Symptoms:
The interface stops receiving CAN frames when reception of CAN frame
and call to the introduced get_berr_counter function coincide.
Reproduction:
Ip requests, among others, the berr field for the can interfaces. NOTE
that it does so even if called as 'ip link show lo', as interface-based
filtering is only done after the system calls to receive interface
information.
Run candump on a MCP-based can interface that has a lot of traffic (via
'cangen -g1' on another can node).
On the system with the MCP chip, run
while /bin/true; do ip link > /dev/null ; done;
Reception of CAN-frames (as shown by candump) will cease within
seconds.
This issue got introduced by commit
1b59090a47101b4bf379d2c35986ad3f0bcb2aa1 as access to the SPI registers
of the MCP251x were not locked.
Issue report and patch courtesy David R. Piegdon of Indurad GmbH.
Enable IEEE 1588 precision time protocol (PTP) support.
Springville/i211 with a blank Flash/iNVM use different PCI IDs. Extend
the driver to load despite i210/i211 data sheets claiming tools only,
not for driver.
Only warn rather than fail on NVM validation failures on Apalis T30.
Revise Ethernet MAC address assignment: should now handle up to two
instances of custom user MACs (2nd one with a 0x100000 offset). This
way customer does not have to worry about NVM on a secondary Ethernet
on the carrier board and still gets a valid official MAC address from
us (e.g. analogous to how we did it on our Protea carrier board).
Use the Toradex OUI as default MAC address if no valid one is
encountered.
Tested on samples of Apalis T30 2GB V1.0B, V1.0C and Apalis T30 1GB
V1.0A both with blank NVMs as well as iNVMs programmed with Intel's
defaults.
Springville/i211 with a blank Flash/iNVM use a different PCI ID (tools
only, not for driver) than properly programmed ones.
Integrate latest igb driver version 5.1.2
(igb-5.1.2.tar.gz from e1000.sf.net).
Add a new ethtool operation (get_rxfh_indir_size) to get the
indirectional table size. Use this to validate the user buffer size
before calling get_rxfh_indir or set_rxfh_indir. Use get_rxnfc to get
the number of RX rings, and validate the contents of the new
indirection table before calling set_rxfh_indir. Remove this
validation from drivers.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Acked-by: Dimitris Michailidis <dm@chelsio.com>
drivers/media/video/tegra_v4l2_camera.c
reverted to current driver supporting ACM rather than CSI2
drivers/media/video/videobuf2-dma-nvmap.c
drivers/video/tegra/host/Makefile
I211 with a blank iNVM uses a different PCI ID. Hack the driver to load
despite i211 data sheet claiming tools only, not for driver.
Please note that the existing driver hacks concerning NVM validation
skipping and Ethernet MAC address assignment equally apply.
Tested on initial samples of Apalis T30 1GB V1.0A.
According to Realtek, the firmware provides
power optimizations. The driver works without
the firmware. Plus, there are scenarios where
the firmware is not available, which makes the
driver wait at request_firmware call (i.e.,
60 sec wait).
Bug 1236060
Bug 991551
Change-Id: Ifcaa4b2dd48c4111ded33cf2bade7dc1f6422821
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Reviewed-on: http://git-master/r/258353
GVS: Gerrit_Virtual_Submit
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Turns out after suspend an unbind and bind operation is executed upon
which we subsequently gave out the 2nd custom user MAC address followed
by the default ASIX MAC address.
This patch fixes it by checking for the custom user MAC address upon
unbinding and in this case properly releasing it for subsequent reuse.
Integrate CAN support for the Colibri Evaluation Board V3.1a with built-in
MCP2515 SPI CAN controller resp. the Colibri Evaluation Board V2.1c with its
built-in SJA1000 CAN controller connected to the GMI bus.
The following kernel configuration needs to be enabled as well:
CONFIG_CAN
CONFIG_CAN_RAW
CONFIG_CAN_BCM
CONFIG_CAN_DEV
Plus depending on the Evaluation Board revision:
CONFIG_CAN_MCP251X
or
CONFIG_CAN_SJA1000
CONFIG_CAN_SJA1000_PLATFORM
Optional support for 32-bit GMI as well as xPOD CAN on MECS Tellurium for
Colibri T20 is provided via commented defines in
arch/arm/mach-tegra/board-colibri_t20.h.
arch/arm/mach-tegra/common.c
drivers/ata/ahci-tegra.c
The following commit actually missed adding the new files:
7925180aee227f3de7af4a8cbad1c4b203a9132e
Springville with a blank Flash uses a different PCI ID. Hack the driver
to load despite i210 data sheet claiming tools only, not for driver.
