path: root/drivers/of
2014-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) BPF debugger and asm tool by Daniel Borkmann. 2) Speed up create/bind in AF_PACKET, also from Daniel Borkmann. 3) Correct reciprocal_divide and update users, from Hannes Frederic Sowa and Daniel Borkmann. 4) Currently we only have a "set" operation for the hw timestamp socket ioctl, add a "get" operation to match. From Ben Hutchings. 5) Add better trace events for debugging driver datapath problems, also from Ben Hutchings. 6) Implement auto corking in TCP, from Eric Dumazet. Basically, if we have a small send and a previous packet is already in the qdisc or device queue, defer until TX completion or we get more data. 7) Allow userspace to manage ipv6 temporary addresses, from Jiri Pirko. 8) Add a qdisc bypass option for AF_PACKET sockets, from Daniel Borkmann. 9) Share IP header compression code between Bluetooth and IEEE802154 layers, from Jukka Rissanen. 10) Fix ipv6 router reachability probing, from Jiri Benc. 11) Allow packets to be captured on macvtap devices, from Vlad Yasevich. 12) Support tunneling in GRO layer, from Jerry Chu. 13) Allow bonding to be configured fully using netlink, from Scott Feldman. 14) Allow AF_PACKET users to obtain the VLAN TPID, just like they can already get the TCI. From Atzm Watanabe. 15) New "Heavy Hitter" qdisc, from Terry Lam. 16) Significantly improve the IPSEC support in pktgen, from Fan Du. 17) Allow ipv4 tunnels to cache routes, just like sockets. From Tom Herbert. 18) Add Proportional Integral Enhanced packet scheduler, from Vijay Subramanian. 19) Allow openvswitch to mmap'd netlink, from Thomas Graf. 20) Key TCP metrics blobs also by source address, not just destination address. From Christoph Paasch. 21) Support 10G in generic phylib. From Andy Fleming. 22) Try to short-circuit GRO flow compares using device provided RX hash, if provided. From Tom Herbert. The wireless and netfilter folks have been busy little bees too. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2064 commits) net/cxgb4: Fix referencing freed adapter ipv6: reallocate addrconf router for ipv6 address when lo device up fib_frontend: fix possible NULL pointer dereference rtnetlink: remove IFLA_BOND_SLAVE definition rtnetlink: remove check for fill_slave_info in rtnl_have_link_slave_info qlcnic: update version to 5.3.55 qlcnic: Enhance logic to calculate msix vectors. qlcnic: Refactor interrupt coalescing code for all adapters. qlcnic: Update poll controller code path qlcnic: Interrupt code cleanup qlcnic: Enhance Tx timeout debugging. qlcnic: Use bool for rx_mac_learn. bonding: fix u64 division rtnetlink: add missing IFLA_BOND_AD_INFO_UNSPEC sfc: Use the correct maximum TX DMA ring size for SFC9100 Add Shradha Shah as the sfc driver maintainer. net/vxlan: Share RX skb de-marking and checksum checks with ovs tulip: cleanup by using ARRAY_SIZE() ip_tunnel: clear IPCB in ip_tunnel_xmit() in case dst_link_failure() is called net/cxgb4: Don't retrieve stats during recovery ...
