Change wlan interface from mlan to wlan.
Bug 954218
Change-Id: I5b2b2840a4830eda908a47cc0fc59d0479a1df34
Signed-off-by: Narayan Reddy <narayanr@nvidia.com>
Reviewed-on: http://git-master/r/98997
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
add Konfig to marvel 8797 and some tailing
space corrections.
Bug 954218
Change-Id: I2885f2a74dea14ffeeb5dad65e03e217c77c5013
Reviewed-on: http://git-master/r/98436
Initial commit for Marvell sd8797 Wi-Fi driver
Package Ver: T3T-14.69.11.p111-M2614303_A0B0-MGPL
Bug 954218
Change-Id: I76fcadb5cda054d1e489c4cff77a3c461bdac742
Signed-off-by: Mohan T <mohant@nvidia.com>
Reviewed-on: http://git-master/r/97305
Add system suspend count and avoid urb activity during
system suspend. Use async autopm to avoid deadlock with
system suspend. Do not allocate rx urb's constantly -
allocate once upon init, free rx urb upon exit.
Bug 929408, 952748, 957354
Change-Id: I4ea050fc881528cf44d2039d42891e21c9df8c4e
Signed-off-by: Michael Hsu <mhsu@nvidia.com>
(cherry picked from commit 8bd7322127ccf6727d949f4bc1b2a4eac4b6814e)
Reviewed-on: http://git-master/r/95166
Reviewed-by: Vinayak Pane <vpane@nvidia.com>
bug 949219
Change-Id: I5942ba86bd1cbe1f1bd06a7c9f51a10d83e6cabb
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/92819
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
before point reference check valid.
it prevents null point reference panic.
Bug 954883
Signed-off-by: Shawn Joo(Seongho) <sjoo@nvidia.com>
Reviewed-on: http://git-master/r/88781
(cherry picked from commit aac87c7d9c7cf7563bb79a29d517a6ffdba5874f)
Change-Id: Ica17acb6cc2a1a7ed03f41d8b569fdb6e2098fc9
Reviewed-on: http://git-master/r/96464
Reviewed-by: Simone Willett <swillett@nvidia.com>
Consume skb buffers only in success case. In fatal error
case stop tx transmission instead. This prevents many retries
and possible kernel crash.
Bug 937178
Signed-off-by: Vinayak Pane <vpane@nvidia.com>
Reviewed-on: http://git-master/r/83290
(cherry picked from commit 974ffdc61f26d86744e1a7b1003117da50df9020)
Change-Id: Ib2b982c0cea91d2ba5e30c04869c4f22dca7ed31
Reviewed-on: http://git-master/r/96331
Tested-by: Vinayak Pane <vpane@nvidia.com>
Reviewed-by: Steve Lin <stlin@nvidia.com>
Enable Custom Regulatory Domain(CRD) support, only if
BCMDHD_CUSTOM_REGULATORY_DOMAIN kernel config is set.
By default BCMDHD_CUSTOM_REGULATORY_DOMAIN is enabled.
Bug 947472
Change-Id: I40ea3c3c531d4e309c0928db396b9cc832be43cc
Signed-off-by: Nitin Bindal <nbindal@nvidia.com>
Reviewed-on: http://git-master/r/88266
Reviewed-by: Narayan Reddy <narayanr@nvidia.com>
Bug 924863
Change-Id: I10d3036ce19f8c1f37e57998c204f3a72bd42f85
Signed-off-by: Steve Lin <stlin@nvidia.com>
Reviewed-on: http://git-master/r/89718
Add ID of BCM4330 to supported chips.
Remove ID of BCM4329 as it is not supported.
Bug 956238
Change-Id: I5c9e809245161d76c3decab3e5252ce111a2a07d
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Reviewed-on: http://git-master/r/90657
Tested-by: Gerrit_Virtual_Submit
Reviewed-by: Allen Martin <amartin@nvidia.com>
rename bcmsdh_remove & bcmsdh_probe to *_bcmdhd
to resolve symbol conflicts with bcm4329 driver.
Bug 956238
Change-Id: I750238ddf9b3a0d9ff9583a7ec456aceef28531c
Reviewed-on: http://git-master/r/90656
Add rx, tx, error statistics feature
Bug 932703
Change-Id: Ic7a6232dd3b48feff2b064fcff8f0d146b1e9902
Signed-off-by: Shawn Joo <sjoo@nvidia.com>
Reviewed-on: http://git-master/r/89305
In suspend mode WLC_E_TXFAIL event is causing autowake
when the device is connected to an AP,so discarding the
WLC_E_TXFAIL event initialization as per BRCM team suggestion.
