commit 6954cc1f238199e971ec905c5cc87120806ac981 upstream.
Fix null-pointer dereference at probe when the mdio platform device is
missing (e.g. when it has been disabled in DT).
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit 0b5a958cf4df3a5cd578b861471e62138f55c85e upstream.
As remarked by Christopher R. Baker in his post at
http://marc.info/?l=linux-can&m=139707295706465&w=2
there's a possibility for an use after free condition at device removal.
This simplified patch introduces an additional variable to prevent the issue.
Thanks for catching this.
Reported-by: Christopher R. Baker <cbaker@rec.ri.cmu.edu>
Signed-off-by: Stephane Grosjean <s.grosjean@peak-system.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit 59993f48b38fd46863b23bb1bb1dc3291e7278fb upstream.
This reverts commit f8d56d8f892be43a2404356073e16401eb5a42e6 ("net:
eth: cpsw: Correctly attach to GPIO bitbang MDIO driver").
Fix potential null-pointer dereference at probe if the mdio-gpio device
has not been successfully probed yet.
The offending commit is plain wrong for a number of reasons. First of
all it accesses internal driver data of an unrelated device. Neither
does it check that the data is non-null (which it is in case the device
has not been probed yet).
Furthermore, the decision on whether to treat any driver data according
to the mdio-gpio driver's internals is made based on the node name. But
the name is not compared against "mdio" which is the normal name for the
node, but rather against "gpio" which the node does not have to be named
(and shouldn't be according to the binding documentation). [ If this
hack is to be kept out-of-tree it should at least be matching against
the compatible property. ]
Cc: Stefan Roese <sr@denx.de>
[ Upstream commit da1de8dfff09d33d4a5345762c21b487028e25f5 ]
Following commit befdf89 "net/mlx4_core: Preserve pci_dev_data after
__mlx4_remove_one()", there are two mlx4 pci callbacks which will
attempt to release the mlx4_priv object -- .shutdown and .remove.
This leads to a use-after-free access to the already freed mlx4_priv
instance and trigger a "Kernel access of bad area" crash when both
.shutdown and .remove are called.
During reboot or kexec, .shutdown is called, with the VFs probed to
the host going through shutdown first and then the PF. Later, the PF
will trigger VFs' .remove since VFs still have driver attached.
Fix that by keeping only one driver entry which releases mlx4_priv.
Fixes: befdf89 ('net/mlx4_core: Preserve pci_dev_data after __mlx4_remove_one()')
CC: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Wei Yang <weiyang@linux.vnet.ibm.com>
[ Upstream commit befdf8978accecac2e0739e6b5075afc62db37fe ]
pci_match_id() just match the static pci_device_id, which may return NULL if
someone binds the driver to a device manually using
/sys/bus/pci/drivers/.../new_id.
This patch wrap up a helper function __mlx4_remove_one() which does the tear
down function but preserve the drv_data. Functions like
mlx4_pci_err_detected() and mlx4_restart_one() will call this one with out
releasing drvdata.
Fixes: 97a5221 "net/mlx4_core: pass pci_device_id.driver_data to __mlx4_init_one during reset".
CC: Amir Vadai <amirv@mellanox.com>
CC: Jack Morgenstein <jackm@dev.mellanox.co.il>
CC: Or Gerlitz <ogerlitz@mellanox.com>
Acked-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
[ Upstream commit 2853af6a2ea1a8ed09b09dd4fb578e7f435e8d34 ]
When we mirror packets from a vxlan tunnel to other device,
the mirror device should see the same packets (that is, without
outer header). Because vxlan tunnel sets dev->hard_header_len,
tcf_mirred() resets mac header back to outer mac, the mirror device
actually sees packets with outer headers
Vxlan tunnel should set dev->needed_headroom instead of
dev->hard_header_len, like what other ip tunnels do. This fixes
the above problem.
Cc: stephen hemminger <stephen@networkplumber.org>
Cc: Pravin B Shelar <pshelar@nicira.com>
Signed-off-by: Cong Wang <cwang@twopensource.com>
[ Upstream commit daf37b556e437ec1ea1a597dcfeff338068380e1 ]
Fixes:ee45fd92c739
("sfc: Use TX PIO for sufficiently small packets")
The linux net driver uses memcpy_toio() in order to copy into
the PIO buffers.
Even on a 64bit machine this causes 32bit accesses to a write-
combined memory region.
There are hardware limitations that mean that only 64bit
naturally aligned accesses are safe in all cases.
Due to being write-combined memory region two 32bit accesses
may be coalesced to form a 64bit non 64bit aligned access.
Solution was to open-code the memory copy routines using pointers
and to only enable PIO for x86_64 machines.
Not tested on platforms other than x86_64 because this patch
disables the PIO feature on other platforms.
Compile-tested on x86 to ensure that works.
The WARN_ON_ONCE() code in the previous version of this patch
has been moved into the internal sfc debug driver as the
assertion was unnecessary in the upstream kernel code.