2014-01-24Merge tag 'devicetree-for-3.14' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree updates from Rob Herring: - Add new documents with guidelines for DT binding stability and review process. This is one of the outcomes of Kernel Summit DT discussions - Remove a bunch of device_type usage which is only for OF and deprecated with FDT - Fix a long standing issue with compatible string match ordering - Various minor binding documentation updates * tag 'devicetree-for-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: dt-bindings: add rockchip vendor prefix serial: vt8500: Add missing binding document for arch-vt8500 serial driver. dt/bindings: submitting patches and ABI documents DT: Add vendor prefix for Emerging Display Technologies of: add vendor prefixe for EPFL of: add vendor prefix for Gumstix of: add vendor prefix for Ka-Ro electronics GmbH devicetree: macb: Document clock properties dts: bindings: trivial clock bindings doc fixes of: Fix __of_device_is_available check dt/bindings: Remove device_type "serial" from marvell,mv64360-mpsc dt/bindings: remove device_type "network" references dt/bindings: remove users of device_type "mdio" dt/bindings: Remove references to linux,phandle properties dt/bindings: Remove all references to device_type "ethernet-phy" of: irq: Ignore disabled intc's when searching map of: irq: Ignore disabled interrupt controllers OF: base: match each node compatible against all given matches first dt-bindings: add GIC-400 binding
2014-01-23Merge remote-tracking branch 'grant/devicetree/next' into for-3.14Rob Herring
2014-01-17Merge remote-tracking branch 'grant/devicetree/next' into for-3.14Rob Herring
2014-01-17platform: introduce OF style 'modalias' support for platform busZhang Rui
Fix a problem that, the platform bus supports the OF style modalias in .uevent() call, but not in its device 'modalias' sysfs attribute. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-01-16of: Fix __of_device_is_available checkXiubo Li
From IEEE 1275, there defined a standard 'status' property indicating the operational status of one device. The 'status' property has four possible values: 'okay/ok', 'disabled', 'fail' and 'fail-xxx'. If it is absent, that means the status of the device is unknown or okay. The __of_device_is_available checks the state of the 'status' property of a device. If the property is absent or set to 'okay/ok', it returns 1. Otherwise it returns 0. While in __of_device_is_available: > status = of_get_property(device, "status", &statlen); > if (status == NULL) > return 1; The status value returned from 'of_get_property()' will be NULL in two cases: Firstly: the 'device' value (device node) is NULL. Secondly: the 'status' property is actaully not exist. If the device node is NULL, the __of_device_is_available will return true, that will mean the absent state of the 'status' property. So this add the device node check before checking the 'status' property's state, and if the device node is not exist, 0 will be returned. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2014-01-13phylib: Add of_phy_attachAndy Fleming
10G PHYs don't currently support running the state machine, which is implicitly setup via of_phy_connect(). Therefore, it is necessary to implement an OF version of phy_attach(), which does everything except start the state machine. Signed-off-by: Andy Fleming <afleming@gmail.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-13phylib: introduce PHY_INTERFACE_MODE_XGMII for 10G PHYAndy Fleming
2014-01-06Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/qlogic/qlcnic/qlcnic_sriov_pf.c net/ipv6/ip6_tunnel.c net/ipv6/ip6_vti.c ipv6 tunnel statistic bug fixes conflicting with consolidation into generic sw per-cpu net stats. qlogic conflict between queue counting bug fix and the addition of multiple MAC address support. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-30Merge remote-tracking branch 'grant/devicetree/merge' into dt-fixesdt-fixes-for-3.13Rob Herring
2013-12-30of/irq: Fix device_node refcount in of_irq_parse_raw()Cédric Le Goater
Commit 2361613206e6, "of/irq: Refactor interrupt-map parsing" changed the refcount on the device_node causing an error in of_node_put(): ERROR: Bad of_node_put() on /pci@800000020000000 CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.13.0-rc3-dirty #2 Call Trace: [c00000003e403500] [c0000000000144fc] .show_stack+0x7c/0x1f0 (unreliable) [c00000003e4035d0] [c00000000070f250] .dump_stack+0x88/0xb4 [c00000003e403650] [c0000000005e8768] .of_node_release+0xd8/0xf0 [c00000003e4036e0] [c0000000005eeafc] .of_irq_parse_one+0x10c/0x280 [c00000003e4037a0] [c0000000005efd4c] .of_irq_parse_pci+0x3c/0x1d0 [c00000003e403840] [c000000000038240] .pcibios_setup_device+0xa0/0x2e0 [c00000003e403910] [c0000000000398f0] .pcibios_setup_bus_devices+0x60/0xd0 [c00000003e403990] [c00000000003b3a4] .__of_scan_bus+0x1a4/0x2b0 [c00000003e403a80] [c00000000003a62c] .pcibios_scan_phb+0x30c/0x410 [c00000003e403b60] [c0000000009fe430] .pcibios_init+0x7c/0xd4 This patch adjusts the refcount in the walk of the interrupt tree. When a match is found, there is no need to increase the refcount on 'out_irq->np' as 'newpar' is already holding a ref. The refcount balance between 'ipar' and 'newpar' is maintained in the skiplevel: goto label. This patch also removes the usage of the device_node variable 'old' which seems useless after the latest changes. Signed-off-by: Cédric Le Goater <clg@fr.ibm.com> Signed-off-by: Rob Herring <robh@kernel.org>
