path: root/drivers/net/wireless/rtlwifi/base.c
2011-07-21rtlwifi: Convert printks to pr_<level>Joe Perches
Use the current logging styles. Add pr_fmt where appropriate. Remove now unnecessary prefixes from printks. Convert hard coded prefix to __func__. Add a missing "\n" to a format. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-20wireless: rtlwifi: throw away MAC_FMT and use %pM insteadAndy Shevchenko
Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-20rtlwifi: rtl8192{c,ce,cu,se}: Remove comparisons of booleans with trueMike McCormack
These are a potential source of confusion, as most C code treats all non-zero values as true. Signed-off-by: Mike McCormack <mikem@ring3k.org> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-01rtlwifi: Fix warnings from gcc 4.6.0Larry Finger
gcc 4.6.0 warnings for rtlwifi: CC [M] drivers/net/wireless/rtlwifi/base.o drivers/net/wireless/rtlwifi/base.c: In function ‘rtl_tx_agg_stop’: drivers/net/wireless/rtlwifi/base.c:891:23: warning: variable ‘tid_data’ set but not used [-Wunused-but-set-variable] drivers/net/wireless/rtlwifi/base.c: In function ‘rtl_tx_agg_oper’: drivers/net/wireless/rtlwifi/base.c:921:23: warning: variable ‘tid_data’ set but not used [-Wunused-but-set-variable] CC [M] drivers/net/wireless/rtlwifi/efuse.o drivers/net/wireless/rtlwifi/efuse.c: In function ‘efuse_pg_packet_write’: drivers/net/wireless/rtlwifi/efuse.c:928:24: warning: variable ‘dataempty’ set but not used [-Wunused-but-set-variable] drivers/net/wireless/rtlwifi/efuse.c: In function ‘efuse_get_current_size’: drivers/net/wireless/rtlwifi/efuse.c:1179:5: warning: variable ‘hoffset’ set but not used [-Wunused-but-set-variable] CC [M] drivers/net/wireless/rtlwifi/ps.o drivers/net/wireless/rtlwifi/ps.c: In function ‘rtl_ps_set_rf_state’: drivers/net/wireless/rtlwifi/ps.c:85:19: warning: variable ‘rtstate’ set but not used [-Wunused-but-set-variable] CC [M] drivers/net/wireless/rtlwifi/regd.o drivers/net/wireless/rtlwifi/regd.c: In function ‘_rtl_dump_channel_map’: drivers/net/wireless/rtlwifi/regd.c:310:28: warning: variable ‘ch’ set but not used [-Wunused-but-set-variable] CC [M] drivers/net/wireless/rtlwifi/usb.o drivers/net/wireless/rtlwifi/usb.c: In function ‘_rtl_usb_transmit’: drivers/net/wireless/rtlwifi/usb.c:826:21: warning: variable ‘urb_list’ set but not used [-Wunused-but-set-variable] drivers/net/wireless/rtlwifi/usb.c:825:23: warning: variable ‘skb_list’ set but not used [-Wunused-but-set-variable] Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-05Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/libertas/if_cs.c drivers/net/wireless/rtlwifi/pci.c net/bluetooth/l2cap_sock.c
2011-04-26rtlwifi: rtl8192ce: rtl8192cu: Fix most sparse warningsLarry Finger
Fix most sparse warnings in rtlwifi, rtl8192ce and rtl8192cu drivers. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-26rtlwifi: Convert core routines for addition of rtl8192se and rtl8192deChaoming_Li
Convert core routines for addition of RTL8192SE and RTL8192DE code. Additional files are changed to allow compilation. Signed-off-by: Chaoming_Li <chaoming_li@realsil.com.cn> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-26rtlwifi: Change base routines for addition of rtl8192se and rtl8192deChaoming_Li
Change base routines for addition of RTL8192SE and RTL8192DE code. Additional files are modified to allow compilation. Signed-off-by: Chaoming_Li <chaoming_li@realsil.com.cn> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-25Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/iwlwifi/iwl-core.c drivers/net/wireless/rt2x00/rt2x00queue.c drivers/net/wireless/rt2x00/rt2x00queue.h
2011-04-12rtlwifi: rtl8192ce: Fix LED initializationChaoming Li
Driver rtl8192ce does not initialize the LED correctly. Signed-off-by: Chaoming Li <chaoming_li@realsil.com.cn> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-12Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/ath/ar9170/main.c drivers/net/wireless/ath/ar9170/phy.c drivers/net/wireless/zd1211rw/zd_rf_rf2959.c
2011-04-04rtlwifi: Remove unused/unneeded variablesLarry Finger