This bug fix applies to v3.13 and v3.14 stable branches.
Signed-off-by: Shradha Shah <sshah@solarflare.com>
[ Upstream commit 87757a917b0b3c0787e0563c679762152be81312 ]
unregister_netdevice_many() API is error prone and we had too
many bugs because of dangling LIST_HEAD on stacks.
See commit f87e6f47933e3e ("net: dont leave active on stack LIST_HEAD")
In fact, instead of making sure no caller leaves an active list_head,
just force a list_del() in the callee. No one seems to need to access
the list after unregister_netdevice_many()
[ Upstream commit ba6de0f5304ccdc45ae260e7e0feb6e0ef2dd558 ]
Lars writes: "I'm only 99% sure that the net interfaces are qmi
interfaces, nothing to lose by adding them in my opinion."
And I tend to agree based on the similarity with the two Olicard
modems we already have here.
Reported-by: Lars Melin <larsm17@gmail.com>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
[ Upstream commit d8b0426af5b67973585712c9af36b86f6ea97815 ]
Commit 4a55530f38e4 (net: sh_eth: modify the definitions of register) managed
to leave out the E-DMAC register entries in sh_eth_offset_fast_sh3_sh2[], thus
totally breaking SH7619/771x support. Add the missing entries using the data
from before that commit.
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Acked-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
[ Upstream commit 530aa2d0d9d55ab2775d47621ddf4b5b15bc1110 ]
The current behaviour of the sh_eth driver is not to use the RNC bit
for the receive ring. This means that every packet recieved is not only
generating an IRQ but it also stops the receive ring DMA as well until
the driver re-enables it after unloading the packet.
This means that a number of the following errors are generated due to
the receive packet FIFO overflowing due to nowhere to put packets:
net eth0: Receive FIFO Overflow
Since feedback from Yoshihiro Shimoda shows that every supported LSI
for this driver should have the bit enabled it seems the best way is
to remove the RMCR default value from the per-system data and just
write it when initialising the RMCR value. This is discussed in
the message (http://www.spinics.net/lists/netdev/msg284912.html).
I have tested the RMCR_RNC configuration with NFS root filesystem and
the driver has not failed yet. There are further test reports from
Sergei Shtylov and others for both the R8A7790 and R8A7791.
There is also feedback fron Cao Minh Hiep[1] which reports the
same issue in (http://comments.gmane.org/gmane.linux.network/316285)
showing this fixes issues with losing UDP datagrams under iperf.
Tested-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
Acked-by: Simon Horman <horms+renesas@verge.net.au>
[ Upstream commit 9d0d68faea6962d62dd501cd6e71ce5cc8ed262b ]
Now it is not possible to set mtu to team device which has a port
enslaved to it. The reason is that when team_change_mtu() calls
dev_set_mtu() for port device, notificator for NETDEV_PRECHANGEMTU
event is called and team_device_event() returns NOTIFY_BAD forbidding
the change. So fix this by returning NOTIFY_DONE here in case team is
changing mtu in team_change_mtu().
Introduced-by: 3d249d4c "net: introduce ethernet teaming device"
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Acked-by: Flavio Leitner <fbl@redhat.com>
[ Upstream commit 7df566bbdd0af0785542b89466a937e94257fcfb ]
This function is called from dcbnl_build_peer_app(). The "info"
struct isn't initialized at all so we disclose 2 bytes of uninitialized
stack data. We should clear it before passing it to the user.
Fixes: 48365e485275 ('qlcnic: dcb: Add support for CEE Netlink interface.')
commit b804eeb6649d75caeccbeae9f5623fc7b8bdfdfa upstream.
The per rate stats should be cleared when aggregation state changes
to avoid making rate scale decisions based on throughput figures which
were collected prior to the aggregation state change and are now stale.
While at it make sure any clearing of the per rate stats will get logged.
Signed-off-by: Eyal Shapira <eyalx.shapira@intel.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
commit 3ca71f603bb1a0f55e1ba24618ba45617bc36f70 upstream.
instead of duplicating the same loop multiple times,
use a new function for it.
this will be later used also for clearing other
windows in the table.
Signed-off-by: Eliad Peller <eliadx.peller@intel.com>
commit 7bacc782270ff7db3b9f29fa5d24ad2ee1e8e81d upstream.
This feature has been causing trouble - disable it for now.
commit a6bc92803e7f765e02c923cf37c8e280e729642a upstream.
A few entries were wrong and this caused throughput issues.
Fixes: dac94da8dba3 ("iwlwifi: mvm: new BT Coex API")
commit 1c4abec0baf25ffb92a28cc99d4231feeaa4d3f3 upstream.
There was a deadlock in monitor mode when we were setting the
channel if the channel was not 1.
