commit 93b6bd26b74efe46b4579592560f9f1cb7b61994 upstream.
We've had many reports of rt61pci failures with powersaving enabled.
Therefore, as a stop-gap measure, disable powersaving of the rt61pci
until we have found a proper solution.
Also disable powersaving on rt2800pci as it most probably will show
the same problem.
Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com>
Acked-by: Ivo van Doorn <IvDoorn@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (34 commits)
net/fsl_pq_mdio: add module license GPL
can: fix WARN_ON dump in net/core/rtnetlink.c:rtmsg_ifinfo()
can: should not use __dev_get_by_index() without locks
hisax: remove bad udelay call to fix build error on ARM
ipip: Fix handling of DF packets when pmtudisc is OFF
qlge: Set PCIe reset type for EEH to fundamental.
qlge: Fix early exit from mbox cmd complete wait.
ixgbe: fix traffic hangs on Tx with ioatdma loaded
ixgbe: Fix checking TFCS register for TXOFF status when DCB is enabled
ixgbe: Fix gso_max_size for 82599 when DCB is enabled
macsonic: fix crash on PowerBook 520
NET: cassini, fix lock imbalance
ems_usb: Fix byte order issues on big endian machines
be2net: Bug fix to send config commands to hardware after netdev_register
be2net: fix to set proper flow control on resume
netfilter: xt_connlimit: fix regression caused by zero family value
rt2x00: Don't queue ieee80211 work after USB removal
Revert "ipw2200: fix oops on missing firmware"
decnet: netdevice refcount leak
netfilter: nf_nat: fix NAT issue in 2.6.30.4+
This prevents the rt2x00 driver from queueing ieee80211 work after the
USB card has been removed, preventing a kernel panic.
Signed-off-by: Sean Cross <sean@chumby.com>
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (21 commits)
mac80211: check interface is down before type change
cfg80211: fix NULL ptr deref
libertas if_usb: Fix crash on 64-bit machines
mac80211: fix reason code output endianness
mac80211: fix addba timer
ath9k: fix misplaced semicolon on rate control
b43: Fix DMA TX bounce buffer copying
mac80211: fix BSS leak
rt73usb.c : more ids
gre: Fix dev_addr clobbering for gretap
sky2: set carrier off in probe
net: fix sk_forward_alloc corruption
pcnet_cs: add cis of PreMax PE-200 ethernet pcmcia card
r8169: Fix card drop incoming VLAN tagged MTU byte large jumbo frames
ibmtr: possible Read buffer overflow?
net: Fix RPF to work with policy routing
net: fix kmemcheck annotations
e1000e: rework disable K1 at 1000Mbps for 82577/82578
e1000e: config PHY via software after resets
stolen from windows inf file(07/17/2009, 1.03.05.0000)
Ovislink 0x1b75, 0x7318
MSI 0x0db0, 0x4600
WideTell 0x7167, 0x3840
Signed-off-by: Xose Vazquez Perez <xose.vazquez@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (43 commits)
net: Fix 'Re: PACKET_TX_RING: packet size is too long'
netdev: usb: dm9601.c can drive a device not supported yet, add support for it
qlge: Fix firmware mailbox command timeout.
qlge: Fix EEH handling.
AF_RAW: Augment raw_send_hdrinc to expand skb to fit iphdr->ihl (v2)
bonding: fix a race condition in calls to slave MII ioctls
virtio-net: fix data corruption with OOM
sfc: Set ip_summed correctly for page buffers passed to GRO
cnic: Fix L2CTX_STATUSB_NUM offset in context memory.
MAINTAINERS: rt2x00 list is moderated
airo: Reorder tests, check bounds before element
mac80211: fix for incorrect sequence number on hostapd injected frames
libertas spi: fix sparse errors
mac80211: trivial: fix spelling in mesh_hwmp
cfg80211: sme: deauthenticate on assoc failure
mac80211: keep auth state when assoc fails
mac80211: fix ibss joining
b43: add 'struct b43_wl' missing declaration
b43: Fix Bugzilla #14181 and the bug from the previous 'fix'
rt2x00: Fix crypto in TX frame for rt2800usb
Signed-off-by: Benoit PAPILLAULT <benoit.papillault@free.fr>
After m68k's task_thread_info() doesn't refer to current,
it's possible to remove sched.h from interrupt.h and not break m68k!
