[ Upstream commit ca29fd7cce5a6444d57fb86517589a1a31c759e1 ]
When process the outbound packet of ipv6, we should assign the master
device to output device other than input device.
Signed-off-by: Keefe Liu <liuqifa@huawei.com>
Acked-by: Mahesh Bandewar <maheshb@google.com>
[ Upstream commit 45ab4b13e46325d00f4acdb365d406e941a15f81 ]
The mss variable tracks the last max segment size sent to the TSO
engine. We do not update the hardware as long as we receive skb:s with
the same value in gso_size.
During a network device down/up cycle (mapped to stmmac_release() and
stmmac_open() callbacks) we issue a reset to the hardware and it
forgets the setting for mss. However we did not zero out our mss
variable so the next transmission of a gso packet happens with an
undefined hardware setting.
This triggers a hang in the TSO engine and eventuelly the netdev
watchdog will bark.
Fixes: f748be531d70 ("stmmac: support new GMAC4")
Signed-off-by: Lars Persson <larper@axis.com>
[ Upstream commit a4abd7a80addb4a9547f7dfc7812566b60ec505c ]
The qmi_wwan minidriver support a 'raw-ip' mode where frames are
received without any ethernet header. This causes alignment issues
because the skbs allocated by usbnet are "IP aligned".
Fix by allowing minidrivers to disable the additional alignment
offset. This is implemented using a per-device flag, since the same
minidriver also supports 'ethernet' mode.
Fixes: 32f7adf633b9 ("net: qmi_wwan: support "raw IP" mode")
Reported-and-tested-by: Jay Foster <jay@systech.com>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
[ Upstream commit f9409e7f086fa6c4623769b4b2f4f17a024d8143 ]
Quectel BG96 is an Qualcomm MDM9206 based IoT modem, supporting both
CAT-M and NB-IoT. Tested hardware is BG96 mounted on Quectel development
board (EVB). The USB id is added to qmi_wwan.c to allow QMI
communication with the BG96.
Signed-off-by: Sebastian Sjoholm <ssjoholm@mac.com>
Acked-by: Bjørn Mork <bjorn@mork.no>
[ Upstream commit 67bd52386125ce1159c0581cbcd2740addf33cd4 ]
hwsim_new_radio_nl() now copies the name attribute in order to add a
null-terminator. mac80211_hwsim_new_radio() (indirectly) copies it
again into the net_device structure, so the first copy is not used or
freed later. Free the first copy before returning.
Fixes: ff4dd73dd2b4 ("mac80211_hwsim: check HWSIM_ATTR_RADIO_NAME length")
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
[ Upstream commit 068d9f90a6978c3e3a662d9e85204a7d6be240d2 ]
The amount of TX/RX buffers that the vNIC driver currently allocates
is different from the amount agreed upon in negotiation with firmware.
Correct that by allocating the requested number of buffers confirmed
by firmware.
Signed-off-by: Thomas Falcon <tlfalcon@linux.vnet.ibm.com>
[ Upstream commit 142c0ac445792c492579cb01f1cfd4e32e6dfcce ]
Use a counter to track the number of outstanding transmissions sent
that have not received completions. If the counter reaches the maximum
number of queue entries, stop transmissions on that queue. As we receive
more completions from firmware, wake the queue once the counter reaches
an acceptable level.
This patch prevents hardware/firmware TX queue from filling up and
and generating errors. Since incorporating this fix, internal testing
has reported that these firmware errors have stopped.
[ Upstream commit 78d5505432436516456c12abbe705ec8dee7ee2b ]
On failure to configure a VF MAC/VLAN filter we should not attempt to
rollback filters that we failed to configure with -EEXIST.
Signed-off-by: Michal Schmidt <mschmidt@redhat.com>
[ Upstream commit 83bd9eb8fc69cdd5135ed6e1f066adc8841800fd ]
VFs are currently missing the VLAN filtering feature, because we were
checking the PF's acquire response before actually performing the acquire.
Fix it by setting the feature flag later when we have the PF response.
[ Upstream commit 22118d861cec5da6ed525aaf12a3de9bfeffc58f ]
It is too late to check for the limit of the number of VF multicast
addresses after they have already been copied to the req->multicast[]
array, possibly overflowing it.
