Rework of_property_read_u32 to read an array of values. Then
of_property_read_u32 becomes an inline with array size of 1.
Also make struct device_node ptr const.
The existing dt codes usually call of_get_property to get a string
property and save it as a 'const char *'. The patch adds'const' for
of_property_read_string parameter **out_string to make the converting
of existing code a little easier.
Add helper functions to retrieve unsigned integer and string property
values from properties of a device node. These helper functions can be
used to lookup a property in a device node, perform error checking and
read the property value.
[grant.likely@secretlab.ca: Proposal and initial implementation]
Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org>
[grant.likely: some word smithing and be more defensive validating the string]
There are a few use cases where it is convenient to pass NULL to
of_match_node() and have it fail gracefully. The patch adds a null
check to the beginning so taht it does so.
Use the sparse annotations so we can keep track of endianness.
Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com>
The flat tree code wasn't fixing the endianness on phandle values when
unflattening the tree, and the code in drivers/of wasn't always doing a
be32_to_cpu before trying to dereference the phandle values. This patch
fixes them.
This patch tightens up the behaviour of of_modalias_node() to be more
predicatable and to eliminate the explicit of_modalias_tablep[] that
is currently used to override the first entry in the compatible list
of a device. The override table was needed originally because spi
and i2c drivers had no way to do of-style matching. Now that all
devices can have an of_node pointer, and all drivers can have an
of_match_table, the explicit override table is no longer needed
because each driver can specify its own OF-style match data.
The mpc8349emitx-mcu driver is modified to explicitly specify the
correct device to bind against.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Rather than defining of_chosen in each arch, it can be defined for all
in driver/of/base.c
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Michal Simek <monstr@monstr.eu>
Properties in the device tree are specified as big-endian. At present,
the only platforms to support device trees are also big-endian, so we've
been acessing the properties as raw values.
We'd like to add device tree support to little-endian platforms too, so
add endian conversion to the sites where we access property values in
the common of code.
Compiled on powerpc (ppc44x_defconfig & ppc64_defconfig) and arm (fdt
support only for now).
We use a few procfs-specific functions (eg, proc_device_tree_*) which
aren't covered by the current includes. This causes the following build
error on arm:
drivers/of/base.c: In function 'prom_add_property':
drivers/of/base.c:861: error: implicit declaration of function 'proc_device_tree_add_prop'
drivers/of/base.c: In function 'prom_remove_property':
drivers/of/base.c:902: error: implicit declaration of function 'proc_device_tree_remove_prop'
drivers/of/base.c: In function 'prom_update_property':
drivers/of/base.c:946: error: implicit declaration of function 'proc_device_tree_update_prop'
Add proc_fs.h for these prototypes.
machine is compatible is an OF-specific call. It should have
the of_ prefix to protect the global namespace.
Merge common function between powerpc, sparc and microblaze. Code is
identical for powerpc and microblaze, but adds a lock (and release) of
the devtree_lock on sparc.
Merge common code between PowerPC and Microblaze
Tested-by: Wolfram Sang <w.sang@pengutronix.de>
Merge common code between PowerPC and MicroBlaze
Reviewed-by: Wolfram Sang <w.sang@pengutronix.de>
Tested-by: Michal Simek <monstr@monstr.eu>
Merge common code between Microblaze and PowerPC, and make it available
to Sparc
Acked-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com>
Acked-by: Stephen Rothwell <sfr@canb.auug.org.au>
The alias isn't needed any longer since the m25p80 driver converted to the
module device table matching.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: Ben Dooks <ben-linux@fluff.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1244 commits)
pkt_sched: Rename PSCHED_US2NS and PSCHED_NS2US
ipv4: Fix fib_trie rebalancing
Bluetooth: Fix issue with uninitialized nsh.type in DTL-1 driver
Bluetooth: Fix Kconfig issue with RFKILL integration
PIM-SM: namespace changes
ipv4: update ARPD help text
net: use a deferred timer in rt_check_expire
ieee802154: fix kconfig bool/tristate muckup
bonding: initialization rework
bonding: use is_zero_ether_addr
bonding: network device names are case sensative
bonding: elminate bad refcount code
bonding: fix style issues
bonding: fix destructor
bonding: remove bonding read/write semaphore
bonding: initialize before registration
bonding: bond_create always called with default parameters
x_tables: Convert printk to pr_err
netfilter: conntrack: optional reliable conntrack event delivery
list_nulls: add hlist_nulls_add_head and hlist_nulls_del
For serial flash support we need to:
- Add QE Par IO Bank E device tree node, a GPIO from this bank is
used for SPI chip-select line;
- Add serial-flash node;
- Add proper module alias into of/base.c.
of_parse_phandle() is a helper function to read and parse a phandle
property and return a pointer to the resulting device_node.
