Now that a new mac80211-based driver for Realtek devices has been submitted,
it is time to reorganize the directories. Rather than having directories
rtlwifi and rtl818x be in drivers/net/wireless/, they will now be in
drivers/net/wireless/realtek/. This change simplifies the directory
structure, but does not result in any configuration changes that are
visable to the user.
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
As we're running out of hardware capability flags pretty quickly,
convert them to use the regular test_bit() style unsigned long
bitmaps.
This introduces a number of helper functions/macros to set and to
test the bits, along with new debugfs code.
The occurrences of an explicit __clear_bit() are intentional, the
drivers were never supposed to change their supported bits on the
fly. We should investigate changing this to be a per-frame flag.
packet.
rtl8192cu can't connect to AP after physical reconnect.
according to dmesg, that problem's cause was DHCP timeout.
rtl_is_special_data function checks packet type for adjusting rate.
when that function is called from _rtl_rc_get_highest_rix, it can not
calculate offset correctly. so i add argument is_encn in rtl_is_special_data.
is_enc variable mean that iv header is added in skb parameter.
i test only rtl8192cu chipset. because i doesn't have other rtlwifi chipsets.
Signed-off-by: Taehee Yoo <ap420073@gmail.com>
Routine rtl_is_special_data() is supposed to identify packets that need to
use a low bit rate so that the probability of successful transmission is
high. The current version has a bug that causes all IPv6 packets to be
labelled as special, with a corresponding low rate of transmission. A
complete fix will be quite intrusive, but until that is available, all
IPv6 packets are identified as regular.
This patch also removes a magic number.
Reported-and-tested-by: Alan Fisher <acf@unixcube.org>
Cc: Stable <stable@vger.kernel.org> [3.18+]
Cc: Alan Fisher <acf@unixcube.org>
With this change, all of the drivers now use the common routine. As this
driver has VHT capability, an additional parameter is needed, thus all the
drivers had to be modified.
This common set of rate descriptors is renamed to be DESC_RATExx.
Four of the drivers (92ce, 92cu, 92de, and 92se) supply an argument to the
rate-mapping routine that is never used, thus it can be removed.
Use "%s" in the workqueue allocation to make sure the rtl_hal_cfg name
can never accidentally leak information via a format string.
Each of the routines in the rtlwifi common driver needs to be modified
for the coming changes. This patch prepares core.c, but also touches other
files.
When the rtlwifi family of drivers was converted to use a workqueue when
entering or leaving power save mode (commits a269913c52, a5ffbe0a19,
41affd5286, b9116b9a2b, and 6539306b2c), the code began scheduling work from
the callback routine of a different workqueue with a resulting increase in
overhead.
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
This value is no longer used by mac80211, and practically no
driver ever set it to a correct value anyway, so remove it.
Ether_addr_equal_64bits is more efficient than ether_addr_equal, and can be
used when each argument is an array within a structure that contains at
least two bytes of data beyond the array.
The structures involved are:
ieee80211_hdr defined in include/linux/ieee80211.h and
rtl_mac defined in drivers/net/wireless/rtlwifi/wifi.h
This was done using Coccinelle (http://coccinelle.lip6.fr/).
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
This driver has a watchdog timer that attempts to reconnect when beacon frames
are not seen for 6 seconds. This patch disables that reconnect whenever the
device has never been connected.
All of the rtlwifi drivers have an error in the routine that tests if
the data is "special". If it is, the subsequant transmission will be
at the lowest rate to enhance reliability. The 16-bit quantity is
big-endian, but was being extracted in native CPU mode. One of the
effects of this bug is to inhibit association under some conditions
as the TX rate is too high.
Based on suggestions by Joe Perches, the entire routine is rewritten.
One of the local headers contained duplicates of some of the ETH_P_XXX
definitions. These are deleted.
Cc: Mark Cave-Ayland <mark.cave-ayland@ilande.co.uk>
Cc: Stable <stable@vger.kernel.org> [2.6.38+]
Several of the drivers supported by rtlwifi individually implement the same
routine that supports scans. As a first step, create this routine in
driver rtlwifi.
Use the new bool function ether_addr_equal to add
some clarity and reduce the likelihood for misuse
of compare_ether_addr for sorting.