Bug 880970
Bug 941420
Change-Id: I5db727004873a77b8b264e7dde2525e678519c54
Reviewed-on: http://git-master/r/90074
make wext and cfg80211 integration from
bcmdhd choices
Bug 924521
Change-Id: Ie0c46159003985e4e4b29b2809fe881ce924dbee
Reviewed-on: http://git-master/r/88908
MMC_PM_KEEP_POWER should be set before each suspend/resume cycle as
mmc drivers clears MMC_PM_KEEP_POWER from pm_flags on resume.
Bug 942826
Change-Id: Ie11c661bdc3450cc4e75fa7700b96aedc69d628a
Signed-off-by: Rakesh Kumar <krakesh@nvidia.com>
Reviewed-on: http://git-master/r/87703
Reviewed-by: Rakesh Goyal <rgoyal@nvidia.com>
Tested-by: Rakesh Goyal <rgoyal@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
MMC_PM_KEEP_POWER should be set before each suspend/resume cyble as
Bug 942826
Change-Id: Ifc647b500d744a37206a4879f1e3df495bc4123a
Signed-off-by: Rakesh Goyal <rgoyal@nvidia.com>
Reviewed-on: http://git-master/r/87208
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
In the driver code wireless extension features are
controlled through WIRELESS_EXT config option.
However, WIRELESS_EXT is turned on by the BCMDHD_WEXT
option of this driver.
Hence, the instead of using WIRELESS_EXT, BCMDHD_WEXT
is used to control wireless extension features.
Bug 924521
(cherry picked from commit 22a9df35537080fbd8a2045c574c5b3e5d08f1ab)
Change-Id: I68a49271fd3f3616b3beb07f5350d616f3bd9459
Reviewed-on: http://git-master/r/82878
Make delayed firmware loading a Kconfig option.
Config option BCMDHD_INSMOD_NO_FW_LOAD controls
this feature.
Bug 924521
(cherry picked from commit 9a0219b500f677381b3d912c73a9755cb0eb1caa)
Change-Id: I5d48f6c7484bbf8d5d6825f4b3a08d711ff86558
Reviewed-on: http://git-master/r/82877
Move CSCAN driver compilation flag to CONFIG_BCMDHD_CSCAN_ENABLE
Kconfig option; CSCAN is not supported in all userspace environments.
The driver implementation of PNO_SUPPORT has a dependency on CSCAN, so
make that option controlled by CONFIG_BCMDHD_CSCAN_ENABLE.
This CL is inspired from http://git-master/r/#change,76730
Bug 924521
(cherry picked from commit 240664309eaba6ec56297ff7c2704176708189e7)
Change-Id: I3481b48750089800c0aa977f05d7512880d6d74c
Reviewed-on: http://git-master/r/82876
handled missed wake_unlocks in bcmdhd wlan driver
Bug 924611
Reviewed-on: http://git-master/r/84302
(cherry picked from commit d54a9823622acf981b782260a717f0091ea69fd7)
Change-Id: I4faff6d6fbee8ac62e3d19d6b5ef27ee5a20e60b
Reviewed-on: http://git-master/r/85692
Tested-by: Narayan Reddy <narayanr@nvidia.com>
Set the parent field of the netdevice, which causes sysfs
to create a device subdirectory under the netdevice. Without
this subdirectory the user-space NetworkManager cannot manage
the network device.
Implemented using void * to maintain current driver implementation
of segregated OS-specific implementation.
This CL contains changes similar to http://git-master/r/77889
which was done for bcm4329.
Bug 924521
(cherry picked from commit 8ce30af25321844cb0e89a3c23f0a6521885b6db)
Change-Id: I78ef9883ae1f85dbd3ad18e0ee2dece1559c4da8
Reviewed-on: http://git-master/r/82875
Reuse rx urb to avoid memory leak.
Detect usb interface disconnect state to avoid rx / tx urb submit
on disconnected interface.
Signed-off-by: Seshendra Gadagottu <sgadagottu@nvidia.com>
Reviewed-on: http://git-master/r/77969
(cherry picked from commit 343dcb023cd465a6210239cf64ebed5858223096)
Change-Id: I7e49c73b47f6e1c803cd5f0cdb2e6f81bf8171d3
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/82722
Reviewed-by: Seshendra Gadagottu <sgadagottu@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
Move CSCAN driver compilation flag to CONFIG_BCM4329_CSCAN_ENABLE
make that option controlled by CONFIG_BCM4329_CSCAN_ENABLE.