2013-12-30of/Kconfig: Spelling s/one/once/Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org> Signed-off-by: Rob Herring <robh@kernel.org>
2013-12-30Revert "of/address: Handle #address-cells > 2 specially"Rob Herring
This reverts commit e38c0a1fbc5803cbacdaac0557c70ac8ca5152e7. Nikita Yushchenko reports: While trying to make freescale p2020ds and mpc8572ds boards working with mainline kernel, I faced that commit e38c0a1f (Handle Both these boards have uli1575 chip. Corresponding part in device tree is something like uli1575@0 { reg = <0x0 0x0 0x0 0x0 0x0>; #size-cells = <2>; #address-cells = <3>; ranges = <0x2000000 0x0 0x80000000 0x2000000 0x0 0x80000000 0x0 0x20000000 0x1000000 0x0 0x0 0x1000000 0x0 0x0 0x0 0x10000>; isa@1e { ... I.e. it has #address-cells = <3> With commit e38c0a1f reverted, devices under uli1575 are registered correctly, e.g. for rtc OF: ** translation for device /pcie@ffe09000/pcie@0/uli1575@0/isa@1e/rtc@70 ** OF: bus is isa (na=2, ns=1) on /pcie@ffe09000/pcie@0/uli1575@0/isa@1e OF: translating address: 00000001 00000070 OF: parent bus is default (na=3, ns=2) on /pcie@ffe09000/pcie@0/uli1575@0 OF: walking ranges... OF: ISA map, cp=0, s=1000, da=70 OF: parent translation for: 01000000 00000000 00000000 OF: with offset: 70 OF: one level translation: 00000000 00000000 00000070 OF: parent bus is pci (na=3, ns=2) on /pcie@ffe09000/pcie@0 OF: walking ranges... OF: default map, cp=a0000000, s=20000000, da=70 OF: default map, cp=0, s=10000, da=70 OF: parent translation for: 01000000 00000000 00000000 OF: with offset: 70 OF: one level translation: 01000000 00000000 00000070 OF: parent bus is pci (na=3, ns=2) on /pcie@ffe09000 OF: walking ranges... OF: PCI map, cp=0, s=10000, da=70 OF: parent translation for: 01000000 00000000 00000000 OF: with offset: 70 OF: one level translation: 01000000 00000000 00000070 OF: parent bus is default (na=2, ns=2) on / OF: walking ranges... OF: PCI map, cp=0, s=10000, da=70 OF: parent translation for: 00000000 ffc10000 OF: with offset: 70 OF: one level translation: 00000000 ffc10070 OF: reached root node With commit e38c0a1f in place, address translation fails: OF: ** translation for device /pcie@ffe09000/pcie@0/uli1575@0/isa@1e/rtc@70 ** OF: bus is isa (na=2, ns=1) on /pcie@ffe09000/pcie@0/uli1575@0/isa@1e OF: translating address: 00000001 00000070 OF: parent bus is default (na=3, ns=2) on /pcie@ffe09000/pcie@0/uli1575@0 OF: walking ranges... OF: ISA map, cp=0, s=1000, da=70 OF: parent translation for: 01000000 00000000 00000000 OF: with offset: 70 OF: one level translation: 00000000 00000000 00000070 OF: parent bus is pci (na=3, ns=2) on /pcie@ffe09000/pcie@0 OF: walking ranges... OF: default map, cp=a0000000, s=20000000, da=70 OF: default map, cp=0, s=10000, da=70 OF: not found ! Thierry Reding confirmed this commit was not needed after all: "We ended up merging a different address representation for Tegra PCIe and I've confirmed that reverting this commit doesn't cause any obvious regressions. I think all other drivers in drivers/pci/host ended up copying what we did on Tegra, so I wouldn't expect any other breakage either." There doesn't appear to be a simple way to support both behaviours, so reverting this as nothing should be depending on the new behaviour. Cc: stable@vger.kernel.org # v3.7+ Signed-off-by: Rob Herring <robh@kernel.org>
2013-12-11of: Fix NULL dereference in unflatten_and_copy()James Hogan
Check whether initial_boot_params is NULL before dereferencing it in unflatten_and_copy_device_tree() for the case where no device tree is available but the arch can still boot to a minimal usable system without it. In this case also log a warning for when the kernel log buffer is obtainable. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-12-06net: of_mdio: parse "max-speed" property to set PHY supported featuresFlorian Fainelli
The "max-speed" property is defined per the ePAPR specification to express the maximum speed a PHY supports. Use that property, if present to set the phydev->supported features which properly restricts the PHY within the range of defined speeds. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-06net: of_mdio: do not overwrite PHY interrupt configurationFlorian Fainelli
