USBID conflict [WUBI-100GW
is a ISL3886+NET2280 (LM86 firmare) solution,
whereas WL-682 is a ISL3887 (LM87 firmware)]
device.
Source: <http://www.wikidevi.com/wiki/Intersil/p54/usb/windows>
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
commit 3194b7fcdf6caea338b5d2c72d76fed80437649c upstream.
Added USB ID for T-Com Sinus 154 data II.
Signed-off-by: Tomasz Guszkowski <tsg@o2.pl>
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
This structure needs to always stick around, even if CONFIG_HOTPLUG
is disabled, otherwise we can oops when trying to probe a device that
was added after the structure is thrown away.
Thanks to Fengguang Wu and Bjørn Mork for tracking this issue down.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Reported-by: Bjørn Mork <bjorn@mork.no>
Cc: stable <stable@vger.kernel.org>
CC: Christian Lamparter <chunkeey@googlemail.com>
CC: "John W. Linville" <linville@tuxdriver.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB 3.5-rc1 changes from Greg Kroah-Hartman:
"Here is the big USB 3.5-rc1 pull request for the 3.5-rc1 merge window.
It's touches a lot of different parts of the kernel, all USB drivers,
due to some API cleanups (getting rid of the ancient err() macro) and
some changes that are needed for USB 3.0 power management updates.
There are also lots of new drivers, pimarily gadget, but others as
well. We deleted a staging driver, which was nice, and finally
dropped the obsolete usbfs code, which will make Al happy to never
have to touch that again.
There were some build errors in the tree that linux-next found a few
days ago, but those were fixed by the most recent changes (all were
due to us not building with CONFIG_PM disabled.)
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'usb-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (477 commits)
xhci: Fix DIV_ROUND_UP compile error.
xhci: Fix compile with CONFIG_USB_SUSPEND=n
USB: Fix core compile with CONFIG_USB_SUSPEND=n
brcm80211: Fix compile error for .disable_hub_initiated_lpm.
Revert "USB: EHCI: work around bug in the Philips ISP1562 controller"
MAINTAINERS: Add myself as maintainer to the USB PHY Layer
USB: EHCI: fix command register configuration lost problem
USB: Remove races in devio.c
USB: ehci-platform: remove update_device
USB: Disable hub-initiated LPM for comms devices.
xhci: Add Intel U1/U2 timeout policy.
xhci: Add infrastructure for host-specific LPM policies.
USB: Add macros for interrupt endpoint types.
xhci: Reserve one command for USB3 LPM disable.
xhci: Some Evaluate Context commands must succeed.
USB: Disable USB 3.0 LPM in critical sections.
USB: Add support to enable/disable USB3 link states.
USB: Allow drivers to disable hub-initiated LPM.
USB: Calculate USB 3.0 exit latencies for LPM.
USB: Refactor code to set LPM support flag.
arch/arm/mach-exynos/mach-nuri.c
arch/arm/mach-exynos/mach-universal_c210.c
drivers/net/wireless/ath/ath6kl/usb.c
Hub-initiated LPM is not good for USB communications devices. Comms
devices should be able to tell when their link can go into a lower power
state, because they know when an incoming transmission is finished.
Ideally, these devices would slam their links into a lower power state,
using the device-initiated LPM, after finishing the last packet of their
data transfer.
If we enable the idle timeouts for the parent hubs to enable
hub-initiated LPM, we will get a lot of useless LPM packets on the bus
as the devices reject LPM transitions when they're in the middle of
receiving data. Worse, some devices might blindly accept the
hub-initiated LPM and power down their radios while they're in the
middle of receiving a transmission.
The Intel Windows folks are disabling hub-initiated LPM for all USB
communications devices under a xHCI USB 3.0 host. In order to keep
the Linux behavior as close as possible to Windows, we need to do the
same in Linux.
Set the disable_hub_initiated_lpm flag for for all USB communications
drivers. I know there aren't currently any USB 3.0 devices that
implement these class specifications, but we should be ready if they do.
