path: root/drivers/net/wireless/zd1211rw/zd_mac.c
2011-02-25mac80211: make tx() operation return voidJohannes Berg
The return value of the tx operation is commonly misused by drivers, leading to errors. All drivers will drop frames if they fail to TX the frame, and they must also properly manage the queues (if they didn't, mac80211 would already warn). Removing the ability for drivers to return a BUSY value also allows significant cleanups of the TX TX handling code in mac80211. Note that this also fixes a bug in ath9k_htc, the old "return -1" there was wrong. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Tested-by: Sedat Dilek <sedat.dilek@googlemail.com> [ath5k] Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> [rt2x00] Acked-by: Larry Finger <Larry.Finger@lwfinger.net> [b43, rtl8187, rtlwifi] Acked-by: Luciano Coelho <coelho@ti.com> [wl12xx] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-04zd1211rw: enable NL80211_IFTYPE_APJussi Kivilinna
It should be safe to enable AP-mode now. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-04zd1211rw: reset device when CR_BCN_FIFO_SEMAPHORE freezes in beacon setupJussi Kivilinna
When driver fails to acquire device semaphore lock, device usually freezes soon afterwards. So failing to acquire lock indicates us that not everything is going right in device/fw. So reset device when this happens. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-04zd1211rw: add TX watchdog and device resettingJussi Kivilinna
When doing transfers at high speed for long time, tx queue can freeze. So add tx watchdog. TX-watchdog checks for locked tx-urbs and reset hardware when such is detected. Merely unlinking urb was not enough, device have to be reseted. Hw settings are restored so that any open link will stay on after reset. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-04zd1211rw: collect driver settings and add function to restore theimJussi Kivilinna
We need HW hard reset later in patchset to reset device after TX-stall. Collect all settings that we have set to driver for later reset and add restore function. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-04zd1211rw: batch beacon config commands togetherJussi Kivilinna
Beacon config function writes beacon to hw one write per byte. This is very slow (usually taking more than 100ms to finish) and causes high CPU usage when in AP-mode (kworker at ~50% on Intel Atom N270). By batching commands together zd_mac_config_beacon() runtime can be lowered to 1/5th and lower CPU usage to saner levels (<10% on Atom). Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-04zd1211rw: add beacon watchdog and setting HW beacon more failsafeJussi Kivilinna
When doing tx/rx at high packet rate (for example simply using ping -f), device starts to fail to respond to control messages. On non-AP modes this only causes problems for LED updating code but when we are running in AP-mode we are writing new beacon to HW usually every 100ms. Now if control message fails in HW beacon setup, device lock is kept locked and beacon data partially written. This can and usually does cause: 1. HW beacon setup fail now on, as driver cannot acquire device lock. 2. Beacon-done interrupt stop working as device has incomplete beacon. Therefore make zd_mac_config_beacon() always try to release device lock and add beacon watchdog to restart beaconing when stall is detected. Also fix zd_mac_config_beacon() try acquiring device lock for max 500ms, as what old code appeared to be trying to do using loop and msleep(1). Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-04zd1211rw: implement beacon fetching and handling ieee80211_get_buffered_bc()Jussi Kivilinna
2011-02-04zd1211rw: let zd_set_beacon_interval() set dtim_period and add AP-beacon flagJussi Kivilinna
Add support for AP-mode beacon. Also disable beacon when interface is set down as otherwise hw will keep flooding NEXT_BCN interrupts. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-04zd1211rw: fix ack_pending in filter_ack causing tx-packet ordering problem ↵Jussi Kivilinna
on monitor For reasons not very clear yet to me, filter_ack leaves matching tx-packet pending with 'ack_pending'. This causes tx-packet to be passed back to upper layer after next packet has been transfered and tx-packets might end up coming come out of monitor interface in wrong order vs. rx. Because of this when enable AP-mode, hostapd monitor interface would get packets in wrong order causing problems in WPA association. So don't use mac->ack_pending when in AP-mode. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-04zd1211rw: support setting BSSID for AP modeJussi Kivilinna
2011-02-04zd1211rw: move set_rts_cts_work to bss_info_changedJussi Kivilinna
As bss_info_changed may sleep, we can as well set RTS_CTS register right away. Keep mac->short_preamble for later use (hw reset). Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-04zd1211rw: move set_multicast_hash and set_rx_filter from workers to ↵Jussi Kivilinna
configure_filter Workers not needed anymore since configure_filter may sleep. Keep mac->multicast_hash for later use (hw reset). Signed-off-by: Jussi Kivilinna <jussi.kivilina@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-04zd1211rw: add locking for mac->process_intrJussi Kivilinna
2010-12-15workqueue: convert cancel_rearming_delayed_work[queue]() users to ↵Tejun Heo