Bug 929960
Signed-off-by: Eric Brower <ebrower@nvidia.com>
(cherry picked from commit af965bf9a82041353a322a3205574ff402c6ff05)
Reviewed-on: http://git-master/r/77890
(cherry picked from commit 2f641aa2781afc80ed496978c55fc83aa251f727)
Change-Id: Iaf9ba7c7122571c7b5c5a670e0b9330d53a8940e
Reviewed-on: http://git-master/r/82721
the network device.
Bug 929960
Reviewed-on: http://git-master/r/77889
(cherry picked from commit 5055320be16c36557e1ab9966ff7537500ca6d4d)
Change-Id: Ia5ea298c32823f896428905a779a734140306861
Reviewed-on: http://git-master/r/82720
[ Upstream commit b924551bed09f61b64f21bffe241afc5526b091a ]
bond_alb_init_slave() is called from bond_enslave() and sets the slave's MAC
address. This is done differently for TLB and ALB modes.
bond->alb_info.rlb_enabled is used to discriminate between the two modes but
this flag may be uninitialized if the slave is being enslaved prior to calling
bond_open() -> bond_alb_initialize() on the master.
It turns out all the callers of alb_set_slave_mac_addr() pass
bond->alb_info.rlb_enabled as the hw parameter.
This patch cleans up the unnecessary parameter of alb_set_slave_mac_addr() and
makes the function decide based on the bonding mode instead, which fixes the
above problem.
Reported-by: Narendra K <Narendra_K@Dell.com>
Signed-off-by: Jiri Bohac <jbohac@suse.cz>
Signed-off-by: Jay Vosburgh <fubar@us.ibm.com>
Change-Id: I83909e006b8e2dcbe35c35c80f2e236e7e4743bf
Reviewed-on: http://git-master/r/79692
Defer tx urb submit to work function to avoid problems with autopm
not fully resumed.
BUG 929408
Reviewed-on: http://git-master/r/77228
Change-Id: Id559d65384780067e48faee6c79134eb35d298fc
Reviewed-on: http://git-master/r/78014
Do not submit rx urb if usb interface is disconnected.
BUG 922418
Reviewed-on: http://git-master/r/74880
Change-Id: I42fa715307275b9d1175ef624acef6c098732261
Reviewed-on: http://git-master/r/77746
Linux 3.1.10
Change-Id: I465d184c492e8041dd0cd90f2cb70fde17ba7118
Adding FLAG_RMNET to change ncm net device name
for Ericsson modem.
Bug 901367
Change-Id: I4a029cc10a02176035319ed4ac1e7b9af349cbd1
Reviewed-on: http://git-master/r/74912
Reviewed-by: WK Tsai <wtsai@nvidia.com>
Signed-off-by: BH Hsieh <bhsieh@nvidia.com>
Reviewed-on: http://git-master/r/76459
As we can program the Ethernet EEPROM, we do not need
the NVIDIA hack anymore.
This reverts commit a87ed2225d0367835c6ba0ad880f7b1049deaaa2.
Bug 923832
Change-Id: I157315f65a9eb2df964dd07431ce52cc08adca6c
Reviewed-on: http://git-master/r/74074
Reviewed-by: Eric Brower <ebrower@nvidia.com>
Reviewed-by: Jong Kim <jongk@nvidia.com>
Reviewed-on: http://git-master/r/75541
In case of failure to load RAW-IP network driver, cleanup
resources (memory, usb driver registration).
Reviewed-on: http://git-master/r/67183
(cherry picked from commit 0fbfd527eccdf9a690db1a77d1ec4699bbdf44a8)
Change-Id: I1cdfe941a71a6d43601c77196d7a61757680ed80
Reviewed-on: http://git-master/r/74864
Reviewed-on: http://git-master/r/75540
commit d90db4b12bc1b9b8a787ef28550fdb767ee25a49 upstream.
When downloading firmware into the device, the driver fails to check the
return when allocating an skb. When the allocation fails, a BUG can be
generated, as seen in https://bugzilla.redhat.com/show_bug.cgi?id=771656.
Linux 3.1.9
Makefile
Change-Id: I22227ab33ba7ddaba8e6fe049393c58a83d73648
commit f7d9821a6a9c83450ac35e76d3709e32fd38b76f upstream.