Many thanks to Heiko Carstens for allowing this.
Thrustmaster FunAccess WIFI USB works with rt73usb with little
modification of rt73usb.c.
Tested with version 2.3.0 of driver.
Signed-off-by: Michal Szalata <szalat@gmail.com>
Remove the redundant l2pad parameter from the definition of
rt2x00crypto_rx_insert_iv which is used when only CONFIG_RT2500PCI but
none of the other rt2x00 family drivers is configured.
Signed-off-by: Andrew Price <andy@andrewprice.me.uk>
The calculated values for the ACK timeout and ACK
consume time are different then the values as
used by the Legacy drivers.
After testing from James Ledwith it appeared that
the calculated values caused a high amount of TX
failures, and the values from the Legacy drivers
were the most optimal to prevent TX failure due to
excessive retries.
The symptoms of this problem:
- Rate control module always falls back to 1Mbs
- Low throughput when bitrate was fixed
Possible side-effects (not confirmed but highly likely)
- Problems with DHCP
- Broken connections due to lack of probe response
This should fix at least:
Kernel bugzilla reports: [13362], [13009], [9273]
Fedora bugzilla reports: [443203]
but possible some additional bugs as well.
The old function rt2x00queue_payload_align() handled
both adding and removing L2 padding and some basic
frame alignment. The entire function was being abused
because it had multiple functions and the header length
argument was somtimes used to align the header instead
of the payload.
Additionally there was a bug when inserting L2 padding
that only the payload was aligned but not the header. This
happens when the header wasn't aligned properly by mac80211,
but rt2x00lib only moves the payload.
A secondary problem was that when removing L2 padding during
TXdone or RX the skb wasn't resized to the proper size.
Split the function into seperate functions each handling
its task as it should.
Not all values of the TX status enumeration were
covered during updating of the TX statistics. This
could lead to wrong bitrate tuning but also wrong
behavior in tools like hostapd.
Since patch "rt2x00: bss_info_changed() callback is allowed to sleep" the
variable delayed wasn't used anymore. This means it can be removed
along with the call to schedule_work which depended on that variable.
The bss_info_changed() callback function no longer needs
to be atomic. Remove the scheduled work structure and
call into the driver directly.
Additionaly this makes the DRIVER_REQUIRE_SCHEDULED
flag redundant so it can be removed.
The configure_filter() callback function no longer needs
call into the driver configure_filter() directly.
rt2800pci can handle different retry rates,
it will always step 1 rate down after a failed
transmission so creating the retry rate list
for mac80211 is quite simple.
According to the original Ralink driver,
LG_FBK_CFG0_OFDMMCS2FBK should be initialized to 9 rather then 3.
Based on a patch for rt2800pci from Benoit
In the TX descriptor the Packet ID must not be 0,
so add 1 to the ID. The wireless CLI ID is not allowed
to be 0 either, but also must be initialized with the
wcid value rather then keyid.
When the RX descriptor indicates the frame was L2 padded,
the SKBDESC_L2_PADDED flag should be set to make sure the
L2 padding is removed before it is send to mac80211.
Add new defines for RF chipsets which can be found
by the driver. We don't have to check for these
chips specifically yet, but it is better to have
the defines in now.
Fixed comments about SHARED_KEY_TABLE_BASE and SHARED_KEY_MODE_BASE.
Fixed initialization loop for SHARED_KEY_MODE_ENTRY.
Based on a patch for rt2800pci from Benoit.
The rfkill_poll callback function in the drivers check a bit
to see if the RFKILL key has been pressed. However when the
bit is set it means the radio is active and the device can be
used.
The wiphy_rfkill_set_hw_state() function expects the inversed,
so '1' must be send when the radio must be disabled.
Over time, a whole bunch of drivers have come up
with their own scheme to delay the configure_filter
operation to a workqueue. To be able to simplify
things, allow configure_filter to sleep, and add
a new prepare_multicast callback that drivers that
need the multicast address list implement. This new
callback must be atomic, but most drivers either
don't care or just calculate a hash which can be
done atomically and then uploaded to the hardware
non-atomically.
