path: root/drivers/net/wireless/rt2x00/rt2x00usb.c
2009-04-20rt2x00: Don't free register information on suspendIvo van Doorn
After suspend & resume the rt2x00 devices won't wakeup anymore due to a broken register information setup. The most important problem is the release of the EEPROM buffer which is completely cleared and never read again after the suspend. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-09rt2x00: Add kill_tx_queue callback functionIvo van Doorn
provide rt2x00lib the possibility to kill a particular TX queue. This can be useful when disabling the radio, but more importantly will allow beaconing to be disabled when mac80211 requests this (during scanning for example) Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29rt2x00: Update copyright year to 2009Ivo van Doorn
2009-01-12rt2x00: Fix segementation faultIvo van Doorn
The queue_end() macro points to 1 position after the queue, which means that if we want to know if queue is at the end of the queue we should first increment the position and then check if it is a valid entry. This fixes a segmentation fault which only occurs when the device has enough endpoints to provide a dedicated endpoint for all TX queues (which likely won't happen for rt2500usb and rt73usb, but will happen for rt2800usb). Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-25rt2x00: Detect USB BULK in/out endpointsIvo van Doorn
Instead of hardcoding the used in/out endpoints we should detect them by walking through all available endpoints. rt2800usb will gain the most out of this, because the legacy drivers indicate that there are multiple endpoints available. However this code might benefit at least rt73usb as well for the MIMO queues, and if we are really lucky rt2500usb will benefit because for the TX and PRIO queues. Even if rt2500usb and rt73usb do not get better performance after this patch, the endpoint detection still belongs to rt2x00usb, and it shouldn't hurt to always try to detect the available endpoints. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-25rt2x00: Move rt73usb register access wrappers into rt2x00usbIvo van Doorn
rt2500usb and rt73usb have different register word sizes, for that reason the register access wrappers were never moved into rt2x00usb. With rt2800usb on its way, we should favor the 32bit register access and move those wrappers into rt2x00usb. That saves duplicate code, since only rt2500usb will need the special 16bit wrappers. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-21rt2x00: Fix race condition when using inderect registersIvo van Doorn
Indirect registers require multiple calls to the CSR register in order to access the indirect registers. This must be protected under a lock to prevent race conditions which could cause invalid data to be returned when reading from the indirect register or silent failures when writing data to the indirect register. USB drivers where already protected under a mutex, so rename the mutex and make PCI drivers use the mutex as well. This now means that BBP and RF registers are no longer accessible in interrupt context. That is not a bad situation since the slow behavior of accessing those registers means we don't _want_ to access them in interrupt context either. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-21rt2x00: Cleanup TX/RX entry handlingIvo van Doorn
Merge the callback functions init_txentry() and init_rxentry(). This makes life in rt2x00lib a lot simpler and we can cleanup several functions. rt2x00pci contained "fake" FIELD definitions for descriptor words. This is not flexible since it assumes the driver will always have the same field to indicate if a driver is available or not. This should be dependent on the driver, and we should add a callback function for this. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-29rt2x00: skb->data pointer should not include TX descriptorMattias Nissler
Make sure the skb->data pointer points to the frame data, not the TX descriptor. The frame dumping code relies on that. Signed-off-by: Mattias Nissler <mattias.nissler@gmx.de> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-29rt2x00: Fix race conditions in flag handlingIvo van Doorn
Some of the flags should be accessed atomically to prevent race conditions. The flags that are most important are those that can change often and indicate the actual state of the device, queue or queue entry. The big flag rename was done to move all state flags to the same naming type as the other rt2x00dev flags and made sure all places where the flags were used were changed. ;) Thanks to Stephen for most of the queue flags updates, which fixes some of the most obvious consequences of the race conditions. Among those the notorious: rt2x00queue_write_tx_frame: Error - Arrived at non-free entry in the non-full queue 0. rt2x00queue_write_tx_frame: Error - Arrived at non-free entry in the non-full queue 0. rt2x00queue_write_tx_frame: Error - Arrived at non-free entry in the non-full queue 0. Signed-off-by: Stephen Blackheath <tramp.enshrine.stephen@blacksapphire.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-18rt2x00: Fix txdone_entry_desc_flagsJochen Friedrich
txdone_entry_desc_flags is used with __set_bit and test_bit which bit-shift the values, so don't bit-shift the flags in the enum. Also make sure flags are initialized before being used. Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-02rt2x00: Fix compile warningIvo van Doorn
