For RAW-IP network driver, use async version of autopm calls
since it might be called in interrupt context.
Change-Id: Ie8ab3fd1ab1268d01d3e9333d2b27a1b3ccf0686
Signed-off-by: Michael Hsu <mhsu@nvidia.com>
Reviewed-on: http://git-master/r/69890
Reviewed-by: Seshendra Gadagottu <sgadagottu@nvidia.com>
Add a couple -Wno-error options when building with the new toolchain;
it's stricter. These can be removed once the code is fixed not to
cause warnings (see bug 888158).
Bug 830289
Signed-off-by: Matt Pedro <mapedro@nvidia.com>
(cherry picked from commit 4a2bbb6dc6ab70a8e562d8db4d6016c28c290ce0)
Change-Id: I9944bf4a5fac005fed5ff5d92c38c5be32ea6f55
Reviewed-on: http://git-master/r/68740
Tested-by: Matthew Pedro <mapedro@nvidia.com>
Reviewed-by: Allen Martin <amartin@nvidia.com>
arch/arm/Kconfig
Change-Id: If8aaaf3efcbbf6c9017b38efb6d76ef933f147fa
commit 274b89ca3b006926cb9b45d78ab5906f4c0fc0aa upstream.
Group keys in IBSS or AP mode are not programmed
into the device since we give the key to it with
every TX packet. However, we do need mac80211 to
create the MMIC & PN in all cases. Move the code
around to set the key flags all the time. We set
them even when the key is removed again but that
is obviously harmless.
Reported-by: Reinette Chatre <reinette.chatre@intel.com>
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
commit 34a5b4b6af104cf18eb50748509528b9bdbc4036 upstream.
The ht40 setting should not change after association unless channel switch
This fix a problem we are seeing which cause uCode assert because driver
sending invalid information and make uCode confuse
Here is the firmware assert message:
kernel: iwlagn 0000:03:00.0: Microcode SW error detected. Restarting 0x82000000.
kernel: iwlagn 0000:03:00.0: Loaded firmware version: 17.168.5.3 build 42301
kernel: iwlagn 0000:03:00.0: Start IWL Error Log Dump:
kernel: iwlagn 0000:03:00.0: Status: 0x000512E4, count: 6
kernel: iwlagn 0000:03:00.0: 0x00002078 | ADVANCED_SYSASSERT
kernel: iwlagn 0000:03:00.0: 0x00009514 | uPc
kernel: iwlagn 0000:03:00.0: 0x00009496 | branchlink1
kernel: iwlagn 0000:03:00.0: 0x00009496 | branchlink2
kernel: iwlagn 0000:03:00.0: 0x0000D1F2 | interruptlink1
kernel: iwlagn 0000:03:00.0: 0x00000000 | interruptlink2
kernel: iwlagn 0000:03:00.0: 0x01008035 | data1
kernel: iwlagn 0000:03:00.0: 0x0000C90F | data2
kernel: iwlagn 0000:03:00.0: 0x000005A7 | line
kernel: iwlagn 0000:03:00.0: 0x5080B520 | beacon time
kernel: iwlagn 0000:03:00.0: 0xCC515AE0 | tsf low
kernel: iwlagn 0000:03:00.0: 0x00000003 | tsf hi
kernel: iwlagn 0000:03:00.0: 0x00000000 | time gp1
kernel: iwlagn 0000:03:00.0: 0x29703BF0 | time gp2
kernel: iwlagn 0000:03:00.0: 0x00000000 | time gp3
kernel: iwlagn 0000:03:00.0: 0x000111A8 | uCode version
kernel: iwlagn 0000:03:00.0: 0x000000B0 | hw version
kernel: iwlagn 0000:03:00.0: 0x00480303 | board version
kernel: iwlagn 0000:03:00.0: 0x09E8004E | hcmd
kernel: iwlagn 0000:03:00.0: CSR values:
kernel: iwlagn 0000:03:00.0: (2nd byte of CSR_INT_COALESCING is CSR_INT_PERIODIC_REG)