Do the check before copying.
Also fix the error path to not skip unlocking vf2pf_mutex.
[ Upstream commit 466e8bf10ac104d96e1ea813e8126e11cb72ea20 ]
It is possible to crash the kernel by accessing a PTP device while its
associated bnx2x interface is down. Before the interface is brought up,
the timecounter is not initialized, so accessing it results in NULL
dereference.
Fix it by checking if the interface is up.
Use -ENETDOWN as the error code when the interface is down.
-EFAULT in bnx2x_ptp_adjfreq() did not seem right.
Tested using phc_ctl get/set/adj/freq commands.
[ Upstream commit 239870f2a0ebf75cc8f6d987dc528c5243f93d69 ]
Signed-off-by: Maarten Blomme <Maarten.Blomme@flir.com>
[ Upstream commit 4342696df764ec65dcdfbd0c10d90ea52505f8ba ]
commit 5c3de777bdaf48bd0cfb43097c0d0fb85056cab7 upstream.
In the function brcmf_sdio_firmware_callback() the driver is
unbound from the sdio function devices in the error path.
However, the order in which it is done resulted in a use-after-free
issue (see brcmf_ops_sdio_remove() in bcmsdh.c). Hence change
the order and first unbind sdio function #2 device and then
unbind sdio function #1 device.
Fixes: 7a51461fc2da ("brcmfmac: unbind all devices upon failure in firmware callback")
Reported-by: Stefan Wahren <stefan.wahren@i2se.com>
Reviewed-by: Hante Meuleman <hante.meuleman@broadcom.com>
Reviewed-by: Pieter-Paul Giesberts <pieter-paul.giesberts@broadcom.com>
Reviewed-by: Franky Lin <franky.lin@broadcom.com>
Signed-off-by: Arend van Spriel <arend.vanspriel@broadcom.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit 12147edc434c9e4c7c2f5fee2e5519b2e5ac34ce upstream.
In mcba_usb, we have observed that when you unplug the device, the driver will
endlessly resubmit failing URBs, which can cause CPU stalls. This issue
is fixed in mcba_usb by catching the codes seen on device disconnect
(-EPIPE and -EPROTO).
This driver also resubmits in the case of -EPIPE and -EPROTO, so fix it
in the same way.
Signed-off-by: Martin Kelly <mkelly@xevo.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit 7a31ced3de06e9878e4f9c3abe8f87d9344d8144 upstream.
in the same way.
commit bd352e1adfe0d02d3ea7c8e3fb19183dc317e679 upstream.
in the same way.
commit 6aa8d5945502baf4687d80de59b7ac865e9e666b upstream.
in the same way.
commit 8bd13bd522ff7dfa0eb371921aeb417155f7a3be upstream.
Avoid flooding the kernel log with "Formate error", if incomplete message
are received.
Signed-off-by: Jimmy Assarsson <jimmyassarsson@gmail.com>
commit e84f44eb5523401faeb9cc1c97895b68e3cfb78d upstream.
The conditon in the while-loop becomes true when actual_length is less than
2 (MSG_HEADER_LEN). In best case we end up with a former, already
dispatched msg, that got msg->len greater than actual_length. This will
result in a "Format error" error printout.
Problem seen when unplugging a Kvaser USB device connected to a vbox guest.
warning: comparison between signed and unsigned integer expressions
[-Wsign-compare]
commit 435019b48033138581a6171093b181fc6b4d3d30 upstream.
The allocated buffer was not freed if usb_submit_urb() failed.
commit f6c23b174c3c96616514827407769cbcfc8005cf upstream.
After commit d75b1ade567f ("net: less interrupt masking in NAPI") napi
repoll is done only when work_done == budget.
So we need to return budget if there are still packets to receive.
Signed-off-by: Oliver Stäbler <oliver.staebler@bytesatwork.ch>
commit d86b5672b1adb98b4cdd6fbf0224bbfb03db6e2e upstream.
Unavoidable crashes in netfront_resume() and netback_changed() after a
previous fail in talk_to_netback() (e.g. when we fail to read MAC from
xenstore) were discovered. The failure path in talk_to_netback() does
unregister/free for netdev but we don't reset drvdata and we try accessing
it after resume.