If irq_of_parse_and_map fails to find an interrupt line for a given PHY, we will force the PHY interrupt to be PHY_POLL, completely overriding the previous value that the MDIO bus may have set for us (e.g: PHY_IGNORE_INTERRUPT). In case of failure, just restore the previous value. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-06net: of_mdio: use PHY_MAX_ADDR constantFlorian Fainelli
Use the PHY_MAX_ADDR constant for checking if a MDIO bus address is valid instead of using a plain "32". Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-06net: of_mdio: factor PHY registration from of_mdiobus_registerFlorian Fainelli
Since commit 779d835e ("net: of_mdio: scan mdiobus for PHYs without reg property") we have two foreach loops which do pretty much the same thing. Factor the PHY device registration in a function helper: of_mdiobus_register_phy() which takes care of the details and allows for future PHY specific extensions. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-04of: irq: Ignore disabled intc's when searching mapPeter Crosthwaite
When searching the interrupt map, if a matched parent is disabled, just ignore it and move on with the search. This allows for specifying connection of a single device IRQ to multiple interrupt controllers via the interrupt map schema. This change allows for selection of the active interrupt controller via the already existing status = "disabled" mechanism. Signed-off-by: Peter Crosthwaite <peter.crosthwaite@xilinx.com> Acked-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-12-04of: irq: Ignore disabled interrupt controllersPeter Crosthwaite
When searching the system for interrupt controllers, skip over any that are explicitly disabled. This makes interrupt controllers consistent with regular devices, which can be marked as do-not-probe via the status = "disabled" dts property. Signed-off-by: Peter Crosthwaite <peter.crosthwaite@xilinx.com> Acked-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-12-04OF: base: match each node compatible against all given matches firstSebastian Hesselbarth
Currently, of_match_node compares each given match against all node's compatible strings with of_device_is_compatible. To achieve multiple compatible strings per node with ordering from specific to generic, this requires given matches to be ordered from specific to generic. For most of the drivers this is not true and also an alphabetical ordering is more sane there. Therefore, this patch modifies of_match_node to match each of the node's compatible strings against all given matches first, before checking the next compatible string. This implies that node's compatibles are ordered from specific to generic while given matches can be in any order. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Tested-by: Meelis Roos <mroos@linux.ee> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-14Merge branch 'for-linus-dma-masks' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull DMA mask updates from Russell King: "This series cleans up the handling of DMA masks in a lot of drivers, fixing some bugs as we go. Some of the more serious errors include: - drivers which only set their coherent DMA mask if the attempt to set the streaming mask fails. - drivers which test for a NULL dma mask pointer, and then set the dma mask pointer to a location in their module .data section - which will cause problems if the module is reloaded. To counter these, I have introduced two helper functions: - dma_set_mask_and_coherent() takes care of setting both the streaming and coherent masks at the same time, with the correct error handling as specified by the API. - dma_coerce_mask_and_coherent() which resolves the problem of drivers forcefully setting DMA masks. This is more a marker for future work to further clean these locations up - the code which creates the devices really should be initialising these, but to fix that in one go along with this change could potentially be very disruptive. The last thing this series does is prise away some of Linux's addition to "DMA addresses are physical addresses and RAM always starts at zero". We have ARM LPAE systems where all system memory is above 4GB physical, hence having DMA masks interpreted by (eg) the block layers as describing physical addresses in the range 0..DMAMASK fails on these platforms. Santosh Shilimkar addresses this in this series; the patches were copied to the appropriate people multiple times but were ignored. Fixing this also gets rid of some ARM weirdness in the setup of the max*pfn variables, and brings ARM into line with every other Linux architecture as far as those go" * 'for-linus-dma-masks' of git://git.linaro.org/people/rmk/linux-arm: (52 commits) ARM: 7805/1: mm: change max*pfn to