commit c713fb071edc0efc01a955f65a006b0e1795d2eb upstream.
There has been a coding error in rtl8821ae since it was first introduced,
namely that an 8-bit register was read using a 16-bit read in
_rtl8821ae_dbi_read(). This error was fixed with commit 40b368af4b75
("rtlwifi: Fix alignment issues"); however, this change led to
instability in the connection. To restore stability, this change
was reverted in commit b8b8b16352cd ("rtlwifi: rtl8821ae: Fix connection
lost problem").
Unfortunately, the unaligned access causes machine checks in ARM
architecture, and we were finally forced to find the actual cause of the
problem on x86 platforms. Following a suggestion from Pkshih
<pkshih@realtek.com>, it was found that increasing the ASPM L1
latency from 0 to 7 fixed the instability. This parameter was varied to
see if a smaller value would work; however, it appears that 7 is the
safest value. A new symbol is defined for this quantity, thus it can be
easily changed if necessary.
Fixes: b8b8b16352cd ("rtlwifi: rtl8821ae: Fix connection lost problem")
Cc: Stable <stable@vger.kernel.org> # 4.14+
Fix-suggested-by: Pkshih <pkshih@realtek.com>
Tested-by: James Cameron <quozl@laptop.org> # x86_64 OLPC NL3
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
In commit d86e64768859 ("rtlwifi: rtl818x: constify local structures"),
the configuration struct for most of the drivers was changed to be
constant. The problem is that five of the modified drivers need to be
able to update the firmware name based on the exact model of the card.
As the file names were stored in one of the members of that struct,
these drivers would fail with a kernel BUG splat when they tried to
update the firmware name.
Rather than reverting the previous commit, I used a suggestion by
Johannes Berg and made the firmware file name pointers be local to
the routines that update the software variables.
The configuration struct of rtl8192cu, which was not touched in the
previous patch, is now constantfied.
Fixes: d86e64768859 ("rtlwifi: rtl818x: constify local structures")
Suggested-by: Johannes Berg <johannes@sipsolutions.net>
Cc: Stable <stable@vger.kernel.org> # 4.8
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
The entries in this enum may be referenced in debug output. Adding explicit
values simplifies the lookup.
Compiling the rtlwifi drivers for ARM with gcc -Wextra warns about lots of
incorrect code that results from 'char' being unsigned here, e.g.
realtek/rtlwifi/rc.c:113:18: error: comparison is always true due to limited range of data type [-Werror=type-limits]
realtek/rtlwifi/rtl8188ee/dm.c:1070:22: error: comparison is always false due to limited range of data type [-Werror=type-limits]
realtek/rtlwifi/rtl8192ce/trx.c:54:16: error: comparison is always false due to limited range of data type [-Werror=type-limits]
realtek/rtlwifi/rtl8192cu/mac.c:601:16: error: comparison is always false due to limited range of data type [-Werror=type-limits]
realtek/rtlwifi/rtl8192de/trx.c:53:16: error: comparison is always false due to limited range of data type [-Werror=type-limits]
realtek/rtlwifi/rtl8192ee/phy.c:1268:12: error: comparison is always true due to limited range of data type [-Werror=type-limits]
realtek/rtlwifi/rtl8192se/rf.c:150:20: error: comparison is always false due to limited range of data type [-Werror=type-limits]
realtek/rtlwifi/rtl8723be/dm.c:877:29: error: comparison is always false due to limited range of data type [-Werror=type-limits]
realtek/rtlwifi/rtl8723be/phy.c:386:16: error: comparison is always true due to limited range of data type [-Werror=type-limits]
realtek/rtlwifi/rtl8821ae/dm.c:1514:38: error: comparison is always false due to limited range of data type [-Werror=type-limits]
realtek/rtlwifi/rtl8821ae/phy.c:1558:11: error: comparison is always false due to limited range of data type [-Werror=type-limits]
realtek/rtlwifi/rtl8821ae/phy.c:386:24: error: comparison is always false due to limited range of data type [-Werror=type-limits]
realtek/rtlwifi/rtl8821ae/trx.c:55:12: error: comparison is always false due to limited range of data type [-Werror=type-limits]
realtek/rtlwifi/stats.c:31:16: error: comparison is always false due to limited range of data type [-Werror=type-limits]
This patch changes all uses of 'char' in this driver that refer to
8-bit integers to use 's8' instead, which is signed on all architectures.