Fix the bug by removing the whole xen device completely with
device_unregister(), this guarantees we won't have any calls into netfront
after a failure.
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
[ Upstream commit 01f8902bcf3ff124d0aeb88a774180ebcec20ace ]
Fix hardware setup of multicast address hash:
- Never clear the hardware hash (to avoid packet loss)
- Construct the hash register values in software and then write once
to hardware
Signed-off-by: Rui Sousa <rui.sousa@nxp.com>
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
[ Upstream commit ebf692f85ff78092cd238166d8d7ec51419f9c02 ]
This patch fixes an issue where the type of counters in the queue(s)
and interface are not in sync (queue counters are int, interface
counters are long), causing incorrect reporting of tx/rx values
of the vif interface and unclear counter overflows.
This patch sets both counters to the u64 type.
Signed-off-by: Mart van Santen <mart@greenhost.nl>
Reviewed-by: Paul Durrant <paul.durrant@citrix.com>
[ Upstream commit e2e004acc7cbe3c531e752a270a74e95cde3ea48 ]
This fixes a crash when running out of grant refs when creating many
queues across many netdevs.
* If creating queues fails (i.e. there are no grant refs available),
call xenbus_dev_fatal() to ensure that the xenbus device is set to the
closed state.
* If no queues are created, don't call xennet_disconnect_backend as
netdev->real_num_tx_queues will not have been set correctly.
* If setup_netfront() fails, ensure that all the queues created are
cleaned up, not just those that have been set up.
* If any queues were set up and an error occurs, call
xennet_destroy_queues() to clean up the napi context.
* If any fatal error occurs, unregister and destroy the netdev to avoid
leaving around a half setup network device.
Signed-off-by: Ross Lagerwall <ross.lagerwall@citrix.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
[ Upstream commit 4993b39ab04b083ff6ee1147e7e7f120feb6bf7f ]
Recent commit 34393529163a ("be2net: fix MAC addr setting on privileged
BE3 VFs") allows privileged BE3 VFs to set its MAC address during
initialization. Although the initial MAC for such VFs is already
programmed by parent PF the subsequent setting performed by VF is OK,
but in certain cases (after fresh boot) this command in VF can fail.
The MAC should be initialized only when:
1) no MAC is programmed (always except BE3 VFs during first init)
2) programmed MAC is different from requested (e.g. MAC is set when
interface is down). In this case the initial MAC programmed by PF
needs to be deleted.
The adapter->dev_mac contains MAC address currently programmed in HW so
it should be zeroed when the MAC is deleted from HW and should not be
filled when MAC is set when interface is down in be_mac_addr_set() as
no programming is performed in this case.
Example of failure without the fix (immediately after fresh boot):
# ip link set eth0 up <- eth0 is BE3 PF
be2net 0000:01:00.0 eth0: Link is Up
# echo 1 > /sys/class/net/eth0/device/sriov_numvfs <- Create 1 VF
be2net 0000:01:04.0: Emulex OneConnect(be3): VF port 0
# ip link set eth8 up <- eth8 is created privileged VF
be2net 0000:01:04.0: opcode 59-1 failed:status 1-76
RTNETLINK answers: Input/output error
# echo 0 > /sys/class/net/eth0/device/sriov_numvfs <- Delete VF
iommu: Removing device 0000:01:04.0 from group 33
# echo 1 > /sys/class/net/eth0/device/sriov_numvfs <- Create it again
be2net 0000:01:04.0 eth8: Link is Up
Initialization is now OK.
