path: root/drivers/net/wireless/zd1211rw/zd_usb.c
2008-05-21misc drivers/net endianness noiseAl Viro
2008-05-12zd1211rw: fix potential use-after-free bugJohannes Berg
zd_mac_tx_to_dev() could potentially free the skb, or hand it off to mac80211 which might free it. Hence, this code needs to get the usb pointer out of skb->cb before handing it off to that function. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-29wireless: use get/put_unaligned_* helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: John W. Linville <linville@tuxdriver.com> Cc: Michael Buesch <mb@bu3sch.de> Cc: Daniel Drake <dsd@gentoo.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-06zd1211rw: support for mesh interface and beaconingLuis Carlos Cobo
The previously unused CR_CAM_MODE register is set to MODE_AP_WDS. This makes the driver ack mesh (WDS) frames. It does not affect Infra functionality of the driver. Previously missing beaconing support has been added. This might also help implement a currently missing ah-hoc mode. Support for interrupts from the device have been added, but we are not handling most of them. Mesh interfaces are considered associated as long as the interface is up. Signed-off-by: Luis Carlos Cobo <luisca@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28zd1211rw: add copyright noticesDaniel Drake
Requested by Michael Wu. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28zd1211rw: Add ID for Trendnet TEW-429UB ADaniel Drake
Tested by chloubs on IRC zd1211 chip 157e:300a v4810 high 00-11-e0 AL7230B_RF pa0 g---- Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28zd1211rw: port to mac80211Daniel Drake
This seems to be working smoothly now. Let's not hold back the mac80211 transition any further. This patch ports the existing driver from softmac to mac80211. Many thanks to everyone who helped out with the porting efforts. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-18[PATCH] zd1211rw, fix oops when ejecting install mediaMarc Pignat
The disconnect function can dereference the net_device structure when it is never allocated. This is the case when ejecting the device installer. Signed-off-by: Marc Pignat <marc.pignat@hevs.ch> Acked-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] zd1211rw: Add ID for TalkTalk SNU5630NS/05Daniel Drake
Tested by Su-Jong You zd1211b chip 0471:1237 v4810 high 00-12-bf AL2230_RF pa0 g--N Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[ZD1211RW]: Removed zd_util.c and zd_util.hUlrich Kunitz
The kernel now provides a generic hexdump implementation should we need it again, so we can remove it from zd1211rw. After removing that, only one single-user function is left in zd_util. Move that to zd_mac and remove zd_util. Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[ZD1211RD]: add USB id for Telegent TG54USB WLAN adapterUlrich Kunitz
Reinhard Speyerer reported at 2007-08-10 a new device. Here are the information strings. Product: Telegent TG54USB WLAN Adapter USB ID: 129b:1666 Chip ID: zd1211 chip 129b:1666 v4330 high 00-01-36 RF2959_RF pa0 ----- FCC ID: N89-UW620Z Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[PATCH] zd1211rw: Add ID for ZyXEL M-202 XtremeMIMODaniel Drake
Tested by Nathen Meyers FCC ID: SI5WUB221Z zd1211b chip 0586:340a v4810 high 00-13-49 AL2230_RF pa0 ----S Despite the product name, I'm pretty sure this isn't a MIMO device. It appears just to be a normal ZD1211B and we have never heard of these devices having more than 1 RF. I guess they named this product this way to make it appear that it fits in with the rest of their XtremeMIMO product range. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] zd1211rw: Add ID for Sitecom WL-162Daniel Drake
Tested by Giuseppe Lippolis zd1211b chip 0cde:001a v4810 high 00-60-b3 AL2230_RF pa0 g--NS Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-17[PATCH] zd1211rw: Add ID for Siemens Gigaset USB Stick 54Daniel Drake
Tested by David Santinoli zd1211b chip 129b:1667 v4810 high 00-01-e3 AL2230S_RF pa0 ---N- Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-17[PATCH] zd1211rw: Add ID for Planex GW-US54GXSMasakazu Mokuno
This patch adds the ID for Planex GW-US54GXS USB wireless adapter sold in Japan. Since this device returns the regulatory region as 0x49, the patch 'Allow channels 1-11 for unrecognised regulatory domains' is required. Tested by Masakazu Mokuno zd1211b chip 2019:5303 v4810 high 00-90-cc AL2230_RF pa0 ---N- Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-16Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (37 commits) forcedeth bug fix: realtek phy forcedeth bug fix: vitesse phy forcedeth bug fix: cicada phy atl1: reorder atl1_main functions atl1: fix excessively indented code atl1: cleanup atl1_main atl1: header file cleanup atl1: remove irq_sem cdc-subset to support new vendor/product ID 8139cp: implement the missing dev->tx_timeout myri10ge: Remove nonsensical limit in the tx done routine gianfar: kill unused header EP93XX_ETH must select MII macb: Add multicast capability macb: Use generic PHY layer s390: add barriers to qeth driver s390: scatter-gather for inbound traffic in qeth driver eHEA: Introducing support vor DLPAR memory add Fix a potential NULL pointer dereference in free_shared_mem() in drivers/net/s2io.c [PATCH] softmac: Fix ESSID problem ...