[ INFO: possible circular locking dependency detected ]
3.14.3 #4 Not tainted
iw/3323 is trying to acquire lock:
(&local->chanctx_mtx){+.+.+.}, at: [<ffffffffa062e2f2>] ieee80211_vif_release_channel+0x42/0xb0 [mac80211]
but task is already holding lock:
(&local->iflist_mtx){+.+...}, at: [<ffffffffa0609e0a>] ieee80211_set_monitor_channel+0x5a/0x1b0 [mac80211]
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #2 (&local->iflist_mtx){+.+...}:
[<ffffffff810d95bb>] __lock_acquire+0xb3b/0x13b0
[<ffffffff810d9ee0>] lock_acquire+0xb0/0x1f0
[<ffffffff817eb9c8>] mutex_lock_nested+0x78/0x4f0
[<ffffffffa06225cf>] ieee80211_iterate_active_interfaces+0x2f/0x60 [mac80211]
[<ffffffffa0518189>] iwl_mvm_recalc_multicast+0x49/0xa0 [iwlmvm]
[<ffffffffa051822e>] iwl_mvm_configure_filter+0x4e/0x70 [iwlmvm]
[<ffffffffa05e6d43>] ieee80211_configure_filter+0x153/0x5f0 [mac80211]
[<ffffffffa05e71f5>] ieee80211_reconfig_filter+0x15/0x20 [mac80211]
[snip]
-> #1 (&mvm->mutex){+.+.+.}:
[<ffffffffa0517246>] iwl_mvm_add_chanctx+0x56/0xe0 [iwlmvm]
[<ffffffffa062ca1e>] ieee80211_new_chanctx+0x13e/0x410 [mac80211]
[<ffffffffa062d953>] ieee80211_vif_use_channel+0x1c3/0x5a0 [mac80211]
[<ffffffffa06035ab>] ieee80211_add_virtual_monitor+0x1ab/0x6b0 [mac80211]
[<ffffffffa06052ea>] ieee80211_do_open+0xe6a/0x15a0 [mac80211]
[<ffffffffa0605a79>] ieee80211_open+0x59/0x60 [mac80211]
[snip]
-> #0 (&local->chanctx_mtx){+.+.+.}:
[<ffffffff810d6cb7>] check_prevs_add+0x977/0x980
[<ffffffffa0609ec3>] ieee80211_set_monitor_channel+0x113/0x1b0 [mac80211]
[<ffffffffa058fb37>] cfg80211_set_monitor_channel+0x77/0x2b0 [cfg80211]
[<ffffffffa056e0b2>] __nl80211_set_channel+0x122/0x140 [cfg80211]
[<ffffffffa0581374>] nl80211_set_wiphy+0x284/0xaf0 [cfg80211]
[snip]
Chain exists of:
&local->chanctx_mtx --> &mvm->mutex --> &local->iflist_mtx
Possible unsafe locking scenario:
CPU0 CPU1
lock(&local->iflist_mtx);
lock(&mvm->mutex);
lock(&local->chanctx_mtx);
*** DEADLOCK ***
This deadlock actually occurs:
INFO: task iw:3323 blocked for more than 120 seconds.
Not tainted 3.14.3 #4
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
iw D ffff8800c8afcd80 4192 3323 3322 0x00000000
ffff880078fdb7e0 0000000000000046 ffff8800c8afcd80 ffff880078fdbfd8
00000000001d5540 00000000001d5540 ffff8801141b0000 ffff8800c8afcd80
ffff880078ff9e38 ffff880078ff9e38 ffff880078ff9e40 0000000000000246
Call Trace:
[<ffffffff817ea841>] schedule_preempt_disabled+0x31/0x80
[<ffffffff817ebaed>] mutex_lock_nested+0x19d/0x4f0
[<ffffffffa06225cf>] ? ieee80211_iterate_active_interfaces+0x2f/0x60 [mac80211]
[<ffffffffa052a680>] ? iwl_mvm_power_mac_update_mode+0xc0/0xc0 [iwlmvm]
[<ffffffffa0529357>] _iwl_mvm_power_update_binding+0x27/0x80 [iwlmvm]
[<ffffffffa0516eb1>] iwl_mvm_unassign_vif_chanctx+0x81/0xc0 [iwlmvm]
[<ffffffffa062d3ff>] __ieee80211_vif_release_channel+0xdf/0x470 [mac80211]
[<ffffffffa062e2fa>] ieee80211_vif_release_channel+0x4a/0xb0 [mac80211]
This fixes https://bugzilla.kernel.org/show_bug.cgi?id=75541
Reviewed-by: Johannes Berg <johannes.berg@intel.com>
commit 83f7a85f1134c6e914453f5747435415a23d516b upstream.
In case RFKILL is in KILL position, the NIC will issue an
interrupt straight away. This interrupt won't be sent
because it is masked in the hardware.
But if our interrupt service routine is called for another
reason (SHARED_IRQ), then we'll look at the interrupt cause
and service it. This can cause bad things if we are not
ready yet.