Remove some unused variables and correct spelling errors. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-01rtlwifi: Fix error registering rate-controlChaoming Li
When a second module such as rtl8192ce or rtl8192cu links to rtlwifi, the attempt to register a rate-control mechanism fails with the warning shown below. The fix is to select the RC mechanism when rtlwifi is initialized. WARNING: at net/mac80211/rate.c:42 ieee80211_rate_control_register+0xc9/0x100 [mac80211]() Hardware name: HP Pavilion dv2700 Notebook PC Modules linked in: arc4 ecb rtl8192ce rtl8192cu(+) rtl8192c_common rtlwifi snd_hda_codec_conexant amd74xx(+) ide_core sg mac80211 snd_hda_intel snd_hda_codec i2c_nforce2 snd_pcm snd_timer cfg80211 snd k8temp hwmon serio_raw joydev i2c_core soundcore snd_page_alloc rfkill forcedeth video ac battery button ext3 jbd mbcache sd_mod ohci_hcd ahci libahci libata scsi_mod ehci_hcd usbcore fan processor thermal Pid: 2227, comm: modprobe Not tainted 2.6.38-rc6-wl+ #468 Call Trace: [<ffffffff8104a3da>] ? warn_slowpath_common+0x7a/0xb0 [<ffffffff8104a425>] ? warn_slowpath_null+0x15/0x20 [<ffffffffa02de409>] ? ieee80211_rate_control_register+0xc9/0x100 [mac80211] [<ffffffffa03b3790>] ? rtl_rate_control_register+0x10/0x20 [rtlwifi] [<ffffffffa03ab9c9>] ? rtl_init_core+0x189/0x620 [rtlwifi] [<ffffffff811cfff8>] ? __raw_spin_lock_init+0x38/0x70 [<ffffffffa03b9dea>] ? rtl_usb_probe+0x709/0x82e [rtlwifi] [<ffffffffa002a7fd>] ? usb_match_one_id+0x3d/0xc0 [usbcore] [<ffffffffa002aae9>] ? usb_probe_interface+0xb9/0x160 [usbcore] [<ffffffff8126ed19>] ? driver_probe_device+0x89/0x1a0 [<ffffffff8126eed3>] ? __driver_attach+0xa3/0xb0 [<ffffffff8126ee30>] ? __driver_attach+0x0/0xb0 [<ffffffff8126dd4e>] ? bus_for_each_dev+0x5e/0x90 [<ffffffff8126e9d9>] ? driver_attach+0x19/0x20 [<ffffffff8126e5e8>] ? bus_add_driver+0x158/0x290 [<ffffffff8126f151>] ? driver_register+0x71/0x140 [<ffffffff811cfff8>] ? __raw_spin_lock_init+0x38/0x70 [<ffffffffa002a2cc>] ? usb_register_driver+0xdc/0x190 [usbcore] [<ffffffffa0013000>] ? rtl8192cu_init+0x0/0x20 [rtl8192cu] [<ffffffffa001301e>] ? rtl8192cu_init+0x1e/0x20 [rtl8192cu] [<ffffffff810002cf>] ? do_one_initcall+0x3f/0x180 [<ffffffff8108fd4b>] ? sys_init_module+0xbb/0x200 [<ffffffff81002c7b>] ? system_call_fastpath+0x16/0x1b ---[ end trace 726271c07a47439e ]--- rtlwifi:rtl_init_core():<0-0> rtl: Unable to register rtl_rc,use default RC !! ieee80211 phy0: Selected rate control algorithm 'minstrel_ht' Signed-off-by: Chaoming Li <chaoming_li@realsil.com.cn> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-21rtlwifi: rtl8192ce: Fix endian warningsLarry Finger
Drivers rtlwifi, and rtl8192ce generate a large number of sparse warnings. This patch fixes most of them. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-21rtlwifi: Modify some rtl8192ce routines for merging rtl8192cuLarry Finger
Modify some rtl8192ce routines for merging with rtl8192cu. In addition, remove some usage of Hungarian notation. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-22rtlwifi: rtl8192ce: Fix driver problem when radio switch off at module loadLarry Finger
If the radio enable switch is off when the driver is loaded, it is not possible to get radio output until the driver is unloaded and reloaded with the switch on. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-20rtlwifi: use alloc_workqueueJohn W. Linville
create_workqueue is deprecated. The workqueue usage does not seem to demand any special treatment, so do not set any flags either. Signed-off-by: John W. Linville <linville@tuxdriver.com> Tested-by: Larry Finger <Larry.Finger@lwfinger.net> Acked-by: Tejun Heo <tj@kernel.org>
2010-12-20rtlwifi: Fix use of mutex in interrupt codeLarry Finger
A previous conversion from semaphoreto mutexes missed the fact that one of the semaphores was used in interrupt code. Fixed by changing to a spinlock. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-16rtlwifi: Switch locking from semaphores to mutexesLarry Finger
2010-12-15rtl8192ce: Add new driverLarry Finger