kernel: iwlagn 0000:03:00.0: CSR_HW_IF_CONFIG_REG: 0X00480303
kernel: iwlagn 0000:03:00.0: CSR_INT_COALESCING: 0X0000ff40
kernel: iwlagn 0000:03:00.0: CSR_INT: 0X00000000
kernel: iwlagn 0000:03:00.0: CSR_INT_MASK: 0X00000000
kernel: iwlagn 0000:03:00.0: CSR_FH_INT_STATUS: 0X00000000
kernel: iwlagn 0000:03:00.0: CSR_GPIO_IN: 0X00000030
kernel: iwlagn 0000:03:00.0: CSR_RESET: 0X00000000
kernel: iwlagn 0000:03:00.0: CSR_GP_CNTRL: 0X080403c5
kernel: iwlagn 0000:03:00.0: CSR_HW_REV: 0X000000b0
kernel: iwlagn 0000:03:00.0: CSR_EEPROM_REG: 0X07d60ffd
kernel: iwlagn 0000:03:00.0: CSR_EEPROM_GP: 0X90000001
kernel: iwlagn 0000:03:00.0: CSR_OTP_GP_REG: 0X00030001
kernel: iwlagn 0000:03:00.0: CSR_GIO_REG: 0X00080044
kernel: iwlagn 0000:03:00.0: CSR_GP_UCODE_REG: 0X000093bb
kernel: iwlagn 0000:03:00.0: CSR_GP_DRIVER_REG: 0X00000000
kernel: iwlagn 0000:03:00.0: CSR_UCODE_DRV_GP1: 0X00000000
kernel: iwlagn 0000:03:00.0: CSR_UCODE_DRV_GP2: 0X00000000
kernel: iwlagn 0000:03:00.0: CSR_LED_REG: 0X00000078
kernel: iwlagn 0000:03:00.0: CSR_DRAM_INT_TBL_REG: 0X88214dd2
kernel: iwlagn 0000:03:00.0: CSR_GIO_CHICKEN_BITS: 0X27800200
kernel: iwlagn 0000:03:00.0: CSR_ANA_PLL_CFG: 0X00000000
kernel: iwlagn 0000:03:00.0: CSR_HW_REV_WA_REG: 0X0001001a
kernel: iwlagn 0000:03:00.0: CSR_DBG_HPET_MEM_REG: 0Xffff0010
kernel: iwlagn 0000:03:00.0: FH register values:
kernel: iwlagn 0000:03:00.0: FH_RSCSR_CHNL0_STTS_WPTR_REG: 0X21316d00
kernel: iwlagn 0000:03:00.0: FH_RSCSR_CHNL0_RBDCB_BASE_REG: 0X021479c0
kernel: iwlagn 0000:03:00.0: FH_RSCSR_CHNL0_WPTR: 0X00000060
kernel: iwlagn 0000:03:00.0: FH_MEM_RCSR_CHNL0_CONFIG_REG: 0X80819104
kernel: iwlagn 0000:03:00.0: FH_MEM_RSSR_SHARED_CTRL_REG: 0X000000fc
kernel: iwlagn 0000:03:00.0: FH_MEM_RSSR_RX_STATUS_REG: 0X07030000
kernel: iwlagn 0000:03:00.0: FH_MEM_RSSR_RX_ENABLE_ERR_IRQ2DRV: 0X00000000
kernel: iwlagn 0000:03:00.0: FH_TSSR_TX_STATUS_REG: 0X07ff0001
kernel: iwlagn 0000:03:00.0: FH_TSSR_TX_ERROR_REG: 0X00000000
kernel: iwlagn 0000:03:00.0: Start IWL Event Log Dump: display last 20 entries
kernel: ------------[ cut here ]------------
WARNING: at net/mac80211/util.c:1208 ieee80211_reconfig+0x1f1/0x407()
kernel: Hardware name: 4290W4H
kernel: Pid: 1896, comm: kworker/0:0 Not tainted 3.1.0 #2
kernel: Call Trace:
kernel: [<ffffffff81036558>] ? warn_slowpath_common+0x73/0x87
kernel: [<ffffffff813b8966>] ? ieee80211_reconfig+0x1f1/0x407
kernel: [<ffffffff8139e8dc>] ? ieee80211_recalc_smps_work+0x32/0x32
kernel: [<ffffffff8139e95a>] ? ieee80211_restart_work+0x7e/0x87
kernel: [<ffffffff810472fa>] ? process_one_work+0x1c8/0x2e3
kernel: [<ffffffff810480c9>] ? worker_thread+0x17a/0x23a
kernel: [<ffffffff81047f4f>] ? manage_workers.clone.18+0x15b/0x15b
kernel: [<ffffffff8104ba97>] ? kthread+0x7a/0x82
kernel: [<ffffffff813d21b4>] ? kernel_thread_helper+0x4/0x10
kernel: [<ffffffff8104ba1d>] ? kthread_flush_work_fn+0x11/0x11
kernel: [<ffffffff813d21b0>] ? gs_change+0xb/0xb
Reported-by: Udo Steinberg <udo@hypervisor.org>
commit 8a39ef8ba0fa0410d71db8e981e887fe4fdeca88 upstream.