Hack the driver to skip NVM validation on Apalis T30 for now.
Hack the driver to use a hard-code MAC address on Apalis T30 for now.
This patch adds new initialization functions and device support
for i210 and i211 devices.
Signed-off-by: Carolyn Wyborny <carolyn.wyborny@intel.com>
Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com>
82580 and later parts did not have low power setting functions. This patch
adds the specific functions, pointers and assignments for these low
power settings.
initialize SSID variable properly to ensure
no memory overrun.
Bug 1204024
Change-Id: I2485c13edcf6a0feeae3cd4b2e9e98910a771dd2
Reviewed-on: http://git-master/r/190684
do not allow scheduling hang thread after cleanup
is done.
Bug 1210849
Bug 1205910
Bug 1163014
Change-Id: Idc5f9fd6a3d210843f1168e57ceef107599d5789
Reviewed-on: http://git-master/r/189721
Reviewed-by: Allen Martin <amartin@nvidia.com>
Add BERR counter functionality to MCP251x driver.
Signed-off-by: Mitja Spes <mitja@lxnav.com>
Revise Ethernet MAC address assignment: should now use MAC from EEPROM
if set and further handles up to two instances of custom user MACs (2nd
one with a 0x100000 offset). This way customer does not have to put
EEPROM on a secondary Ethernet on the carrier board and still gets a
valid official MAC address from us (e.g. analogous to how we did it on
arch/arm/mach-tegra/tegra3_usb_phy.c
arch/arm/mach-tegra/usb_phy.c
drivers/usb/gadget/tegra_udc.c
drivers/usb/otg/Makefile
drivers/video/tegra/fb.c
sound/soc/tegra/tegra_pcm.c
problem:
The macro wiphy_from_scan retrieves wiphy from
wl_priv->escan_info.wiphy which is in turn set by
a 'scan' initiated from kernel space (like
scheduled scan) or from user space (like iwlist command).
Without a scan, a 'connect' crashes in function
wl_inform_single_bss, with NULL pointer access,
as the variable wiphy (in turn, wl->escan_info.wiphy)
is not initialized properly.
solution:
wireless_device data structures maintained for both
STA and P2P mode point to the same wiphy (see,
wl_cfgp2p_register_ndev in wl_cfgp2p.c). So,
irrespective of whatever wireless_device is in
use, a scan will always set wl_priv->escan_info.wiphy
to the same wiphy. There is no point in getting
wiphy using wl_priv->escan_info.wiphy, rather use
the wiphy referred by all wireless_device structures.
Bug 1029792
Bug 1029733
Change-Id: I6d744950d3a053642ffa998b3c3f3ba60c0cb687
Reviewed-on: http://git-master/r/141629
Do not turn off mmc at probe if watchdog thread is
in use.
Bug 1029792
Bug 1029733
Change-Id: Ia2e303daa27688c96e7fa5941e01cf821166c498
Reviewed-on: http://git-master/r/141628
cleanup bcmdhd driver Kconfig and Makefile
Bug 1029792
Bug 1029733
Change-Id: Ic947644d2159a52fab7aea1621e12e51d8ee6332
Reviewed-on: http://git-master/r/141627
Merge with latest NVIDIA L4T R16.
Only real conflict concerning inverted VBUS gpio support.
Commit 4231d47e6fe69f061f96c98c30eaf9fb4c14b96d(net/usbnet: avoid
recursive locking in usbnet_stop()) fixes the recursive locking
problem by releasing the skb queue lock before unlink, but may
cause skb traversing races:
- after URB is unlinked and the queue lock is released,
the refered skb and skb->next may be moved to done queue,
even be released
- in skb_queue_walk_safe, the next skb is still obtained
by next pointer of the last skb
- so maybe trigger oops or other problems
This patch extends the usage of entry->state to describe 'start_unlink'
state, so always holding the queue(rx/tx) lock to change the state if
the referd skb is in rx or tx queue because we need to know if the
refered urb has been started unlinking in unlink_urbs.
