commit dc6405712268fe514d3dd89aa936c4397b0871b9 upstream.
The current number of RX buffers queued is 32, which is too small under
heavy load. That number is doubled.
commit 65b9cc97c6852fae19dc5c7745e9abc8dd380aad upstream.
The USB drivers were not updating the beacon statistics, which led to
false beacon loss indications.
commit bcfb879432094c267c35a7ff75d953d3a66c193a upstream.
Commit a269913c5 entitled "rtlwifi: Rework rtl_lps_leave() and
rtl_lps_enter() to use work queue" has two bugs for USB drivers.
Firstly, the work queue in question was not initialized. Secondly,
the callback routine used by this queue is contained within the
file used for PCI devices. As a result, it is not available for
architectures without PCI hardware.
Reported-by: Richard Genoud <richard.genoud@gmail.com>
Tested-by: Richard Genoud <richard.genoud@gmail.com>
Cc: Richard Genoud <richard.genoud@gmail.com>
Driver rtl8192cu can connect to WPA2 networks, but fails for any other
encryption method. The cause is a failure to set the rate control data
blocks. These changes fix https://bugzilla.redhat.com/show_bug.cgi?id=952793
and https://bugzilla.redhat.com/show_bug.cgi?id=761525.
A major change in the rtlwifi family recently added code to detect when
there is loss of AP signals. One critical statement needed for the USB
driver was missed.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
net/mac80211/sta_info.c
net/wireless/core.h
Add proper alignment at first packet copy, to avoid extra copies made later
in networking stack.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi>
Move processing of received packets to tasklet from hard-irq context.
RX path has extra copying of packets, that can be avoided.
Use dedicated DMA coherent buffers for RX urbs, to avoid allocation of large
skbuffs in hard-irq context and improve performance.
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
Cc: stable@vger.kernel.org
Signed-off-by: Andrei Epure <epure.andrei@gmail.com>
separately
rtlwifi allocates both setup_packet and data buffer of control message urb,
using shared kmalloc in _usbctrl_vendorreq_async_write. Structure used for
allocating is:
struct {
u8 data[254];
struct usb_ctrlrequest dr;
Because 'struct usb_ctrlrequest' is __packed, setup packet is unaligned and
DMA mapping of both 'data' and 'dr' confuses ARM/sunxi, leading to memory
corruptions and freezes.
Patch changes setup packet to be allocated separately.
[v2]:
- Use WARN_ON_ONCE instead of WARN_ON
Cc: <stable@vger.kernel.org>
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
drivers/net/wireless/iwlwifi/dvm/tx.c
When the new_id entry in /sysfs is used for a foreign USB device, rtlwifi
BUGS with a NULL pointer dereference because the per-driver configuration
data is not available. The probe function has been restructured as
suggested by Ben Hutchings <bhutchings@solarflare.com>.
Cc: Stable <stable@vger.kernel.org>
Building this driver with "make W=1" results in the following 2 warnings:
drivers/net/wireless/rtlwifi/usb.c:829:21: warning: variable ‘urb_list’ set but not used [-Wunused-but-set-variable]
drivers/net/wireless/rtlwifi/usb.c:828:23: warning: variable ‘skb_list’ set but not used [-Wunused-but-set-variable]
In routine _rtl_rx_pre_process(), skb_dequeue() is called to get an skb;
however, the wrong variable name is used in subsequent calls.
Reported-by: Guenter Roeck <linux@roeck-us.net>
We fail to release 'urb' if '_rtl_prep_rx_urb()' fails in
_rtl_usb_receive().
This patch should take care of the leak.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Incorrect use of usb_alloc_coherent memory as input buffer to usb_control_msg
can cause problems in arch DMA code, for example kernel BUG at
'arch/arm/include/asm/dma-mapping.h:321' on ARM (linux-3.4).
Change _usb_writeN_sync use kmalloc'd buffer instead.
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
If _rtl_usb_receive fails, the device is
probably not ready. Hence the error code
should be passed to the caller, so it can
react accordingly and notify the user.
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
The rtlwifi family of drivers has the following sparse errors:
CHECK drivers/net/wireless/rtlwifi/usb.c
drivers/net/wireless/rtlwifi/usb.c:122:17: warning: cast to restricted __le32
CHECK drivers/net/wireless/rtlwifi/rtl8192c/dm_common.c
drivers/net/wireless/rtlwifi/rtl8192c/dm_common.c:1157:13: warning: context imbalance in 'rtl92c_dm_refresh_rate_adaptive_mask' - different lock contexts for basic block
CHECK drivers/net/wireless/rtlwifi/rtl8192ce/hw.c
drivers/net/wireless/rtlwifi/rtl8192ce/hw.c:1909:30: warning: cast to restricted __le32
CHECK drivers/net/wireless/rtlwifi/rtl8192ce/sw.c
drivers/net/wireless/rtlwifi/rtl8192ce/sw.c:345:1: warning: symbol 'rtl92ce_pci_ids' was not declared. Should it be static?
