The usb max packet size won't change during the
device's presence. We should store it in a
variable inside rt2x00dev and use that.
This should also fix a division error when the
device is being hot-unplugged while a frame is
being send out.
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com>
The validation of the chipset revision was broken
since for rt2500usb and rt73usb different registers
should be read. When rt2500usb was loaded for a rt73
device it would false think the chipset was correct
because the wrong register was read and validated.
This has been fixed by expanding the check to also
see if the first 4 bits of the revision is not-0
(When reading the wrong register offset the returned
value is usually 0 which can be interpreted as invalid)
Version bump
Reorganize configuration handling by creating a extra
structure which contains precalculated values based
on the mac80211 values which are usefull for all
individual drivers.
This also fixes the preamble configuration problem,
up untill now preamble was never configured since
by default the rate->val value was used when changing
the mode.
Now rate->val will only be used to set the basic rate mask.
The preamble configuration will now be done correctly
through the erp_ie_changed callback function.
The TX datalen must always be converted to a value rt73 and rt2500usb
understand. Both require to use a different size then skb->len.
First off this is required because the descriptor must be added,
but the second is because the value must be a multiple of either 2 or 4,
and it should not be a multiple of the USB packetmax
All drivers use the same values for TSF sync,
this will move the value determination into rt2x00config.c,
and the definition for the values to rt2x00reg.h
As reported by Modestas Vainius, enabling rkfill in 1 driver and
disabling it in a second could cause a NULL pointer exception when
the rfkill-disabled driver still sets the CONFIG_SUPPORT_HW_BUTTON flag.
Furthermore, rfkill expects the timeout as a value in milliseconds
instead of jiffies. Also increase the timeout to a second,
since this 250ms would be overkill.
Also the flag DEVICE_ENABLED_RADIO_HW is causing problems
for devices which do not support the hardware button
while rfkill is enabled in the driver.
To remidy this we should inverse the flag and its meaning,
rename the flag to DEVICE_DISABLED_RADIO_HW this means that
by default the radio is enabled by the hardware button (if present)
and can only be disabled explicitely.
We shouldn't use changed_flags when configuring the packet filter,
we work directly with the total_flags which is safe enough since
we already check if something has changed after we applied our
packet filtering flag rules.
Also make sure that when the packet filter is scheduled, the
rt2x00dev->interface.filter is cleared to make sure the drivers
will update the packet filter instead of failing at the check:
*total_flags == rt2x00dev->interface.filter
By putting the flags into a enumeration we can
make it easier maintable since we don't have to
assign numbers for each flag. This makes it easier
to insert and remove flags.
Store the started state into a new flag DEVICE_STARTED_SUSPEND
and set this when suspending while the device was started.
We can't check for is_interface_present() since only mac80211
knows if there are monitor interfaces present.
The various drivers contained duplicate code to handle the
MAC and BSSID initialization correctly. This moves the
address copy to little endian variables to rt2x00config.
Since I cannot convince the lazy driver authors (hello Michael)
to stop (ab)using the MGMT interface type internally in their
drivers, this patch introduces a new _INVALID type especially
for their use and changes all affected drivers to use it.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Version bump
The rt2x00dev->flags has become a chaos over time,
this will reorganize the flags by renaming, deleting, adding
and properly implement the flags.
Apparently rt2561s actually has PCI ID 0x0301
and rt2561 actually has PCI ID 0x0302.
Where rt2561s supports Turbo.
Drivers are currently supposed to keep track of monitor
interfaces if they allow so-called "hard" monitor, and
they are also supposed to keep track of multicast etc.
This patch changes that, replaces the set_multicast_list()
callback with a new configure_filter() callback that takes
filter flags (FIF_*) instead of interface flags (IFF_*).
For a driver, this means it should open the filter as much
as necessary to get all frames requested by the filter flags.
Accordingly, the filter flags are named "positively", e.g.
FIF_ALLMULTI.
Multicast filtering is a bit special in that drivers that
have no multicast address filters need to allow multicast
frames through when either the FIF_ALLMULTI flag is set or
when the mc_count value is positive.
At the same time, drivers are no longer notified about
monitor interfaces at all, this means they now need to
implement the start() and stop() callbacks and the new
change_filter_flags() callback. Also, the start()/stop()
ordering changed, start() is now called *before* any
add_interface() as it really should be, and stop() after
any remove_interface().
The patch also changes the behaviour of setting the bssid
to multicast for scanning when IEEE80211_HW_NO_PROBE_FILTERING
is set; the IEEE80211_HW_NO_PROBE_FILTERING flag is removed
and the filter flag FIF_BCN_PRBRESP_PROMISC introduced.
This is a lot more efficient for hardware like b43 that
supports it and other hardware can still set the BSSID
to all-ones.
Driver modifications by Johannes Berg (b43 & iwlwifi), Michael Wu
(rtl8187, adm8211, and p54), Larry Finger (b43legacy), and
Ivo van Doorn (rt2x00).
Signed-off-by: Michael Wu <flamingice@sourmilk.net>