include the physical offset of memory ARM: 7797/1: mmc: Use dma_max_pfn(dev) helper for bounce_limit calculations ARM: 7796/1: scsi: Use dma_max_pfn(dev) helper for bounce_limit calculations ARM: 7795/1: mm: dma-mapping: Add dma_max_pfn(dev) helper function ARM: 7794/1: block: Rename parameter dma_mask to max_addr for blk_queue_bounce_limit() ARM: DMA-API: better handing of DMA masks for coherent allocations ARM: 7857/1: dma: imx-sdma: setup dma mask DMA-API: firmware/google/gsmi.c: avoid direct access to DMA masks DMA-API: dcdbas: update DMA mask handing DMA-API: dma: edma.c: no need to explicitly initialize DMA masks DMA-API: usb: musb: use platform_device_register_full() to avoid directly messing with dma masks DMA-API: crypto: remove last references to 'static struct device *dev' DMA-API: crypto: fix ixp4xx crypto platform device support DMA-API: others: use dma_set_coherent_mask() DMA-API: staging: use dma_set_coherent_mask() DMA-API: usb: use new dma_coerce_mask_and_coherent() DMA-API: usb: use dma_set_coherent_mask() DMA-API: parport: parport_pc.c: use dma_coerce_mask_and_coherent() DMA-API: net: octeon: use dma_coerce_mask_and_coherent() DMA-API: net: nxp/lpc_eth: use dma_coerce_mask_and_coherent() ...
2013-11-12Merge tag 'devicetree-for-3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree updates from Rob Herring: "DeviceTree updates for 3.13. This is a bit larger pull request than usual for this cycle with lots of clean-up. - Cross arch clean-up and consolidation of early DT scanning code. - Clean-up and removal of arch prom.h headers. Makes arch specific prom.h optional on all but Sparc. - Addition of interrupts-extended property for devices connected to multiple interrupt controllers. - Refactoring of DT interrupt parsing code in preparation for deferred probe of interrupts. - ARM cpu and cpu topology bindings documentation. - Various DT vendor binding documentation updates" * tag 'devicetree-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (82 commits) powerpc: add missing explicit OF includes for ppc dt/irq: add empty of_irq_count for !OF_IRQ dt: disable self-tests for !OF_IRQ of: irq: Fix interrupt-map entry matching MIPS: Netlogic: replace early_init_devtree() call of: Add Panasonic Corporation vendor prefix of: Add Chunghwa Picture Tubes Ltd. vendor prefix of: Add AU Optronics Corporation vendor prefix of/irq: Fix potential buffer overflow of/irq: Fix bug in interrupt parsing refactor. of: set dma_mask to point to coherent_dma_mask of: add vendor prefix for PHYTEC Messtechnik GmbH DT: sort vendor-prefixes.txt of: Add vendor prefix for Cadence of: Add empty for_each_available_child_of_node() macro definition arm/versatile: Fix versatile irq specifications. of/irq: create interrupts-extended property microblaze/pci: Drop PowerPC-ism from irq parsing of/irq: Create of_irq_parse_and_map_pci() to consolidate arch code. of/irq: Use irq_of_parse_and_map() ...
2013-11-12Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Benjamin Herrenschmidt: "The bulk of this is LE updates. One should now be able to build an LE kernel and even run some things in it. I'm still sitting on a handful of patches to enable the new ABI that I *might* still send this merge window around, but due to the incertainty (they are pretty fresh) I want to keep them separate. Other notable changes are some infrastructure bits to better handle PCI pass-through under KVM, some bits and pieces added to the new PowerNV platform support such as access to the CPU SCOM bus via sysfs, and support for EEH error handling on PHB3 (Power8 PCIe). We also grew arch_get_random_long() for both pseries and powernv when running on P7+ and P8, exploiting the HW rng. And finally various embedded updates from freescale" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (154 commits) powerpc: Fix fatal SLB miss when restoring PPR powerpc/powernv: Reserve the correct PE number powerpc/powernv: Add PE to its own PELTV powerpc/powernv: Add support for indirect XSCOM via debugfs powerpc/scom: Improve debugfs interface powerpc/scom: Enable 64-bit addresses powerpc/boot: Properly handle the base "of" boot wrapper powerpc/bpf: Support MOD operation powerpc/bpf: Fix DIVWU instruction opcode of: Move definition of of_find_next_cache_node into common code. powerpc: Remove big endianness assumption in of_find_next_cache_node powerpc/tm: Remove interrupt disable in __switch_to() powerpc: word-at-a-time optimization for 64-bit Little Endian powerpc/bpf: BPF JIT compiler for 64-bit Little Endian powerpc: Only save/restore SDR1 if in hypervisor mode powerpc/pmu: Fix ADB_PMU_LED_IDE dependencies powerpc/nvram: Fix endian issue when using the partition length powerpc/nvram: Fix endian issue when reading the NVRAM size powerpc/nvram: Scan partitions only once powerpc/mpc512x: remove unnecessary #if ...