CHECK drivers/net/wireless/rtlwifi/rtl8192cu/trx.c
drivers/net/wireless/rtlwifi/rtl8192cu/trx.c:494:9: warning: cast from restricted __le16
CHECK drivers/net/wireless/rtlwifi/rtl8192se/fw.c
drivers/net/wireless/rtlwifi/rtl8192se/fw.c:490:17: warning: cast to restricted __le32
drivers/net/wireless/rtlwifi/rtl8192se/fw.c:494:17: warning: cast to restricted __le32
drivers/net/wireless/rtlwifi/rtl8192se/fw.c:499:17: warning: cast to restricted __le32
drivers/net/wireless/rtlwifi/rtl8192se/fw.c:510:25: warning: cast to restricted __le32
drivers/net/wireless/rtlwifi/rtl8192se/fw.c:607:9: warning: cast to restricted __le16
drivers/net/wireless/rtlwifi/rtl8192se/fw.c:650:9: warning: cast to restricted __le16
drivers/net/wireless/rtlwifi/rtl8192se/fw.c:652:9: warning: cast to restricted __le16
CHECK drivers/net/wireless/rtlwifi/rtl8192se/trx.c
drivers/net/wireless/rtlwifi/rtl8192se/trx.c:758:9: warning: cast from restricted __le32
drivers/net/wireless/rtlwifi/rtl8192se/trx.c:788:17: warning: cast from restricted __le32
drivers/net/wireless/rtlwifi/rtl8192se/trx.c:804:17: warning: cast to restricted __le32
drivers/net/wireless/rtlwifi/rtl8192se/trx.c:807:17: warning: cast from restricted __le32
Remove the control.sta pointer from ieee80211_tx_info to free up
sufficient space in the TX skb control buffer for the upcoming
Transmit Power Control (TPC).
Instead, the pointer is now on the stack in a new control struct
that is passed as a function parameter to the drivers' tx method.
Signed-off-by: Thomas Huehn <thomas@net.t-labs.tu-berlin.de>
Signed-off-by: Alina Friedrichsen <x-alina@gmx.net>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
[reworded commit message]
In commit a7959c1, the USB part of rtlwifi was switched to convert
_usb_read_sync() to using a preallocated buffer rather than one
that has been acquired using kmalloc. Although this routine is named
as though it were synchronous, there seem to be simultaneous users,
and the selection of the index to the data buffer is not multi-user
safe. This situation is addressed by adding a new spinlock. The routine
cannot sleep, thus a mutex is not allowed.
In commit b0302ab, the rtlwifi family of drivers was converted to use
asynchronous firmware loading. Unfortumately, the implementation was
racy, and the ieee80211 routines could be started before rtl_init_core()
was called to setup the data.
This patch fixes the bug noted in https://bugzilla.kernel.org/show_bug.cgi?id=43187.
Reported-by: Joshua Roys <Joshua.Roys@gtri.gatech.edu>
Tested-by: Neptune Ning <frostyplanet@gmail.com>
Cc: Stable <stable@vger.kernel.org> [3.3]
The current version of rtlwifi for USB operations uses kmalloc to
acquire a 32-bit buffer for each read of the device. When
_usb_read_sync() is called with the rcu_lock held, the result is
a "sleeping function called from invalid context" BUG. This is
reported for two cases in https://bugzilla.kernel.org/show_bug.cgi?id=42775.
The first case has the lock originating from within rtlwifi and could
be fixed by rearranging the locking; however, the second originates from
within mac80211. The kmalloc() call is removed from _usb_read_sync()
by creating a ring buffer pointer in the private area and
allocating the buffer data in the probe routine.
Cc: Stable <stable@vger.kernel.org> [This version good for 3.3+ - different patch for 3.2 - 2.6.39]
In usb.c, routine _rtl_usb_init_sw() always returns 0, and rtl_usb_probe()
never checks the returned value. Thus we can change _rtl_usb_init_sw() to
a void routine. In addition, remove the underscore at the beginning of the
name of the routine.
In the unlikely event of a misread of the USB end point count, the driver
generates a divide fault. To prevent this, add a check of the value
returned by _rtl_usb_init(). In addition, add some logging to indicate
why the condition occurred.
This patch addresses a kernel bugzilla report and two recent mail threads.
The kernel bugzilla report is https://bugzilla.kernel.org/show_bug.cgi?id=42632,
which reports a udev timeout on boot.