The other part of this patch is based on Huajun's patch:
always traverse from head of the tx/rx queue to get skb which is
to be unlinked but not been started unlinking.
Signed-off-by: Huajun Li <huajun.li.lee@gmail.com>
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Cc: Oliver Neukum <oneukum@suse.de>
Cc: stable@kernel.org
(cherry picked from commit 5b6e9bcdeb65634b4ad604eb4536404bbfc62cfa)
Bug 1040642
Change-Id: I1a8c248016529bebf71d540738ad4726cf3f59b7
Signed-off-by: Steve Lin <stlin@nvidia.com>
Reviewed-on: http://git-master/r/128693
|kernel BUG at kernel/rtmutex.c:724!
|[<c029599c>] (rt_spin_lock_slowlock+0x108/0x2bc) from [<c01c2330>] (defer_bh+0x1c/0xb4)
|[<c01c2330>] (defer_bh+0x1c/0xb4) from [<c01c3afc>] (rx_complete+0x14c/0x194)
|[<c01c3afc>] (rx_complete+0x14c/0x194) from [<c01cac88>] (usb_hcd_giveback_urb+0xa0/0xf0)
|[<c01cac88>] (usb_hcd_giveback_urb+0xa0/0xf0) from [<c01e1ff4>] (musb_giveback+0x34/0x40)
|[<c01e1ff4>] (musb_giveback+0x34/0x40) from [<c01e2b1c>] (musb_advance_schedule+0xb4/0x1c0)
|[<c01e2b1c>] (musb_advance_schedule+0xb4/0x1c0) from [<c01e2ca8>] (musb_cleanup_urb.isra.9+0x80/0x8c)
|[<c01e2ca8>] (musb_cleanup_urb.isra.9+0x80/0x8c) from [<c01e2ed0>] (musb_urb_dequeue+0xec/0x108)
|[<c01e2ed0>] (musb_urb_dequeue+0xec/0x108) from [<c01cbb90>] (unlink1+0xbc/0xcc)
|[<c01cbb90>] (unlink1+0xbc/0xcc) from [<c01cc2ec>] (usb_hcd_unlink_urb+0x54/0xa8)
|[<c01cc2ec>] (usb_hcd_unlink_urb+0x54/0xa8) from [<c01c2a84>] (unlink_urbs.isra.17+0x2c/0x58)
|[<c01c2a84>] (unlink_urbs.isra.17+0x2c/0x58) from [<c01c2b44>] (usbnet_terminate_urbs+0x94/0x10c)
|[<c01c2b44>] (usbnet_terminate_urbs+0x94/0x10c) from [<c01c2d68>] (usbnet_stop+0x100/0x15c)
|[<c01c2d68>] (usbnet_stop+0x100/0x15c) from [<c020f718>] (__dev_close_many+0x94/0xc8)
defer_bh() takes the lock which is hold during unlink_urbs(). The safe
walk suggest that the skb will be removed from the list and this is done
by defer_bh() so it seems to be okay to drop the lock here.
Reported-by: AnÃbal Almeida Pinto <anibal.pinto@efacec.com>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Acked-by: Oliver Neukum <oliver@neukum.org>
(cherry picked from commit 4231d47e6fe69f061f96c98c30eaf9fb4c14b96d)
net/usbnet: reserve headroom on rx skbs
network drivers should reserve some headroom on incoming skbs so that we
dont need expensive reallocations, eg forwarding packets in tunnels.
This NET_SKB_PAD padding is done in various helpers, like
__netdev_alloc_skb_ip_align() in this patch, combining NET_SKB_PAD and
NET_IP_ALIGN magic.
Acked-by: Oliver Neukum <oneukum@suse.de>
(cherry picked from commit 7bdd402706cf26bfef9050dfee3f229b7f33ee4f)
usbnet: use netif_tx_wake_queue instead of netif_start_queue
If host is going to autosuspend function with two interfaces and
if IP packet has arrived in-between of two usbnet_suspend() callbacks,
i.e usbnet_resume() is called in-between, tx data flow is stopped.
When autosuspend timer expires and device is put to autosuspend
again, tx queue is waked up and data can be sent again.