Done via cocci script: (and a little typing)
$ cat compare_ether_addr.cocci
expression a,b;
- !compare_ether_addr(a, b)
+ ether_addr_equal(a, b)
expression a,b;
- compare_ether_addr(a, b)
+ !ether_addr_equal(a, b)
expression a,b;
- !ether_addr_equal(a, b) == 0
expression a,b;
- !ether_addr_equal(a, b) != 0
expression a,b;
- ether_addr_equal(a, b) == 0
expression a,b;
- ether_addr_equal(a, b) != 0
expression a,b;
- !!ether_addr_equal(a, b)
The present build configuration for the rtlwifi family of drivers will
fail under two known conditions:
(1) If rtlwifi is selected without selecting any of the dependent drivers,
there are errors in the build.
(2) If the PCI drivers are built into the kernel and the USB drivers are modules,
or vice versa, there are missing globals.
The first condition is fixed by never building rtlwifi unless at least one
of the device drivers is selected. The second failure is fixed by splitting
the PCI and USB codes out of rtlwifi, and creating their own mini drivers.
If the drivers that use them are modules, they will also be modules.
Although a number of files are touched by this patch, only Makefile and Kconfig
have undergone significant changes. The only modifications to the other files
were to export entry points needed by the new rtl_pci and rtl_usb units, or to
rename two variables that had names that were likely to cause namespace collisions.
Reported-by: Fengguang Wu <fengguang.wu@intel.com> [Condition 1]
Reported-by: Ben Hutchings <bhutchings@solarflare.com> [Condition 2]
Cc: Ben Hutchings <bhutchings@solarflare.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Pull networking updates from David Miller:
"This is a re-do of the net-next pull request for the current merge
window. The only difference from the one I made the other day is that
this has Eliezer's interface renames and the timeout handling changes
made based upon your feedback, as well as a few bug fixes that have
trickeled in.
Highlights:
1) Low latency device polling, eliminating the cost of interrupt
handling and context switches. Allows direct polling of a network
device from socket operations, such as recvmsg() and poll().
Currently ixgbe, mlx4, and bnx2x support this feature.
Full high level description, performance numbers, and design in
commit 0a4db187a999 ("Merge branch 'll_poll'")
From Eliezer Tamir.
2) With the routing cache removed, ip_check_mc_rcu() gets exercised
more than ever before in the case where we have lots of multicast
addresses. Use a hash table instead of a simple linked list, from
Eric Dumazet.
3) Add driver for Atheros CQA98xx 802.11ac wireless devices, from
Bartosz Markowski, Janusz Dziedzic, Kalle Valo, Marek Kwaczynski,
Marek Puzyniak, Michal Kazior, and Sujith Manoharan.
4) Support reporting the TUN device persist flag to userspace, from
Pavel Emelyanov.
5) Allow controlling network device VF link state using netlink, from
Rony Efraim.
6) Support GRE tunneling in openvswitch, from Pravin B Shelar.
7) Adjust SOCK_MIN_RCVBUF and SOCK_MIN_SNDBUF for modern times, from
Daniel Borkmann and Eric Dumazet.
8) Allow controlling of TCP quickack behavior on a per-route basis,
from Cong Wang.
9) Several bug fixes and improvements to vxlan from Stephen
Hemminger, Pravin B Shelar, and Mike Rapoport. In particular,
support receiving on multiple UDP ports.
10) Major cleanups, particular in the area of debugging and cookie
lifetime handline, to the SCTP protocol code. From Daniel
Borkmann.
11) Allow packets to cross network namespaces when traversing tunnel
devices. From Nicolas Dichtel.
12) Allow monitoring netlink traffic via AF_PACKET sockets, in a
manner akin to how we monitor real network traffic via ptype_all.
From Daniel Borkmann.
13) Several bug fixes and improvements for the new alx device driver,
from Johannes Berg.
14) Fix scalability issues in the netem packet scheduler's time queue,
by using an rbtree. From Eric Dumazet.
15) Several bug fixes in TCP loss recovery handling, from Yuchung
Cheng.
16) Add support for GSO segmentation of MPLS packets, from Simon
Horman.