rt2x00usb_vendor_request_large_buff is write-only, so it is safe to make the argument a const. Fixes compile warning: drivers/net/wireless/rt2x00/rt73usb.c: In function 'rt73usb_load_firmware': drivers/net/wireless/rt2x00/rt73usb.c:916: warning: passing argument 5 of 'rt2x00usb_vendor_request_large_buff' discards qualifiers from pointer target typ Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-29rt2x00: Support for large vendor requestsIwo Mergler
Adds an extra rt2x00 vendor request function to support register transfers beyond the CSR_CACHE_SIZE / USB packet size limit. This is useful for firmware uploads, beacon templates and keys, all of which are to large to do with a single USB request. Signed-off-by: Iwo Mergler <Iwo@call-direct.com.au> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-27rt2x00: kill URB for all TX queues during disable_radio()Ivo van Doorn
During rt2x00usb_disable_radio() all pending urb's should be killed and not only those from the RX queue. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-26rt2x00: Fix sparse warning on nested container_of()Ivo van Doorn
Sparse produces warnings about nested contain_of() statements, this means that lines like: interface_to_usbdev(to_usb_interface(rt2x00dev->dev)); will upset sparse. Add a new macro to rt2x00usb.h which will convert to device structure to the usb_device pointer in 2 steps to prevent this sparse warning. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-26rt2x00: Cleanup symbol exportsIvo van Doorn
With a bit of code moving to rt2x00lib within the TX and RX paths we can now remove a lot of EXPORT_SYMBOL_GPL() statements. This cleans up the interface between rt2x00lib and the drivers and has the additional benefit that rt2x00pci and rt2x00usb are trimmed down in size as well since they have less to do. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-26rt2x00: Replace statically allocated DMA buffers with mapped skb's.Gertjan van Wingerde
The current PCI drivers require a lot of pre-allocated DMA buffers. Reduce this by using dynamically mapped skb's (using pci_map_single) instead of the pre- allocated DMA buffers that are allocated at device start-up time. At the same time move common RX path code into rt2x00lib from rt2x00pci and rt2x00usb, as the RX paths now are now almost the same. Signed-off-by: Gertjan van Wingerde <gwingerde@kpnplanet.nl> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-26rt2x00: Centralize allocation of RX skbs.Gertjan van Wingerde
In preparation of replacing the statically allocated DMA buffers with dynamically mapped skbs, centralize the allocation of RX skbs to rt2x00queue.c and let rt2x00pci already use them. Signed-off-by: Gertjan van Wingerde <gwingerde@kpnplanet.nl> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-26rt2x00: Convert rt2x00 to use generic DMA-mapping APIGertjan van Wingerde
At the same time clean up the device administration a bit, by storing a pointer to struct device instead of a void pointer that is dependent on the type of device. The normal PCI and USB subsystem provided macros can be used to convert the device pointer to the right type. This makes the rt2x00 driver a bit more type-safe. Signed-off-by: Gertjan van Wingerde <gwingerde@kpnplanet.nl> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-16Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/rt2x00/Kconfig drivers/net/wireless/rt2x00/rt2x00usb.c net/sctp/protocol.c
2008-06-14rt2x00: Fix double usage of skb->cb in USB RX path.Gertjan van Wingerde
It is not safe to use the skb->cb area for both the rxd and skb_frame_desc data at the same time, while they occupy an overlapping piece of memory. This can lead to hard to trace crashes as pointers within skb_frame_desc are pointing into nowhere, or the rxd data is overwritten with non-sense. Fix it by copying the rxd to a small buffer on the stack. Signed-off-by: Gertjan van Wingerde <gwingerde@kpnplanet.nl> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-14rt2x00: Centralize RX packet alignment handling in rt2x00lib.Gertjan van Wingerde
When rt2x00pci will be switched over to dynamically mapped skb's instead of statically allocated DMA buffers, it no longer can handle alignment of RX packets in a copy step, and needs to implement the same scheme as rt2x00usb does. In order to make the patch on dynamically mapped skb's smaller, already centralize the alignment handling into rt2x00lib. This allows us to move more code in rt2x00lib, and thus remove code duplication between rt2x00usb and rt2x00pci. Signed-off-by: Gertjan van Wingerde <gwingerde@kpnplanet.nl> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-14rt2x00: Cleanup struct skb_frame_desc.Gertjan van Wingerde
The data and data_len fields aren't really necessary in struct skb_frame_desc, as they can be deduced from the skb itself. Signed-off-by: Gertjan van Wingerde <gwingerde@kpnplanet.nl> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-14rt2x00: Don't kick TX queue after each frameIvo van Doorn
TX queues shouldn't be kicked after each frame that is put into the queue. This could cause problems during RTS and CTS-to-self as well as with fragmentation. In all those cases you want all frames to be send out in a single burst. Off course we shouldn't let the queue fill up entirely, thus we introduce a 10% threshold which, when reached, will force the frames to be send out regardless of the frame. In addition we should prevent queues to become full in such a way that the tx() handler can fail. Instead of stopping the queue when it is full, we should stop it when it is below the threshold. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-14rt2x00: Move generic TX frame writing code into rt2x00queueIvo van Doorn