v2 - Corrected the comment and condition check suggested by Suresh & Harsha
Fixes: 34393529163a ("be2net: fix MAC addr setting on privileged BE3 VFs")
Cc: Sathya Perla <sathya.perla@broadcom.com>
Cc: Ajit Khaparde <ajit.khaparde@broadcom.com>
Cc: Sriharsha Basavapatna <sriharsha.basavapatna@broadcom.com>
Cc: Somnath Kotur <somnath.kotur@broadcom.com>
Signed-off-by: Ivan Vecera <cera@cera.cz>
Acked-by: Sriharsha Basavapatna <sriharsha.basavapatna@broadcom.com>
[ Upstream commit c73e44269369e936165f0f9b61f1f09a11dae01c ]
This fixes the following smatch and coccinelle warnings:
drivers/net/ethernet/cavium/thunder/thunder_xcv.c:119 xcv_setup_link() error: we previously assumed 'xcv' could be null (see line 118) [smatch]
drivers/net/ethernet/cavium/thunder/thunder_xcv.c:119:16-20: ERROR: xcv is NULL but dereferenced. [coccinelle]
Fixes: 6465859aba1e66a5 ("net: thunderx: Add RGMII interface type support")
Signed-off-by: Vincent Stehlé <vincent.stehle@laposte.net>
Cc: Sunil Goutham <sgoutham@cavium.com>
[ Upstream commit cf626c3b252b2c9d131be0dd66096ec3bf729e54 ]
As pr commit "net: phy: phy drivers should not set SUPPORTED_[Asym_]Pause"
this phy driver should not set these feature bits.
Signed-off-by: Sean Nyekjaer <sean.nyekjaer@prevas.dk>
Fixes: 9d162ed69f51 ("net: phy: micrel: add support for KSZ8795")
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit 3ab1b469e847ba425af3c5ad5068cc94b55b38d0 ]
The use of the passed through netlink src_net to check for a
cross netns operation was wrong. Using the GTP socket and the
GTP netdevice is always correct (even if the netdev has been
moved to new netns after link creation).
Remove the now obsolete net field from gtp_dev.
Signed-off-by: Andreas Schultz <aschultz@tpip.net>
Acked-by: Pablo Neira Ayuso <pablo@netfilter.org>
[ Upstream commit c6ce1d08eede4c2968ed08aafa3165e8e183c5a1 ]
3GPP TS 29.281 and 3GPP TS 29.060 imply that GTP-U packets should be
sent with the DF bit cleared. For example 3GPP TS 29.060, Release 8,
Section 13.2.2:
> Backbone router: Any router in the backbone may fragment the GTP
> packet if needed, according to IPv4.
Acked-by: Harald Welte <laforge@netfilter.org>
[ Upstream commit 18a3ed59d09cf81a6447aadf6931bf0c9ffec5e0 ]
Remove Rx overflow log messages as in an environment where logging results
in network traffic logging may cause further overflows.
Fixes: c156633f1353 ("Renesas Ethernet AVB driver proper")
Signed-off-by: Kazuya Mizuguchi <kazuya.mizuguchi.ks@renesas.com>
[simon: reworked changelog]
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Acked-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
[ Upstream commit ce7e40c432ba84da104438f6799d460a4cad41bc ]
ipddp_route structs contain alignment padding so kernel heap memory
is leaked when they are copied to user space in
ipddp_ioctl(SIOCFINDIPDDPRT). Change kmalloc() to kzalloc() to clear
that memory.
Signed-off-by: Vlad Tsyrklevich <vlad@tsyrklevich.net>
[ Upstream commit 6052cd1af86f9833b6b0b60d5d4787c4a06d65ea ]
The adapter->pmac_id[0] item is used for primary MAC address but
this is not true for adapter->uc_list[0] as is assumed in
be_set_uc_list(). There are N UC addresses copied first from net_device
to adapter->uc_list[1..N] and then N UC addresses from
adapter->uc_list[0..N-1] are sent to HW. So the last UC address is never
stored into HW and address 00:00:00:00;00:00 (from uc_list[0]) is used
instead.
Fixes: b717241 be2net: replace polling with sleeping in the FW completion path
[ Upstream commit 1d0f110a2c6c4bca3dbcc4b0e27f1e3dc2d44a2c ]
Commit 988d44b "be2net: Avoid redundant addition of mac address in HW"
introduced be_dev_mac_add & be_uc_mac_add helpers that incorrectly
access adapter->uc_list as an array of bytes instead of an array of
be_eth_addr. Consequently NIC is not filled with valid data so unicast
filtering is broken.