17) Make network notifiers have a real data type for the opaque
pointer that's passed into them. Use this to properly handle
network device flag changes in arp_netdev_event(). From Jiri
Pirko and Timo Teräs.
18) Convert several drivers over to module_pci_driver(), from Peter
Huewe.
19) tcp_fixup_rcvbuf() can loop 500 times over loopback, just use a
O(1) calculation instead. From Eric Dumazet.
20) Support setting of explicit tunnel peer addresses in ipv6, just
like ipv4. From Nicolas Dichtel.
21) Protect x86 BPF JIT against spraying attacks, from Eric Dumazet.
22) Prevent a single high rate flow from overruning an individual cpu
during RX packet processing via selective flow shedding. From
Willem de Bruijn.
23) Don't use spinlocks in TCP md5 signing fast paths, from Eric
Dumazet.
24) Don't just drop GSO packets which are above the TBF scheduler's
burst limit, chop them up so they are in-bounds instead. Also
from Eric Dumazet.
25) VLAN offloads are missed when configured on top of a bridge, fix
from Vlad Yasevich.
26) Support IPV6 in ping sockets. From Lorenzo Colitti.
27) Receive flow steering targets should be updated at poll() time
too, from David Majnemer.
28) Fix several corner case regressions in PMTU/redirect handling due
to the routing cache removal, from Timo Teräs.
29) We have to be mindful of ipv4 mapped ipv6 sockets in
upd_v6_push_pending_frames(). From Hannes Frederic Sowa.
30) Fix L2TP sequence number handling bugs, from James Chapman."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1214 commits)
drivers/net: caif: fix wrong rtnl_is_locked() usage
drivers/net: enic: release rtnl_lock on error-path
vhost-net: fix use-after-free in vhost_net_flush
net: mv643xx_eth: do not use port number as platform device id
net: sctp: confirm route during forward progress
virtio_net: fix race in RX VQ processing
virtio: support unlocked queue poll
net/cadence/macb: fix bug/typo in extracting gem_irq_read_clear bit
Documentation: Fix references to defunct linux-net@vger.kernel.org
net/fs: change busy poll time accounting
net: rename low latency sockets functions to busy poll
bridge: fix some kernel warning in multicast timer
sfc: Fix memory leak when discarding scattered packets
sit: fix tunnel update via netlink
dt:net:stmmac: Add dt specific phy reset callback support.
dt:net:stmmac: Add support to dwmac version 3.610 and 3.710
dt:net:stmmac: Allocate platform data only if its NULL.
net:stmmac: fix memleak in the open method
ipv6: rt6_check_neigh should successfully verify neigh if no NUD information are available
net: ipv6: fix wrong ping_v6_sendmsg return value
For the workqueue creation interfaces that do not expect format strings,
make sure they cannot accidently be parsed that way. Additionally, clean
up calls made with a single parameter that would be handled as a format
string. Many callers are passing potentially dynamic string content, so
use "%s" in those cases to avoid any potential accidents.
The usage of strict_strtoul() is not preferred, because
strict_strtoul() is obsolete. Thus, kstrtoul() should be
used.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
drivers/net/wireless/ath/carl9170/debug.c
drivers/net/wireless/ath/carl9170/main.c
net/mac80211/ieee80211_i.h
required by adding rtl81988ee
This patch combines the remaining changes in the rtlwifi family to handle
the addition of rtl8188ee. A number of these changes eliminate some CamelCase
variable names, and other shorten common variable names so that long lines
in the new driver could be shortened.
Cc: jcheung@suse.com
Cc: machen@suse.com
Cc: mmarek@suse.cz
Cc: zhiyuan_yang@realsil.com.cn
In commit a5ffbe0, some of the calls to rtl_lps_leave() were switched
to be called from a work queue to avoid a scheduling while atomic bug.
This patch converts the remaining calls to use the work queue. In
addition, the call to rtl_lps_enter() is also switched to the work
queue. None of these newly converted calls had triggered the bug (yet),
but this change make all of them fit a single pattern.
Cc: machen@suse.com
Cc: mmarek@suse.cz
Cc: page_he@realsil.com.cn
These changes add the new variables for P2P and modify the various struct
definitions for other new features.