The write_tx_data functions in rt2x00pci and rt2x00usb have a lot in common. This moves that duplicate code into rt2x00queue_write_tx_frame(). Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-14rt2x00: Implement rt2x00usb_kick_tx_queue()Ivo van Doorn
rt2x00usb_kick_tx_queue() will loop over all entries within the INDEX_DONE->INDEX range and kick each entry which is pending to be kicked. This makes the kick_tx_queue approach work the same as with the PCI drivers which will allow for more code generalisation into rt2x00lib. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-14rt2x00: Removed unused descriptor read in txdoneIvo van Doorn
rt2x00usb doesn't need the TX descriptor in the TX done path. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-13rt2x00: Don't kill guardian_urb when it wasn't createdIvo van Doorn
This fixes a "BUG: unable to handle kernel paging request" bug in rt73usb which was caused by killing the guardian_urb while it had never been allocated for rt73usb. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21mac80211: move TX info into skb->cbJohannes Berg
This patch converts mac80211 and all drivers to have transmit information and status in skb->cb rather than allocating extra memory for it and copying all the data around. To make it fit, a union is used where only data that is necessary for all steps is kept outside of the union. A number of fixes were done by Ivo, as well as the rt2x00 part of this patch. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21rt2x00: Merge RX and TX entry private dataIvo van Doorn
With the pending removal of the tx_control structure we can merge the RX and TX entry private data structure in advance. This will temporarily increase the required memory for the queue, but that overhead will only be limited. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21rt2x00: Split rt2x00lib_write_tx_desc()Ivo van Doorn
Split rt2x00lib_write_tx_desc() up into a TX descriptor initializor and TX descriptor writer. This split is required to properly allow mac80211 to move its tx_control structure into the skb->cb array. The rt2x00queue_create_tx_descriptor() function will read all tx control information and convert it into a rt2x00 TX descriptor information structure. After that function is complete, we have all information we needed from the tx control structure and are free to start writing into the skb->cb array for our own purposes. rt2x00queue_write_tx_descriptor() will be in charge of really sending the TX descriptor to the hardware and kicking the TX queue. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21rt2x00: Preserve descriptor information after memmove()Ivo van Doorn
Due to usage of memmove() in rt2x00usb the descriptor can become corrupted because it is being overwritten by the data part. Overall having the descriptor in front of the frame is a bad idea, we can however use the skb->cb array for this task, since that contains more then enough room to hold the entire descriptor and preserve the information long enough. After this we can also cleanup the alignment code a bit to make it work a bit more flexible to allow for all kinds of odd header lengths. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21rt2x00: Fix TX status reportingIvo van Doorn
The tx_status enumeration was broken since the introduction of rt61pci. That driver uses different values to report the status of the tx action. This would lead to frames that were reported as success but actually failed to be send out, or frames that were neither successfull or failure which were reported as failure. Fix this by change the TX status reporting and more explicitely check for failure or success. Note that a third possibility is added "unknown". Not all hardware (USB) can report the actual TX status, for rt61pci some frames will receive this status because the TXdone handler is never called for those frames. This unknown will now be handled as neither success or failure, so we no longer increment the failure counter while this conclusion could not be determined from the real status of the frame. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-07rt2x00: Add helper macrosIvo van Doorn
Add some helper macro's to help determining the the timeout for USB register access. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-07rt2x00: Use rt2x00 queue numberingIvo van Doorn
Use the rt2x00 queue enumeration as much as possible, removing the usage of the mac80211 queue numbering wherever it is possible. This makes it easier for mac80211 to change it queue identification scheme without having to deal with big changes in the rt2x00 code. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-13rt2x00:correct rx packet length for USB devicesAdam Baker
When fixing up the packet alignment, if we had to add 2 bytes to the front of the skb we need to remember to take them off the end afterwards. This fixes reception of encrypted packets which were otherwise failing with an invalid ICV. Signed-off-by: Adam Baker <linux@baker-net.org.uk> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-13rt2x00: Initialize TX control field in data entriesMattias Nissler
In the TX path, the driver didn't copy the TX control data structure. Thus, it was invalid in the TX done handler, causing serious trouble and misbehaviour. Signed-off-by: Mattias Nissler <mattias.nissler@gmx.de> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-13rt2x00: Align RX descriptor to 4 bytesIvo van Doorn