Continue the init process even fail to enable msi
out_iounmap is no longer used, remove it
Reported-by: werner <w.landgraf@ru.ru>
Tested-by: werner <w.landgraf@ru.ru>
commit 68fa64ef606bcee688fce46d07aa68f175070156 upstream.
Fix __le32 to __le16 conversion of the first word of an 8-word block
of EEPROM read via the efuse method.
Reported-and-tested-by: Ingvar Hagelund <ingvar@redpill-linpro.com>
Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com>
Acked-by: Helmut Schaa <helmut.schaa@googlemail.com>
Acked-by: Ivo van Doorn <IvDoorn@gmail.com>
commit 2d1618170eb493d18f66f2ac03775409a6fb97c6 upstream.
priv->work must not be synced while priv->mutex is locked, because
the mutex is taken in the work handler.
Move cancel_work_sync down to after the device shutdown code.
This is safe, because the work handler checks fw_state and bails out
early in case of a race.
Signed-off-by: Michael Buesch <m@bues.ch>
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
commit 32d3a3922d617a5a685a5e2d24b20d0e88f192a9 upstream.
The tx_lock is not initialized properly. Add spin_lock_init().
commit e55b32c110b025ce07b40227f620e99700bf8741 upstream.
rtl_lps_leave can be called from interrupt context, so we have to
disable interrupts when taking lps_lock.
Below is full lockdep info about deadlock:
[ 93.815269] =================================
[ 93.815390] [ INFO: inconsistent lock state ]
[ 93.815472] 2.6.41.1-3.offch.fc15.x86_64.debug #1
[ 93.815556] ---------------------------------
[ 93.815635] inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage.
[ 93.815743] swapper/0 [HC0[0]:SC1[1]:HE1:SE0] takes:
[ 93.815832] (&(&rtlpriv->locks.lps_lock)->rlock){+.?...}, at: [<ffffffffa025dad6>] rtl_lps_leave+0x26/0x103 [rtlwifi]
[ 93.815947] {SOFTIRQ-ON-W} state was registered at:
[ 93.815947] [<ffffffff8108e10d>] __lock_acquire+0x369/0xd0c
[ 93.815947] [<ffffffff8108efb3>] lock_acquire+0xf3/0x13e
[ 93.815947] [<ffffffff814e981d>] _raw_spin_lock+0x45/0x79
[ 93.815947] [<ffffffffa025de34>] rtl_swlps_rf_awake+0x5a/0x76 [rtlwifi]
[ 93.815947] [<ffffffffa025aec0>] rtl_op_config+0x12a/0x32a [rtlwifi]
[ 93.815947] [<ffffffffa01d614b>] ieee80211_hw_config+0x124/0x129 [mac80211]
[ 93.815947] [<ffffffffa01e0af3>] ieee80211_dynamic_ps_disable_work+0x32/0x47 [mac80211]
[ 93.815947] [<ffffffff81075aa5>] process_one_work+0x205/0x3e7
[ 93.815947] [<ffffffff81076753>] worker_thread+0xda/0x15d
[ 93.815947] [<ffffffff8107a119>] kthread+0xa8/0xb0
[ 93.815947] [<ffffffff814f3184>] kernel_thread_helper+0x4/0x10
[ 93.815947] irq event stamp: 547822
[ 93.815947] hardirqs last enabled at (547822): [<ffffffff814ea1a7>] _raw_spin_unlock_irqrestore+0x45/0x61
[ 93.815947] hardirqs last disabled at (547821): [<ffffffff814e9987>] _raw_spin_lock_irqsave+0x22/0x8e
[ 93.815947] softirqs last enabled at (547790): [<ffffffff810623ed>] _local_bh_enable+0x13/0x15
[ 93.815947] softirqs last disabled at (547791): [<ffffffff814f327c>] call_softirq+0x1c/0x30
[ 93.815947]
[ 93.815947] other info that might help us debug this:
[ 93.815947] Possible unsafe locking scenario:
[ 93.815947]
[ 93.815947] CPU0
[ 93.815947] ----
[ 93.815947] lock(&(&rtlpriv->locks.lps_lock)->rlock);
[ 93.815947] <Interrupt>
[ 93.815947]
[ 93.815947] *** DEADLOCK ***
[ 93.815947]
[ 93.815947] no locks held by swapper/0.