2007-07-15zd1211rw: too early inclusion of asm/unaligned.hAl Viro
2007-07-10[PATCH] zd1211rw: Defer firmware load until first ifupDaniel Drake
While playing with the firmware a while back, I discovered a way to access the device's entire address space before the firmware has been loaded. Previously we were loading the firmware early on (during probe) so that we could read the MAC address from the EEPROM and register a netdevice. Now that we can read the EEPROM without having firmware, we can defer firmware loading until later while still reading the MAC address early on. This has the advantage that zd1211rw can now be built into the kernel -- previously if this was the case, zd1211rw would be loaded before the filesystem is available and firmware loading would fail. Firmware load and other device initialization operations now happen the first time the interface is brought up. Some architectural changes were needed: handling of the is_zd1211b flag was moved into the zd_usb structure, MAC address handling was obviously changed, and a preinit_hw stage was added (the order is now: init, preinit_hw, init_hw). Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-10[PATCH] zd1211rw: Add ID for Buffalo WLI-U2-KG54LDaniel Drake
Tested by Zen Kato zd1211b chip 0411:00da v4810 high 00-16-01 AL2230S_RF pa0 g--N- Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-08[PATCH] zd1211rw: Add ID for ZyXEL G-200v2Daniel Drake
Tested by Guy Gallagher zd1211 chip 0586:3407 v4721 high 00-13-49 AL2230_RF pa0 g--- FCC ID SI5WUB200Z Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-08[PATCH] zd1211rw: Add ID for ZyXEL AG-225H v2Daniel Drake
Tested by davo on IRC zd1211b chip 0586:3413 v4810 full 00-13-49 AL7230B_RF pa0 ----- Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-08[PATCH] zd1211rw: Add ID for Sitecom WL-117Matthew Davidson
This is another "driverless" device which first presents itself as a USB CDROM drive. A separate patch has been submitted to make usb-storage ignore that device, so that zd1211rw can eject it. zd1211 chip 0df6:9075 v4916 full 00-0c-f6 AL2230_RF pa0 ---- Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-08[PATCH] zd1211rw: Added new USB id for Planex GW-US54ZGLUlrich Kunitz
Alan Tam <Tam at SiuLung dot com> asked for inclusion of this device into the tree. zd1211b chip 0053:5301 v4810 high 00-90-cc AL2230_RF pa0 ---N Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-28[PATCH] zd1211rw: Add ID for ZyXEL AG-220Daniel Drake
Tested by Christoph Sager and Tomas Klas zd1211b chip 0586:3412 v4810 high 00-13-49 AL7230B_RF pa0 g---- Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-28[PATCH] zd1211rw: Add another ID for Linksys WUSBF54GDaniel Drake
Tested by TiCPU on irc zd1211 chip 13b1:001e v4802 high 00-14-bf AL2230_RF pa0 g--- Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-28[PATCH] zd1211rw: More device IDsDaniel Drake
ASUS A9Rp Tested by Serge zd1211b chip 0b05:171b v4802 high 00-17-31 AL2230_RF pa0 g-- ZyXEL G-202 Tested by Marcus D. Hanwell zd1211b chip 0586:3410 v4810 high 00-13-49 AL2230_RF pa0 g--- US Robotics USR805423 Tested by Pascal S. de Kloe FCC ID: RAXWN4501H zd1211b chip 0baf:0121 v4810 high 00-14-c1 AL2230_RF pa0 g--N Julien Pinon reports this also comes in AL2230S form Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-28[PATCH] zd1211rw: changed GFP_NOFS to GFP_KERNELUlrich Kunitz
Michael Buesch commented that GFP_NOFS should not be used in a network driver. Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-23Add missing USRobotics Wireless Adapter (Model 5423) id into zd1211rwS.Çağlar Onur
USRobotics Wireless Adapter (Model 5423) works well with current zd1211rw driver also (i have tested 2.6.18, 2.6.20 and 2.6.21-rc7). It just needs its ID added to the list of devices. Signed-off-by: S.Çağlar Onur <caglar@pardus.org.tr> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09Merge branch 'upstream' of ↵Jeff Garzik