cancel_delayed_work_sync() cancel_rearming_delayed_work[queue]() has been superceded by cancel_delayed_work_sync() quite some time ago. Convert all the in-kernel users. The conversions are completely equivalent and trivial. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: "David S. Miller" <davem@davemloft.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: netdev@vger.kernel.org Cc: Anton Vorontsov <cbou@mail.ru> Cc: David Woodhouse <dwmw2@infradead.org> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: Alex Elder <aelder@sgi.com> Cc: xfs-masters@oss.sgi.com Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: netfilter-devel@vger.kernel.org Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: linux-nfs@vger.kernel.org
2010-06-16zd1211rw: change ZD_REGDOMAIN_JAPAN_* namingJohn W. Linville
ZD_REGDOMAIN_JAPAN_ADD and ZD_REGDOMAIN_JAPAN_GW_US54GXS seem a little verbose to me... Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-16zd1211rw: add 0x49 -> JP regulatory domain mapKouhei Sutou
0x49 is used by PLANEX GW-US54GXS (2019:5303). Signed-off-by: Kouhei Sutou <kou@clear-code.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-02wireless: fix several minor description typosWalter Goldens
Signed-off-by: Walter Goldens <goldenstranger@yahoo.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (108 commits) bridge: ensure to unlock in error path in br_multicast_query(). drivers/net/tulip/eeprom.c: fix bogus "(null)" in tulip init messages sky2: Avoid rtnl_unlock without rtnl_lock ipv6: Send netlink notification when DAD fails drivers/net/tg3.c: change the field used with the TG3_FLAG_10_100_ONLY constant ipconfig: Handle devices which take some time to come up. mac80211: Fix memory leak in ieee80211_if_write() mac80211: Fix (dynamic) power save entry ipw2200: use kmalloc for large local variables ath5k: read eeprom IQ calibration values correctly for G mode ath5k: fix I/Q calibration (for real) ath5k: fix TSF reset ath5k: use fixed antenna for tx descriptors libipw: split ieee->networks into small pieces mac80211: Fix sta_mtx unlocking on insert STA failure path rt2x00: remove KSEG1ADDR define from rt2x00soc.h net: add ColdFire support to the smc91x driver asix: fix setting mac address for AX88772 ipv6 ip6_tunnel: eliminate unused recursion field from ip6_tnl{}. net: Fix dev_mc_add() ...
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-02zd1211rw: fix potential array underflowDan Carpenter
The first chunk fixes a debugging assert to print a warning about array underflows. The second chunk corrects a potential array underflow. I also removed an assert in the second chunk because it can no longer happen. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Benoit Papillault <benoit.papillault@free.fr> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-04Fix a grammar error (redundant "be") in commentAdam Buchbinder
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-01-19Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-core.h
2010-01-12Merge branch 'master' of ↵David S. Miller
2010-01-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6John W. Linville
Conflicts: net/mac80211/iface.c
2010-01-04zd1211rw: Fix multicast filtering.Benoit Papillault
If multicast parameter (as returned by zd_op_prepare_multicast) has changed, no bit in changed_flags is set. To handle this situation, we do not return if changed_flags is 0. If we do so, we will have some issue with IPv6 which uses multicast for link layer address resolution. Signed-off-by: Benoit Papillault <benoit.papillault@free.fr> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-30Merge branch 'master' of ↵David S. Miller
2009-12-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6John W. Linville
Conflicts: drivers/net/wireless/libertas/scan.c
2009-12-29Merge branch 'master' of ↵David S. Miller
2009-12-28mac80211: remove struct ieee80211_if_init_confJohannes Berg
All its members (vif, mac_addr, type) are now available in the vif struct directly, so we can pass that instead of the conf struct. I generated this patch (except the mac80211 and header file changes) with this semantic patch: @@ identifier conf, fn, hw; type tp; @@ tp fn(struct ieee80211_hw *hw, -struct ieee80211_if_init_conf *conf) +struct ieee80211_vif *vif) { <... ( -conf->type +vif->type | -conf->mac_addr +vif->addr | -conf->vif +vif ) ...> } Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28wireless: remove remaining qual codeJohannes Berg
This removes the remaining users of the rx status 'qual' field and the field itself. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-10-27zd1211rw: Fix TX status reporting in order to have proper rate controlBenoit PAPILLAULT
First, we reduce the number of hardware retries to 0 (ie 2 real retries for each rate). Next, when we report the retries to mac80211, we always report a retry count of 1 (it seems to be 2 in fact, but using 2 seems to lead to wrong performance for some reason). We use a state machine to determine the real fate of a packet based on the 802.11 ACK and what the Zydas hardware is saying when a real retry occurs. The real retry rates are encoded in a static array. It has been tested with both zd1211 and zd1211b hardware. Of course, since the Zydas hardware is not reporting retries accurately, we are just doing our best in order to get the best performance (ie higher throughput). Signed-off-by: Benoit PAPILLAULT <benoit.papillault@free.fr> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-20mac80211: allow configure_filter callback to sleepJohannes Berg