The rtl_intf_ops structures are never modified, so declare them as const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
This enum is already perfectly aliased to enum nl80211_band, and
the only reason for it is that we get IEEE80211_NUM_BANDS out of
it. There's no really good reason to not declare the number of
bands in nl80211 though, so do that and remove the cfg80211 one.
Use to_delayed_work() instead of open-coding it.
Signed-off-by: Geliang Tang <geliangtang@163.com>
[Update commit message]
Signed-off-by: Julian Calaby <julian.calaby@gmail.com>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
A number of new laptops have been delivered with only a single antenna.
In principle, this is OK; however, a problem arises when the on-board
EEPROM is programmed to use the other antenna connection. The option
of opening the computer and moving the connector is not always possible
as it will void the warranty in some cases. In addition, this solution
breaks the Windows driver when the box dual boots Linux and Windows.
A fix involving a new module parameter has been developed. This commit
adds the new parameter and implements the changes needed for the driver.
Cc: Stable <stable@vger.kernel.org> [V4.0+]
Smatch reports the following warning:
CHECK drivers/net/wireless/realtek/rtlwifi/rc.c
drivers/net/wireless/realtek/rtlwifi/rc.c:144 _rtl_rc_rate_set_series() warn: impossible condition '(wireless_mode == 256) => (0-255 == 256)'
This warning arises because commit acc6907b87a9 ("rtlwifi: Fix warning
from ieee80211_get_tx_rates() when using 5G") now checks the wireless
mode for WIRELESS_MODE_AC_ONLY (BIT(8)) in _rtl_rc_rate_set_series().
As a result, all quantities used to store the wireless mode must be u16.
This patch also reorders struct rtl_sta_info to save a little space.
Fixes: d76d65fd2695 ("rtlwifi: fix broken VHT support")
Reported-by: Dan Williams <dcbw@redhat.com>
passing rtl_stats by value is inefficient; the structure is over 300
bytes in size and generally just one field (packet_report_type)
is being accessed, so the pass by value is a relatively large overhead.
This change just affects just the rx_command_packet calls.
There are several copies of the 5G channel tables in this driver. These
are removed so that the tables in the core will be used. This change
also removes a useless message of "Channel 163 in Group not found".
The number of possible 5G channels was reduced from 54 to a better
value of 49 during the conversion.
There are 3 drivers in this family that have 5G radios. Each of them
defines local copies of the available channels. This patch adds the
two arrays to the core driver.
git://git.kernel.org/pub/scm/linux/kernel/git/kvalo/wireless-drivers-next
Kalle Valo says:
here's a bigger pull request for 4.4. The diffstat looks scary as we
created a new directory realtek for all realtek drivers. In the future
I'm planning to create similar directories for all vendors, currently we
just have ath, mediatek and realtek. This change has been in linux-next
for a couple of weeks so it should be safe, but of course you never
know.
There's also a new driver rtl8xxxu for few realtek USB devices. This
just made it to the last linux-next build.
Otherwise there's nothing really special, more info below. If time
permits, and it's ok for you, I'm hoping to send you a one more pull
request this week.
brcmfmac
* using netdev carrier state
* add and rework some cfg80211 callbacks mainly for AP mode
* use devcoredump when triggered by firmware event
realtek
* create new directory drivers/net/wireless/realtek/ for all realtek
drivers, not visible to users (no kconfig changes etc)
* add rtl8xxxu, a new mac80211 driver for RTL8723AU, RTL8188CU,
RTL8188RU, RTL8191CU, RTL8192CU and hopefully more in the future
ath10k
* add board 2 API support for automatically choosing correct board file
* data path optimisations
* disable PCI power save for qca988x and QCA99x0 due to interop reasons
wil6210
* BlockAckReq support
* firmware crashdump using devcoredump
* capture all frames with sniffer
Now that a new mac80211-based driver for Realtek devices has been submitted,
it is time to reorganize the directories. Rather than having directories
rtlwifi and rtl818x be in drivers/net/wireless/, they will now be in
drivers/net/wireless/realtek/. This change simplifies the directory
structure, but does not result in any configuration changes that are
visable to the user.
