path: root/drivers/net/wireless/rt2x00/rt2x00pci.c
2008-05-12rt2x00: Clean up error handling of PCI queue DMA allocation.Ivo van Doorn
When, for some reason, the rt2x00pci module fails to allocate DMA memory for the queues, it tries to undo the complete initialization of the PCI device, including freeing of the irq. This results in the following error in dmesg, as the irq hadn't been requested yet: [ 78.123456] Trying to free already-free IRQ 17 Fix this by implementing proper error handling code, instead of just using the full uninitialization function. Signed-off-by: Gertjan van Wingerde <gwingerde@kpnplanet.nl> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-13rt2x00: Initialize TX control field in data entriesMattias Nissler
In the TX path, the driver didn't copy the TX control data structure. Thus, it was invalid in the TX done handler, causing serious trouble and misbehaviour. Signed-off-by: Mattias Nissler <mattias.nissler@gmx.de> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Fix Descriptor DMA initializationIvo van Doorn
As Adam Baker reported the DMA address for the descriptor base was incorrectly initialized in the PCI drivers. Instead of the DMA base for the descriptor, the DMA base for the data was passed resulting in a broken TX/RX state for PCI drivers. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Don't report driver generated frames to tx_status()Ivo van Doorn
This adds a new flag for the skb_frame_desc structure which is used to tag rts/cts frames that are generated by the driver. Through the tag we can recognize frames we have generated ourselves, so we don't report their tx status to mac80211. This patch is based on the original patch by Mattias Nissler <mattias.nissler@gmx.de>. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Fix skbdesc->data_len initializationIvo van Doorn
skbdesc->data_len was not initialized correctly in rt2x00pci, rt2x00usb, rt2500usb and rt73usb. The value was set to queue->data_size which means that the incorrect frame size was pased to the upper layers. Correctly base the value on either the skb->len, or the rx frame size passed to the driver by the device. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: make csr_cache and csr_addr an unionIvo van Doorn
The csr_cache and csr_addr pointers are both the same size and they are never used both by the same driver. This makes them a nice candidate for an union. We could merge into 1 pointer, but that would either upset sparse, or require a lot of __force casts. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Fix invalid DMA freeIvo van Doorn
Be more strict when using the queue_entry_priv_pci_rx and queue_entry_priv_pci_tx structures. Only use a particular type that matches the queue type. When freeing the DMA the priv_tx->data and priv_tx->dma was used. This is incorrect since the start of the DMA was in fact the priv_tx->desc pointer. Instead of recalculating the dma_addr_t for the DMA start this patch will swap the data and descriptor part of the allocated memory. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Move beacon and atim queue defines into rt2x00Ivo van Doorn
As Johannes Berg indicated the BEACON and AFTER_BEACON queue indeces in mac80211 should be removed because they are too hardware specific. This patch adds the queue index defines into rt2x00queue.h and removes the dependency of the defines inside mac80211.h. Also move rt2x00pci_beacon_update() into rt2400pci and rt2500pci individually since it is no longer a generic function since rt61 and rt2800 no longer use that. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Add per-interface structureIvo van Doorn
Rework the interface handling. Delete the interface structure and replace it with a per-interface structure. This changes the way rt2x00 handles the active interface drastically. Copy ieee80211_bss_conf to the this rt2x00_intf structure during the bss_info_changed() callback function. This will allow us to reference it later, and removes the requirement for the device flag SHORT_PREAMBLE flag which is interface specific. Drivers receive the option to give the maximum number of virtual interfaces the device can handle. Virtual interface support: rt2400pci: 1 sta or 1 ap, * monitor interfaces rt2500pci: 1 sta or 1 ap, * monitor interfaces rt2500usb: 1 sta or 1 ap, * monitor interfaces rt61pci: 1 sta or 4 ap, * monitor interfaces rt73usb: 1 sta or 4 ap, * monitor interfaces At the moment none of the drivers support AP and STA interfaces simultaneously, this is a hardware limitation so future support will be very unlikely. Each interface structure receives its dedicated beacon entry, with this we can easily work with beaconing while multiple master mode interfaces are currently active. The configuration handlers for the MAC, BSSID and type are often called together since they all belong to the interface configuration. Merge the 3 configuration calls and cleanup the API between rt2x00lib and the drivers. While we are cleaning up the interface configuration anyway, we might as well clean up the configuration handler as well. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Queue handling overhaulIvo van Doorn