This patch updates files base.{c,h} for the changes in the newest vendor
driver.
This patch updates files ps.{c,h} for the changes in the newest vendor
driver.
This patch updates files debug.{c,h}, efuse.c, pci.{c,h}, and wifi.h for
the changes in the newest vendor driver.
This patch updates files core.c, ps.c, rc.c, and wifi.h for
Cc: machen@suse.com
Cc: mmarek@suse.cz
Drivers that don't use chanctxes cannot perform VHT association because
they still use a "backward compatibility" pair of {ieee80211_channel,
nl80211_channel_type} in ieee80211_conf and ieee80211_local.
Signed-off-by: Karl Beldan <karl.beldan@rivierawaves.com>
[fix kernel-doc]
For VHT, many more bandwidth changes are possible. As a first
step, stop toggling the IEEE80211_HT_CAP_SUP_WIDTH_20_40 flag
in the HT capabilities and instead introduce a bandwidth field
indicating the currently usable bandwidth to transmit to the
station. Of course, make all drivers use it.
To achieve this, make ieee80211_ht_cap_ie_to_sta_ht_cap() get
the station as an argument, rather than the new capabilities,
so it can set up the new bandwidth field.
If the station is a VHT station and VHT bandwidth is in use,
also set the bandwidth accordingly.
Doing this allows us to get rid of the supports_40mhz flag as
the HT capabilities now reflect the true capability instead of
the current setting.
While at it, also fix ieee80211_ht_cap_ie_to_sta_ht_cap() to not
ignore HT cap overrides when MCS TX isn't supported (not that it
really happens...)
Kernel commits 41affd5 and 6539306 changed the locking in rtl_lps_leave()
from a spinlock to a mutex by doing the calls indirectly from a work queue
to reduce the time that interrupts were disabled. This change was fine for
most systems; however a scheduling while atomic bug was reported in
https://bugzilla.redhat.com/show_bug.cgi?id=903881. The backtrace indicates
that routine rtl_is_special(), which calls rtl_lps_leave() in three places
was entered in atomic context. These direct calls are replaced by putting a
request on the appropriate work queue.
Reported-and-tested-by: Nathaniel Doherty <ntdoherty@gmail.com>
Cc: Nathaniel Doherty <ntdoherty@gmail.com>
Cc: Stanislaw Gruszka <sgruszka@redhat.com>
the new driver
This patch completes the addition of the new driver for the Realtek
RTL8723AE devices by adding the make file and by modifying Kconfig
and Makefile of rtlwifi. Some variable names were shortened to ease
the problem of limiting all lines to 80 characters, thus changes were
made to wifi.h and rtl8192{ce,cu,sw}/hw.c.
Cc: <chaoming_li@realsil.com.cn>
Remove the control.sta pointer from ieee80211_tx_info to free up
sufficient space in the TX skb control buffer for the upcoming
Transmit Power Control (TPC).
Instead, the pointer is now on the stack in a new control struct
that is passed as a function parameter to the drivers' tx method.
Signed-off-by: Thomas Huehn <thomas@net.t-labs.tu-berlin.de>
Signed-off-by: Alina Friedrichsen <x-alina@gmx.net>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
[reworded commit message]
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
Remove unused argument hw from call to rtl_tid_to_ac().
Adding casts of objects to the same type is unnecessary
and confusing for a human reader.
For example, this cast:
int y;
int *p = (int *)&y;
I used the coccinelle script below to find and remove these
unnecessary casts. I manually removed the conversions this
script produces of casts with __force, __iomem and __user.
type T;
T *p;
- (T *)p
+ p
Neatened the mwifiex_deauthenticate_infra function which
was doing odd things with array pointers and not using
is_zero_ether_addr.
expression a,b;
expression a,b;
expression a,b;
expression a,b;
expression a,b;
expression a,b;
expression a,b;
When the rate-control indexing is incorrectly set up, mac80211 issues
a warning and returns NULL from the call to ieee80211_get_tx_rate().
When this happens, avoid a NULL pointer dereference.
This patch correct some typos in a comment.