Fixes: 988d44b be2net: Avoid redundant addition of mac address in HW
[ Upstream commit 38e5a85562a6cd911fc26d951d576551a688574c ]
Inserting the TSB means adding an extra 8 bytes in front the of packet
that is going to be used as metadata information by the TDMA engine, but
stripped off, so it does not really help with the packet padding.
For some odd packet sizes that fall below the 60 bytes payload (e.g: ARP)
we can end-up padding them after the TSB insertion, thus making them 64
bytes, but with the TDMA stripping off the first 8 bytes, they could
still be smaller than 64 bytes which is required to ingress the switch.
Fix this by swapping the padding and TSB insertion, guaranteeing that
the packets have the right sizes.
Fixes: 80105befdb4b ("net: systemport: add Broadcom SYSTEMPORT Ethernet MAC driver")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit bb7da333d0a9f3bddc08f84187b7579a3f68fd24 ]
Since we need to pad our packets, utilize skb_put_padto() which
increases skb->len by how much we need to pad, allowing us to eliminate
the test on skb->len right below.
[ Upstream commit a9a8cdb368d99bb655b5cdabea560446db0527cc ]
ip6_route_output() never returns NULL so
check dst->error instead of !dst.
Signed-off-by: Varun Prakash <varun@chelsio.com>
[ Upstream commit 61b6034c6cfdcb265bb453505c3d688e7567727a ]
is_power_of_2 expects unsigned long and we pass u64 max_val_cycles,
this will be truncated on 32 bit systems, and the result is not what we
were expecting.
div_u64 expects u32 as a second argument and we pass
max_val_cycles_rounded which is u64 hence it will always be truncated.
Fix was tested on both 64 and 32 bit systems and got same results for
max_val_cycles and max_val_cycles_rounded.
Fixes: 4850cf458157 ("net/mlx4_en: Resolve dividing by zero in 32-bit system")
Signed-off-by: Slava Shwartsman <slavash@mellanox.com>
Signed-off-by: Tariq Toukan <tariqt@mellanox.com>
[ Upstream commit d15697de60db5570532fdedb8e13b2251d65b8e3 ]
The driver does not check if mapping dma memory succeed.
The patch adds the checks and failure handling.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
[ Upstream commit 7cfe0455ee1218add152e986b89b4bb8dbeafcdd ]
The cts protection vdev parameter, in new QCA9377 TF2.0 firmware,
requires bss peer to be created for the STATION vdev type.
bss peer is being allocated by the firmware after vdev_start/_up commands.
mac80211 may call the cts protection setup at any time, so the
we needs to track the situation and defer the cts configuration
to prevent firmware asserts, like below:
[00]: 0x05020001 0x000015B3 0x0099ACE2 0x00955B31
[04]: 0x0099ACE2 0x00060730 0x00000004 0x00000000
[08]: 0x0044C754 0x00412C10 0x00000000 0x00409C54
[12]: 0x00000009 0x00000000 0x00952F6C 0x00952F77
[16]: 0x00952CC4 0x00910712 0x00000000 0x00000000
[20]: 0x4099ACE2 0x0040E858 0x00421254 0x004127F4
[24]: 0x8099B9B2 0x0040E8B8 0x00000000 0xC099ACE2
[28]: 0x800B75CB 0x0040E8F8 0x00000007 0x00005008
[32]: 0x809B048A 0x0040E958 0x00000010 0x00433B10
[36]: 0x809AFBBC 0x0040E9A8 0x0042BB74 0x0042BBBC
[40]: 0x8091D252 0x0040E9C8 0x0042BBBC 0x00000001
[44]: 0x809FFA45 0x0040EA78 0x0043D3E4 0x0042C2C8
[48]: 0x809FCEF4 0x0040EA98 0x0043D3E4 0x00000001
[52]: 0x80911210 0x0040EAE8 0x00000010 0x004041D0
[56]: 0x80911154 0x0040EB28 0x00400000 0x00000000
Signed-off-by: Bartosz Markowski <bartosz.markowski@tieto.com>
Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
[ Upstream commit 486b5c22ea1d35e00e90dd79a32a9ee530b18915 ]
With the added support for the bnxt_re RDMA driver, both drivers can be
allocating completion rings in any order. The firmware does not know
which completion ring should be receiving async events. Add an
extra step to tell firmware the completion ring number for receiving
async events after bnxt_en allocates the completion rings.