Explicitly clean the interrupt cause register to make sure
we won't service anything before we are ready to.
Reported-and-tested-by: Alexander Monakov <amonakov@gmail.com>
commit b20a774495671f037e7160ea2ce8789af6b61533 upstream.
In commit da1e2046e5, the flow for enabling/disabling an Si errata
workaround (e1000_lv_jumbo_workaround_ich8lan) was changed to fix a problem
with iAMT connections dropping on interface down with jumbo frames set.
Part of this change was to move the function call disabling the workaround
to e1000e_down() from the e1000_setup_rctl() function. The mechanic for
disabling of this workaround involves writing several MAC and PHY registers
back to hardware defaults.
After this commit, when the driver is loaded with the cable out, the PHY
registers are not programmed with the correct default values. This causes
the device to be capable of transmitting packets, but is unable to recieve
them until this workaround is called.
The flow of e1000e's open code relies upon calling the above workaround to
expicitly program these registers either with jumbo frame appropriate settings
or h/w defaults on 82579 and newer hardware.
Fix this issue by adding logic to e1000_setup_rctl() that not only calls
e1000_lv_jumbo_workaround_ich8lan() when jumbo frames are set, to enable the
workaround, but also calls this function to explicitly disable the workaround
in the case that jumbo frames are not set.
Signed-off-by: Dave Ertman <davidx.m.ertman@intel.com>
Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com>
commit 8fc1e8c240aab968db658b2d8d079b4391207a36 upstream.
When brcm80211 firmware is not installed networking hangs.
A deadlock happens because we call ieee80211_unregister_hw()
from the .start callback of struct ieee80211_ops. When .start
is called we are under rtnl lock and ieee80211_unregister_hw()
tries to take it again.
Function call stack:
dev_change_flags()
__dev_change_flags()
__dev_open()
ASSERT_RTNL() <-- Assert rtnl lock
ops->ndo_open()
.ndo_open = ieee80211_open,
ieee80211_open()
ieee80211_do_open()
drv_start()
local->ops->start()
.start = brcms_ops_start,
brcms_ops_start()
brcms_remove()
rtnl_lock() <-- Here we deadlock
Introduced by:
commit 25b5632fb35ca61b8ae3eee235edcdc2883f7a5e
("brcmsmac: request firmware in .start() callback")
This patch fixes the bug by removing the call to brcms_remove()
and moves the brcms_request_fw() call to the top of the .start
callback to not initiate anything unless firmware is installed.
Signed-off-by: Emil Goode <emilgoode@gmail.com>
commit b709323d2477614823a38c2f2a9a206e087e28fc upstream.
Prior to cd14ef54d25 (igb: Change to use statically allocated array for
MSIx entries), having msix_entries different from NULL was an indicator
that MSIX is enabled.
In igb_set_interrupt_capabiliy we may fall back to MSI-only. Prior to
the above patch msix_entries was set to NULL by
igb_reset_interrupt_capability.
However, now we are checking the flag for IGB_FLAG_HAS_MSIX and so the
stack gets completly confused:
[ 42.659791] ------------[ cut here ]------------
[ 42.715032] WARNING: CPU: 7 PID: 0 at net/sched/sch_generic.c:264 dev_watchdog+0x15c/0x1fb()
[ 42.848263] NETDEV WATCHDOG: eth0 (igb): transmit queue 0 timed out
[ 42.923253] Modules linked in:
[ 42.959875] CPU: 7 PID: 0 Comm: swapper/7 Not tainted 3.14.0-rc2-mptcp #437
[ 43.043184] Hardware name: HP ProLiant DL165 G7, BIOS O37 01/26/2011
[ 43.119215] 0000000000000108 ffff88023fdc3da8 ffffffff81487847 0000000000000108
[ 43.208165] ffff88023fdc3df8 ffff88023fdc3de8 ffffffff81034e7d ffff88023fdc3dd8
[ 43.297120] ffffffff813fff10 ffff880236018000 ffff880236b178c0 0000000000000008
[ 43.386071] Call Trace:
[ 43.415303] <IRQ> [<ffffffff81487847>] dump_stack+0x49/0x62
[ 43.484174] [<ffffffff81034e7d>] warn_slowpath_common+0x77/0x91
[ 43.556049] [<ffffffff813fff10>] ? dev_watchdog+0x15c/0x1fb
[ 43.623759] [<ffffffff81034f2b>] warn_slowpath_fmt+0x41/0x43