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Gustavo Padovan <gustavo@padovan.org>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
Cc: Hansjoerg Lipp <hjlipp@web.de>
Cc: Tilman Schmidt <tilman@imap.cc>
Cc: Karsten Keil <isdn@linux-pingi.de>
Cc: Peter Korsgaard <jacmet@sunsite.dk>
Cc: Jan Dumon <j.dumon@option.com>
Cc: Petko Manolov <petkan@users.sourceforge.net>
Cc: Steve Glendinning <steve.glendinning@smsc.com>
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: Kalle Valo <kvalo@qca.qualcomm.com>
Cc: "Luis R. Rodriguez" <mcgrof@qca.qualcomm.com>
Cc: Jouni Malinen <jouni@qca.qualcomm.com>
Cc: Vasanthakumar Thiagarajan <vthiagar@qca.qualcomm.com>
Cc: Senthil Balasubramanian <senthilb@qca.qualcomm.com>
Cc: Christian Lamparter <chunkeey@googlemail.com>
Cc: Brett Rudley <brudley@broadcom.com>
Cc: Roland Vossen <rvossen@broadcom.com>
Cc: Arend van Spriel <arend@broadcom.com>
Cc: "Franky (Zhenhui) Lin" <frankyl@broadcom.com>
Cc: Kan Yan <kanyan@broadcom.com>
Cc: Dan Williams <dcbw@redhat.com>
Cc: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Cc: Ivo van Doorn <IvDoorn@gmail.com>
Cc: Gertjan van Wingerde <gwingerde@gmail.com>
Cc: Helmut Schaa <helmut.schaa@googlemail.com>
Cc: Herton Ronaldo Krzesinski <herton@canonical.com>
Cc: Hin-Tak Leung <htl10@users.sourceforge.net>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: Chaoming Li <chaoming_li@realsil.com.cn>
Cc: Daniel Drake <dsd@gentoo.org>
Cc: Ulrich Kunitz <kune@deine-taler.de>
Drivers that refer to a __devexit function in an operations
structure need to annotate that pointer with __devexit_p so
replace it with a NULL pointer when the section gets discarded.
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Drivers that load firmware from their probe routine have problems with
the latest versions of udev as they get timeouts while waiting for user
space to start. The problem is fixed by using request_firmware_nowait()
and delaying the start of mac80211 until the firmware is loaded.
To prevent the possibility of the driver being unloaded while the
firmware loading callback is still active, a completion queue entry
is used.
Also, to simplify the firmware loading procedure, this patch removes
the old, unofficial and confusing fallback firmware names. However,
they are still supported! So any user - who is still using them -
is hereby advised to link/rename their old firmware filenames:
isl3890usb to isl3886usb
isl3887usb_bare to isl3887usb
This converts the drivers in drivers/net/* to use the
module_usb_driver() macro which makes the code smaller and a bit
simpler.
Added bonus is that it removes some unneeded kernel log messages about
drivers loading and/or unloading.
Cc: Wolfgang Grandegger <wg@grandegger.com>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: Oliver Neukum <oliver@neukum.name>
Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi>
Cc: Roel Kluin <roel.kluin@gmail.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Jiri Pirko <jpirko@redhat.com>
Cc: Pavel Roskin <proski@gnu.org>
Cc: Yoann DI-RUZZA <y.diruzza@lim.eu>
Cc: George <george0505@realtek.com>
The device.h header was including module.h, making it present for
most of these drivers. But we want to clean that up. Call out the
include of module.h in the modular network drivers.
Cc: <stable@kernel.org>
Reported-by: Mark Davis <marked86@gmail.com>
Reported-by: Mark Davis [via p54/devices wiki]
drivers/net/bnx2x/bnx2x.h
drivers/net/wireless/iwlwifi/iwl-1000.c
drivers/net/wireless/iwlwifi/iwl-6000.c
drivers/net/wireless/iwlwifi/iwl-core.h
drivers/vhost/vhost.c
This USB ID is for the WUBI-100GW 802.11g Wireless LAN USB Device that
uses p54usb.
Signed-off-by: Eduardo Costa <ecosta.tmp@gmail.com>
Cc: Stable <stable@kernel.org>
This patch adds five more USBIDs to the table.
Source:
http://www.linuxant.com/pipermail/driverloader/2005q3/002307.html
http://wireless.kernel.org/en/users/Drivers/p54/devices (by M. Davis)
Source:
The ISL3887 chip needs a USB reset, whenever the
usb-frontend module "p54usb" is reloaded.
This patch fixes an off-by-one bug, if the user
is running a kernel without the CONFIG_PM option
set and for some reason (e.g.: compat-wireless)
wants to switch between different p54usb modules.
The Medion MD40900 device id [0x0cde, 0x0006] is defined twice.
Comment out the duplicate.