[ 93.815947]
[ 93.815947] stack backtrace:
[ 93.815947] Pid: 0, comm: swapper Not tainted 2.6.41.1-3.offch.fc15.x86_64.debug #1
[ 93.815947] Call Trace:
[ 93.815947] <IRQ> [<ffffffff814dfd00>] print_usage_bug+0x1e7/0x1f8
[ 93.815947] [<ffffffff8101a849>] ? save_stack_trace+0x2c/0x49
[ 93.815947] [<ffffffff8108d55c>] ? print_irq_inversion_bug.part.18+0x1a0/0x1a0
[ 93.815947] [<ffffffff8108dc8a>] mark_lock+0x106/0x220
[ 93.815947] [<ffffffff8108e099>] __lock_acquire+0x2f5/0xd0c
[ 93.815947] [<ffffffff810152af>] ? native_sched_clock+0x34/0x36
[ 93.830125] [<ffffffff810152ba>] ? sched_clock+0x9/0xd
[ 93.830125] [<ffffffff81080181>] ? sched_clock_local+0x12/0x75
[ 93.830125] [<ffffffffa025dad6>] ? rtl_lps_leave+0x26/0x103 [rtlwifi]
[ 93.830125] [<ffffffff8108efb3>] lock_acquire+0xf3/0x13e
[ 93.830125] [<ffffffff814e981d>] _raw_spin_lock+0x45/0x79
[ 93.830125] [<ffffffff81422467>] ? skb_dequeue+0x62/0x6d
[ 93.830125] [<ffffffffa025dad6>] rtl_lps_leave+0x26/0x103 [rtlwifi]
[ 93.830125] [<ffffffffa025f677>] _rtl_pci_ips_leave_tasklet+0xe/0x10 [rtlwifi]
[ 93.830125] [<ffffffff8106281f>] tasklet_action+0x8d/0xee
[ 93.830125] [<ffffffff810629ce>] __do_softirq+0x112/0x25a
[ 93.830125] [<ffffffff814f327c>] call_softirq+0x1c/0x30
[ 93.830125] [<ffffffff81010bf6>] do_softirq+0x4b/0xa1
[ 93.830125] [<ffffffff81062d7d>] irq_exit+0x5d/0xcf
[ 93.830125] [<ffffffff814f3b7e>] do_IRQ+0x8e/0xa5
[ 93.830125] [<ffffffff814ea533>] common_interrupt+0x73/0x73
[ 93.830125] <EOI> [<ffffffff8108b825>] ? trace_hardirqs_off+0xd/0xf
[ 93.830125] [<ffffffff812bb6d5>] ? intel_idle+0xe5/0x10c
[ 93.830125] [<ffffffff812bb6d1>] ? intel_idle+0xe1/0x10c
[ 93.830125] [<ffffffff813f8d5e>] cpuidle_idle_call+0x11c/0x1fe
[ 93.830125] [<ffffffff8100e2ef>] cpu_idle+0xab/0x101
[ 93.830125] [<ffffffff814c6373>] rest_init+0xd7/0xde
[ 93.830125] [<ffffffff814c629c>] ? csum_partial_copy_generic+0x16c/0x16c
[ 93.830125] [<ffffffff81d4bbb0>] start_kernel+0x3dd/0x3ea
[ 93.830125] [<ffffffff81d4b2c4>] x86_64_start_reservations+0xaf/0xb3
[ 93.830125] [<ffffffff81d4b140>] ? early_idt_handlers+0x140/0x140
[ 93.830125] [<ffffffff81d4b3ca>] x86_64_start_kernel+0x102/0x111
Resolves:
https://bugzilla.redhat.com/show_bug.cgi?id=755154
Reported-by: vjain02@students.poly.edu
Reported-and-tested-by: Oliver Paukstadt <pstadt@sourcentral.org>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
GET_CUSTOM_MAC_ENABLE is not required since we are reading
the MAC address from the broadcom chip.