2013-11-08dt: disable self-tests for !OF_IRQRob Herring
Fix OF selftest compile on sparc which does not enable OF_IRQ. drivers/of/selftest.c:177: undefined reference to `of_irq_parse_one' drivers/of/selftest.c:197: undefined reference to `of_irq_parse_one' drivers/of/selftest.c:248: undefined reference to `of_irq_parse_one' Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Grant Likely <grant.likely@linaro.org>
2013-11-07of: irq: Fix interrupt-map entry matchingTomasz Figa
This patch fixes interrupt-map entry matching code to properly match all specifier cells with interrupt map entries. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Tested-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-07Merge remote-tracking branch 'grant/devicetree/next' into for-nextRob Herring
2013-11-03of/irq: Fix potential buffer overflowGrant Likely
Commit 2361613206e6, "of/irq: Refactor interrupt-map parsing" introduced a potential buffer overflow bug because it doesn't do sufficient range checking on the input data. This patch adds the appropriate checking and buffer size adjustments. If the bounds are out of range then warn loudly. MAX_PHANDLE_ARGS should be sufficient. If it is not then the value can be increased. Signed-off-by: Grant Likely <grant.likely@linaro.org> Cc: Rob Herring <rob.herring@calxeda.com>
2013-11-03of/irq: Fix bug in interrupt parsing refactor.Grant Likely
Commit 2361613206e6, "of/irq: Refactor interrupt-map parsing" introduced a bug. The irq parsing will fail for some nodes that don't have a reg property. It is fixed by deferring the check for reg until it is actually needed. Also adjust the testcase data to catch the bug. Signed-off-by: Grant Likely <grant.likely@linaro.org> Tested-by: Stephen Warren <swarren@nvidia.com> Tested-by: Ming Lei <tom.leiming@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com> Cc: Rob Herring <rob.herring@calxeda.com>
2013-11-03of: set dma_mask to point to coherent_dma_maskRob Herring
Platform devices created by DT code don't initialize dma_mask pointer to anything. Set it to coherent_dma_mask by default if the architecture code has not set it. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-10-31DMA-API: amba: get rid of separate dma_maskRussell King
AMBA Primecell devices always treat streaming and coherent DMA exactly the same, so there's no point in having the masks separated. Acked-by: Grant Likely <grant.likely@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-10-31of: Move definition of of_find_next_cache_node into common code.Sudeep KarkadaNagesha
Since the definition of_find_next_cache_node is architecture independent, the existing definition in powerpc can be moved to driver/of/base.c Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Grant Likely <grant.likely@linaro.org> Cc: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Sudeep KarkadaNagesha <sudeep.karkadanagesha@arm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-10-28of/irq: create interrupts-extended propertyGrant Likely
The standard interrupts property in device tree can only handle interrupts coming from a single interrupt parent. If a device is wired to multiple interrupt controllers, then it needs to be attached to a node with an interrupt-map property to demux the interrupt specifiers which is confusing. It would be a lot easier if there was a form of the interrupts property that allows for a separate interrupt phandle for each interrupt specifier. This patch does exactly that by creating a new interrupts-extended property which reuses the phandle+arguments pattern used by GPIOs and other core bindings. Signed-off-by: Grant Likely <grant.likely@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Kumar Gala <galak@codeaurora.org> [grant.likely: removed versatile platform hunks into separate patch] Cc: Rob Herring <rob.herring@calxeda.com>
2013-10-24of/irq: Create of_irq_parse_and_map_pci() to consolidate arch code.Grant Likely
Several architectures open code effectively the same code block for finding and mapping PCI irqs. This patch consolidates it down to a single function. Signed-off-by: Grant Likely <grant.likely@linaro.org> Acked-by: Michal Simek <monstr@monstr.eu> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-10-24of/irq: Rework of_irq_count()Thierry Reding