[ 43.692511] [<ffffffff813fff10>] dev_watchdog+0x15c/0x1fb
[ 43.758141] [<ffffffff813ffdb4>] ? __netdev_watchdog_up+0x64/0x64
[ 43.832091] [<ffffffff8103cd04>] call_timer_fn+0x17/0x6f
[ 43.896682] [<ffffffff8103cebe>] run_timer_softirq+0x162/0x1a2
[ 43.967511] [<ffffffff81038520>] __do_softirq+0xcd/0x1cc
[ 44.032104] [<ffffffff81038689>] irq_exit+0x3a/0x48
[ 44.091492] [<ffffffff81026d43>] smp_apic_timer_interrupt+0x43/0x50
[ 44.167525] [<ffffffff8148c24a>] apic_timer_interrupt+0x6a/0x70
[ 44.239392] <EOI> [<ffffffff8100992c>] ? default_idle+0x6/0x8
[ 44.310343] [<ffffffff81009b31>] arch_cpu_idle+0x13/0x18
[ 44.374934] [<ffffffff81066126>] cpu_startup_entry+0xa7/0x101
[ 44.444724] [<ffffffff81025660>] start_secondary+0x1b2/0x1b7
[ 44.513472] ---[ end trace a5a075fd4e7f854f ]---
[ 44.568753] igb 0000:04:00.0 eth0: Reset adapter
[ 46.206945] random: nonblocking pool is initialized
[ 46.465670] irq 44: nobody cared (try booting with the "irqpoll" option)
[ 46.545862] CPU: 7 PID: 0 Comm: swapper/7 Tainted: G W 3.14.0-rc2-mptcp #437
[ 46.640610] Hardware name: HP ProLiant DL165 G7, BIOS O37 01/26/2011
[ 46.716641] ffff8802363f8c84 ffff88023fdc3e38 ffffffff81487847 00000000a03cdb6d
[ 46.805598] ffff8802363f8c00 ffff88023fdc3e68 ffffffff81068489 0000007f81825400
[ 46.894539] ffff8802363f8c00 0000000000000000 0000000000000000 ffff88023fdc3ea8
[ 46.983484] Call Trace:
[ 47.012714] <IRQ> [<ffffffff81487847>] dump_stack+0x49/0x62
[ 47.081585] [<ffffffff81068489>] __report_bad_irq+0x35/0xc1
[ 47.149295] [<ffffffff81068683>] note_interrupt+0x16e/0x1ea
[ 47.217006] [<ffffffff8106679e>] handle_irq_event_percpu+0x116/0x12e
[ 47.294075] [<ffffffff810667e9>] handle_irq_event+0x33/0x4f
[ 47.361787] [<ffffffff81068c95>] handle_fasteoi_irq+0x83/0xd1
[ 47.431577] [<ffffffff81003d5b>] handle_irq+0x1f/0x28
[ 47.493047] [<ffffffff81003567>] do_IRQ+0x4e/0xd4
[ 47.550358] [<ffffffff8148b06a>] common_interrupt+0x6a/0x6a
[ 47.618066] <EOI> [<ffffffff8100992c>] ? default_idle+0x6/0x8
[ 47.689016] [<ffffffff81009b31>] arch_cpu_idle+0x13/0x18
[ 47.753605] [<ffffffff81066126>] cpu_startup_entry+0xa7/0x101
[ 47.823397] [<ffffffff81025660>] start_secondary+0x1b2/0x1b7
[ 47.892146] handlers:
[ 47.919301] [<ffffffff812fbd7d>] igb_intr
So, this patch unsets the flag to indicate that we are not using MSIX.
This patch does exactly this: Unsetting the flag when falling back to MSI.
Fixes: cd14ef54d25b (igb: Change to use statically allocated array for MSIx entries)
Cc: Carolyn Wyborny <carolyn.wyborny@intel.com>
Signed-off-by: Christoph Paasch <christoph.paasch@uclouvain.be>
commit cb06d102327eadcd1bdc480bfd9f8876251d1007 upstream.
When igb_set_interrupt_capability() calls
igb_reset_interrupt_capability() (e.g., because CONFIG_PCI_MSI is unset),
num_q_vectors has been set but no vector has yet been allocated.
igb_reset_interrupt_capability() will then call igb_reset_q_vector,
which assumes that the vector is allocated. As this is not the case, we
are accessing a NULL-pointer.
This patch fixes it by checking that q_vector is indeed different from
NULL.
Fixes: 02ef6e1d0b0023 (igb: Fix queue allocation method to accommodate changing during runtime)
commit c243e96335c56e56dcf6a00593104554fb06b689 upstream.
If "vf_id" is smaller than hw->func_caps.vf_base_id then it leads to
an array underflow of the pf->vf[] array. This is unlikely to happen
unless the hardware is bad, but it's a small change and it silences a
static checker warning.
Fixes: 7efa84b7abc1 ('i40e: support VFs on PFs other than 0')
Tested-by: Sibai Li <sibai.li@intel.com>
commit 3234f5b06fc3094176a86772cc64baf3decc98fc upstream.
Fixes: a53268be0cb9 ('rtlwifi: rtl8192cu: Fix too long disable of IRQs')
commit 8834d3608cc516f13e2e510f4057c263f3d2ce42 upstream.
When disable beaconing we clear register with beacon and newer set it
back, what make we stop send beacons infinitely.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit 0229cdafb6f67064a217591d48b0f6abf14e8385 upstream.