Change-Id: I813ddb30a6a7c94b2d4eb050c7968b7261169ec9
Reviewed-on: http://git-master/r/66469
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
Tested-by: Rakesh Kumar <krakesh@nvidia.com>
Rebase-Id: R668c1a91afcd24cc1f3a17f64106d67d9e02f784
In order to support bcm4329 and bcm4330 in single binary, driver has
to construct firmware path names dynamically.
Change-Id: I7bdb0fd51f21494b4cb61c65fe9ba23e0eb5604f
Reviewed-on: http://git-master/r/60884
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: R4b22880696a239bd16f570156bb013b00d6a2d67
bcm4329 and bcm4330 need different firmware files. This change
detects chipid and loads firmware located at
CONFIG_BCMDHD_FW_DIR/firmware_bcm<chipid>.bin
Bug 820860
(cherry picked from commit 850c98cc99c0bd8feee523a6c62501de9be3c770)
Change-Id: I043ffeda3ae8fe6f5c0c133bacc4aba7a080b983
Reviewed-on: http://git-master/r/60221
Rebase-Id: R59196ff5cb76aedcfaae1e84277a2ae27ce92314
While using inband interrupt and SDIO_ISR_THREAD defined,
wifi irq handler run in context of ksdioirqd.
While turning off wifi, bcmdhd driver releases irq in a different thread.
If there is a pending wifi interrupt(not served) it never get cleared as driver
has removed the irq handler.
Bug 857429
Change-Id: Ib9b041f49d18e973824a5a5b9ce4a6d771b231ca
Reviewed-on: http://git-master/r/60220
Rebase-Id: R6416b3a56b1987bb1fc5686ebdd29deb6fc99e6c
during system suspend if wifi is on but not connected, android
sets RTC alarm to wake up system after 2 mins of system suspend
to turn off wifi. during turning off wifi it was observed that
BCM4329 MAC is giving spurious sdio interrupts which was causing
lockup issue (mmc_lock) between sdio interrupt handling process
and wifi stop process, to fix this issue sdio interrupts are
disabled before giving MAC reset from host.
Bug 834444
Bug 798783
Bug 796147
Bug 797230
Bug 780047
Bug 818687
(cherry picked from commit 113676ec197fc62b7dce23dad4e081c940319846)
Original-Change-Id: I810894ded26bcfb44cff52aba16f2a5dbcba8f28
Reviewed-on: http://git-master/r/47478
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Rebase-Id: R89453877feceb4702ae89d0bfab90dfda1e4bbd1
makeing dhd_doflow true and changing queue size to resolve
udp iperf uplink error/warning messages mentioned below
write2 failed: Connection refused
read failed: Connection refused
[ 3] WARNING: did not receive ack of last datagram after 1 tries.
BUG 789046
Original-Change-Id: Iadea7e74bece039b4656c495c11e551f625fd4e0
Reviewed-on: http://git-master/r/21462
Reviewed-by: Rakesh Goyal <rgoyal@nvidia.com>
Tested-by: Rakesh Goyal <rgoyal@nvidia.com>
Original-Change-Id: I87ac5570785a7613eb655410ac22aaa1c5b94b5d
Rebase-Id: R0433497e222034bbdedca2cef3c54422f6424b5a
warning is treated as error do checking the condition
and increasing DHD_REGISTRATION_TIMEOUT
Original-Change-Id: I369eda5d629c887bee3f79f9edc8a64bf6df5aa5
Reviewed-on: http://git-master/r/16990
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Original-Change-Id: I835479bf59524735d059b5450bc380766b933e56
Rebase-Id: R1800ef9e7dcbfe689a14d0a5d9bf9a01a5330807
In case of inband interrupts i.e SDIO CARD INT, two
level of thread switching takes place to process wifi
interrupts one in SDHCI and the other in Wifi driver if
"SDIO_ISR_THREAD" flag is disabled.