The of_irq_to_resource() helper that is used to implement of_irq_count() tries to resolve interrupts and in fact creates a mapping for resolved interrupts. That's pretty heavy lifting for something that claims to just return the number of interrupts requested by a given device node. Instead, use the more lightweight of_irq_map_one(), which, despite the name, doesn't create an actual mapping. Perhaps a better name would be of_irq_translate_one(). Signed-off-by: Thierry Reding <treding@nvidia.com> Acked-by: Rob Herring <rob.herring@calxeda.com> [grant.likely: fixup s/of_irq_map_one/of_irq_parse_one/] Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-10-24of: Add testcases for interrupt parsingGrant Likely
This patch extends the DT selftest code with some test cases for the interrupt parsing functions. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2013-10-24of: Add helper for printing an of_phandle_args structureGrant Likely
It is sometimes useful for debug to get the contents of an of_phandle_args structure out into the kernel log. Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-10-24of/irq: Refactor interrupt-map parsingGrant Likely
All the users of of_irq_parse_raw pass in a raw interrupt specifier from the device tree and expect it to be returned (possibly modified) in an of_phandle_args structure. However, the primary function of of_irq_parse_raw() is to check for translations due to the presence of one or more interrupt-map properties. The actual placing of the data into an of_phandle_args structure is trivial. If it is refactored to accept an of_phandle_args structure directly, then it becomes possible to consume of_phandle_args from other sources. This is important for an upcoming patch that allows a device to be connected to more than one interrupt parent. It also simplifies the code a bit. The biggest complication with this patch is that the old version works on the interrupt specifiers in __be32 form, but the of_phandle_args structure is intended to carry it in the cpu-native version. A bit of churn was required to make this work. In the end it results in tighter code, so the churn is worth it. Signed-off-by: Grant Likely <grant.likely@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-10-24of/irq: simplify args to irq_create_of_mappingGrant Likely
All the callers of irq_create_of_mapping() pass the contents of a struct of_phandle_args structure to the function. Since all the callers already have an of_phandle_args pointer, why not pass it directly to irq_create_of_mapping()? Signed-off-by: Grant Likely <grant.likely@linaro.org> Acked-by: Michal Simek <monstr@monstr.eu> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-10-24of/irq: Replace of_irq with of_phandle_argsGrant Likely
struct of_irq and struct of_phandle_args are exactly the same structure. This patch makes the kernel use of_phandle_args everywhere. This in itself isn't a big deal, but it makes some follow-on patches simpler. Signed-off-by: Grant Likely <grant.likely@linaro.org> Acked-by: Michal Simek <monstr@monstr.eu> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-10-24of/irq: Rename of_irq_map_* functions to of_irq_parse_*Grant Likely
The OF irq handling code has been overloading the term 'map' to refer to both parsing the data in the device tree and mapping it to the internal linux irq system. This is probably because the device tree does have the concept of an 'interrupt-map' function for translating interrupt references from one node to another, but 'map' is still confusing when the primary purpose of some of the functions are to parse the DT data. This patch renames all the of_irq_map_* functions to of_irq_parse_* which makes it clear that there is a difference between the parsing phase and the mapping phase. Kernel code can make use of just the parsing or just the mapping support as needed by the subsystem. The patch was generated mechanically with a handful of sed commands. Signed-off-by: Grant Likely <grant.likely@linaro.org> Acked-by: Michal Simek <monstr@monstr.eu> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-10-15of/irq: Pass trigger type in IRQ resource flagsTomasz Figa
Some drivers might rely on availability of trigger flags in IRQ resource, for example to configure the hardware for particular interrupt type. However current code creating IRQ resources from data in device tree does not configure trigger flags in resulting resources. This patch tries to solve the problem, based on the fact that irq_of_parse_and_map() configures the trigger based on DT interrupt specifier and IRQD_TRIGGER_* flags are consistent with IORESOURCE_IRQ_*, and we can get correct trigger flags by calling irqd_get_trigger_type() after mapping the interrupt. Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com> [grant.likely: Merged the two assignments to r->flags] Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-10-15of: Fix dereferencing node name in debug output to be safeGrant Likely