If slave device already has a receive handler registered, then the
error unwind of bonding device enslave function is broken.
The following will leave a pointer to freed memory in the slave
device list, causing a later kernel panic.
# modprobe dummy
# ip li add dummy0-1 link dummy0 type macvlan
# modprobe bonding
# echo +dummy0 >/sys/class/net/bond0/bonding/slaves
The fix is to detach the slave (which removes it from the list)
in the unwind path.
Reviewed-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr>
commit 6c15d74defd38e7e7f8805392578b7a1d508097e upstream.
At this point if skb->len happens to be 2, the subsequant skb_pull(skb, 4)
call won't work and the skb->len won't be decreased and won't ever reach 0,
resulting in an infinite loop.
With an ASIX 88772 under heavy load, without this patch, rx_fixup() reaches
an infinite loop in less than a minute. With this patch applied,
no infinite loop even after hours of heavy load.
Signed-off-by: Aurelien Jacobs <aurel@gnuage.org>
Cc: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
commit e8303a3b2196272c3eb994d0fd1a189a958a2bdd upstream.
Adds the device id needed for the USB Ethernet Adapter delivered by
ASUS with their Zenbook.
Acked-by: Grant Grundler <grundler@chromium.org>
commit 3f1764945eaac532c20ab1f23afa352a40f797b2 upstream.
Commit 80900d0140a7648587982c8f299830e900e49165 accidently broke
the ABI for testmode commands. Restore the ABI again.
Signed-off-by: Pontus Fuchs <pontus.fuchs@gmail.com>
Signed-off-by: Luciano Coelho <coelho@ti.com>
commit f6efe96edd9c41c624c8f4ddbc4930c1a2d8f1e1 upstream.
An nvs with malformed contents could cause the processing of the
calibration data to read beyond the end of the buffer. Prevent this
from happening by adding bound checking.
Reviewed-by: Luciano Coelho <coelho@ti.com>
commit 2131d3c2f99b081806fdae7662c92fe6acda52af upstream.
Check for out of bound FEM index to prevent reading beyond ini
memory end.
commit 3f81f8f1524ccca24df1029b0cf825ecef5e5cdc upstream.
Testing on the openSUSE wireless forum has shown that a Linksys
WUSB54GC v3 with USB ID 1737:0077 works with rt2800usb when the ID is
written to /sys/.../new_id. This ID can therefore be moved out of UNKNOWN.
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com>
Acked-by: Ivo van Doorn <IvDoorn@gmail.com>
commit b25bfda38236f349cde0d1b28952f4eea2148d3f upstream.
don't do aggregation related stuff for 'AP mode client power save
handling' if aggregation is not enabled in the driver, otherwise it
will lead to panic because those data structures won't be never
intialized in 'ath_tx_node_init' if aggregation is disabled
EIP is at ath_tx_aggr_wakeup+0x37/0x80 [ath9k]
EAX: e8c09a20 EBX: f2a304e8 ECX: 00000001 EDX: 00000000
ESI: e8c085e0 EDI: f2a304ac EBP: f40e1ca4 ESP: f40e1c8c
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
Process swapper/1 (pid: 0, ti=f40e0000 task=f408e860
task.ti=f40dc000)
Stack:
0001e966 e8c09a20 00000000 f2a304ac e8c085e0 f2a304ac
f40e1cb0 f8186741
f8186700 f40e1d2c f922988d f2a304ac 00000202 00000001
c0b4ba43 00000000
0000000f e8eb75c0 e8c085e0 205b0001 34383220 f2a304ac
f2a30000 00010020
Call Trace:
[<f8186741>] ath9k_sta_notify+0x41/0x50 [ath9k]
[<f8186700>] ? ath9k_get_survey+0x110/0x110 [ath9k]
[<f922988d>] ieee80211_sta_ps_deliver_wakeup+0x9d/0x350
[mac80211]
[<c018dc75>] ? __module_address+0x95/0xb0
[<f92465b3>] ap_sta_ps_end+0x63/0xa0 [mac80211]
[<f9246746>] ieee80211_rx_h_sta_process+0x156/0x2b0
[mac80211]
[<f9247d1e>] ieee80211_rx_handlers+0xce/0x510 [mac80211]
[<c018440b>] ? trace_hardirqs_on+0xb/0x10
[<c056936e>] ? skb_queue_tail+0x3e/0x50
[<f9248271>] ieee80211_prepare_and_rx_handle+0x111/0x750
[mac80211]
[<f9248bf9>] ieee80211_rx+0x349/0xb20 [mac80211]
[<f9248949>] ? ieee80211_rx+0x99/0xb20 [mac80211]
[<f818b0b8>] ath_rx_tasklet+0x818/0x1d00 [ath9k]
[<f8187a75>] ? ath9k_tasklet+0x35/0x1c0 [ath9k]
[<f8187b33>] ath9k_tasklet+0xf3/0x1c0 [ath9k]
[<c0151b7e>] tasklet_action+0xbe/0x180
Cc: Senthil Balasubramanian <senthilb@qca.qualcomm.com>
Cc: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
Reported-by: Ashwin Mendonca <ashwinloyal@gmail.com>
Tested-by: Ashwin Mendonca <ashwinloyal@gmail.com>
Signed-off-by: Mohammed Shafi Shajakhan <mohammed@qca.qualcomm.com>
Change-Id: I3cd9332f9e8fc79020b34c3f8cfb1a1a5f8a9bf4
Reviewed-on: http://git-master/r/74234
commit 96f1f05af76b601ab21a7dc603ae0a1cea4efc3d upstream.