A cursory look suggests that at76c50x-usb, ar9170,
mwl8k (which is actually very broken now), rt2x00,
wl1251, wl1271 and zd1211 should make use of this
new capability.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
When beacon is being updated to refresh TIM (AP mode), beacon frames are
de-synchronizing (i.e. two neighbor beacon frames - before and after
update - are being transmitted with a wrong time interval).
That is because xxx_write_beacon should disable beacon generation only
while beacon data are being uploaded to the device, but it should not
disable the beacon clock.
Signed-off-by: Igor Perminov <igor.perminov@inbox.ru>
This patch implements FIF_PSPOLL filter flag support in rt2x00 drivers,
which has been introduced in mac80211 (see
http://marc.info/?l=linux-wireless&m=124897986330807&w=2).
The patch "Implement set_tim callback for all drivers" can cause kernel
oops in rt73usb_write_beacon. The oops is caused by one of the following
race conditions:
* In case of two near calls to set_tim: rt2x00lib_beacondone_iter is
cleaning the beacon skb, whereas rt73usb_write_beacon is still using it.
* In case of two near updates of beacon: first as the result of set_tim
and second as the result of a call from an application (e.g. hostapd).
This patch fixes the race condition by rearranging the update logic and
guarding rt2x00_intf->beacon->skb with a mutex.
Small changes in signal level was not detected up by the
MOVING_AVERAGE() due to a rounding error, using 'int' type.
rt2x00lib_antenna_diversity_eval:
rssi: -62 -62 -62 -62 -62 -62 -62 -62 -62 -62 -62 -62 -62 -62 -62
rssi_avg: -57 -57 -57 -57 -57 -57 -57 -57 -57 -57 -57 -57 -57 -57 -57
The signal level reported back could be significantly (5dBm)
different from the actual value. A level +3dBm is the same as
double the AP output power.
Signed-off-by: Lars Ericsson <Lars_Ericsson@telia.com>
Antanna quality statistics is not handled correctly, which leads to
software diversity being shutdown completly.
The main problem is that during antenna diversity statistics can
be reset resulting in loosing the signal strength just before
evaluation.
rssi history is not updated correctly leading to incorrect comparison
material for basing antenna switching on.
Some hardware require the ieee80211 header to be aligned to a
4-byte boundary before mapping it to the DMA. Otherwise some
frames (like beacons) will not be send out correctly by the
device.
Check the IEEE80211_TX_CTL_MORE_FRAMES flag to help determining
if the DMA queue should be kicked. At the moment this is combined
with the ieee80211_has_morefrags() but we might remove that later.
IEEE80211_CONF_CHANGE_RADIO_ENABLED
In the config() callback function the fields radio_enabled and
the change flag IEEE80211_CONF_CHANGE_RADIO_ENABLED have been
deprecated. This removes the usage of those fields by improving
antenna change detection in the antenna configuration function.
Change rt2x00_rf_read() and rt2x00_rf_write() to subtract 1 from the rf
register number. This is needed because the rf registers are enumerated
starting with one. The size of the rf register cache is just enough to
hold all registers, so writing to the highest register was corrupting
memory. Add a check to make sure that the rf register number is valid.
Signed-off-by: Pavel Roskin <proski@gnu.org>
Cc: stable@kernel.org
Unloading rt61pci can leave the device in such state that reloading
rt61pci would fail to reinitialize it. Bogus data would be read from
the EEPROM and the RF version won't be recognized.
It appears that unloading rt61pci with power saving enabled would have
such effect. To initialize the device properly, SOFT_RESET_CSR should
be set to the same value as rt61pci_config_ps() uses to wake up the
device.
The mac80211 workqueue exists to enable mac80211 and drivers
to queue their own work on a single threaded workqueue. mac80211
takes care to flush the workqueue during suspend but we never
really had requirements on drivers for how they should use
the workqueue in consideration for suspend.