Several locations in the of_address and of_irq code dereference the full_name parameter from a device_node pointer without checking if the pointer is valid. This patch switches to use of_node_full_name() which always checks the pointer. Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-10-15of: Fix iteration bug over CPU reg propertiesGrant Likely
The size of each hwid in a cpu nodes 'reg' property is defined by the parents #address-cells property in the normal way. The cpu parsing code has a bug where it will overrun the end of the property if address-cells is greater than one. This commit fixes the problem by adjusting the array size by the number of address cells. It also makes sure address-cells isn't zero for that would cause an infinite loop. v2: bail if #address-cells is zero instead of forcing to OF_ROOT_NODE_ADDR_CELLS_DEFAULT. Forcing it will cause the reg property to be parsed incorrectly. Signed-off-by: Grant Likely <grant.likely@linaro.org> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-10-15of: Make cpu node handling more portable.David Miller
Use for_each_node_by_type() to iterate all cpu nodes in the system. Provide and overridable function arch_find_n_match_cpu_physical_id, which sees if the given device node matches 'cpu' and if so sets '*thread' when non-NULL to the cpu thread number within the core. The default implementation behaves the same as the existing code. Add a sparc64 implementation. Signed-off-by: David S. Miller <davem@davemloft.net> Tested-by: Sudeep KarkadaNagesha <Sudeep.KarkadaNagesha@arm.com> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-10-15Revert "drivers: of: add initialization code for dma reserved memory"Marek Szyprowski
This reverts commit 9d8eab7af79cb4ce2de5de39f82c455b1f796963. There is still no consensus on the bindings for the reserved memory and various drawbacks of the proposed solution has been shown, so the best now is to revert it completely and start again from scratch later. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-10-14Revert "of: Feed entire flattened device tree into the random pool"Grant Likely
This reverts commit 109b6236294b53d8eaa50be7d9e9ad37079f5f7e. Tim Bird expressed concern that this will have a bad effect on boot time, and while simple tests have shown it to be okay with simple tree, a device tree blob can potentially be quite large and add_device_randomness() is not a fast function. Rather than do this for all platforms unconditionally, I'm reverting this patch and would like to see it revisited. Instead of feeding the entire tree into the random pool, it would probably be appropriate to hash the tree and feed the hash result into the pool. There really isn't a lot of randomness in a device tree anyway. In the majority of cases only a handful of properties are going to be different between machines with the same baseboard. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2013-10-14of: fix unnecessary warning on missing /cpus nodeGrant Likely
Not all DT platforms have all the cpus collected under a /cpus node. That just happens to be a details of FDT, ePAPR and PowerPC platforms. Sparc does something different, but unfortunately the current code complains with a warning if /cpus isn't there. This became a problem with commit f86e4718, "driver/core cpu: initialize of_node in cpu's device structure", which caused the function to get called for all architectures. This commit is a temporary fix to fail silently if the cpus node isn't present. A proper fix will come later to allow arch code to provide a custom mechanism for decoding the CPU hwid if the 'reg' property isn't appropriate. Signed-off-by: Grant Likely <grant.likely@linaro.org> Cc: David Miller <davem@davemloft.net> Cc: Sudeep KarkadaNagesha <Sudeep.KarkadaNagesha@arm.com> Cc: Rob Herring <rob.herring@calxeda.com>
2013-10-09of: implement of_node_to_nid as a weak functionRob Herring
Implement of_node_to_nid as weak function to remove the dependency on asm/prom.h. This is in preparation to make prom.h optional. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Grant Likely <grant.likely@linaro.org>
2013-10-09of: implement pci_address_to_pio as weak functionRob Herring
Implement pci_address_to_pio as weak function to remove the dependency on asm/prom.h. This is in preparation to make prom.h optional. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Grant Likely <grant.likely@linaro.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: x86@kernel.org Cc: Grant Likely <grant.likely@linaro.org>