If we have no beacon data before association, delay smart FIFO
enablement until after we have this data.
Not doing so can cause association failures in extremely silent
environments (usually only a shielded box/room) as beacon RX is
not sent to the host immediately, and then the association time
event ends without the host receiving any beacon even though it
was on the air - it's just stuck on the FIFO.
Fixes: 1f3b0ff8ecce ("iwlwifi: mvm: Add Smart FIFO support")
commit 431031851ea72a25abb9ad4df56a0f3b997e3026 upstream.
This will allow to load the new firmware.
commit 87d5e4155c0088e6766b4f0193b63fa0eab71220 upstream.
After being idle for a long time (>5sec) the rs statistics
will be stale so we prefer to reset rs and start from legacy
rates again. This gives better results when the attenuation
increased signficantly (e.g. we got further from the AP) and
after a while we start Tx
Note that the first Tx after the idle period will still go out
in the old modulation and rate but this seemed a simpler approach
compared to adding a timer or modifying mac80211 for this.
The negative impact is negligble as we'll recover quickly.
commit e53839eb9882c99d3781eab0fe1b2d4369a6a2cc upstream.
Change the down/upscale decision logic a bit to be based
on different success ratio thresholds. This fixes the implementation
compared to the rate scale algorithm which was planned to yield
optimal results. Also fix a case where a lower rate wasn't explored
despite being a potential for better throughput.
While at it rewrite rs_get_rate_action to be more clear and clean.
commit d8fff919ecd7820084675c2814913445e95640ac upstream.
Don't search columns which are unlikely to succeed as previous
columns searched with less aggressive modulation failed.
commit fd7dbee51b3d98402edb11fec0c93d96476e0ae1 upstream.
Allow switching back to legacy Tx columns so we'll stop doing
HT/VHT in case we're far from the AP. Stop active aggregation when
making a deciding to stay in a legacy column.
Despite having low legacy rates in the LQ table lower entries
it doesn't help much in case we're doing aggregations as the
aggregation was being transmitted in the initial rate of the table.
This should help traffic stalls when far from the AP.
commit 80f2679e589503bd6cbaaa1f9c1cd9dd7dfae032 upstream.
Add 2 new HW IDs for the 7265 series.
Signed-off-by: Oren Givon <oren.givon@intel.com>
commit d9088f60425e0acd8a8f05fdfcfdd288d3258641 upstream.
mimo_delim was always set to 0 instead of pointing to
the first SISO entry after MIMO rates.
This can cause keep transmitting in MIMO even when we shouldn't.
For example when the peer is requesting static SMPS.
commit 08a732f4e4a842f0101e5ea03d79e9d613ffadbe upstream.
It was missing.
[ Upstream commit 81c708068dfedece038e07d818ba68333d8d885d ]
I've missed to add a NULL entry to the bond_intmax_tbl when I introduced
it with the conversion of arp_interval so add it now.
CC: Jay Vosburgh <j.vosburgh@gmail.com>
CC: Veaceslav Falico <vfalico@gmail.com>
CC: Andy Gospodarek <andy@greyhouse.net>
Fixes: 7bdb04ed0dbf ("bonding: convert arp_interval to use the new option API")
Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com>
Acked-by: Veaceslav Falico <vfalico@gmail.com>
[ Upstream commit b394745df2d9d4c30bf1bcc55773bec6f3bc7c67 ]
After the call to phy_init_hw failed in phy_attach_direct, phy_detach is called
to detach the phy device from its network device. If the attached driver is a
generic phy driver, this also detaches the driver. Subsequently phy_resume
is called, which assumes without checking that a driver is attached to the
device. This will result in a crash such as
Unable to handle kernel paging request for data at address 0xffffffffffffff90
Faulting instruction address: 0xc0000000003a0e18
Oops: Kernel access of bad area, sig: 11 [#1]
NIP [c0000000003a0e18] .phy_attach_direct+0x68/0x17c
LR [c0000000003a0e6c] .phy_attach_direct+0xbc/0x17c
Call Trace:
[c0000003fc0475d0] [c0000000003a0e6c] .phy_attach_direct+0xbc/0x17c (unreliable)
[c0000003fc047670] [c0000000003a0ff8] .phy_connect_direct+0x28/0x98
[c0000003fc047700] [c0000000003f0074] .of_phy_connect+0x4c/0xa4
Only call phy_resume if phy_init_hw was successful.
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit 1c3639005f48492e5f2d965779efd814e80f8b15 ]
If the sfc driver is in legacy interrupt mode (either explicitly by
using interrupt_mode module param or by falling back to it) it will
hit a warning at kernel/irq/manage.c because it will try to free an irq
which wasn't allocated by it in the first place because the MSI(X) irqs are
zero and it'll try to free them unconditionally. So fix it by checking if
we're in legacy mode and freeing the appropriate irqs.