Originally-by: Ben Collins <ben.collins@ubuntu.com>
Signed-off-by: Leann Ogasawara <leann.ogasawara@canonical.com>
Add Dell WLA3310 USB wireless card, which has a Z-Com XG-705A chipset, to the
USB Ids in p54usb.
Signed-off-by: Jason Dravet <dravet@hotmail.com>
Tested-by: Richard Gregory Tillmore <rtillmore@gmail.com>
Use kmemdup when some other buffer is immediately copied into the
allocated region.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
expression from,to,size,flag;
statement S;
- to = \(kmalloc\|kzalloc\)(size,flag);
+ to = kmemdup(from,size,flag);
if (to==NULL || ...) S
- memcpy(to, from, size);
// </smpl>
This patch removes from drivers/net/ all the unnecessary
return; statements that precede the last closing brace of
void functions.
It does not remove the returns that are immediately
preceded by a label as gcc doesn't like that.
It also does not remove null void functions with return.
Done via:
$ grep -rP --include=*.[ch] -l "return;\n}" net/ | \
xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }'
with some cleanups by hand.
Compile tested x86 allmodconfig only.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (37 commits)
smc91c92_cs: fix the problem of "Unable to find hardware address"
r8169: clean up my printk uglyness
net: Hook up cxgb4 to Kconfig and Makefile
cxgb4: Add main driver file and driver Makefile
cxgb4: Add remaining driver headers and L2T management
cxgb4: Add packet queues and packet DMA code
cxgb4: Add HW and FW support code
cxgb4: Add register, message, and FW definitions
netlabel: Fix several rcu_dereference() calls used without RCU read locks
bonding: fix potential deadlock in bond_uninit()
net: check the length of the socket address passed to connect(2)
stmmac: add documentation for the driver.
stmmac: fix kconfig for crc32 build error
be2net: fix bug in vlan rx path for big endian architecture
be2net: fix flashing on big endian architectures
be2net: fix a bug in flashing the redboot section
bonding: bond_xmit_roundrobin() fix
drivers/net: Add missing unlock
net: gianfar - align BD ring size console messages
net: gianfar - initialize per-queue statistics
Thanks to Chris Chabot for giving his old wireless usb dongle to me
to test it under Linux.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Yet another USB ID.
Signed-off-by: Jean-François Moine <moinejf@free.fr>
Signed-off-by: Shimada Hirofumi <hirofumi@flycat.org>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
On 2.6.32-rc6 from wireless-testing, the following warning is emitted:
WARNING: at lib/dma-debug.c:860 check_for_stack+0xaa/0xe0()
Hardware name: HP Pavilion dv2700 Notebook PC
ehci_hcd 0000:00:02.1: DMA-API: device driver maps memory fromstack
[addr=ffff8800b6e2bca8]
Modules linked in: <Removed>
Pid: 16378, comm: modprobe Not tainted 2.6.32-rc6-wl #244
Call Trace:
[<ffffffff81049698>] warn_slowpath_common+0x78/0xb0
[<ffffffff8104972c>] warn_slowpath_fmt+0x3c/0x40
[<ffffffff811ae52a>] check_for_stack+0xaa/0xe0
[<ffffffff811afc8d>] debug_dma_map_page+0xfd/0x170
[<ffffffffa006297a>] usb_hcd_submit_urb+0x3da/0x9c0 [usbcore]
[<ffffffff81076e6f>] ? lockdep_init_map+0x5f/0x5d0
[<ffffffffa0063365>] usb_submit_urb+0xe5/0x260 [usbcore]
[<ffffffffa0064b7e>] usb_start_wait_urb+0x5e/0xf0 [usbcore]
[<ffffffffa0063943>] ? usb_init_urb+0x23/0x40 [usbcore]
[<ffffffffa0064cd4>] usb_bulk_msg+0xc4/0x150 [usbcore]
[<ffffffffa0441a91>] T.719+0x31/0x40 [p54usb]
[<ffffffffa0441acf>] p54u_upload_firmware_3887+0x2f/0x490 [p54usb]
[<ffffffffa049c667>] ? p54_parse_firmware+0x427/0x450 [p54common]
<Rest of traceback removed>
---[ end trace f77df0316ddad3de ]---
Cc: Stable <stable@vger.org>
This patch adds a new usbid for Zcomax XG-705A to the device table.