master.kernel.org:/pub/scm/linux/kernel/git/linville/wireless-2.6 into upstream
2007-02-07[PATCH] zd1211rw: Added error stats updateUlrich Kunitz
Added update of network device error statistics. Based on earlier work by Maxime Austruy. Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-02-07[PATCH] zd1211rw: Reset device in the probe callUlrich Kunitz
This resets the device in the probe call. It does work with 2.6.19.2 including the softmac patches. It might fix the reboot/reset problems a lot of people reported. Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-02-07[PATCH] zd1211rw: fix potential leak in usb_initMaxime Austruy
usb_init should call destroy_workqueue when usb_register fails. Signed-off-by: Maxime Austruy <maxime@tralhalla.org> Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-02-05[PATCH] zd1211rw: Add ID for ZyXEL ZyAIR G-220 v2Daniel Drake
Tested by Marijn Schouten zd1211b chip 0586:340f v4810 high 00-13-49 AL2230_RF pa0 g--- FCC ID: I88G220V2 Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-02-05[PATCH] zd1211rw: Add ID for Linksys WUSBF54GDaniel Drake
Tested by Henrik Hjelte zd1211b chip 13b1:0024 v4802 high 00-14-bf AL2230_RF pa0 ---- Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-02-05[PATCH] zd1211rw: Remove addressing abstractionDaniel Drake
Instead of passing our own custom 32-bit addresses around and translating them, this patch makes all our register address constants absolute and removes the translation. There are two ugly parts: - fw_reg_addr() is needed to compute addresses of firmware registers, as this is dynamic based upon firmware - inc_addr() needs a small hack to handle byte vs word addressing However, both of those are only small, and we don't use fw_regs a whole lot anyway. The bonuses here include simplicity and improved driver readability. Also, the fact that registers are now referenced by 16-bit absolute addresses (as opposed to 32-bit pseudo addresses) means that over 2kb compiled code size has been shaved off. Includes some touchups and sparse fixes from Ulrich Kunitz. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-02-05[PATCH] zd1211rw: Consistency for address space constantsDaniel Drake
The zd1211rw address space has confused me once too many times. This patch introduces the following naming notation: Memory space is split into segments (cr, fw, eeprom) and segments may contain components (e.g. boot code inside eeprom). These names are arbitrary and only for the description below: x_START: Absolute address of segment start (previously these were named such as CR_BASE_OFFSET, but they weren't really offsets unless you were considering them as an offset to 0) x_LEN: Segment length x_y_LEN: Length of component y of segment x x_y_OFFSET: Relative address of component y into segment x. The absolute address for this component is (x_START + x_y_OFFSET) I also renamed EEPROM registers to EEPROM data. These 'registers' can't be written to using standard I/O and really represent predefined data from the vendor. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-02-05[PATCH] zd1211rw: 2 new ZD1211B device ID'sDaniel Drake
Philips SNU5600, tested by unibrow zd1211b chip 0471:1236 v4810 high 00-12-bf AL2230_RF pa0 g-- SMC Ez Connect 802.11g (SMCWUSB-G), tested by Victorino Sanz Prat zd1211b chip 083a:4505 v4810 full 00-13-f7 AL2230_RF pa0 g--N Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-19[PATCH] zd1211rw: Call ieee80211_rx in taskletUlrich Kunitz
The driver called ieee80211_rx in hardware interrupt context. This has been against the intention of the ieee80211_rx function. It caused a bug in the crypto routines used by WPA. This patch calls ieee80211_rx in a tasklet. Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-02[PATCH] zd1211rw: Optimized handling of zero length entries in length infoUlrich Kunitz