CC: Zenghui Shi <zshi@redhat.com>
CC: Ben Hutchings <ben@decadent.org.uk>
CC: <linux-net-drivers@solarflare.com>
CC: Shradha Shah <sshah@solarflare.com>
CC: David S. Miller <davem@davemloft.net>
Fixes: 1899c111a535 ("sfc: Fix IRQ cleanup in case of a probe failure")
Reported-by: Zenghui Shi <zshi@redhat.com>
Acked-by: Shradha Shah <sshah@solarflare.com>
[ Upstream commit bbeb0eadcf9fe74fb2b9b1a6fea82cd538b1e556 ]
Clearing the IFF_ALLMULTI flag on a down interface could cause an allmulti
overflow on the underlying interface.
Attempting the set IFF_ALLMULTI on the underlying interface would cause an
error and the log message:
"allmulti touches root, set allmulti failed."
Signed-off-by: Peter Christensen <pch@ordbogen.com>
[ Upstream commit 6b5eeb7f874b689403e52a646e485d0191ab9507 ]
This driver maps 802.1q VLANs to MBIM sessions. The mapping is based on
a bogus assumption that all tagged frames will use the acceleration API
because we enable NETIF_F_HW_VLAN_CTAG_TX. This fails for e.g. frames
tagged in userspace using packet sockets. Such frames will erroneously
be considered as untagged and silently dropped based on not being IP.
Fix by falling back to looking into the ethernet header for a tag if no
accelerated tag was found.
Fixes: a82c7ce5bc5b ("net: cdc_ncm: map MBIM IPS SessionID to VLAN ID")
Cc: Greg Suarez <gsuarez@smithmicro.com>
[ Upstream commit 4f4178f3bb1f470d7fb863ec531e08e20a0fd51c ]
Fixes this warning introduced by commit 5b8f15f78e6f
("net: cdc_mbim: handle IPv6 Neigbor Solicitations"):
[ INFO: suspicious RCU usage. ]
3.15.0-rc3 #213 Tainted: G W O
net/8021q/vlan_core.c:69 suspicious rcu_dereference_check() usage!
rcu_scheduler_active = 1, debug_locks = 1
no locks held by ksoftirqd/0/3.
stack backtrace:
CPU: 0 PID: 3 Comm: ksoftirqd/0 Tainted: G W O 3.15.0-rc3 #213
Hardware name: LENOVO 2776LEG/2776LEG, BIOS 6EET55WW (3.15 ) 12/19/2011
0000000000000001 ffff880232533bf0 ffffffff813a5ee6 0000000000000006
ffff880232530090 ffff880232533c20 ffffffff81076b94 0000000000000081
0000000000000000 ffff8802085ac000 ffff88007fc8ea00 ffff880232533c50
Call Trace:
[<ffffffff813a5ee6>] dump_stack+0x4e/0x68
[<ffffffff81076b94>] lockdep_rcu_suspicious+0xfa/0x103
[<ffffffff813978a6>] __vlan_find_dev_deep+0x54/0x94
[<ffffffffa04a1938>] cdc_mbim_rx_fixup+0x379/0x66a [cdc_mbim]
[<ffffffff813ab76f>] ? _raw_spin_unlock_irqrestore+0x3a/0x49
[<ffffffff81079671>] ? trace_hardirqs_on_caller+0x192/0x1a1
[<ffffffffa059bd10>] usbnet_bh+0x59/0x287 [usbnet]
[<ffffffff8104067d>] tasklet_action+0xbb/0xcd
[<ffffffff81040057>] __do_softirq+0x14c/0x30d
[<ffffffff81040237>] run_ksoftirqd+0x1f/0x50
[<ffffffff8105f13e>] smpboot_thread_fn+0x172/0x18e
[<ffffffff8105efcc>] ? SyS_setgroups+0xdf/0xdf
[<ffffffff810594b0>] kthread+0xb5/0xbd
[<ffffffff813a84b1>] ? __wait_for_common+0x13b/0x170
[<ffffffff810593fb>] ? __kthread_parkme+0x5c/0x5c
[<ffffffff813b147c>] ret_from_fork+0x7c/0xb0
Fixes: 5b8f15f78e6f ("net: cdc_mbim: handle IPv6 Neigbor Solicitations")
[ Upstream commit 83d3459a5928f18c9344683e31bc2a7c3c25562a ]
Carrying out PCI speed/width checks through pcie_get_minimum_link()
on VFs yield wrong results, so remove them.
Fixes: b912b2f ('net/mlx4_core: Warn if device doesn't have enough PCI bandwidth')
Signed-off-by: Eyal Perry <eyalpe@mellanox.com>
[ Upstream commit 9becd707841207652449a8dfd90fe9c476d88546 ]
Commit 4d619f625a60 ("net: cdc_ncm: no point in filling up the NTBs
if we send ZLPs") changed the padding logic for devices with the ZLP
flag set. This meant that frames of any size will be sent without
additional padding, except for the single byte added if the size is
a multiple of the USB packet size. But if the unpadded size is
identical to the maximum frame size, and the maximum size is a
multiplum of the USB packet size, then this one-byte padding will
overflow the buffer.