Enabling "SDIO_ISR_THREAD" flag will prevent deferred
MAC interrupts processing because it is preventing thread
context switching in wifi driver.
Bug 789444
Bug 787054
Bug 795460
Original-Change-Id: I4b00b5a1a3127380699c958d802e5d823078896e
Reviewed-on: http://git-master/r/24273
Rebase-Id: Rf7c499bdc13df3b0e651b726fff4b71c49c40c75
Initiate broadcast scan (active scan) just after
initializing with network interface.
BUG 781501
Original-Change-Id: I6c9bc7b458fff604c12ea3c94c4d4a5255b3bb91
Reviewed-on: http://git-master/r/23216
Reviewed-by: Rahul Bansal <rbansal@nvidia.com>
Tested-by: Rahul Bansal <rbansal@nvidia.com>
Rebase-Id: R3593349369720bf76c758e4b77ec0d41726cfad6
During suspend/resume wifi chip's power mode is changed and this
impacts chip's internal registers reading/writing. Delaying reads/
writes to wifi chip from HZ/100 to 3*HZ which gives time for chip
to settle its state.
BUG 798783
Original-Change-Id: Ie9c06c2d03fb38b6fba5acca48490d12c358e496
Reviewed-on: http://git-master/r/22150
Rebase-Id: R67e6b0385695a1044c7673190136e41dbec4a9be
Making sure that Rx pkt is acknowledged and sent
to network interface by wifi driver before system
goes in suspend.
BUG ID 767438
Original-Change-Id: Ie88176ec11aa1d2fe4253d9b0472d13a4742d300
Reviewed-on: http://git-master/r/12703
Rebase-Id: Ra548a45038befb153207f78f373cf433fe89dccb
enable wireless extension and bcm4329 kernel driver
Bug 724105
Original-Change-Id: I7d5ac551bd1e3bc2c440b0cd9ef4b09fbd7c34d5
Reviewed-on: http://git-master/r/9884
Rebase-Id: R394b04a7c824aff5fb92500afe3217ffc5f46ff7
arch/arm/mach-tegra/Kconfig
arch/arm/mach-tegra/board-ventana.c
drivers/misc/Kconfig
drivers/video/tegra/dc/hdmi.c
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Cannot have source file execute permission set, due to
upstreamability rules.
Reviewed-on: http://git-master/r/63893
(cherry picked from commit 4a5bc78eb59fa4ca289883c716f87054b231d66d)
Change-Id: Ide67423f2acc477d9322ac06fd60b81d6a146589
Reviewed-on: http://git-master/r/66527
Rebase-Id: Ree193fb0e103e8104625148be76bed93d4e50046
Autoresume usb interface before tx and autosuspend after tx
completes. Also mark last busy time to prevent autosuspend
until some idle time has occurred.
Reviewed-on: http://git-master/r/63993
(cherry picked from commit cfbe77e471d96feda7efd3d8e3f35114a7a32bf7)
Change-Id: I4f419ea29aad6a06b786e6ffb8b17b2016c6e21d
Reviewed-on: http://git-master/r/66528
Reviewed-by: Michael Hsu <mhsu@nvidia.com>
Tested-by: Michael Hsu <mhsu@nvidia.com>
Rebase-Id: R76d1761a632abc1d05563016f046d60c7b68853a
Use module variable to allow dynamic configuration of number
of RAW-IP network interfaces.
BUG 853232
Reviewed-on: http://git-master/r/59447
(cherry picked from commit 0fbbd5191c3f1bcd873a2f13edeb63050dab33c1)
Change-Id: Ic53ba7a4f937b0d0def24129965be38cadcf774a
Reviewed-on: http://git-master/r/62736
Rebase-Id: R5f366227cd990e0101a37b85097afa87a9619b06
Cancel pending rx urbs during suspend, and resubmit
rx urbs after resume.