This introduces a big queue handling overhaul, this also renames "ring" to "queues". Move queue handling into rt2x00queue.c and the matching header, use Kerneldoc to improve rt2x00 library documentation. Access to the queues is now protected under a spinlock, this to prevent race conditions which could corrupt the indexing system of the queue. Each queue entry allocates x bytes for driver/device specific data, this cleans up the queue structure significantly and improves code readability. rt2500usb no longer needs 2 entries in the beacon queue to correctly send out the guardian byte. This is now handled in the entry specific structure. rt61 and rt73 now use the correct descriptor size for beacon frames, since this data is written into the registers not the entire TXD descriptor was used but instead of a subset of it named TXINFO. Finally this also fixes numerous other bugs related to incorrect beacon handling or beacon related code. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Update copyright noticeIvo van Doorn
2008-01-28rt2x00: Always call ieee80211_stop_queue() when return NETDEV_TX_BUSYIvo van Doorn
Apparently it was possible that ieee80211_stop_queue() was not full while NETDEV_TX_BUSY was being reported back. I think that is what causing the WARN_ON(). This moves all calls to ieee80211_stop_queue() in rt2x00mac.c where it is easier to determine if the queue should be halted. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28rt2x00: Add TX/RX frame dumping facilityIvo van Doorn
This adds TX/RX frame dumping capabilities through debugfs. The intention is that with this approach debugging of rt2x00 is simplified since _all_ frames going in and out of the device are send to debugfs as well along with additional information like the hardware descriptor. Based on the patch by Mattias Nissler. Mattias also has some tools that will make the dumped frames available to wireshark: http://www-user.rhrk.uni-kl.de/~nissler/rt2x00/ Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28rt2x00: Add skb descriptorIvo van Doorn
Use the skb->cb field to add a frame description that can be used to transfer information passed each rt2x00 layer. This reduces the required arguments for rt2x00lib_write_tx_desc(). Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28rt2x00: Replace DRV_NAME with KBUILD_MODNAMEIvo van Doorn
DRV_NAME was always set to the KBUILD_MODNAME value, lets clean everything up by removing DRV_NAME and just use KBUILD_MODNAME directly. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28rt2x00: Move duplicate code into rt2x00pci_txdone()Ivo van Doorn
rt2400pci, rt2500pci and rt61 require different txdone handling, but the code that pushes the frame upstream and cleans up the entry is identical to all of them. This will create the function rt2x00pci_txdone() to remove the duplicate code. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28rt2x00: Remove data_desc structureIvo van Doorn
Coverty indicated that data_desc with a single element array is bad coding style. This removes the structure and forces everybody to use __le32. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-16rt2x00: Fix ieee80211 payload alignmentIvo van Doorn
As Johannes Berg indicated, the NET_IP_ALIGN doesn't need to be used for ieee80211 frames. This means we can simplify the alignment calculation to just use the result of the header size modulus 4 as frame alignment. Furthermore we shouldn't use NET_IP_ALIGN in rt2x00usb because it could be 0 on some architectures and we absolutely need to have 2 bytes reserved for possible aligning. Signed-off-by: Ivo van Doorn<IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-10rt2x00: Put 802.11 data on 4 byte boundaryIvo van Doorn
Check the size of the ieee80211 header during rxdone and make sure the data behind the ieee80211 header is placed on a 4 byte boundary. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] mac80211: revamp interface and filter configurationJohannes Berg
Drivers are currently supposed to keep track of monitor interfaces if they allow so-called "hard" monitor, and they are also supposed to keep track of multicast etc. This patch changes that, replaces the set_multicast_list() callback with a new configure_filter() callback that takes filter flags (FIF_*) instead of interface flags (IFF_*). For a driver, this means it should open the filter as much as necessary to get all frames requested by the filter flags. Accordingly, the filter flags are named "positively", e.g. FIF_ALLMULTI. Multicast filtering is a bit special in that drivers that have no multicast address filters need to allow multicast frames through when either the FIF_ALLMULTI flag is set or when the mc_count value is positive. At the same time, drivers are no longer notified about monitor interfaces at all, this means they now need to implement the start() and stop() callbacks and the new change_filter_flags() callback. Also, the start()/stop() ordering changed, start() is now called *before* any add_interface() as it really should be, and stop() after any remove_interface(). The patch also changes the behaviour of setting the bssid to multicast for scanning when IEEE80211_HW_NO_PROBE_FILTERING is set; the IEEE80211_HW_NO_PROBE_FILTERING flag is removed and the filter flag FIF_BCN_PRBRESP_PROMISC introduced. This is a lot more efficient for hardware like b43 that supports it and other hardware can still set the BSSID to all-ones. Driver modifications by Johannes Berg (b43 & iwlwifi), Michael Wu (rtl8187, adm8211, and p54), Larry Finger (b43legacy), and Ivo van Doorn (rt2x00). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[RT2x00]: add driver for Ralink wireless hardwareIvo van Doorn