We extend mac80211 to document how the mac80211 workqueue should
be used, how it should not be used and finally move raw access to
the workqueue to mac80211 only. Drivers and mac80211 use helpers
to queue work onto the mac80211 workqueue:
* ieee80211_queue_work()
* ieee80211_queue_delayed_work()
These helpers will now warn if mac80211 already completed its
suspend cycle and someone is trying to queue work. mac80211
flushes the mac80211 workqueue prior to suspend a few times,
but we haven't taken the care to ensure drivers won't add more
work after suspend. To help with this we add a warning when
someone tries to add work and mac80211 already completed the
suspend cycle.
Drivers should ensure they cancel any work or delayed work
in the mac80211 stop() callback.
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
When only rt2400pci or rt2500pci is compiled without any of the other
rt2x00 modules, then CONFIG_RT2X00_LIB_CRYPTO will not be enabled.
However rt2x00mac_set_tim() implemented within #ifdef CONFIG_RT2X00_LIB_CRYPTO
statements while the declaration is placed outside the definition. This results in linking
errors as reporte by Ken.
rt2x00_set_tim() has nothing to do with crypto, and thus should be moved outside
of the #ifdef statements.
These drivers have been around for a while, if there are issues
they should be reported. rt2800usb is still a bit flaky though.
rt2x00dev->default_ant should be initialized once by the driver,
and should not be changed afterwards. Because rt2x00lib_config_antenna()
was using a reference to the struct antenna_setup it actually had the oppurtunity
to change the default antenna setting and it actually did that during the validation.
Instead of passing a pointer to antenna_setup the entire structure should be copied.
Fix a bunch of spelling errors in the rt2x00 drivers
Signed-off-by: Luis Correia <luis.f.correia@gmail.com>
Use %pM instead, and also remove stray variables
declared with DECLARE_MAC_BUF.
Acked-by: Kalle Valo <kalle.valo@nokia.com>
The DEVICE_STATE_DISABLED_RADIO_HW flag is only read but never set,
it is an ancient part of one of the many versions of the rfkill implementations
in rt2x00. It is about time is disappears.
Implement set_tim callback for all rt2x00 drivers, this makes the
device wake up powersaving stations properly while in AP mode.
The only way to update the beacon is by simply calling mac80211 and
requesting the new beacon. This means the set_tim() event is mostly the
same as a beacon_done() event which was already defined in rt2x00lib.
Signed-off-by: Stefan Steuerwald <salsasepp@googlemail.com>
drivers/net/wireless/iwmc3200wifi/netdev.c
net/wireless/scan.c
The commit below changed the semantics of rt2x00_check_rev so that it no
longer checked the bottom 4 bits of the rev were non-zero. During that
conversion this part of the check was not propogated to the rt2500usb
initialisation.
commit 358623c22c9fd837b3b1b444377037f72553dc9f
Author: Ivo van Doorn <ivdoorn@gmail.com>
Date: Tue May 5 19:46:08 2009 +0200
rt2x00: Simplify rt2x00_check_rev
Without this check rt73 devices are miss recognised as rt2500 devices and
two drivers are loaded. Preventing the device being used. Reinstate this
check.
Signed-off-by: Andy Whitcroft <apw@canonical.com>
Remove the input_polldev from rt2x00 and replace it with
the rfkill interface offered by the wiphy structure. This
simplifies the entire rfkill handling in rt2x00 and allows
us to remove the CONFIG_RT2X00_LIB_RFKILL option and always
enables rfkill capabilities.
Within mac80211, we often need to copy the rx status into
skb->cb. This is wasteful, as drivers could be building it
in there to start with. This patch changes the API so that
drivers are expected to pass the RX status in skb->cb, now
accessible as IEEE80211_SKB_RXCB(skb). It also updates all
drivers to pass the rx status in there, but only by making
them memcpy() it into place before the call to the receive
function (ieee80211_rx(_irqsafe)). Each driver can now be
optimised on its own schedule.
Johannes is trying to get rid of the master netdev and in the process will
remove skb->do_not_encrypt field. This removes the do_not_encrypt
usage from rt2x00 to make the change easier.
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Documentation/feature-removal-schedule.txt
drivers/scsi/fcoe/fcoe.c
net/core/drop_monitor.c
net/core/net-traces.c