The first mail thread, which was on LKML (http://lkml.indiana.edu/hypermail/
linux/kernel/1112.3/00965.html) was for a WARNING that occurs after a
suspend/resume cycle for rtl8192cu.
The scond mail thread (http://marc.info/?l=linux-wireless&m=132655490826766&w=2)
concerned changes in udev that break drivers that delay while firmware is loaded
on modprobe.
This patch converts all rtlwifi-based drivers to use the asynchronous firmware
loading mechanism. Drivers rtl8192ce, rtl8192cu and rtl8192de share a common
callback routine. Driver rtl8192se needs different handling of the firmware,
thus it has its own code.
Although the rtlwifi family of devices contains 11 copies of the pr_fmt
macro, the macro is not defined for all routines that need it. By moving
the macro to wifi.h, a single copy is available for all routines.
In https://bugzilla.redhat.com/show_bug.cgi?id=771656, a kernel bug was
triggered due to a failed skb allocation that was not checked. This event
lead to an audit of all memory allocations in the complete rtlwifi family
of drivers. This patch fixes the rest.
Consolidate printks to avoid possible message interleaving
and reduce the object size.
Remove unnecessary RT_ASSERT parentheses.
Align arguments.
Coalesce formats.
Remove unnecessary __func__ use as the macro uses it.
$ size drivers/net/wireless/rtlwifi/built-in.o*
588901 55333 127216 771450 bc57a drivers/net/wireless/rtlwifi/built-in.o.new
590002 55333 127560 772895 bcb1f drivers/net/wireless/rtlwifi/built-in.o.old
Remove unnecessary RT_TRACE parentheses.
Miscellaneous typo and grammar fixes.
Add missing newlines to formats.
Remove duplicate KERN_DEBUG prefixes.
Coalesce formats.
Align arguments.
594841 55333 129680 779854 be64e drivers/net/wireless/rtlwifi/built-in.o.new
607022 55333 138720 801075 c3933 drivers/net/wireless/rtlwifi/built-in.o.old
Make the macros a bit more readable.
Use do {...} while (0) without terminating semicolons.
Add missing terminating semicolon to a few uses.
drivers/net/wireless/rtlwifi/usb.c: In function ‘_usb_read_sync’:
drivers/net/wireless/rtlwifi/usb.c:102:6: warning: ‘status’ may be used uninitialized in this function
drivers/net/wireless/rtlwifi/usb.c:102:6: note: ‘status’ was declared here
My compiler is dumb, but better to eliminate the warning than to have
anyone waste time evaluating this again...
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux
drivers/net/wireless/iwlegacy/iwl-debugfs.c
drivers/net/wireless/iwlegacy/iwl-rx.c
drivers/net/wireless/iwlegacy/iwl-scan.c
drivers/net/wireless/iwlegacy/iwl-tx.c
include/net/bluetooth/bluetooth.h
Driver rtlwifi fails on a big-endian host.
These changes have been tested on a Mac PowerBook G4, which has
a PPC processor.
Although this patch touches some of the code that will affect endian
issues on PCI hardware through drivers rtl8192ce, rtl8192se, and
rtl8192de, these have not been tested due to lack of suitable hardware.
Driver rtl8192cu writes the firmware with 32-bit asynchronous writes. This
design is OK for USB 2.0 adapters, but the current implementation of
xhcu-hcd has a limited ring size, which is exceeded. By converting to
synchronous block writes, this error is avoided.
The USB driver does not retry reads - allow 10 tries.
Signed-off-by: George <george0505@realtek.com>
These were getting the macros from an implicit module.h
include via device.h, but we are planning to clean that up.
drivers/net: Add export.h to wireless/brcm80211/brcmfmac/bcmsdh.c
This relatively recently added file uses EXPORT_SYMBOL and hence
needs export.h included so that it is compatible with the module.h
split up work.
Driver rtl8192cu assigns a new struct rtl_tcb_desc object, but fails to
clear it.
Cc: Stable <stable@kernel.org> [2.6.39+]
Use the current logging styles.
Add pr_fmt where appropriate.
Remove now unnecessary prefixes from printks.
Convert hard coded prefix to __func__.
Add a missing "\n" to a format.
Convert usb routines for addition of RTL8192SE and RTL8192DE code
Signed-off-by: Chaoming_Li <chaoming_li@realsil.com.cn>
Convert core routines for addition of RTL8192SE and RTL8192DE code.
Additional files are changed to allow compilation.
Change base routines for addition of RTL8192SE and RTL8192DE code.
Additional files are modified to allow compilation.
Some compiler/architecture combinations generate some warnings that are
not seen on my main system. Two of the "warnings" about unitialized variables
are really bugs.
Drivers rtlwifi, and rtl8192ce generate a large number of
sparse warnings. This patch fixes most of them.
