path: root/drivers/nubus
2018-07-23nubus: Set default dma mask for nubus_board devicesFinn Thain
A 32-bit mask is used by default because a NuBus slot has 32 address/data lines and a NuBus board is free to use all of them. Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2018-06-05Merge tag 'char-misc-4.18-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here is the "big" char and misc driver patches for 4.18-rc1. It's not a lot of stuff here, but there are some highlights: - coreboot driver updates - soundwire driver updates - android binder updates - fpga big sync, mostly documentation - lots of minor driver updates All of these have been in linux-next for a while with no reported issues" * tag 'char-misc-4.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (81 commits) vmw_balloon: fixing double free when batching mode is off MAINTAINERS: Add driver-api/fpga path fpga: clarify that unregister functions also free documentation: fpga: move fpga-region.txt to driver-api documentation: fpga: add bridge document to driver-api documentation: fpga: move fpga-mgr.txt to driver-api Documentation: fpga: move fpga overview to driver-api fpga: region: kernel-doc fixes fpga: bridge: kernel-doc fixes fpga: mgr: kernel-doc fixes fpga: use SPDX fpga: region: change api, add fpga_region_create/free fpga: bridge: change api, don't use drvdata fpga: manager: change api, don't use drvdata fpga: region: don't use drvdata in common fpga code Drivers: hv: vmbus: Removed an unnecessary cast from void * ver_linux: Drop redundant calls to system() to test if file is readable ver_linux: Move stderr redirection from function parameter to function body misc: IBM Virtual Management Channel Driver (VMC) rpmsg: Correct support for MODULE_DEVICE_TABLE() ...
2018-05-16proc: introduce proc_create_single{,_data}Christoph Hellwig
Variants of proc_create{,_data} that directly take a seq_file show callback and drastically reduces the boilerplate code in the callers. All trivial callers converted over. Signed-off-by: Christoph Hellwig <hch@lst.de>
2018-05-14nubus: Call bus_register unconditionallyFinn Thain
Loading a NuBus driver module on a non-NuBus machine triggers the BUG_ON(!drv->bus->p) in driver_register(), because bus_register() was not called, because it is conditional on MACH_IS_MAC. Fix the crash by calling bus_register() unconditionally. Call it from a postcore_initcall(), like other busses do. Hence, the bus type is available for device_register(), which happens in a subsys initcall, and for driver_register(), which happens in a device or module initcall. Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Reported-by: Michael Schmitz <schmitzmic@gmail.com> Tested-by: Stan Johnson <userm57@yahoo.com> Fixes: 7f86c765a6a2 ("nubus: Add support for the driver model") Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-16nubus: Add support for the driver modelFinn Thain
This patch brings basic support for the Linux Driver Model to the NuBus subsystem. For flexibility, the matching of boards with drivers is left up to the drivers. This is also the approach taken by NetBSD. A board may have many functions, and drivers may have to consider many functional resources and board resources in order to match a device. This implementation does not bind drivers to resources (nor does it bind many drivers to the same board). Apple's NuBus declaration ROM design is flexible enough to allow that, but I don't see a need to support it as we don't use the "slot zero" resources (in the main logic board ROM). Eliminate the global nubus_boards linked list by rewriting the procfs board iterator around bus_for_each_dev(). Hence the nubus device refcount can be used to determine the lifespan of board objects. Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2018-01-16nubus: Adopt standard linked list implementationFinn Thain
This increases code re-use and improves readability. Cc: "David S. Miller" <davem@davemloft.net> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2018-01-16nubus: Rename struct nubus_devFinn Thain
It is misleading to call a functional resource a "device". In adopting the Linux Driver Model, the struct device will be embedded in struct nubus_board. That will compound the terminlogy problem because drivers will bind with boards, not with functional resources. Avoid this by renaming struct nubus_dev as struct nubus_rsrc. "Functional resource" is the vendor's terminology so this helps avoid confusion. Cc: "David S. Miller" <davem@davemloft.net> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2018-01-16nubus: Rework /proc/bus/nubus/s/ implementationFinn Thain