There are a high number of split USB transactions, which contain only one packet but have a length info field. This patch optimizes this code by stopping parsing the length info structure if a zero length field is encountered. Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-02[PATCH] zd1211rw: cleanupsUlrich Kunitz
Bit-field constants in zd_chip.h are now defined using a shift expression. The value 0x08 is now (1 << 3). The fix is intended to improve readability. Remove misleading comment in zd_mac.c: The function already returns -EPERM in managed mode (IW_MODE_INFRA). Remove unused code in zd_mac.c: The unused code intended for debugging rx_status values is no longer useful. Added dump_stack() to ZD_ASSERT macro: Output of the stack helps to debug assertions. Keep in mind that the ZD_ASSERT() macro only results in code, if DEBUG is defined. Improved comments for filter_rx() zd_usb.c: Added driver name to module init and exit functions Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-02[PATCH] zd1211rw: Add ID for Belkin F5D7050 v4000Daniel Drake
zd1211b chip 050d:705c v4810 high 00-17-3f AL2230_RF pa0 g--N Tested by Bryan Barnard Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-02[PATCH] zd1211rw: Add ID for Planex GW-US54MiniDaniel Drake
zd1211 chip 14ea:ab13 v4330 high 00-90-cc AL2230_RF pa0 g--- Tested by Tetsuya Yatagai. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-02[PATCH] zd1211rw: Add ID for ZyXEL G-220Daniel Drake
Tested by Newsome on IRC zd1211 chip 0586:3401 v4330 high 00-13-49 AL2230_RF pa0 g--- Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-02[PATCH] zd1211rw: Add 3 more device IDsDaniel Drake
iNexQ UR055g: Tested by Todor T Zviskov zd1211 chip 1435:0711 v4330 high 00-10-a7 AL2230_RF pa0 g-- ZyXEL AG-225, FCC ID SI5WUB410: Tested by Nathan zd1211 chip 0586:3409 v4810 full 00-13-49 AL7230B_RF pa0 g--- Yakumo QuickWLAN USB: Tested by EdB zd1211 chip 0b3b:1630 v4330 high 00-01-36 RF2959_RF pa0 --- Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-11-28[PATCH] zd1211rw: Fix of a locking bugUlrich Kunitz
This patch fixes the bug as reported in the kernel bug tracker under the id 7244. The bug was simply that the interrupt lock has been locked outside an interrupt without blocking the interrupt. Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-25[PATCH] zd1211rw: Added workqueueUlrich Kunitz
For housekeeping and watchdog tasks a workqueue is created. The central workqueue is not used to prevent crashes creates by bugs. It might be changed, when the housekeeping is stabilized. Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-09-11[PATCH] zd1211rw: Add ID for Asus WL-159gDaniel Drake
Tested by Vincent TOUCHARD zd1211 chip 0b05:170c v4802 high 00-11-d8 AL2230_RF pa0 g--- Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-09-11[PATCH] zd1211rw: Add ID for Siemens Gigaset USB Stick 54Daniel Drake
Tested by Martin Dummer. zd1211 chip 0b3b:5630 v4330 high 00-01-e3 RF2959_RF pa0 --- Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-08-14[PATCH] zd1211rw: cleanupsUlrich Kunitz
Add static to 2 internal functions. Thanks goes to Adrian Bunk, who found that. Also made some modifications to the clear functions: After a discussion on the mailing list, I implemented this code to have on the one hand sufficient test in debug mode, but on the other hand reduce the overhead for structure clearing to a minimum. A new macro ZD_MEMCLEAR is introduced, which produces code if DEBUG is set. Locks are not set anymore for structure clearing, but in debug mode, there is a verification, that the locks have not been set. Finally, removed a misleading comment regarding locking in the disconnect path. Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