This behavior might be repeated several times in a row.
Tested on Intel/ARM.
Reviewed-by: Sjur Brændeland <sjur.brandeland@stericsson.com>
Tested-by: Dmitry Tarnyagin <dmitry.tarnyagin@stericsson.com>
Signed-off-by: Alexey Orishko <alexey.orishko@stericsson.com>
(cherry picked from commit 1aa9bc5b2f4cf8c48944fb9a607bf1dd674e2c10)
usbnet: increase URB reference count before usb_unlink_urb
problem by releasing the skb queue lock, but it makes usb_unlink_urb
racing with defer_bh, and the URB to being unlinked may be freed before
or during calling usb_unlink_urb, so use-after-free problem may be
triggerd inside usb_unlink_urb.
The patch fixes the use-after-free problem by increasing URB
reference count with skb queue lock held before calling
usb_unlink_urb, so the URB won't be freed until return from
usb_unlink_urb.
Reported-by: Dave Jones <davej@redhat.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
(cherry picked from commit 0956a8c20b23d429e79ff86d4325583fc06f9eb4)
usbnet: don't clear urb->dev in tx_complete
URB unlinking is always racing with its completion and tx_complete
may be called before or during running usb_unlink_urb, so tx_complete
must not clear urb->dev since it will be used in unlink path,
otherwise invalid memory accesses or usb device leak may be caused
(cherry picked from commit 5d5440a835710d09f0ef18da5000541ec98b537a)
usbnet: consider device busy at each recieved packet
usbnet should centrally handle busy reporting in the rx path
so subdrivers need not worry. This hurts use cases which do
rx only or predominantly.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
(cherry picked from commit 8a78335442cea429afb2b964318b6e257448ea00)
usbnet: fix leak of transfer buffer of dev->interrupt
The transfer buffer of dev->interrupt is allocated in .probe path,
but not freed in .disconnet path, so mark the interrupt URB as
URB_FREE_BUFFER to free the buffer when the URB is destroyed.
(cherry picked from commit 267a83e8e00dc5a878b24c39883643c20a8b1482)
Bug 1036768
Change-Id: I5d6620c8ff4e6cef52c3f467fb2196658c4d47b1
Reviewed-on: http://git-master/r/125338
Bug 1023045
Change-Id: Id6e43c852a90cbd5445daf38279ed690712c3332
Signed-off-by: Narayan Reddy <narayanr@nvidia.com>
Reviewed-on: http://git-master/r/117637
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
-enable warnings as errors compilation flag
bug 949219
Change-Id: Ifeaba174d59c437e0068324b73dffd287f90c957
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Reviewed-on: http://git-master/r/118041
Reviewed-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-by: Sheshagiri Shenoy <sshenoy@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Reviewed-by: Sri Krishna Chowdary <schowdary@nvidia.com>
Modified device info element for ZM5250 to
sync with framework.
Change-Id: I855678edccef50c549960ee209e500ec6d692e36
Signed-off-by: BH Hsieh <bhsieh@nvidia.com>
Power off the card when wifi is off and power up only when wifi
is turned on
Bug 1011349
Change-Id: I26a8188d932516c0490dec858acd9e8ea2c5adf8
Signed-off-by: Om Prakash Singh <omp@nvidia.com>
Reviewed-on: http://git-master/r/118097
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Disable failing auto detach stuff for now as it caused the following issue upon cable disconnect:
[ 49.504039] eth0: EEPROM (0x18) = : 0800
[ 49.624580] eth0: EVENT: AX_CHK_AUTODETACH
We noticed stability issues trying to mount a root file system over NFS.
Looks like an updated driver from Asix works much better.
BTW: The mainline driver also has issues doing the same:
[ 174.422441] asix 1-1:1.0: eth0: asix_rx_fixup() Bad Header Length
[ 174.430045] asix 1-1:1.0: eth0: asix_rx_fixup() Bad RX Length 1645
Further investigation pending (e.g. backporting post 3.5 mainline driver).
Upon receiving IPv6 packet, set ethernet header's ether type
to 0x86dd. For transmission of IPv6, nothing extra required,
as the 14 byte ethernet header (containing the 0x86dd ether
type) is already stripped off as part of the raw-ip protocol.