The /proc/bus/nubus/s/ directory tree for any slot s is missing a lot of information. The struct file_operations methods have long been left unimplemented (hence the familiar compile-time warning, "Need to set some I/O handlers here"). Slot resources have a complex structure which varies depending on board function. The logic for interpreting these ROM data structures is found in nubus.c. Let's not duplicate that logic in proc.c. Create the /proc/bus/nubus/s/ inodes while scanning slot s. During descent through slot resource subdirectories, call the new nubus_proc_add_foo() functions to create the procfs inodes. Also add a new function, nubus_seq_write_rsrc_mem(), to write the contents of a particular slot resource to a given seq_file. This is used by the procfs file_operations methods, to finally give userspace access to slot ROM information, such as the available video modes. Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2018-01-16nubus: Generalize block resource handlingFinn Thain
Scrap the specialized code to unpack video mode name resources and driver resources. It isn't useful. Instead, add a re-usable function to handle lists of block resources of any kind, and descend into the video mode table resource directory. Rename callers as nubus_get_foo(), consistent with their purpose and with related functions in the same file. Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2018-01-16nubus: Remove redundant codeFinn Thain
Eliminate unused values from struct nubus_dev to save wasted memory (a Radius PrecisionColor 24X card has about 95 functional resources and up to six such cards may be fitted). Also remove redundant static variable initialization, an unreachable !MACH_IS_MAC conditional, the unused nubus_find_device() function, the bogus get_nubus_list() prototype and the pointless card_present temporary variable. Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2018-01-16nubus: Call proc_mkdir() not more than once per slot directoryFinn Thain
This patch fixes the following WARNING. proc_dir_entry 'nubus/a' already registered Modules linked in: CPU: 0 PID: 1 Comm: swapper Tainted: G W 4.13.0-00036-gd57552077387 #1 Stack from 01c1bd9c: 01c1bd9c 003c2c8b 01c1bdc0 0001b0fe 00000000 00322f4a 01c43a20 01c43b0c 01c8c420 01c1bde8 0001b1b8 003a4ac3 00000148 000faa26 00000009 00000000 01c1bde0 003a4b6c 01c1bdfc 01c1be20 000faa26 003a4ac3 00000148 003a4b6c 01c43a71 01c8c471 01c10000 00326430 0043d00c 00000005 01c71a00 0020bce0 00322964 01c1be38 000fac04 01c43a20 01c8c420 01c1bee0 01c8c420 01c1be50 000fac4c 01c1bee0 00000000 01c43a20 00000000 01c1bee8 0020bd26 01c1bee0 Call Trace: [<0001b0fe>] __warn+0xae/0xde [<00322f4a>] memcmp+0x0/0x5c [<0001b1b8>] warn_slowpath_fmt+0x2e/0x36 [<000faa26>] proc_register+0xbe/0xd8 [<000faa26>] proc_register+0xbe/0xd8 [<00326430>] sprintf+0x0/0x20 [<0020bce0>] nubus_proc_attach_device+0x0/0x1b8 [<00322964>] strcpy+0x0/0x22 [<000fac04>] proc_mkdir_data+0x64/0x96 [<000fac4c>] proc_mkdir+0x16/0x1c [<0020bd26>] nubus_proc_attach_device+0x46/0x1b8 [<0020bce0>] nubus_proc_attach_device+0x0/0x1b8 [<00322964>] strcpy+0x0/0x22 [<00001ba6>] kernel_pg_dir+0xba6/0x1000 [<004339a2>] proc_bus_nubus_add_devices+0x1a/0x2e [<000faa40>] proc_create_data+0x0/0xf2 [<0003297c>] parse_args+0x0/0x2d4 [<00433a08>] nubus_proc_init+0x52/0x5a [<00433944>] nubus_init+0x0/0x44 [<00433982>] nubus_init+0x3e/0x44 [<000020dc>] do_one_initcall+0x38/0x196 [<000020a4>] do_one_initcall+0x0/0x196 [<0003297c>] parse_args+0x0/0x2d4 [<00322964>] strcpy+0x0/0x22 [<00040004>] __up_read+0xe/0x40 [<004231d4>] repair_env_string+0x0/0x7a [<0042312e>] kernel_init_freeable+0xee/0x194 [<00423146>] kernel_init_freeable+0x106/0x194 [<00433944>] nubus_init+0x0/0x44 [<000a6000>] kfree+0x0/0x156 [<0032768c>] kernel_init+0x0/0xda [<00327698>] kernel_init+0xc/0xda [<0032768c>] kernel_init+0x0/0xda [<00002a90>] ret_from_kernel_thread+0xc/0x14 ---[ end trace 14a6d619908ea253 ]--- ------------[ cut here ]------------ This gets repeated with each additional functional reasource. The problem here is the call to proc_mkdir() when the directory already exists. Each nubus_board gets a directory, such as /proc/bus/nubus/s/ where s is the hex slot number. Therefore, store the 'procdir' pointer in struct nubus_board instead of struct nubus_dev. Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2018-01-16nubus: Validate slot resource IDsFinn Thain
While we are here, include the slot number in the related error messages. Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2018-01-16nubus: Fix log spamFinn Thain
Testing shows that a single Radius PrecisionColor 24X display board, which has 95 functional resources, produces over a thousand lines of log messages. Suppress these messages with pr_debug(). Remove some redundant messages relating to nubus_get_subdir() calls. Fix the format block debug messages as the sequence of entries is backwards (my bad). Move the "scanning slots" message to its proper location. Fixes: 71ae40e4cf33 ("nubus: Clean up printk calls") Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2018-01-16nubus: Use static functions where possibleFinn Thain