Over time, a whole bunch of drivers have come up with their own scheme to delay the configure_filter operation to a workqueue. To be able to simplify things, allow configure_filter to sleep, and add a new prepare_multicast callback that drivers that need the multicast address list implement. This new callback must be atomic, but most drivers either don't care or just calculate a hash which can be done atomically and then uploaded to the hardware non-atomically. A cursory look suggests that at76c50x-usb, ar9170, mwl8k (which is actually very broken now), rt2x00, wl1251, wl1271 and zd1211 should make use of this new capability. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14zd1211rw: make it clear we don't use leds.h LED stuffLuis R. Rodriguez
zd1211rw uses its own LED stuff so let rename its LED stuff as such. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-04mac80211: redefine usage of the mac80211 workqueueLuis R. Rodriguez
The mac80211 workqueue exists to enable mac80211 and drivers to queue their own work on a single threaded workqueue. mac80211 takes care to flush the workqueue during suspend but we never really had requirements on drivers for how they should use the workqueue in consideration for suspend. We extend mac80211 to document how the mac80211 workqueue should be used, how it should not be used and finally move raw access to the workqueue to mac80211 only. Drivers and mac80211 use helpers to queue work onto the mac80211 workqueue: * ieee80211_queue_work() * ieee80211_queue_delayed_work() These helpers will now warn if mac80211 already completed its suspend cycle and someone is trying to queue work. mac80211 flushes the mac80211 workqueue prior to suspend a few times, but we haven't taken the care to ensure drivers won't add more work after suspend. To help with this we add a warning when someone tries to add work and mac80211 already completed the suspend cycle. Drivers should ensure they cancel any work or delayed work in the mac80211 stop() callback. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10mac80211: push rx status into skb->cbJohannes Berg
Within mac80211, we often need to copy the rx status into skb->cb. This is wasteful, as drivers could be building it in there to start with. This patch changes the API so that drivers are expected to pass the RX status in skb->cb, now accessible as IEEE80211_SKB_RXCB(skb). It also updates all drivers to pass the rx status in there, but only by making them memcpy() it into place before the call to the receive function (ieee80211_rx(_irqsafe)). Each driver can now be optimised on its own schedule. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20zd1211rw: Replace ZD_CS_MULTICAST with ZD_CS_NO_ACKGábor Stefanik
According to my tests, all that ZD_CS_MULTICAST does is to disable retrying/waiting for an ACK. Reflect this by renaming the bit to ZD_CS_NO_ACK and setting it based on IEEE80211_TX_CTL_NO_ACK, instead of is_multicast_ether_addr. Signed-off-by: Gábor Stefanik <netrolller.3d@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-06mac80211: unify config_interface and bss_info_changedJohannes Berg
The config_interface method is a little strange, it contains the BSSID and beacon updates, while bss_info_changed contains most other BSS information for each interface. This patch removes config_interface and rolls all the information it previously passed to drivers into bss_info_changed. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/igb/igb_main.c drivers/net/qlge/qlge_main.c drivers/net/wireless/ath9k/ath9k.h drivers/net/wireless/ath9k/core.h drivers/net/wireless/ath9k/hw.c
2009-03-16zd1211rw: Do not panic on device eject when associatedJouni Malinen
zd_op_tx() must not return an arbitrary error value since that can leave mac80211 trying to retransmit the frame and with the extra data pushed into the beginning of the skb on every attempt, this will end up causing a kernel panic (skb_under_panic from skb_push call). This can happen, e.g., when ejecting the device when associated. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-05zd1211rw: Implement get_tsf()Alina Friedrichsen
This patch implements get_tsf() of ieee80211_ops in the zd1211rw driver. Signed-off-by: Alina Friedrichsen <x-alina@gmx.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27cfg80211: move all regulatory hints to workqueueLuis R. Rodriguez
All regulatory hints (core, driver, userspace and 11d) are now processed in a workqueue. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-13zd1211rw: honour enable_beacon confJohannes Berg
This makes zd1211rw honour enable_beacon, as well as fixing a memory leak: the beacon skb is leaked when configuring it to the hardware fails. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-13zd1211rw: do not ratelimit no-opsJohannes Berg
It is rather confusing to see this in the log: [ 695.606877] __ratelimit: 40 callbacks suppressed [ 700.726878] __ratelimit: 40 callbacks suppressed without ever seeing any actual message. This is because zd1211rw doesn't compile out the net_ratelimit() call properly if debugging is not enabled. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-09mac80211: remove HW_SIGNAL_DBJohannes Berg
Giving the signal in dB isn't much more useful to userspace than giving the signal in unspecified units. This removes some radiotap information for zd1211 (the only driver using this flag), but it helps a lot for getting cfg80211-based scanning which won't support dB, and zd1211 being dB is a little fishy anyway. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Bruno Randolf <bruno@thinktube.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