Signed-off-by: Tristan Pourcelot <tristan.pourcelot@gmail.com>
This patch addresses a kernel bugzilla report and two recent mail threads.
The kernel bugzilla report is https://bugzilla.kernel.org/show_bug.cgi?id=42632,
which reports a udev timeout on boot.
The first mail thread, which was on LKML (http://lkml.indiana.edu/hypermail/
linux/kernel/1112.3/00965.html) was for a WARNING that occurs after a
suspend/resume cycle for rtl8192cu.
The scond mail thread (http://marc.info/?l=linux-wireless&m=132655490826766&w=2)
concerned changes in udev that break drivers that delay while firmware is loaded
on modprobe.
This patch converts all rtlwifi-based drivers to use the asynchronous firmware
loading mechanism. Drivers rtl8192ce, rtl8192cu and rtl8192de share a common
callback routine. Driver rtl8192se needs different handling of the firmware,
thus it has its own code.
Although the rtlwifi family of devices contains 11 copies of the pr_fmt
macro, the macro is not defined for all routines that need it. By moving
the macro to wifi.h, a single copy is available for all routines.
Due to firmware limitations, we may not be able to
support beacon filtering on all virtual interfaces.
To allow this in mac80211, introduce per-interface
driver capability flags that the driver sets when
an interface is added.
Acked-by: Luciano Coelho <coelho@ti.com>
Consolidate printks to avoid possible message interleaving
and reduce the object size.
Remove unnecessary RT_TRACE parentheses.
Miscellaneous typo and grammar fixes.
Add missing newlines to formats.
Remove duplicate KERN_DEBUG prefixes.
Coalesce formats.
Align arguments.
$ size drivers/net/wireless/rtlwifi/built-in.o*
594841 55333 129680 779854 be64e drivers/net/wireless/rtlwifi/built-in.o.new
607022 55333 138720 801075 c3933 drivers/net/wireless/rtlwifi/built-in.o.old
drivers/net/wireless/b43/dma.c
drivers/net/wireless/brcm80211/brcmfmac/dhd_linux.c
DaveM said:
Please, this kind of stuff rots forever and not using bool properly
drives me crazy.
Joe Perches <joe@perches.com> gave me the spatch script:
bool b;
-b = 0
+b = false
bool b;
-b = 1
+b = true
I merely installed coccinelle, read the documentation and took credit.
When I tested commit 6539306, I did not notice that loading an out-of-tree
module turns off lockdep testing in kernel 3.2. For that reason, I missed
the kernel WARNING shown below:
The solution fixes the warning by partially reverting commit 6539306.
[ 84.168146] ------------[ cut here ]------------
[ 84.168155] WARNING: at kernel/mutex.c:198 mutex_lock_nested+0x309/0x310()
[ 84.168158] Hardware name: HP Pavilion dv2700 Notebook PC
[ 84.168161] Modules linked in: nfs lockd auth_rpcgss nfs_acl sunrpc af_packet cpufreq_conservative cpufreq_userspace cpufreq_powersave powernow_k8 mperf e
xt3 jbd ide_cd_mod cdrom snd_hda_codec_conexant arc4 rtl8192ce ide_pci_generic rtl8192c_common rtlwifi snd_hda_intel mac80211 snd_hda_codec snd_pcm snd_timer
amd74xx ide_core cfg80211 k8temp snd joydev soundcore hwmon battery forcedeth i2c_nforce2 sg rfkill ac serio_raw snd_page_alloc button video i2c_core ipv6 a
utofs4 ext4 mbcache jbd2 crc16 sd_mod ahci ohci_hcd libahci libata scsi_mod ehci_hcd usbcore usb_common fan processor thermal
[ 84.168231] Pid: 1218, comm: kworker/u:2 Not tainted 3.2.0-rc5-wl+ #155