BUG 853232
Reviewed-on: http://git-master/r/52855
(cherry picked from commit 6af7fd6d2d43455f2ca54dcacd2f46197410c578)
Change-Id: I33d4cb5180e2e9590a8f58103c83e0d5d5f182fc
Reviewed-on: http://git-master/r/62735
Rebase-Id: R1ad5e21ee2513aa977d96d7e3ae89d80c69fbb28
Reviewed-on: http://git-master/r/54978
Change-Id: I53354ce4aca988afc619d3efa60c0b13381b3997
Reviewed-on: http://git-master/r/62052
Tested-by: Manoj Chourasia <mchourasia@nvidia.com>
Rebase-Id: R08103b51a1c99f565bff42b615268277e4bf06ae
The parameter of NET_IP_ETHERTYPE needs to be configured correctly
for ethernet header and then can transfer data properly.
BUG 870395
Reviewed-on: http://git-master/r/51986
(cherry picked from commit 89bf27954e890e11a11ce45b12fcfce68ad0a45c)
Change-Id: I95c81b73072fe0c64b7cc7fcee0a2a6857969500
Reviewed-on: http://git-master/r/59103
Rebase-Id: R512dbe7fc37c82dc158ca933ea78fd04b3366821
bug 860095
Original-Change-Id: I889a990a2079b5e668c5668ac0a8af6aa0afd95a
Reviewed-on: http://git-master/r/45552
Rebase-Id: R6ab06a2d2a8474fa4efef7e666508ba1d06d3fe6
Added PM calls for raw usbnet ipc drivers.
This is basic version and needs to be extented
for complete power management.
BUG 828389
Original-Change-Id: I77fbf3bf6badfb624f805f68b73fdb5ba617e30c
Reviewed-on: http://git-master/r/40790
Tested-by: Seshendra Gadagottu <sgadagottu@nvidia.com>
Rebase-Id: Rc0f0ac64afd3c36d2178ed011e345bf36958229c
Change RAW-IP network driver to support multiple instances.
Bug 818895, 847608
Original-Change-Id: I30d79a4af38611693c0cc4e045f6ec50a6baff7d
(cherry picked from commit 32bacea781788f43fdf16d1f9edc782e9d599c41)
Reviewed-on: http://git-master/r/39313
Tested-by: Wang-Kai (WK) Tsai <wtsai@nvidia.com>
Reviewed-by: Wang-Kai (WK) Tsai <wtsai@nvidia.com>
Reviewed-by: ChihMin Cheng <ccheng@nvidia.com>
Reviewed-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Rebase-Id: Rea54001cfbb6d0fe53c2e91695db9f023b9e2828
Adding enterprise A01 modem to the cdc ether device list.
Bug 800301
Change-Id: Iafe75c813f0c58c9703a627fbc8b17413ac1a7ed
Reviewed-on: http://git-master/r/32259
Tested-by: Szming Lin <stlin@nvidia.com>
Reviewed-by: Udaykumar Rameshchan Raval <uraval@nvidia.com>
Rebase-Id: Rbe34e2a52a9bf392ea4cb1aabb59fba3d266ac2d
Add RAW-IP network driver for use with modems such as XMM6260.
Change-Id: Ifc863c50fd918eccec63895c82f10fc32f6b8b6f
Reviewed-on: http://git-master/r/30640
Rebase-Id: Rb0e58bf5c545df94d38b6203b1646209128b5477
Adding PH450 modem to the cdc ether device list. The modem network interface
is assigned as wwan0, which is fully supported by the GB telephony framework.
Bug 800301
Original-Change-Id: I616aa5e39a336a47c5f72baec02be6ff8d958859
Reviewed-on: http://git-master/r/28389
Change-Id: Ice65d33a5d31b0abea4e0b8c73a02a6cca7f662c
Rebase-Id: Ra2842afd9c2a854a0b74034e6e10cccc1230d851
- added the tegra dependent layer of the caif protocol.
- integrated with the open source rainbow caif.
- verified the functionality using latest rainbow RIL.
bug 785523
Change-Id: I75be8d2ef6e5562facf902a3f963f34d241bb6c3
Reviewed-on: http://git-master/r/23421
Rebase-Id: R967aadae8836248af8c861a0d55c5ecc75198960
Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
- Fix WFD interface removal
- Fix profile update
- Keep same mode for softap or WFD during early suspend
- Add dhd_console_ms parameter access