Prevent padding if already at maximum frame size, letting usbnet
transmit a ZLP instead in this case.
Fixes: 4d619f625a60 ("net: cdc_ncm: no point in filling up the NTBs if we send ZLPs")
Reported by: Yu-an Shih <yshih@nvidia.com>
[ Upstream commit f114890cdf84d753f6b41cd0cc44ba51d16313da ]
This reverts commit 12a2856b604476c27d85a5f9a57ae1661fc46019.
The commit above doesn't appear to be necessary any more as the
checksums appear to be correctly computed/validated.
Additionally the above commit breaks kvm configurations where
one VM is using a device that support checksum offload (virtio) and
the other VM does not.
In this case, packets leaving virtio device will have CHECKSUM_PARTIAL
set. The packets is forwarded to a macvtap that has offload features
turned off. Since we use CHECKSUM_UNNECESSARY, the host does does not
update the checksum and thus a bad checksum is passed up to
the guest.
CC: Daniel Lezcano <daniel.lezcano@free.fr>
CC: Patrick McHardy <kaber@trash.net>
CC: Andrian Nord <nightnord@gmail.com>
CC: Eric Dumazet <eric.dumazet@gmail.com>
CC: Michael S. Tsirkin <mst@redhat.com>
CC: Jason Wang <jasowang@redhat.com>
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Jason Wang <jasowang@redhat.com>
[ Upstream commit cbdb04279ccaefcc702c8757757eea8ed76e50cf ]
The following is a problematic configuration:
VM1: virtio-net device connected to macvtap0@eth0
VM2: e1000 device connect to macvtap1@eth0
The problem is is that virtio-net supports checksum offloading
and thus sends the packets to the host with CHECKSUM_PARTIAL set.
On the other hand, e1000 does not support any acceleration.
For small TCP packets (and this includes the 3-way handshake),
e1000 ends up receiving packets that only have a partial checksum
set. This causes TCP to fail checksum validation and to drop
packets. As a result tcp connections can not be established.
Commit 3e4f8b787370978733ca6cae452720a4f0c296b8
macvtap: Perform GSO on forwarding path.
fixes this issue for large packets wthat will end up undergoing GSO.
This commit adds a check for the non-GSO case and attempts to
compute the checksum for partially checksummed packets in the
non-GSO case.
[ Upstream commit ddcde142bed44490e338ed1124cb149976d355bb ]
With commit cc9fa74e2a ("slip/slcan: added locking in wakeup function") a
formerly missing locking was added to slip.c and slcan.c by Andre Naujoks.
Alexander Stein contributed the fix 367525c8c2 ("can: slcan: Fix spinlock
variant") as the kernel lock debugging advised to use spin_lock_bh() instead
of just using spin_lock().
This fix has to be applied to the same code section in slip.c for the same
reason too.
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
[ Upstream commit 6f10c5d1b1aeddb63d33070abb8bc5a177beeb1f ]
Dan writes:
"The Dell drivers use the same configuration for PIDs:
81A2: Dell Wireless 5806 Gobi(TM) 4G LTE Mobile Broadband Card
81A3: Dell Wireless 5570 HSPA+ (42Mbps) Mobile Broadband Card
81A4: Dell Wireless 5570e HSPA+ (42Mbps) Mobile Broadband Card
81A8: Dell Wireless 5808 Gobi(TM) 4G LTE Mobile Broadband Card
81A9: Dell Wireless 5808e Gobi(TM) 4G LTE Mobile Broadband Card
These devices are all clearly Sierra devices, but are also definitely
Gobi-based. The A8 might be the MC7700/7710 and A9 is likely a MC7750.
>From DellGobi5kSetup.exe from the Dell drivers:
usbif0: serial/firmware loader?
usbif2: nmea
usbif3: modem/ppp
usbif8: net/QMI"
Reported-by: AceLan Kao <acelan.kao@canonical.com>
Reported-by: Dan Williams <dcbw@redhat.com>
[ Upstream commit 41be7d90993b1502d445bfc59e58348c258ce66a ]
A number of older CMOTech modems are based on Qualcomm
chips and exporting a QMI/wwan function.
[ Upstream commit 75573660c47a0db7cc931dcf154945610e02130a ]
Device interface layout:
0: ff/ff/ff - serial
1: ff/00/00 - serial AT+PPP
2: ff/ff/ff - QMI/wwan
3: 08/06/50 - storage
[ Upstream commit efc0b25c3add97717ece57bf5319792ca98f348e ]
1: ff/ff/ff - serial AT+PPP
2: 08/06/50 - storage
3: ff/ff/ff - serial
4: ff/ff/ff - QMI/wwan
Reported-by: Julio Araujo <julio.araujo@wllctel.com.br>