[ 84.168234] Call Trace:
[ 84.168240] [<ffffffff81048aaa>] warn_slowpath_common+0x7a/0xb0
[ 84.168245] [<ffffffff81048af5>] warn_slowpath_null+0x15/0x20
[ 84.168249] [<ffffffff813811f9>] mutex_lock_nested+0x309/0x310
[ 84.168269] [<ffffffffa00793f9>] ? rtl_ips_nic_on+0x49/0xb0 [rtlwifi]
[ 84.168277] [<ffffffffa00793f9>] rtl_ips_nic_on+0x49/0xb0 [rtlwifi]
[ 84.168284] [<ffffffffa007ab85>] rtl_pci_tx+0x1b5/0x560 [rtlwifi]
[ 84.168291] [<ffffffffa007635a>] rtl_op_tx+0x9a/0xa0 [rtlwifi]
[ 84.168359] [<ffffffffa043cf51>] __ieee80211_tx+0x181/0x2b0 [mac80211]
[ 84.168375] [<ffffffffa043ef06>] ieee80211_tx+0xf6/0x120 [mac80211]
[ 84.168391] [<ffffffffa043ee49>] ? ieee80211_tx+0x39/0x120 [mac80211]
[ 84.168408] [<ffffffffa043f80b>] ieee80211_xmit+0xdb/0x100 [mac80211]
[ 84.168425] [<ffffffffa043f730>] ? ieee80211_skb_resize.isra.26+0xb0/0xb0 [mac80211]
[ 84.168441] [<ffffffffa0440b2a>] ieee80211_tx_skb_tid+0x5a/0x70 [mac80211]
[ 84.168458] [<ffffffffa0443da2>] ieee80211_send_auth+0x152/0x1b0 [mac80211]
[ 84.168474] [<ffffffffa042e169>] ieee80211_work_work+0x1049/0x1860 [mac80211]
[ 84.168489] [<ffffffffa042d120>] ? free_work+0x20/0x20 [mac80211]
[ 84.168504] [<ffffffffa042d120>] ? free_work+0x20/0x20 [mac80211]
[ 84.168510] [<ffffffff81065ffc>] process_one_work+0x17c/0x530
[ 84.168514] [<ffffffff81065f92>] ? process_one_work+0x112/0x530
[ 84.168519] [<ffffffff81066994>] worker_thread+0x164/0x350
[ 84.168524] [<ffffffff8108420d>] ? trace_hardirqs_on+0xd/0x10
[ 84.168528] [<ffffffff81066830>] ? manage_workers.isra.28+0x220/0x220
[ 84.168533] [<ffffffff8106bc17>] kthread+0x87/0x90
[ 84.168539] [<ffffffff813854b4>] kernel_thread_helper+0x4/0x10
[ 84.168543] [<ffffffff81382bdd>] ? retint_restore_args+0xe/0xe
[ 84.168547] [<ffffffff8106bb90>] ? __init_kthread_worker+0x70/0x70
[ 84.168552] [<ffffffff813854b0>] ? gs_change+0xb/0xb
[ 84.168554] ---[ end trace f25a4fdc768c028f ]---
Cc: Stanislaw Gruska <sgruszka@redhat.com>
Cc: Chaoming Li <chaoming_li@realsil.com.cn>
With previous patch "rtlwifi: use work for lps" we can now use mutex for
protecting ps mode changing critical sections. This fixes running system
with interrupts disabled for long time.
Merge ips_lock and lps_lock as they seems to protect the same data
structures (accessed in rtl_ps_set_rf_state() function).
Reported-by: Philipp Dreimann <philipp@dreimann.net>
Tested-by: Larry Finger <Larry.Finger@lwfinger.net>
Cc: Mike McCormack <mikem@ring3k.org>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Tested-by: Tim Gardner <tim.gardner@canonical.com>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux
drivers/net/wireless/iwlegacy/iwl-debugfs.c
drivers/net/wireless/iwlegacy/iwl-rx.c
drivers/net/wireless/iwlegacy/iwl-scan.c
drivers/net/wireless/iwlegacy/iwl-tx.c
include/net/bluetooth/bluetooth.h
Driver rtlwifi fails on a big-endian host.
These changes have been tested on a Mac PowerBook G4, which has
a PPC processor.
Although this patch touches some of the code that will affect endian
issues on PCI hardware through drivers rtl8192ce, rtl8192se, and
rtl8192de, these have not been tested due to lack of suitable hardware.
The device.h header was including module.h, making it present for
most of these drivers. But we want to clean that up. Call out the
include of module.h in the modular network drivers.