Cc: stable@kernel.org
Reported-by: Jari Jaakola <jari.jaakola@gmail.com>
This patch squashes a few old bugs, which have been around since
the initial version of p54usb in one form or another.
we never freed a orphaned frame, when were denied the resources,
which are necessary to pass the data into the usb subsystem.
As a result we could end up with a full queue that wasn't emptied,
until the device was brought down.
Signed-off-by: Christian Lamparter <chunkeey@web.de>
Modify the remaining p54 files to account for the new file organization.
We're going to remove the FIRMWARE_NAME_MAX definition in order to avoid any
firmware name length restriction.
This patch gets rid of the statically allocated p54usb firmware string, and
replaces them with const char pointers.
/drivers/net/wireless/p54/p54usb.c: In function 'p54u_probe':
/drivers/net/wireless/p54/p54usb.c:923: error: 'struct usb_device' has no member named 'reset_resume'
In the struct usb_device the reset_resume attribute is only available
when CONFIG_PM is defined.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
This patch redo the driver code so that p54usb no longer hangs
the kernel on resume.
Since "p54: prevent upload of wrong firmwares" we no longer allow
outdated LM86 firmwares to be uploaded on ISL3887 (LM87) devices.
Therefore we can purge this buggy legacy code altogether.
All three drivers (p54pci, p54usb and p54spi) are implementing the
same functionality three times. So, why not put it into the shared library?!
The patch fixes a problem when the (Soft)LED stayed on after the module was unloaded.
It turned out that the USB core disables all endpoints before calling the disconnect method.
So it was impossible to switch off the radio & LEDs.
A recent change in the usb core "USB: change interface to usb_lock_device_for_reset()"
conflicts with "p54usb: utilize usb_reset_device for 3887".
Sadly, we have to call usb_reset_device before we can upload the firmware on 3887.
Unless someone figures out how to reliably stop the 3887 so the hardware is still usable
next time we want to start it.
This patch will prevent anyone to upload a firmware which was not designed for his device.
There's still a catch:
There is no easy way to detect if a firmware is for PCI or for USB (1st Gen),
because they all share the same LM86 identifier.
Sometimes on unload or reboot the 3887 USB devices become stuck.
<usual log entry>
kernel: usbcore: registered new interface driver p54usb
kernel: usb 2-10: (p54usb) reset failed! (-110)
kernel: p54usb: probe of 2-10:1.0 failed with error -110
and a physical unplug and replug was necessary.
However we should be able to do this in software as well,
without any user interaction.
Artur Skawina confirmed that the first generation devices needs the same
URB_ZERO_PACKET flag, in oder to finish the pending transfer properly.
The second generation has been successfully fixed by
"p54usb: fix random traffic stalls (LM87)" (43af18f06d5)
In theory, the firmware acks the received a data frame, before signaling the driver to free it again.
However Artur Skawina <art.08.09@gmail.com> has shown that it can happen in reverse order as well.
This is very bad and could lead to memory corruptions, oopses and panics.
Thanks to Artur Skawina <art.08.09@gmail.com> for reporting and debugging this issue.
Tested-by: Artur Skawina <art.08.09@gmail.com>
All LM87 firmwares need a explicit termination "packet",
Add the USB ID for Thomson Speedtouch 121g to p54usb.
Signed-off-by: Michiel <michiel@ettema.net>
This patch fixes a serious regression (introduced by:
"p54: fix memory management")
that affected isl3886+net2280 usb devices operation.
This patch simplifies the tx code a bit and will be necessary for
the upcoming stlc45xx<->p54 port.
In detail: we no longer have to tell all back-end drivers directly,
if we want to free a frame right after it was send to the firmware,
or if we do it in the library callback later.
Alan Stern found several flaws in p54usb's implementation and annotated:
"usb_kill_urb() and similar routines do not expect an URB's completion
routine to deallocate it. This is almost obvious -- if the URB is deallocated
before the completion routine returns then there's no way for usb_kill_urb
to detect when the URB actually is complete."
This patch addresses all known limitations in the old implementation and fixes
khub's "use-after-freed" hang, when SLUB debug's poisoning option is enabled.
Tested-by: Larry Finger <Larry.Finger@lwfinger.net>
This fixes the checksum calculation for lm87 firmwares
on big endian platforms, the device treats the data as
an array of 32-bit little endian values so the driver
needs to do that as well.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Acked-by: Christian Lamparter <chunkeey@web.de>