This fixes a couple of warnings from 'make W=1': drivers/nubus/nubus.c:790: warning: no previous prototype for 'nubus_probe_slot' drivers/nubus/nubus.c:824: warning: no previous prototype for 'nubus_scan_bus' Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2018-01-16nubus: Avoid array underflow and overflowFinn Thain
Check array indices. Avoid sprintf. Use buffers of sufficient size. Use appropriate types for array length parameters. Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2017-11-13Merge tag 'm68k-for-v4.15-tag1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k Pull m68k updates from Geert Uytterhoeven: - more printk modernization - various cleanups and fixes (incl. a race condition) for Mac - defconfig updates * tag 'm68k-for-v4.15-tag1' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: m68k/defconfig: Update defconfigs for v4.14-rc7 m68k/mac: Add mutual exclusion for IOP interrupt polling m68k/mac: Disentangle VIA/RBV and NuBus initialization m68k/mac: Disentangle VIA and OSS initialization m68k/mac: More printk modernization
2017-11-09m68k/mac: Disentangle VIA/RBV and NuBus initializationFinn Thain
The Nubus subsystem should not be concerned with differences between VIA, RBV and OSS platforms. It should be portable across Macs and PowerMacs. This goal has implications for the initialization code relating to bus locking and slot interrupts. During Nubus initialization, bus transactions are "unlocked": on VIA2 and RBV machines, via_nubus_init() sets a bit in the via2[gBufB] register to allow bus-mastering Nubus cards to arbitrate for the bus. This happens upon subsys_initcall(nubus_init). But because nubus_init() has no effect on card state, this sequence is arbitrary. Moreover, when Penguin is used to boot Linux, the bus is already unlocked when Linux starts. On OSS machines there's no attempt to unlock Nubus transactions at all. (Maybe there's no benefit on that platform or maybe no-one knows how.) All of this demonstrates that there's no benefit in locking out bus-mastering cards, as yet. (If the need arises, we could lock the bus for the duration of a timing-critical operation.) NetBSD unlocks the Nubus early (at VIA initialization) and we can do the same. via_nubus_init() is also responsible for some VIA interrupt setup that should happen earlier than subsys_initcall(nubus_init). And actually, the Nubus subsystem need not be involved with slot interrupts: SLOT2IRQ works fine because Nubus slot IRQs are geographically assigned (regardless of platform). For certain platforms with PDS slots, some Nubus IRQs may be platform IRQs and this is not something that the NuBus subsystem should worry about. So let's invoke via_nubus_init() earlier and make the platform responsible for bus unlocking and interrupt setup instead of the NuBus subsystem. Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14nubus: Fix pointer validationFinn Thain
Fix bounds checking on slot-space pointer movement. Remove redundant test for zero byte-lanes value. Fix broken byte-lanes vs. address validation. This patch changes the circumstances under which an error is printed to the console and fixes the address validation. The validation code should work correctly now: the broken test for a valid bytelanes value is replaced with a working test (which eliminates false negatives) and the 24-bit directory offset bounds check is fixed (which eliminates false positives). Please see "Designing Cards and Drivers for the Macintosh Family" ch. 8, "NuBus Card Firmware" for an explanation of the bytelanes check and directory offset value. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Michael Schmitz <schmitzmic@gmail.com> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2017-05-14nubus: Remove slot zero probeDavid Huggins-Daines
Some long forgotten changes from the linux-mac68k CVS: Remove the slot 0 (ROM) probing. Remove the pointless White Screen Of Death crap. The original commit is here: http://linux-mac68k.cvs.sourceforge.net/viewvc/linux-mac68k/linux-mac68k/drivers/nubus/nubus.c?r1=1.22.2.1&r2=1.22.2.2&pathrev=linux-2_2 This is mostly dead code removal. It is also a reversion to the pre-v2.3.17 version. The old code was thoroughly tested in Debian Sarge. The present code for probing fake slot resources in Apple's on-board (slot zero) ROMs could be useful if replaced the macintosh_config struct. But it can't do so and we don't want two mechanisms for identifying on-board hardware. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Michael Schmitz <schmitzmic@gmail.com> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2017-04-20nubus: Clean up whitespaceFinn Thain