Bug 1010735
Change-Id: Id574a7feeefbde0504ad0ea449dff28340e9356a
Signed-off-by: Michael Hsu <mhsu@nvidia.com>
Reviewed-on: http://git-master/r/113761
(cherry picked from commit 8bdfd06cae7eede4856ef825ea26b69c9ea065ef)
Reviewed-on: http://git-master/r/117148
Reviewed-by: Vinayak Pane <vpane@nvidia.com>
Tested-by: Vinayak Pane <vpane@nvidia.com>
Reviewed-by: Steve Lin <stlin@nvidia.com>
This module has -Werror turned on, so this was causing the build to
break on GCC 4.6:
drivers/net/wireless/bcm4329/wl_iw.c: In function 'wl_iw_set_pmksa':
drivers/net/wireless/bcm4329/wl_iw.c:5149:5: error: array subscript is above array bounds [-Werror=array-bounds]
drivers/net/wireless/bcm4329/wl_iw.c:5152:5: error: array subscript is above array bounds [-Werror=array-bounds]
It's a partial 'backport' of a change made to the bcmdhd driver:
commit 09a8dc7361d0e603d9935ec7f736fabaa2e6dc7a
net: wireless: bcmdhd: Combined P2P fix
Change-Id: Ie62ad82f884c213553772ac91eaf85e17a807503
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/88694
In suspend mode WLC_E_TXFAIL event is causing autowake
when the device is connected to an AP, so discarding the
WLC_E_TXFAIL event initialization as per BRCM team suggestion.
Bug 1014610
Change-Id: I297dab7ee589f458bba3e26be090665a36c78502
Reviewed-on: http://git-master/r/115633
Reviewed-by: Rakesh Goyal <rgoyal@nvidia.com>
New requirement to support upto 5 rmnet interfaces with
raw-ip. Driver will be able to support dynamically multiple
number of interfaces, maximum to 5.
Bug 1006183
Signed-off-by: Vinayak Pane <vpane@nvidia.com>
Reviewed-on: http://git-master/r/112790
(cherry picked from commit 0dde53830d9e21004b2e90c1b997a54c89767fa1)
Change-Id: I8166c448dbfef0391491ffdef9dff2b0e2693d75
Reviewed-on: http://git-master/r/115611
WFD specific changes integrated from broadcom patch
Bug 1001418
Bug 997838
Change-Id: I0632307bf5fb959def4ee12687430a14ab9e068e
Reviewed-on: http://git-master/r/111032
Tested-by: Rakesh Goyal <rgoyal@nvidia.com>
Do not register bcmdhd driver for all sdio devices.
Bug 1006828
Change-Id: I49e2d2bc7fbda4414392d8a28a0feefb1c8031ec
Reviewed-on: http://git-master/r/113045
Reviewed-by: Simone Willett <swillett@nvidia.com>
Reviewed-on: http://mcrd1-5.corpnet.asus/code-review/master/47846
Tested-by: Kirt Hsieh <Kirt_Hsieh@asus.com>
Reviewed-by: Kirt Hsieh <Kirt_Hsieh@asus.com>
Reviewed-by: Vincent Yue <Vincent_Yue@asus.com>
Bug 984811
Signed-off-by: Roger Hsieh <rhsieh@nvidia.com>
Change-Id: I708dadddf3f3eac9f8bacc72e3aef94247a87e70
Reviewed-on: http://git-master/r/106352
Reviewed-by: Sang-Hun Lee <sanlee@nvidia.com>
Tested-by: Sang-Hun Lee <sanlee@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Modified device info element for PH450 and Tango to
Change-Id: I325571358f8c1875484254a9f497c606adb03180
Signed-off-by: Mohan T <mohant@nvidia.com>
Reviewed-on: http://git-master/r/110765
Reviewed-by: Matthieu Vincenot <mvincenot@nvidia.com>
Update wiphy (wireless hardware description) to
support 5 GHz scan.
Bug 1000888
Change-Id: I1a7a99f97f69dd8f1790f81ee0fb21e209e8d10e
Signed-off-by: Nitin Bindal <nbindal@nvidia.com>
Reviewed-on: http://git-master/r/109556
Bug 999876
Change-Id: I83a139e6c0dd42cf095fa2ac1376732075a15434
Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