Signed-off-by: Michael Chan <michael.chan@broadcom.com>
[ Upstream commit 097e46d2ae90265d1afe141ba6208ba598b79e01 ]
ath10k_wmi_tlv_op_pull_fw_stats() uses tb = ath10k_wmi_tlv_parse_alloc(...)
function, which allocates memory. If any of the three error-paths are
taken, this tb needs to be freed.
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
[ Upstream commit d2e202c06ca42d353d95df12437740921a6d05b5 ]
With command to get board_id from otp, in the case of following
boot get otp board id result 0x00000000 board_id 0 chip_id 0
boot using board name 'bus=pci,bmi-chip-id=0,bmi-board-id=0"
failed to fetch board data for bus=pci,bmi-chip-id=0,bmi-board-id=0 from
ath10k/QCA6174/hw3.0/board-2.bin
The invalid board_id=0 will be used as index to search in the board-2.bin.
Ignore the case with board_id=0, as it means the otp is not carrying
the board id information.
Signed-off-by: Ryan Hsu <ryanhsu@qca.qualcomm.com>
[ Upstream commit 88407beb1b1462f706a1950a355fd086e1c450b6 ]
Ath10k reports the phy capability that supports P2P_DEVICE interface.
When we use the P2P supported wpa_supplicant to start connection, it'll
create two interfaces, one is wlan0 (vdev_id=0) and one is P2P_DEVICE
p2p-dev-wlan0 which is for p2p control channel (vdev_id=1).
ath10k_pci mac vdev create 0 (add interface) type 2 subtype 0
ath10k_add_interface: vdev_id: 0, txpower: 0, bss_power: 0
ath10k_pci mac vdev create 1 (add interface) type 2 subtype 1
ath10k_add_interface: vdev_id: 1, txpower: 0, bss_power: 0
And the txpower in per vif bss_conf will only be set to valid tx power when
the interface is assigned with channel_ctx.
But this P2P_DEVICE interface will never be used for any connection, so
that the uninitialized bss_conf.txpower=0 is assinged to the
arvif->txpower when interface created.
Since the txpower configuration is firmware per physical interface.
So the smallest txpower of all vifs will be the one limit the tx power
of the physical device, that causing the low txpower issue on other
active interfaces.
wlan0: Limiting TX power to 21 (24 - 3) dBm
ath10k_pci mac vdev_id 0 txpower 21
ath10k_mac_txpower_recalc: vdev_id: 1, txpower: 0
ath10k_mac_txpower_recalc: vdev_id: 0, txpower: 21
ath10k_pci mac txpower 0
This issue only happens when we use the wpa_supplicant that supports
P2P or if we use the iw tool to create the control P2P_DEVICE interface.
[ Upstream commit 74c8719b8ee0922593a5cbec0bd6127d86d8a2f4 ]
If we have sdio work requests received when sdio card reset is
happening, we may end up accessing older save_adapter pointer
later which is already freed during card reset.
This patch solves the problem by cancelling those pending requests.
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
[ Upstream commit c705a6b3aa7804d7bc6660183f51e510c61dc807 ]
We accidentally return success when adm8211_alloc_rings() fails but we
should preserve the error code.
Fixes: cc0b88cf5ecf ("[PATCH] Add adm8211 802.11b wireless driver")
[ Upstream commit a51b89698ccc93c7e274eb71377fae49c4593ab2 ]
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
[ Upstream commit 107fded7bf616ad6f46823d98b8ed6405d7adf2d ]
In a few cases the err-variable is not set to a negative error code if a
function call in typhoon_init_one() fails and thus 0 is returned
instead.
It may be better to set err to the appropriate negative error
code before returning.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=188841
Reported-by: Pan Bian <bianpan2016@163.com>
Signed-off-by: Thomas Preisner <thomas.preisner+linux@fau.de>
Signed-off-by: Milan Stephan <milan.stephan+linux@fau.de>
[ Upstream commit 6b6bbb5922a4b1d4b58125a572da91010295fba3 ]
In some cases the return value of a failing function is not being used
and the function typhoon_init_one() returns another negative error code
instead.