Acked-by: Andy Fleming <afleming@freescale.com>
The bindings describes a case where MMC/SD/SDIO slot directly connected to
a SPI bus. Such setups are widely used on embedded PowerPC boards.
The patch also adds the mmc-spi-slot entry to the OpenFirmware modalias
table.
Cc: David Brownell <david-b@pacbell.net>
Cc: Kumar Gala <galak@gate.crashing.org>
Given this list (contains three gpio specifiers, one of which is a hole):
gpios = <&phandle1 1 2 3
0 /* a hole */
&phandle2 4 5 6>;
of_parse_phandles_with_args() would report -ENOENT for the `hole'
specifier item, the same error value is used to report the end of the
list, for example.
Sometimes we want to differentiate holes from real errors -- for
example when we want to count all the [syntax correct] specifiers.
With this patch of_parse_phandles_with_args() will report -EEXITS when
somebody requested to parse a hole.
Also, make the out_{node,args} arguments optional, when counting we
don't really need the out values.
By using 'list++' in the beginning we can simplify the code a
little bit.
Suggested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
This commit adds a routine for finding a device node which has a
certain property. The contents of the property are not taken into
account, merely the presence or absence of the property.
Based on that routine, we add a for_each_ macro for iterating over all
nodes that have a certain property.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
The helper is factored out of of_get_gpio(). Will be used by the QE
pin multiplexing functions (they need to parse the gpios = <> too).
Compatible property values in the form linux,<modalias> is not documented
anywhere and using it leaks Linux implementation details into the device
tree data (which is bad). Remove support for compatible values of this
form.
If any platforms exist which depended on this code (and I don't know of
any), then they can be fixed up by adding legacy translations to the
lookup table in this file.
of/base.c matches on the first (most specific) entries, which isn't
quite practical but it was discussed[1] that this won't change.
The bindings specifies verbose information for the devices, but
it doesn't fit in the I2C ID's 20 characters limit. The limit won't
change[2], and the bindings won't change either as they're correct.
So we have to put an exception for the MPC8349E-mITX-compatible
MCUs.
[1] http://www.mail-archive.com/linuxppc-dev@ozlabs.org/msg21196.html
[2] http://www.nabble.com/-PATCH-1-2--i2c:-expand-I2C's-id.name-to-23-characters-td19577063.html
SPI has a similar problem as I2C in that it needs to determine an
appropriate modalias value for each device node. This patch adapts
the of_i2c of_find_i2c_driver() function to be usable by of_spi also.
Update function of_find_property() to return NULL if the device_node
passed to it is also NULL. Otherwise, passing NULL will cause a null
pointer dereference.
Without this, the legacy_serial driver will crash if there's no
'chosen' node in the device tree.
IEEE 1275 defined a standard "status" property to indicate the operational
status of a device. The property has four possible values: okay, disabled,
fail, fail-xxx. The absence of this property means the operational status
of the device is unknown or okay.
This adds a function called of_device_is_available that checks the state
of the status property of a device. If the property is absent or set to
either "okay" or "ok", it returns 1. Otherwise it returns 0.
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Iterating through a device node's parents is simple enough, but dealing
with the refcounts properly is a little ugly, and replicating that logic
is asking for someone to get it wrong or forget it all together, eg:
while (dn != NULL) {
/* loop body */
tmp = of_get_parent(dn);
of_node_put(dn);
dn = tmp;
So add of_get_next_parent(), inspired by of_get_next_child(). The
contract is that it returns the parent and drops the reference on the
current node, this makes the loop look like:
/* loop body */
dn = of_get_next_parent(dn);
Similar to of_find_compatible_node(), of_find_matching_node() and
for_each_matching_node() allow you to iterate over the device tree
looking for specific nodes, except that they take of_device_id
tables instead of strings.
This also moves of_match_node() from driver/of/device.c to
driver/of/base.c to colocate it with the of_find_matching_node which
depends on it.
This consolidates the routines of_find_node_by_path, of_find_node_by_name,
of_find_node_by_type and of_find_compatible_device. Again, the comparison
of strings are done differently by Sparc and PowerPC and also these add
read_locks around the iterations.
Acked-by: Paul Mackerras <paulus@samba.org>
This adds a read_lock around the child/next accesses on Sparc.
This requires creating dummy of_node_{get,put} routines for sparc and
sparc64. It also adds a read_lock around the parent accesses.
The only change here is that a readlock is taken while the property list
is being traversed on Sparc where it was not taken previously.
Also, Sparc uses strcasecmp to compare property names while PowerPC
uses strcmp.
The only difference here is that Sparc uses strncmp to match compatibility
names while PowerPC uses strncasecmp.
This creates drivers/of/base.c (depending on CONFIG_OF) and puts
the first trivially common bits from the prom.c files into it.