Since we configure all the queues as CHAINABLE, we need to update the
byte count for all the queues, not only the AGGREGATABLE ones.
Not doing so can confuse the SCD and make the fw assert.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
Change-Id: Id5700ae8cfc1b3243ca9f96f6dd0bbf95b05b5e6
Reviewed-on: http://git-master/r/74227
[ Upstream commit a454daceb78844a09c08b6e2d8badcb76a5d73b9 ]
Signed-off-by: Djalal Harouni <tixxdz@opendz.org>
Change-Id: I9bf78b2e47083ebf3363c7017cbcda8bb9ceb30b
Reviewed-on: http://git-master/r/74214
commit 78feb35b8161acd95c33a703ed6ab6f554d29387 upstream.
My previous patch
34a5b4b6af104cf18eb50748509528b9bdbc4036 iwlwifi: do not re-configure
HT40 after associated
Fix the case of HT40 after association on specified AP, but it break the
association for some APs and cause not able to establish connection.
We need to address HT40 before and after addociation.
Reported-by: Andrej Gelenberg <andrej.gelenberg@udo.edu>
Tested-by: Andrej Gelenberg <andrej.gelenberg@udo.edu>
Change-Id: Idb3be35a9693545112a3d22f35efe31bc6efab06
Reviewed-on: http://git-master/r/74191
commit 123877b80ed62c3b897c53357b622574c023b642 upstream.
Check the IEEE80211_TX_CTL_ASSIGN_SEQ flag from mac80211, then decide how to
set the TX_CMD_FLG_SEQ_CTL_MSK bit. Setting the wrong bit in BAR frame whill
make the firmware to increment the sequence number which is incorrect and
cause unknown behavior.
Change-Id: I3b610f6383fc35467b8451621b7ce4d154196e4a
Reviewed-on: http://git-master/r/74190
commit 10636bc2d60942254bda149827b922c41f4cb4af upstream.
The stations always chooses 1Mbps for all trasmitting frames,
whenever the AP is configured to lock the supported rates.
As the max phy rate is always set with the 4th from highest phy rate,
this assumption might be wrong if we have less than that. Fix that.
Cc: Paul Stewart <pstew@google.com>
Reported-by: Ajay Gummalla <agummalla@google.com>
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
Change-Id: I240606b385bb9d0a5c4dec19dfd364289bf478ab
Reviewed-on: http://git-master/r/74189
transition
commit 91ddff8a3b9cc7ac2252aca138220939cf6cc2cf upstream.
In drivers rtl8192ce, rtl8192cu, rtl8192se, and rtl8192de, break
statements would allow ppsc->rfpwr_state to be changed to ERFSLEEP
even though the device is actually in ERFOFF.
Signed-off-by: Philipp Dreimann <philipp@dreimann.net>
Cc: Chaoming Li <chaoming_li@realsil.com.cn>
Change-Id: I4244546343a9d37d6302373d8a1cbb57e1be4334
Reviewed-on: http://git-master/r/74170
task.ti=f40dc000)
Stack:
f40e1cb0 f8186741
c0b4ba43 00000000
f2a30000 00010020
Call Trace:
[mac80211]
[mac80211]
[mac80211]