Some architectures give problems when reading RX frame descriptor words when the descriptor is not aligned on a 4 byte boundrary. Due to optimalizations for the ieee80211 payload 4 byte alignment, it is no longer guarenteed that the descriptor is placed on the 4 byte boundrary (In fact, for rt73usb it is absolutely never aligned to 4 bytes, for rt2500usb it depends on the length of the payload). This will copy the descriptor to a 4 byte aligned location before it is read for the first time. This will also move the payload data alignment in rt2x00usb (instead of inside the driver) where it has always belonged. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Remove async vendor request calls from rt2x00usbIvo van Doorn
The async vendor requests are a ugly hack which is not working correctly. The proper fix for the scheduling while atomic issue is finding out why we can't use led classes for USB drivers and fix that. Just replace all async calls with the regular ones and print an error for the disallowed LED configuration attempts. That will help in determining which led class is causing the problem. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Don't report driver generated frames to tx_status()Ivo van Doorn
This adds a new flag for the skb_frame_desc structure which is used to tag rts/cts frames that are generated by the driver. Through the tag we can recognize frames we have generated ourselves, so we don't report their tx status to mac80211. This patch is based on the original patch by Mattias Nissler <mattias.nissler@gmx.de>. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Kill guardian urb during disable_radioIvo van Doorn
When the radio is being disabled we should also kill the guardian urb which could still be pending in the device. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Fix skbdesc->data_len initializationIvo van Doorn
skbdesc->data_len was not initialized correctly in rt2x00pci, rt2x00usb, rt2500usb and rt73usb. The value was set to queue->data_size which means that the incorrect frame size was pased to the upper layers. Correctly base the value on either the skb->len, or the rx frame size passed to the driver by the device. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: make csr_cache and csr_addr an unionIvo van Doorn
The csr_cache and csr_addr pointers are both the same size and they are never used both by the same driver. This makes them a nice candidate for an union. We could merge into 1 pointer, but that would either upset sparse, or require a lot of __force casts. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Enable LED class support for rt2500usb/rt73usbIvo van Doorn
Add kerneldoc for vendor request functions in rt2x00usb. Add asynchroneous vendor request function in rt2x00usb. With the availability of the asynchroneuous vendor request we can now enable LED class support for rt2500usb and rt73usb. Since LED handling is not important, it doesn't really matter if a register call fails (This solution is better then no LED class support at all). Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Queue handling overhaulIvo van Doorn
This introduces a big queue handling overhaul, this also renames "ring" to "queues". Move queue handling into rt2x00queue.c and the matching header, use Kerneldoc to improve rt2x00 library documentation. Access to the queues is now protected under a spinlock, this to prevent race conditions which could corrupt the indexing system of the queue. Each queue entry allocates x bytes for driver/device specific data, this cleans up the queue structure significantly and improves code readability. rt2500usb no longer needs 2 entries in the beacon queue to correctly send out the guardian byte. This is now handled in the entry specific structure. rt61 and rt73 now use the correct descriptor size for beacon frames, since this data is written into the registers not the entire TXD descriptor was used but instead of a subset of it named TXINFO. Finally this also fixes numerous other bugs related to incorrect beacon handling or beacon related code. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Update copyright noticeIvo van Doorn
2008-01-28drivers/net/wireless/rt2x00/rt2x00usb.c: fix uninitialized var warningAndrew Morton
Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28rt2x00: Data and desc pointer initializationIvo van Doorn
rt2500usb and rt73usb data and desc pointer initialization was incorrect because it was using uninitialized variables to determine the length. In addition rt2500usb used skb_pull and removed the ieee80211 from each received frame instead of using skb_trim to remove the device descriptor from the frame. Finally this also fixes the descriptor override when 4 byte aligning occured. We still need a completely valid descriptor when using the TX/RX dumping capabilities in debugfs. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28rt2x00: Correctly initialize data and desc pointerIvo van Doorn
rt2500usb and rt73usb store the descriptor in different places. This means we should move the initialization of the 2 pointers to the driver callback function fill_rxdone(). Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28rt2x00: Move init_txring and init_rxring into rt2x00libIvo van Doorn
Prior to enabling the radio rt2x00lib should go through all rings and for each entry should call the callback function init_txentry() and init_rxentry(). Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