Signed-off-by: Finn Thain <fthain@telegraphics.com.au> [geert: rebased] Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2017-04-20nubus: Clean up printk callsDavid Huggins-Daines
Some long forgotten changes from the linux-mac68k CVS: Fix swapped DrvrSW and DrvrHW values in printk message. Suppress debug printk messages. Avoid console_loglevel misuse. The original commits are these: http://linux-mac68k.cvs.sourceforge.net/viewvc/linux-mac68k/linux-mac68k/drivers/nubus/nubus.c?r1=1.22.2.1&r2=1.22.2.2&pathrev=linux-2_2 http://linux-mac68k.cvs.sourceforge.net/viewvc/linux-mac68k/linux-mac68k/drivers/nubus/nubus.c?r1=1.21&r2=1.22&pathrev=linux-2_2 The CVS commits fell short of removing all of the misuse of console_loglevel in nubus_add_board() so I finished the job. I've also added some missing message severity levels and converted a printk loop to the MAC address "%pM" format specifier. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2017-04-20nubus: Fix nubus_rewinddirDavid Huggins-Daines
A long forgotten fix from the linux-mac68k CVS: Initialize dir->done pointer in nubus_rewinddir(). The original commit is here: http://linux-mac68k.cvs.sourceforge.net/viewvc/linux-mac68k/linux-mac68k/drivers/nubus/nubus.c?r1=1.22&r2=1.22.2.1&pathrev=linux-2_2 Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2016-12-24Replace <asm/uaccess.h> with <linux/uaccess.h> globallyLinus Torvalds
This was entirely automated, using the script by Al: PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>' sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \ $(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h) to do the replacement at the end of the merge window. Requested-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-27nubus: Remove superfluous interrupt disable/restoreGeert Uytterhoeven
As of commit e4dc601bf99ccd1c ("m68k: Disable/restore interrupts in hwreg_present()/hwreg_write()"), this is no longer needed. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2014-06-04kernel/printk: use symbolic defines for console loglevelsBorislav Petkov
... instead of naked numbers. Stuff in sysrq.c used to set it to 8 which is supposed to mean above default level so set it to DEBUG instead as we're terminating/killing all tasks and we want to be verbose there. Also, correct the check in x86_64_start_kernel which should be >= as we're clearly issuing the string there for all debug levels, not only the magical 10. Signed-off-by: Borislav Petkov <bp@suse.de> Acked-by: Kees Cook <keescook@chromium.org> Acked-by: Randy Dunlap <rdunlap@infradead.org> Cc: Joe Perches <joe@perches.com> Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-04nubus: Kill nubus_proc_detach_device()Geert Uytterhoeven
Commit 59d8053f1e16904d54ed7469d4b36801ea6b8f2c ("proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h") broke Apple NuBus support: drivers/nubus/proc.c: In function ‘nubus_proc_detach_device’: drivers/nubus/proc.c:156: error: dereferencing pointer to incomplete type drivers/nubus/proc.c:158: error: dereferencing pointer to incomplete type Fortunately nubus_proc_detach_device() is unused, and appears to have never been used, so just remove it. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-29nubus: Don't use create_proc_read_entry()David Howells
Don't use create_proc_read_entry() as that is deprecated, but rather use proc_create_data() and seq_file instead. Signed-off-by: David Howells <dhowells@redhat.com> cc: linux-m68k@lists.linux-m68k.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-09nubus: Don't use create_proc_entry()David Howells
Don't use create_proc_entry() in nubus_proc_subdir(). The files created aren't given any way to use them, so for the moment use create_proc_read_entry() with a NULL accessor and generate a compile-time warning. Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2008-10-16nubus: fix mis-indented statementIlpo Järvinen
It seems this is the right way around because otherwise the len usage in the outer loop would be pretty pointless. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: convert /proc/bus/nubus to seq_file interfaceAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_busAlexey Dobriyan
Remove proc_bus export and variable itself. Using pathnames works fine and is slightly more understandable and greppable. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05nubus: kill drivers/nubus/nubus_syms.cAdrian Bunk
nubus: kill drivers/nubus/nubus_syms.c EXPORT_SYMBOL's belong to the actual code. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03drivers/nubus/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
